Thru Hiking: What a Thru Hike Is, Famous US Trails, and How to Prepare
Picture hiking every mile between Georgia and Maine in one long trip. That's the idea behind thru hiking. A thru hike is the long-distance version of backpacking, where you complete an entire long trail in one trip. On the Appalachian Trail, that means finishing it all within 12 months, and you don't have to walk it in order from one end to the other. This guide covers what thru hiking means, the major US trails, resupply, gear, and how a support driver can keep your phone charged.
What Is Thru Hiking?
So, what is thru hiking? It means completing the entire trail within the time recognized for that route. The Appalachian Trail Conservancy counts a hike completed within 12 months, including a flip-flop itinerary that starts partway along the trail. Section hikers walk the same trail in pieces, sometimes over many years. Both groups share the same footpath and follow the same trail rules.
When people search "what is a thru hike" or "what's a thru hike," they usually want the plain version. It's one start, one finish, and no long breaks at home in between. You might take a rest day in town, but the trip keeps moving forward.
What Is a Thru Hiker?
The answer to "what is a thru hiker" is just as simple. It's anyone who sets out to walk a whole trail in one go. The word "thru" is short for "through," so people who type "what is thru" into a search bar are usually after the same idea. You'll also see people ask "what is a through hiker," since "through hiker" is a common alternate spelling. The thru hiking meaning stays the same either way.
Famous US Trails for Thru Hiking
Two trails come up first for most people. Here's how they compare at a glance.
Trail | Length | Route | Who manages it |
Appalachian Trail (A.T.) | 2,190+ miles | Appalachian Mountains, Georgia to Maine | National Park Service, US Forest Service, Appalachian Trail Conservancy, state agencies, and volunteers |
Pacific Crest Trail (PCT) | 2,650 miles | Mexico to Canada through California, Oregon, and Washington | US Forest Service, with partner agencies and the Pacific Crest Trail Association |
The National Park Service describes the Appalachian Trail public footpath as more than 2,190 miles long. It's managed by the NPS, the US Forest Service, the Appalachian Trail Conservancy, many state agencies, and thousands of volunteers. Out West, the Bureau of Land Management describes the 2,650-mile Pacific Crest Trail as stretching from Mexico to Canada.
Long trails build on the same habits as shorter trips. It helps to learn the power options for backpacking trips before you plan something this big.
On a thru hike, you can't carry a big battery on your back. But a support vehicle or a fixed resupply point can keep your devices charged between legs.
Charging on a Thru Hike: Support Vehicles and Resupply Points
Most thru-hikers carry a small power bank and recharge it in town. Some also have a support driver who meets them at road crossings, or a fixed base where they pick up supplies. That's the only place a power station fits, since it stays with the vehicle or base and never goes in your pack.
How Most Hikers Keep Phones Alive
Your phone often does three jobs on a long trail. It's your map, your camera, and your way to reach family. The NPS Ten Essentials list even suggests packing an extra battery for your phone. Add a headlamp and maybe a camera, and you have a small set of devices that all need power.
Most people charge their phone and power bank overnight in a town motel or hostel, then walk to the next town. That works well when towns are a few days apart.
You can also make each charge last longer. Put your phone in airplane mode when you don't need a signal, so it isn't using power to search for service, and turn the screen brightness down. Download offline maps before you leave town, so you can still view your route when there's no network. Cold nights drain batteries faster, so many hikers keep their phone and power bank in their sleeping bag.
When a Support Vehicle Makes Sense
For hikers with a support driver or a fixed resupply base, recharging between legs is easy. An EcoFlow portable power station in the vehicle can top off phones, cameras, and headlamps at each meet-up. It never goes on the trail. And if you don't have that kind of support, it isn't the right tool for your hike.
Before you count on it, confirm who will drive, where you'll meet, and how the unit will get recharged. Keep it dry and inside the vehicle when it rains. Charging only happens where the vehicle or base is, so plan your phone use around those stops.
At a support vehicle, a 1kWh unit can recharge a hiker's phone, camera, and headlamp many times between meet-ups. It can then refill from the car or from solar panels while the hiker is back on the trail.
Example Charging Estimates
How many charges could one unit give? The table below shows estimates only. The device numbers are example values, so check your own device ratings before you plan around them.
Device (example) | Energy per charge (example value) | Estimated charges from EcoFlow DELTA 3 Classic (about 870Wh usable) |
Smartphone | About 15Wh | About 58 |
10,000mAh power bank | About 37Wh | About 23 |
Headlamp battery | About 5Wh | About 174 |
These estimates use usable capacity (1,024Wh × 0.85) divided by the energy per charge. The power bank figure comes from 10,000mAh × 3.7V ÷ 1,000. Real results depend on your devices, cables, and the temperature.
Power Banks for the Trail Itself
On the trail itself, look at hiking power banks worth carrying. A small bank in your hip belt pocket is what keeps your phone going between towns.
Charging is only one part of the plan. Next comes the bigger work of resupply, timing, and permits.
How to Plan a Thru Hike
Planning a thru hike starts with time, money, and resupply. Most hikers mail boxes of food to towns along the route or buy what they need as they go. Permits and seasons change from trail to trail, so check with each trail's managing agency.
Resupply: Mail Drops or Buy as You Go
Many thru-hikers mix both methods. Here's how they stack up.
Method | How it works | Good for | Watch out for |
Mail drops | You pack boxes at home, and someone ships them to post offices or stores along the trail | Special diets and small towns with few stores | Post office hours and changing plans |
Buy as you go | You shop in trail towns every few days | Flexibility and fresh food | Small stores with limited choices and higher prices |
A simple plan lists each resupply town, how far apart they are, and which method you'll use there. That list also tells you where you can charge devices.
Permits, Seasons, and Budget
Each long trail has its own rules. On the PCT, Crater Lake National Park's Pacific Crest Trail permit guidance explains that hikers going 500 or more continuous miles in one trip can get an interagency PCT Long-distance Permit from the Pacific Crest Trail Association. Other trails handle permits differently, so start with the agency that manages yours.
Your start date depends on the season. Snow, heat, and storms all shape when you can safely start and finish. Your budget should cover gear, food, town stays, and travel to and from each end of the trail. Leave room for surprises, like a gear swap halfway through or an extra night in town after a storm.
Get Your Body Ready
Thru-hiking asks a lot of your feet, knees, and back. Before your start date, take long day hikes with a loaded pack and the shoes you plan to wear. These test runs show you what rubs, what aches, and what you can leave at home. They also give you a feel for how many miles a day suits you.
Tell Someone Your Plan
Safety planning matters as much as gear. The NPS suggests you leave a trip plan with a trusted contact who isn't going with you. It should say where you're going and when you expect to be back. The NPS also advises that you learn to use your map and compass or GPS before you head out.
Some hikers bring portable solar chargers for backpacking to stretch their power between towns. Others rely on town stops alone.
With the plan in place, the last piece is what goes on your back. Gear choices can make or break the trip.
Thru Hiking Gear Essentials
Lighter gear matters more as the miles add up. An extra pound feels small on day one and heavy by week six. But safety items stay in the pack, no matter how much weight you want to cut. Start with the NPS Ten Essentials.
The Ten Essentials for a Thru Hike
The NPS list covers ten safety systems that belong in every pack. Here it is with a thru hike tip for each item.
Ten Essential | Thru hike tip |
Navigation | Carry a map and know how to use it, even with a phone app |
Sun protection | Sunglasses, sunscreen, and a hat for long exposed days |
Extra clothing | One warm layer for cold nights and storms |
Illumination | A headlamp, plus a plan to charge or swap batteries |
First-aid supplies | Blister care and any personal medications |
Fire | A lighter or matches kept dry; follow local fire rules |
Repair kit and tools | Tape, a small knife, and patches for your pad |
Nutrition | Enough food to reach the next town, plus a little extra |
Hydration | Bottles and a way to treat water |
Emergency shelter | A space blanket or bivy if your tent fails |
The Big Three
Most of your pack's weight comes from three items. Thru-hikers call them the "big three."
Pack: It should fit your body and your load.
Shelter: A tent or tarp that sets up fast in bad weather.
Sleep system: A bag or quilt and a sleeping pad rated for the coldest nights you expect.
Cutting weight here saves more than trimming small items. Before you buy, compare lightweight versus heavy backpacking gear for long miles.
Thru hiking means covering the full length of a trail, like the 2,190+ mile Appalachian Trail or the 2,650-mile Pacific Crest Trail. Plan your resupply towns, permits, and start season first, since they shape the whole hike. Carry the Ten Essentials and keep gear as light as you safely can. On the trail, a small power bank covers your phone. If you have a support vehicle or a fixed resupply base, the EcoFlow DELTA 3 Classic can wait there to recharge phones, cameras, and headlamps between legs.
What is thru hiking?
Thru hiking means covering a whole long-distance trail. On the Appalachian Trail, you can hike northbound, southbound or follow a flip-flop route, provided you finish all sections within 12 months.
How long is the Appalachian Trail?
The National Park Service lists it as a public footpath of more than 2,190 miles. It runs through the Appalachian Mountains between Georgia and Maine.
How long is the Pacific Crest Trail?
The Bureau of Land Management and the National Park Service both list it at 2,650 miles. It runs from the Mexican border to the Canadian border through California, Oregon, and Washington.
What is the difference between a thru hiker and a section hiker?
A thru hiker walks the whole trail in one trip. A section hiker covers it in pieces, often over several years, and still follows the same trail rules.
How do thru hikers charge phones?
Most carry a power bank and recharge everything during town stops. Some have a support driver or a fixed base with a portable power station that tops off devices at each meet-up.
