Camping Set Up: How to Lay Out a Tent or RV Campsite That Works
A good camping set up isn't about how it looks in photos. It's about where the wind blows, where water runs when it rains, and how far you walk to the cooler in the dark. Get the layout right and the whole trip is easier. This guide covers how to plan a campsite in zones, how tent and RV sites differ, where to put the kitchen and lighting, and how to place power gear so it stays dry and safe. It ends with a quick setup checklist.
Start With the Site: Picking and Reading Your Campsite
Before unpacking, walk the site. Look for the flattest, highest ground. Notice where the wind comes from. Find where water would flow if it rained.
Taking five minutes to assess the dirt saves you hours of frustration later. You do not want to pitch your shelter in a low depression that becomes a muddy puddle by midnight.
Ground Rules and Environmental Impact
Always follow standard outdoor ethics to protect the park. The National Park Service promotes the Leave No Trace principle of "Travel and Camp on Durable Surfaces."
In backcountry spots, pitch camp at least 200 feet from lakes and streams.
In developed state parks and campgrounds, stay on the designated tent pad.
Avoid clearing living brush, digging trenches, or altering the soil structure.
Keep foot traffic centered on established paths to prevent unnecessary soil erosion.
Assessing Natural Hazards and Sunlight
Look up before you look down. Check overhead for dead branches, loose bark, or damaged limbs hanging in the canopy. Campers call these "widowmakers" for a reason, and a sudden wind gust can knock them down.
Track the arc of the sun across your campsite. Setting up under eastern tree cover gives you cool morning shade so your tent doesn't turn into a greenhouse at sunrise.
Checking Campground Hookups and Rules
If you brought a travel trailer, locate the site's electric pedestal, sewer connection, and freshwater spigot. Make sure your hookup hoses and cords can reach without stretching taut across high-traffic walking zones.
Review the campground rules posted at the check-in ranger station. Pay close attention to:
Quiet hours (typically 10 PM to 6 AM).
Fire restrictions or burn bans due to regional dry spells.
Generator run-time rules, which often ban loud gas motors during early mornings.
The choice between tent camping versus RV camping changes where everything goes. Once you know the ground, split the site into zones.
The Zone Method: Sleeping, Kitchen, and Living Areas
Most good campsite setups use three zones. Keep sleeping away from cooking smells and smoke. Put the living area in between.
Organizing your site this way creates a smooth workflow. It keeps dirty cookware away from clean bedding and cuts down on late-night trips across the site.
Zone | Where | Why |
Sleeping (tent) | Highest, flattest spot, upwind of the fire | Stays dry; prevents smoke from entering the tent mesh |
Kitchen | Downwind, near the picnic table | Keeps grease smells, cooking debris, and smoke away from beds |
Living area | Between the two, around the fire ring | Creates a central social spot for easy group movement |
Power and charging | Dry, ventilated spot under cover, off walkways | Keeps sensitive electronics dry and eliminates tripping hazards |
The Sleeping Zone
Your tent needs flat, smooth dirt free from sharp rocks, pinecones, and roots. Always place a durable ground tarp or footprint underneath your tent to stop rising groundwater. Tuck the tarp edges completely under the tent floor so rain cannot pool between the layers.
Face your tent door away from the prevailing wind. This prevents driving rain from pushing through the vestibule zipper seams.
The Kitchen Zone and Food Safety
FoodSafety.gov advises keeping perishable foods at 40°F or below to prevent bacterial growth. Place your coolers in the deepest available shade, ideally under the picnic table or beneath a canopy. Wrap reflective blankets over cooler lids in direct afternoon heat to hold ice longer.
Keep all raw meat double-bagged in leakproof containers. Set your camp stove downwind from the tent zone. That way, drifting bacon grease and cooking aromas do not cling to your sleeping bags. In bear country, follow the destination's food-storage rules and store food, toiletries, and cookware in approved bear-resistant facilities. Use a locked vehicle only where local rules expressly allow it; Yosemite prohibits storing food in cars, including trunks, after dark.
The Living and Fire Zone
The National Park Service highlights the principle of "Minimize Campfire Impacts" by always using established, existing fire rings. Clear dry pine needles, leaves, and twigs within a 10-foot radius of the fire ring perimeter.
Place your camp chairs upwind of the fire ring to avoid inhaling drifting smoke. Keep a full five-gallon bucket of water and a dirt shovel right next to the ring before you strike your first match.
Keep charging gear in a covered spot away from wet grass and fire sparks. String lights and a rug are easy campsite decoration ideas that also help at night.
Lighting and charging are where most campsite setups fall short after dark.
Lighting and Power: Where to Put Them
Plan lights for the kitchen, the path to the tent, and the bathroom route. Keep charging gear in one dry spot. Separate tent sites from RV sites when planning power.
Tripping over guy lines or dark root systems is the quickest way to ruin an evening outdoors. A good camping set up relies on focused, layered lighting paired with a reliable power bank or battery station.
Safe Lighting Rules for Campers
The Consumer Product Safety Commission (CPSC) warns to never burn fuel-based heaters or lanterns inside tents, campers, or enclosed vehicle spaces. Fuel combustion creates deadly, odorless carbon monoxide gas.
Use soft, battery-powered LED lanterns inside the tent.
Mount headlamps near the tent zipper so they are easy to reach in an emergency.
Hang overhead string lights across the cooking area to illuminate meal prep surfaces safely.
Mark tent stakes, tent guylines, and RV steps with small solar pathway markers or reflective tape.
Managing Power for Tent and RV Campsites
Power demands differ drastically depending on how you sleep. Tent campers usually need clean electricity for phone batteries, portable fans, camera equipment, and headlamps. RVers often need to run interior lights, basic water pumps, and RV-ready refrigerators without listening to a rattling gas generator.
Keep all charging hardware off bare dirt. Set your power hubs on an elevated tote or small folding side table under a rain fly. Run cords cleanly along the perimeter of the campsite instead of across main walking trails.
A power station gives a campsite one tidy, quiet power hub. EcoFlow portable power stations sit in a dry, covered spot, and everything charges from there: lanterns, phones, string lights, and, at RV sites, selected devices on the rig's own outlets. Choose by site type: direct plug-in at a tent site, or a 30A connection at an RV site.
At a tent site, plug the lights and phones straight into the unit. A 1kWh model fits under the picnic table or in the vestibule of a large tent, out of the rain, and covers a weekend of charging.
At an RV site without hookups, the goal is getting power into the rig's own outlets. The EcoFlow DELTA 3000 Gen4 offers 3kWh of capacity and 3600W of continuous output. Its AC outlets include a 30A maximum outlet for compatible connections.
How the two products divide the job
Each unit targets distinct camping setups and power profiles:
EcoFlow DELTA 3 Classic: Best for tent sites to power lights, electric camping kettles, laptops, camera batteries, and phones directly via onboard AC outlets and USB ports.
EcoFlow DELTA 3000 Gen4: Designed for RV sites with a compatible 120V/30A inlet, routing power to selected loads directly through the camper's interior distribution panel.
Important operational note: These portable power units are not rainproof or weatherproof. Never leave them exposed to rainfall, high humidity, or direct ground moisture. Always place them in a well-ventilated, dry storage compartment, under a waterproof shelter canopy, or inside a well-ventilated vestibule. Always check total load and outlet current before connecting devices. A single power station does not run a complete RV setup including the air conditioner, electric water heater, and microwave all at once.
Campsite Runtime Estimates
The table below outlines approximate runtimes based on everyday camping energy consumption. These figures are calculated using usable battery capacity divided by daily watt-hour demands.
Usable battery capacity ÷ Daily energy consumption = Estimated Runtime.
Load (example) | Energy used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.) |
String lights, lanterns, and phones (40W for 5 hours) | 200Wh | About 4 nights | About 13 nights |
RV lights, water pump, electric fridge, and phones (120W average) | 2,880Wh | Not suitable for this example | Under 1 day |
These figures are planning estimates, not guaranteed results. Actual consumption varies with appliance cycling, battery conditions, temperature, and usage patterns. The RV example assumes a 120W average draw over 24 hours. Air conditioning and electric water heating aren't included.
Before connecting equipment, check the total load and outlet current. Use compatible, properly rated cords and connections. Keep the power station dry and ventilated.
Knowing how RV electric hookups work makes it easier to plan a site with or without a pedestal. With everything placed, a quick checklist makes the next setup faster.
Campsite Setup Checklist
A checklist helps you follow the same routine on every camping trip. Start with the major equipment. Add lighting, decorations, and other comfort items afterward.
Before Unpacking
Walk the site and check the ground.
Identify wind direction and possible water flow.
Look for overhead hazards.
Locate electrical and water connections at RV sites.
Check campground fire and generator rules.
During Setup
Pitch the tent or level the RV first.
Set up the kitchen downwind.
Place the cooler in the shade.
Arrange chairs and the living area.
Set the power station in a dry, ventilated location.
Run electrical cords along the edges.
Hang lights near the kitchen and walking paths.
Keep emergency equipment accessible.
Before Going to Bed
Store food securely.
Put trash in the appropriate container.
Check that cooking equipment is switched off.
Extinguish campfires completely, following local rules.
Disconnect or secure equipment as needed.
Make sure pathways remain clear.
Remember to follow Leave No Trace principles. Pack out trash, avoid disturbing natural features, and leave the campsite as you found it. The National Park Service recommends disposing of waste properly and leaving natural objects where they belong.
Some camping setups get more elaborate than a basic tent and picnic table. Seeing what a modern glamping setup needs shows how far a simple campsite layout can go.
A good camping set up starts with the ground and wind, uses sleeping, kitchen, and living zones, and keeps lights and power dry and organized. When you walk your site first and group gear by function, camp chores take minutes instead of hours.
Keep your extension cords off the main walking paths. Make sure your food stays properly chilled, and place your campfire safely downwind from sleeping bags.
For reliable camp power, match the system to your rig. The lightweight EcoFlow DELTA 3 Classic offers fast charging and convenient direct plug-in power for tent sites. If you are dry camping in a camper, the EcoFlow DELTA 3000 Gen4 connects directly to your 30A RV inlet to run essential interior appliances smoothly. Pick the right unit for your shelter, set up smart zones, and enjoy your time outdoors.
How should I set up my campsite?
Start by choosing high, flat ground with good drainage. Place your tent away from the cooking area and fire ring. Set the kitchen downwind, with a living area between both zones. Keep coolers shaded and arrange lights along frequently used paths.
Where should the tent go relative to the campfire?
Place the tent well away from the fire ring. Consider the prevailing wind so smoke doesn't blow toward the sleeping area. Follow campground fire restrictions and maintain appropriate clearance from flames and sparks.
How do I set up an RV campsite?
Level the rig on solid blocks first, then connect water and electric hookups. Extend the awning, arrange outdoor furniture, and route all utility cords and hoses along perimeter edges away from main pedestrian walkways.
Where should I put a power station at camp?
Place it in a dry, covered, ventilated location away from cooking equipment. Keep it protected from rain and moisture. Run compatible electrical cords along the campsite edges instead of across walkways.
Can a power station run my RV at a site without hookups?
Yes, it can run selected appliances through a compatible 30A inlet. However, it cannot run heavy-draw equipment like your air conditioner, microwave, and electric water heater all at the same time without tripping the unit's inverter.
