Camping With CPAP: How to Power Your Machine at a Campsite or on the Trail
Camping with CPAP works best with a power plan built around the trip. A drive-up campsite can use a portable power station sized to the machine's measured nightly use. A backpacking trip calls for a light, maker-approved travel battery. In both cases, measure real use at normal settings, since it varies by machine, and ask an equipment provider about approved power options. This article covers both trip types, how to estimate nights of power, packing tips, and what to test before leaving home.
Car Camping vs Backpacking With a CPAP
Car camping lets campers bring more power. Backpacking means carrying every ounce. Camping with CPAP looks different at a car site than on a trail. A CPAP machine and camping trip fit together best when the power source matches the trip type first.
Trip type
Power option
Notes
Drive-up campsite
Portable power station
Size by measured nightly Wh
Campground with hookups
Site power with extension cord rated for the load
Bring a backup
Backpacking
Maker-approved travel battery
Check weight and nights
Matching the Trip to the Power Source
  • Weekend at a drive-up site: One compact power station can cover a short stay, as long as nightly use has been measured first.
  • Long stay with no hookups: Capacity matters more here. The setup may need a recharge plan or a larger battery to bridge the gap.
  • Multi-day trek: Weight sets the limit, so a maker-approved travel battery fits better than a large unit.
What Makers Say About Power Options
Machine makers publish guidance, and it is worth reading before buying anything.
  • 12V and 24V DC sources: ResMed says its S9 and S8 machines work safely with inverters and converters that run from a 12V or 24V DC source. Other models may differ, so a provider should confirm the right cable.
  • Maker accessories: ResMed also points readers to a medical equipment provider for details on the Power Station II and its other accessories. That conversation helps match gear to the exact machine.
Campgrounds With Hookups
Using a CPAP while camping at a powered site is simple, but hookups are not universal. SleepApnea.org suggests checking the campground's website. It also advises confirming the machine works with an extension cord before relying on one. A backup source helps if a site turns out to have no power.
For drive-up trips, compare the CPAP maker’s approved batteries and external power options before choosing a setup.
Powering a CPAP at a Drive-Up Campsite
Anyone camping with CPAP machine gear should measure the machine's nightly watt-hours at home, using usual settings. Then pick a station with enough usable energy for the nights between recharges. An approved DC cable, if the provider offers one, may reduce conversion losses.
For a home sleep-therapy device, ask its manufacturer whether the specific CPAP, adapter, and external power supply are compatible. EcoFlow’s DELTA 3 Classic safety instructions exclude life-sustaining equipment, including hospital-grade CPAP. Measured watt-hours estimate runtime only. Test the approved setup at home at your prescribed settings and bring an independent, approved backup.
For an approved setup, compare the energy needed for the whole weekend with the station’s usable capacity.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
For several nights without recharging, or with the humidifier and heated tube in use, a 2kWh station roughly doubles usable energy.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
How the Two Stations Divide the Job
  • EcoFlow DELTA 3 Classic Portable Power Station. For a compatible home CPAP, compare the measured weekend demand with the usable portion of the station’s 1,024Wh capacity.
  • EcoFlow DELTA 3 Max Portable Power Station. This model suits several nights, or trips where the humidifier and heated tube also draw power.
Recharging at the Campsite
Longer stays often need a top-up. Wall power works at sites with hookups. The EcoFlow DELTA 3 Max Portable Power Station lists solar and vehicle charging through its bundles. Cloudy weather can slow solar charging, so SleepApnea.org suggests keeping a backup battery. Charging times vary by source, so test the recharge routine at home too.
Estimate Nights of Power
The figures below are estimates. They are examples only, and the 120Wh and 400Wh nightly values are placeholders, not medical guidance. Usable energy runs lower than the rated capacity because of conversion losses.
Example
EcoFlow DELTA 3 Classic (about 870Wh usable)
EcoFlow DELTA 3 Max (about 1,741Wh usable)
Illustrative 8-hour night without humidifier (120Wh)
about 7 nights
about 14 nights
Illustrative 8-hour night with humidifier and heated tube (400Wh)
about 2 nights
about 4 nights
The math is simple. Nights equal usable Wh divided by measured Wh per night. Here is how to get the measured number:
  1. Plug a plug-in energy meter between the wall outlet and the CPAP's power supply.
  2. Run a full night at normal settings, with the humidifier and heated tube set as usual.
  3. Read the total watt-hours from the meter in the morning.
  4. Divide the station's usable Wh by that number.
Use the same calculation for a planned backup at home. Test the setup before you need it.
CPAP Camping Packing List and Tips
Pack spares, and protect the machine from dust and moisture. Those two risks matter most for CPAP when camping. For a water-filled humidifier, pack the water specified in its manual, and a full test run belongs before the trip.
CPAP gear packed in dry bagCPAP gear packed in dry bag
What to Pack
  • Therapy gear: Bring the CPAP, mask, tubing, and spare filters. Extra filters take almost no room.
  • Water supplies: If your machine uses a water-filled humidifier, follow the manual’s water requirements and pack distilled water when specified. SleepApnea.org advises against lake or stream water. A compatible ResMed AirMini HumidX setup uses waterless humidification.
  • Power gear: Include the approved DC cable or AC cord, the power source, and an extension cord rated for the load at campground sites.
  • Cleaning supplies: Wipes can remove dirt and dust when water is scarce, but they do not replace soap and water. Used wipes belong in a waterproof bag until disposal.
  • Protection and setup: A dry bag keeps the kit clean in transit. A small table or stand lifts the machine off damp ground.
Check Before the Trip
  1. Ask the equipment provider before using any new power accessory.
  2. Run a full night at home on the same power source planned for camp.
  3. Read the manual for temperature limits. SleepApnea.org notes that extreme heat, cold, or humidity can affect machines and batteries.
  4. Ask a clinician about higher elevations. Most modern machines adjust automatically, but altitude can matter for some sleepers.
  5. Pack a backup plan, such as a spare battery or a nearby site with hookups, in case weather or a late arrival changes things.
Keep your prescribed settings. Do not change the pressure yourself. Ask your prescriber or equipment provider to arrange any authorized adjustment. Avoiding common camping power station mistakes also saves trouble at the site. Backpacking changes the plan, so that comes next.
Weight and nights decide everything. CPAP backpacking leaves no room for extra gear. Many makers offer travel CPAPs and batteries, so a provider can say which ones are approved for the machine.
Backpacker resting beside tent at duskBackpacker resting beside tent at dusk
  • Travel machines: SleepApnea.org notes that smaller travel CPAPs are easier to carry. Whether one can also serve at home depends on the model and prescription. Transcend identifies its Micro 510 as an option for home and travel. Confirm suitability with your care team before switching.
  • Maker-approved batteries: ResMed describes the Power Station II as a way to power compatible ResMed devices when mains power is not available. Carry only batteries the maker approves for the machine.
  • Heated tubing: Heated tubing draws more power and adds weight. A trip with it needs a bigger battery than one without it.
  • Home testing: Run times differ by battery and machine. SleepApnea.org recommends testing every battery at home, so a short backyard trial shows how many nights a pack can cover.
  • Flying to the trailhead: Carry spare lithium-ion batteries in carry-on baggage and protect the terminals. Under FAA PackSafe rules, batteries up to 100 Wh are generally allowed. For spares over 100 Wh through 160 Wh, get airline approval and carry no more than two per passenger. Neither EcoFlow station listed here is within that limit.
That last limit matters. The 1,024Wh and 2,048Wh stations above exceed it, so they stay home on a flight and belong to drive-up trips. Small devices are a different story. For phones on the trail, portable solar chargers for backpacking can cover small loads.
Camping with CPAP starts with trip type. A power station suits drive-up sites, and a maker-approved travel battery suits backpacking. ResMed says to ask an equipment provider about power options. The key step is simple: measure nightly watt-hours at normal settings, then test the setup before leaving.
At drive-up sites, the EcoFlow DELTA 3 Classic Portable Power Station can cover shorter trips. The EcoFlow DELTA 3 Max Portable Power Station gives more room for several nights or humidifier use. Both fit best after nightly use is measured at home, since that number sets the nights each one can cover. No product replaces advice from a clinician or equipment provider, so confirm accessories and settings with them first. Then pack, test, and head out with a plan.
Can you go camping with a CPAP?
Yes. Many campers sleep well on trips with a planned power source. Pick the source by trip type, measure the machine's nightly use at home, and run a full test night before leaving. An equipment provider can confirm approved accessories.
How many nights will a power station run a CPAP?
Divide the station's usable watt-hours by the machine's measured nightly watt-hours. At 120 Wh per night, 870 usable Wh ÷ 120 Wh per night ≈ 7.25 nights, or about seven full nights under those assumptions. Humidifiers and heated tubes raise use, so measure with them on if they are part of therapy.
Can I run a CPAP from a car battery?
ResMed says its S9 and S8 machines work with inverters and converters on a 12V or 24V DC source. Other models differ, so an equipment provider should confirm the right cable or converter before a trip. Test the setup at home first.
Should I turn off my humidifier when camping?
Ask the prescribing clinician or equipment provider before changing humidifier use. Settings are part of therapy, so campers should not adjust them alone. A clinician can also advise on water supply and power needs for the trip.
What's the best power option for backpacking and CPAP use?
A lightweight, maker-approved travel battery is the usual fit, since weight and nights decide the plan. An equipment provider can name which batteries work with a specific machine. Check airline rules too if flying to the trailhead.
Camping
