Flow Battery Explained: How It Works, Where It's Used, and How It Compares
Most batteries keep their chemistry sealed inside each cell. A flow battery does not. In a common dual-flow design, two liquid electrolytes circulate between separate tanks and a cell stack during charge and discharge. That design lets engineers size power and energy separately, which is why flow batteries are studied for long-duration grid storage. This article explains what a flow battery is, how the vanadium version works according to DOE and PNNL, its pros and limits, and how it differs from the lithium iron phosphate batteries inside home and portable power stations.
What Is a Flow Battery and How Does It Work?
A typical dual-flow battery has two tanks of liquid electrolyte and a cell stack with a membrane. Pumps move the liquids through the stack, where chemical reactions store or release electricity. Bigger tanks mean more stored energy.
The Main Parts
The common dual-flow design uses the parts below. Some sources call it a flow cell battery. Not every design matches this list, though. Stanford researchers have developed a membrane-free zinc-manganese design for large-scale storage.
Part | Job |
Electrolyte tanks | Hold the liquids that carry the stored energy |
Cell stack | Provides the space where the electrolytes react |
Membrane | Keeps the two liquids apart while letting ions pass |
Pumps | Move the electrolytes between the tanks and the stack |
How Charging and Discharging Work
The U.S. Department of Energy (DOE) explains that redox flow (RFB) systems store energy in two tanks that sit apart from the cell stack. Pumps send the electrolytes into the stack. In the vanadium version, each electrolyte flows through its own half-cell on one side of a membrane. Ions move through the membrane, while the liquids stay apart.
The Pacific Northwest National Laboratory (PNNL) says the liquids complete chemical reactions "in order to charge and discharge energy." During charging, incoming electricity drives reactions that store energy in the liquids. During discharge, the reactions reverse and release electricity to a load. The electrolytes then return to their tanks.
Think of it as a loop. Pumps pull electrolyte from each tank, push it through the stack, and send it back. Charging and discharging mainly change the direction of the reactions. Because the energy sits in the liquid, the stack does not have to grow when the tanks do.
Why Vanadium Is Common
DOE notes that vanadium redox designs use only one element, vanadium, in both tanks. That single-element approach is a defining trait of the most studied version. The element appears in different oxidation states on each side of the membrane, and those states carry the charge.
Sizing Power and Energy Separately
In a typical lithium cell, power and energy are tied together inside one sealed unit. Here, the stack and the tanks do different jobs. Stack size sets how much power the system can deliver. Tank volume sets how much energy it can store.
DOE points to the "flexibility to design power and energy capacities separately." A utility that needs more hours of storage can often add electrolyte volume instead of adding more stacks.
Other chemistries are also emerging. Flow systems sit alongside research into sodium-ion as a lithium alternative and several other approaches.
These systems are built for utility-scale jobs. For a home or a small off-grid space, storage looks very different.
Flow Batteries vs All-in-One LFP Power Stations
These tank systems serve the grid. Home and off-grid users usually choose all-in-one lithium iron phosphate (LFP) units sized to their loads. The two are different technologies for different jobs, so they compare best by task, not by cell specs.
Start With the Load
Sizing begins with the load, not the chemistry. A cabin, a workshop, and a home backup circuit each draw a different mix of watts and hours. Watts show how much runs at once. Watt-hours measure stored energy, not time. Runtime comes from dividing usable watt-hours by the load in watts.
Battery chemistry choice shapes any system as well. It helps to compare common solar battery types for home use before settling on a format.
All-in-One LFP Units for Small Loads
Grid-scale jobs call for tank systems. For a cabin, workshop, or backup at home, the practical choice is an all-in-one LFP power station. EcoFlow DELTA Gen4 units combine battery, inverter, and solar charging in one box, sized for 120V loads. They follow a different technology route from a flow design.
For a small off-grid workspace or mobile setup, a 3kWh unit can run lights, a laptop, and 120V tools. Loads like these are modest, so a compact all-in-one unit fits better than a tank system. The EcoFlow DELTA 3000 Gen4 is one example.
Some setups need more stored energy. For longer gaps between recharges, or for a fridge, a 3.7kWh unit stores more and can expand. The EcoFlow DELTA 3800 Gen4 fits that role.
How the Products Divide the Job
EcoFlow DELTA 3000 Gen4: Suits small 120V off-grid devices and mobile workspaces.
EcoFlow DELTA 3800 Gen4: Suits longer recharge gaps and compatible expansion.
Both are LFP, not flow batteries.
Runtime Estimates
The table below shows estimated runtimes for two example loads. Treat every figure as an estimate. Real runtime shifts with inverter losses, temperature, and how the loads cycle.
Load (example) | Watts used | EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.) | EcoFlow DELTA 3800 Gen4 (3,199Wh usable est.) |
Lights + laptop + router (20W + 60W + 10W) | about 90W | about 29 hours | about 36 hours |
13.9 cu ft fridge (ENERGY STAR, about 38W average) + lights | about 58W | about 45 hours | about 55 hours |
The method is simple: usable capacity (Wh × 0.85) ÷ load (W).
Delivery Timing and Fit
The EcoFlow US pages list the DELTA 3000 Gen4 as shipping in early December and the DELTA 3800 Gen4 in late November, as checked on November 9, 2026. Delivery timing should be confirmed on the US site for the delivery address. A Gen4 unit is not a fix for an outage happening now.
The 3800 model needs compatible extra batteries and the Smart Extra Battery Expansion Adapter to expand. Neither unit stands in for an existing tank system. The right pick comes down to the real load, the power needed, and the energy needed.
Back to the tank systems and their strengths and limits.
Flow Battery Advantages and Limitations
These systems offer long life and flexible sizing. But they are bulky and still early in commercialization. Most are not suited to homes today.
Advantages
Long discharge window: DOE lists the ability to discharge power for up to 12 hours at a time. That window is why the technology is studied for long-duration storage.
Long cycle life: DOE cites more than 5,000 deep cycles. A deep cycle is a full charge and discharge round, so the figure speaks to durability under heavy use.
Flexible sizing: Separate tanks and stacks let planners match power and energy to the job.
These traits explain the research interest. A system built for several hours of discharge and thousands of cycles fits jobs that repeat daily, such as moving midday solar output to evening demand.
Limitations
Early commercialization: PNNL describes the technology as "still in the early phases of commercialization." That stage affects how much real-world history buyers can review.
Size and plumbing: Tanks, pumps, and piping take up space. They also add moving parts that need maintenance.
Lower energy density: Lithium-ion generally stores more energy in the same volume, so tank systems are rarely compact.
Solid-state is another emerging option. Researchers also weigh solid-state batteries versus lithium-ion for future storage needs.
Finally, where are these systems used?
Where Flow Batteries Are Used
These systems are mainly aimed at grid and long-duration storage. They help smooth solar and wind output. Pilot and commercial projects are still developing.
Grid Reliability
DOE states that storage like vanadium redox batteries is needed to improve the reliability, resiliency, and efficiency of next-generation power grids. Long-duration jobs line up with the 12-hour discharge range DOE describes.
Utilities plan around demand peaks and supply gaps. Storage that discharges for hours gives operators more room to balance the two. In that setting, reliability means fewer shortfalls when other sources dip.
Solar and Wind Support
Solar and wind output changes with weather and time of day. Storage can hold extra energy during strong output and release it when supply drops. Tank-based designs can be sized for several hours of that shifting.
Why Homes Are Different
Residential needs are smaller. A household rarely needs grid-scale capacity, and a tank system takes more room than a wall-mounted unit. LFP storage fits that scale. For now, tank-based storage remains mainly a utility tool.
End-of-life handling matters too. Every chemistry, from vanadium electrolyte to lithium cells, benefits from circular battery recycling.
A flow battery stores energy in liquid electrolytes held in tanks, so power and energy can be sized separately. DOE cites up to 12-hour discharge and over 5,000 deep cycles for vanadium designs. Flow systems suit grid-scale storage, while LFP units suit homes and small off-grid spaces. For small 120V needs, the EcoFlow DELTA 3000 Gen4 or EcoFlow DELTA 3800 Gen4 is the practical route. Check delivery timing on the US site first.
What is a flow battery?
A typical dual-flow battery stores energy in liquid electrolytes kept in external tanks. Pumps move the liquids through a cell stack, where reactions charge and discharge the system. Tank size sets energy, and stack size sets power output.
How long do flow batteries last?
DOE cites more than 5,000 deep cycles for vanadium redox flow batteries. Actual service life still depends on the system design, the operating conditions, and upkeep of the pumps, membranes, and electrolyte at each installation.
Can I use a flow battery at home?
Flow systems are mainly aimed at grid-scale storage, and PNNL notes the technology is still early in commercialization. Tanks, pumps, and piping also take space. Homes usually rely on compact all-in-one lithium units instead.
What is a vanadium flow battery?
A vanadium flow battery uses the element vanadium in both electrolyte tanks, according to DOE. Each electrolyte flows through its own half-cell in the stack. Ions cross the membrane between the half-cells as the reactions store or release energy.
How is a flow battery different from a lithium battery?
Flow batteries keep energy in liquid electrolytes held in tanks. Lithium batteries store it in sealed cells. That split lets flow designs size power and energy separately, while lithium units pack energy into compact packages.
