Dry Camping vs. Boondocking: What’s the Difference?
For many RVers, camping without hookups is part of the experience. But a night at a developed campground can feel very different from staying in a remote spot far from services. That’s where dry camping and boondocking start to differ.
Both mean managing your own power, water, food, and waste. Dry camping usually keeps you closer to campground facilities, while boondocking tends to mean fewer services and more self-sufficiency. The difference may sound small, but it can change how you plan and what you need to bring.
What Is Dry Camping?
Dry camping describes the utility situation: no individual connections for electricity, fresh water, or sewer. The campsite itself may still have a marked pad, maintained roads, restrooms, dumpsters, or a dump station. In other words, the RV is off-grid even if the campground is not.
How Dry Camping Works
Without hookups, everything comes down to what your RV can carry and store. You use water from the freshwater tank, wastewater stays in the holding tanks, and electricity comes from batteries, solar, propane, or a portable power station.
The longer you stay, the more closely you need to watch your water, battery level, and tank capacity. For most RVers, those three things determine when it is time to refill, recharge, or move on.
Where You Can Dry Camp
Dry sites can be found at some national park campgrounds, state parks, basic RV campgrounds, and festival camping areas. Never assume “campground” means the same amenities everywhere. One place may have water and restrooms; another may offer little more than a fire ring. National Park Service reservations and services vary too, so check the specific campground before leaving home.
Pros and Cons of Dry Camping
Dry camping sits between a full-hookup RV park and a remote pullout. You can practice managing limited resources near maintained roads and perhaps a few basic facilities. The tradeoff? It may still cost money, reservations may be required, and a restroom down the road does not recharge batteries or empty tanks.
What Is Boondocking?
Boondocking describes both the lack of hookups and the location. The campsite is usually outside a developed campground, often on public land with few services nearby. Federal agencies commonly call it dispersed camping. The quiet is part of the appeal. So is the responsibility.
How Boondocking Works
Assume the site provides nothing. No faucet. No dump station. No restroom, trash service, or electrical pedestal. Everything comes in with you and leaves with you.
Trip length depends on more than batteries. Freshwater, tank space, food, fuel, road access, weather, and cell coverage can end a stay just as quickly. Usually, one becomes the weak link.
Where You Can Go Boondocking
BLM-managed land is popular, especially in the West. Dispersed camping is generally allowed on most BLM land unless an area is closed or restricted. The general limit is 14 days within 28 days, though local offices may set different rules.
National parks need a closer look. Some allow specific backcountry camping, while many prohibit vehicle camping outside designated sites. A scenic pullout or empty trailhead is not automatically legal. Check the exact land unit, not an old forum post.
Pros and Cons of Boondocking
The upside is space, privacy, fewer campground sounds, and often no nightly fee. The price is convenience. Roads may be rough, turnarounds limited, and water or dump stations surprisingly far away. Nobody is coming for the trash.
Key Differences Between Dry Camping and Boondocking
Here is the shortcut: dry camping tells you what the site lacks. Boondocking also tells you something about where the site is.
Location and Camping Environment
Dry camping can happen at a numbered site reached by pavement. Boondocking usually puts you in a dispersed area where the final stretch may include washboard, low branches, soft shoulders, or a turnaround that looked much larger on satellite view. A small campground mistake is inconvenient. Far from town, it can eat half a day.
EcoFlow DELTA 3 Plus Portable Power StationEcoFlow DELTA 3 Plus Portable Power Station
Hookups and Available Amenities
Dry camping and boondocking can both leave you without an electrical hookup, but the surroundings are often very different. At a campground, water, restrooms, dumpsters, or staff may still be nearby. When you are boondocking, you may have none of those things, so it is better to arrive ready to manage everything yourself.
On a longer stay, power can run down faster than expected once you add a fridge, lights, phones, laptops, and fans. Relying on the RV or tow vehicle for charging is not always practical. The EcoFlow DELTA 3 Plus Portable Power Station has 1,024Wh of capacity and 1,800W of AC output, enough for many everyday campsite needs. It also accepts up to 1,000W of solar input, which can be useful when you are staying off-grid for several days.
1–5kWh expandable with DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, or DELTA Pro 3 Extra Battery via an Alternator Charger XT150 Output Cable. 5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
Self-Sufficiency and Resource Needs
Food is another thing to think about when you are camping far from town. On a multi-day trip, keeping meat, dairy, produce, drinks, and frozen food at the right temperature can be difficult, especially when the nearest store is a long drive away. A portable fridge/freezer is more practical for this kind of stay than relying on a cooler and replacing ice every few days.
The EcoFlow GLACIER Classic Portable Fridge Freezer comes in 35L, 45L, and 55L sizes. The 45L and 55L models also have dual-zone cooling, which is useful when you want to keep fresh food chilled and frozen items separate. With the optional 298Wh plug-in battery, EcoFlow rates the 35L model for up to 43 hours at 39°F and the 45L and 55L models for up to 39 hours at the same setting, based on testing at a 77°F ambient temperature.
Keep food and drinks fresh or frozen with efficient cooling, strong insulation, and flexible storage. A 298Wh plug-in battery supports extended off-grid use, while multiple charging options and app control add convenience.
Dry Camping vs Boondocking Comparison Table
Comparison FactorDry CampingBoondocking
LocationCampgrounds or designated sites without hookupsUsually dispersed or undeveloped areas
HookupsNo full water, electric, or sewer hookupsUsually no hookups
AmenitiesMay include toilets, trash service, water, or staffFew or no facilities
CostMay require a site feeOften free or low-cost on public land
ReservationsSometimes requiredOften not required; local rules may apply
AccessibilityGenerally easier to reachRoads may be rough or remote
PrivacyModerateOften greater
Self-SufficiencyModerateHigh
Best ForCampers wanting off-grid practice near some servicesCampers comfortable managing their own resources
How to Choose Between Dry Camping and Boondocking
The better choice is not the more adventurous one. It is the one that fits the rig, the people traveling in it, and the amount of uncertainty everyone can enjoy before it stops feeling like vacation.
Consider Your Camping Experience
New to camping without hookups? Try two or three nights at a dry campground. That is enough to reveal real water use, battery habits, and tank limits without putting a rough road between you and the solution. Once those limits feel familiar, boondocking becomes much less mysterious.
Compare Your RV’s Off-Grid Capability
Before a longer RV boondocking trip, take an honest inventory of freshwater, holding tanks, batteries, recharging options, propane or fuel, tires, ground clearance, and appliance demand. Capacity is only part of the answer. You also need enough output and a practical way to recharge, whether that means conserving power, using a solar panel, or carrying additional charging equipment. A full battery on arrival is helpful. A plan for day four is better.
Match the Camping Style to Your Trip Length
A short trip can hide problems that become obvious on a longer stay. For a weekend, you may get by with simple conservation habits. But on a week-long boondocking trip, water, refrigeration, waste capacity, charging, and fuel all need closer attention. The key is to plan around the resource you are most likely to run out of first, not just the one with the largest capacity.
Think About Comfort and Convenience
Some RVers enjoy keeping things simple and limiting their power and water use. Others prefer a setup that supports everyday comforts, such as keeping food cold, charging devices, running lights, or using a fan at night. Neither style is wrong. The goal is to build a setup that matches how you actually travel.
EcoFlow GLACIER Classic Portable Fridge FreezerEcoFlow GLACIER Classic Portable Fridge Freezer
Safety Tips for Dry Camping and Boondocking
Remote camping tends to punish assumptions. A little checking before the drive can prevent a long, expensive afternoon later.
Check Weather and Road Conditions
Check the forecast, road reports, fire restrictions, and current land-manager notices. Rain can turn dirt into mud; heat and snow change the margin for error too. If the road looks questionable, stop while there is room to turn around. Four-wheel drive does not shorten an RV.
Plan Power and Water Use
Estimate normal water and electricity use, then leave a reserve. Check batteries and tanks daily; it is easier to leave tomorrow than discover tonight that something critical is gone. A driveway test can expose surprises while the hose and outlet are still nearby.
Store Food and Waste Safely
Keep food at safe temperatures, secure trash, and follow local wildlife-storage rules. “Leave food outside and hope” is never the answer. A dispersed site may have no toilet or dumpster, and RV wastewater belongs at an approved facility. Find it before the tanks are full.
Prepare for Emergencies and Limited Cell Service
Tell someone your destination, route, and return time. Download maps before service disappears, and mark fuel, water, dump stations, and medical care. For remote travel, think beyond the phone. With no signal, it is mostly a camera and offline map.
Follow Local Rules and Leave No Trace
BLM guidance asks campers to use existing disturbed sites, stay on designated roads, pack out trash, and check fire restrictions. Then read the local notices. Seasonal closures, fire bans, stay limits, and vehicle rules can change after an older guide was published.
Dry camping and boondocking both mean going without hookups, but the experience depends heavily on where you stay. Dry camping usually keeps you closer to developed campground facilities, while boondocking often means fewer services and more independence.
The right choice comes down to your RV, your route, and how much self-sufficiency you want. A short trip may only require a basic setup, while longer stays usually need more attention to power, food storage, water, and waste. Extra capacity can make off-grid camping more comfortable, but knowing your own usage is what helps you prepare.
Is Dry Camping the Same as Primitive Camping?
Not quite. Dry camping means the site has no individual water, sewer, or electrical hookups. Primitive camping describes a place with very few developed facilities.
A primitive site is often dry, but a dry site may still have restrooms, trash service, maintained roads, or staff nearby.
Is Overnight Parking Considered Boondocking?
Usually not. Sleeping overnight in a parking lot, rest area, or similar location is generally described as overnight parking, especially when you are stopping to rest rather than setting up camp.
Permission is what matters. Rules vary by property, city, and state, so check signs and ask the property owner when needed. An empty parking lot is not an invitation.
Is Boondocking Legal Everywhere?
No. It is legal only where the landowner or managing agency allows dispersed camping.
Many BLM areas permit it, but local stay limits, closures, fire restrictions, and other rules may apply. National forests, national parks, state lands, and private property operate under different policies. Check the specific location before driving in or settling down for the night.
How Do You Dispose of Waste While Boondocking?
Pack out household trash. RV black and gray water belongs only at an approved dump station or another authorized facility.
Find disposal options before heading into the backcountry and estimate how long the holding tanks will last. Remember that nearly every gallon drawn from the freshwater tank eventually takes up space somewhere else. On a long stay, water conservation is also wastewater management.
Can You Dry Camp in an RV Park?
Yes. Some RV parks and developed campgrounds offer basic sites without individual water, sewer, or electric connections. Shared restrooms, potable water, or a dump station may still be available elsewhere on the property.
For first-time dry campers, that is a useful arrangement. You get a real test of the RV’s off-grid systems without committing to a remote road or a long drive for supplies.
How Long Can You Dry Camp in an RV?
There is no single answer. The limit depends on freshwater, holding tanks, batteries, recharging, food, weather, and the habits of everyone on board. Many RVers discover that water or wastewater storage ends the stay before food or electricity does.
Conservation and recharging can buy more time, but do not plan around running every resource to zero. Keep a reserve, follow the local stay limit, and leave while the RV is still fully capable of leaving.
Camping
