4 Best Solar-Powered Generators for Home Backup in 2025
Securing your family’s energy security has never been more crucial than it is today.
Extreme weather events and blackouts are now occurring across the United States with alarming frequency.
Having a reliable home backup power source is essential.
Up until fairly recently, the only option for homeowners in search of reliable electricity during a power outage was purchasing a fossil-fuel-guzzling portable or standby generator.
That’s no longer true.
Technological innovations, falling prices, and generous tax breaks have made solar generators by far the most viable option for families seeking home backup power today.
But with so many options on the market, it can be hard to figure out what solar-powered generator is right for you.
Not any more.
Read on to find the best solar-powered generator for home backup in 2025— and beyond!
home essential
EcoFlow’s Top Solar-Powered Generators for Home Backup
night power
Best for Entry-Level Backup: EcoFlow DELTA 3 Classic (1024Wh) + 220W Solar Panel
EcoFlow DELTA 3 Classic (1024Wh) + 220W Next Gen Bifacial Portable Solar Panel is the perfect entry-level solar generator solution both for home and recreational use off-grid.
DELTA 3 Classic (1024Wh) is the most affordable entry point into EcoFlow’s new DELTA 3 Series of solar generators and home backup battery systems.
With 500W of solar charge input, you can connect up to two EcoFlow Next-Gen 220W Bifacial Portable Solar Panels.
Or you can max out your solar input with 5 x EcoFlow 100W Portable Solar Panels.
Either way, you get a ton of bang for your buck.
With 1800W of AC output (3600W) EcoFlow DELTA 3 Classic can start and run most high-wattage home appliances, like refrigerators, televisions, space heaters and window or portable air conditioners.
However, it lacks sufficient power output and battery storage capacity to run multiple heavy duty appliances simultaneously during extended power outages.
Most blackouts only last a few hours, in which case you can keep your refrigerator running and your smartphones charged for the duration.
Want to watch some TV while you’re waiting for the power to come back on?
No problem.
Just remember to plug your wi-fi router into your EcoFlow DELTA 3 Classic (1024Wh) as well as your television and stream your favorite shows even during a power outage.
If you leave the portable power station connected to a household wall outlet, it will pass through grid power and automatically switch on during a blackout, ensuring you always have a full charge.
EcoFlow DELTA 3 Classic (1024Wh) is also ideal for home office use.
Desktop computers, external hard drives, and other precision electronics are extremely sensitive to variations in the supply of grid electricity, such as voltage drops and brownouts, let alone power outages.
Surge protector power strips offer limited protection against sudden spikes in power, but do nothing to mitigate the impacts of blackouts or brownouts.
Uninterruptible power supply (UPS) units are rechargeable battery devices that plug directly into grid power using a standard household electrical outlet, and sit between your computer, peripherals, or other devices which you must connect directly to the UPS.
Connecting a power strip or surge protector to a UPS is never recommended because it diminishes the protection the unit offers.
UPS and portable power stations for desktop computers and external hard drives should have an auto-switchover of 10 milliseconds or less (<10ms) to provide data center level protections against voltage and current variations or blackouts.
EcoFlow DELTA 3 Classic offers 10ms auto-switch UPS protection and with 1kW of battery storage, you can run your computer, peripherals, and router for hours during an outage.
Consumer UPS solutions typically only provide about 10-20 minutes of power before the battery runs out. If you’re at your desk when the lights go out, that should be enough time to shut down your computer and peripherals down properly which should prevent data loss and damage from the blackout.
However, if you’re not home and your computer is on, the UPS offers little protection. When the battery runs out, your computer won’t shut down correctly, unless the UPS provides specialty software and connects to your computer with a USB cable or other method.
Whether you need a solar generator for essential home appliances or a UPS for your home, EcoFlow DELTA 3 Classic is an affordable way to get both.
DELTA 3 Classic Portable Power Station Specifications
Storage Capacity (Minimum):
1024Wh
Storage Capacity (Maximum):
N/A
AC Output (Minimum):
1800 W (2600W X-Boost/3600 W Surge)
AC Output (Maximum):
N/A
Solar Charge Capacity (Maximum):
500 W
Weight:
27 lbs (12.1 kg)
Dimensions:
15.67 in × 7.87 in × 11.14 in (398mm × 200mm × 283mm)
Operating Noise Level:
~30 dB
Charging Options:
AC; Solar; Generator; Car Charger (DC); AC+PV
Multi-Charge Options?
Yes (multi-charge)
Battery Chemistry:
LFP (LiFePO4)
UPS
10ms Auto-Switchover
Warranty:
5-year
App Monitoring and Control?
Yes
EcoFlow 220W NextGen Bifacial Portable Solar Panel Specs
Rated Power:
220W (±5W) Front/175W Rear
Efficiency:
25%
Solar Cell Type:
N Type TOPCon Monocrystalline Silicon
Weight:
Approx. 15.4 lb (7.0 kg)
Folded Dimensions:
24.2×23.2×1.3 in/615×590×32 mm
Unfolded Dimensions:
24.2×84.8×1.0 in/615×2155×25 mm
Waterproof/Dustproof Rating:
Open Circuit Voltage:
21.5V (Vmp 18.4V)
Short Circuit Current:
12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
Recommended Portable Power Station:
RIVER 3/DELTA Series
Pros
  • Powers 90% of home appliances
  • Compact enough to take anywhere
  • Generates up to 3kWh of electricity daily with solar panels
  • Charges from 0-80% in under 50 minutes with AC (household) electricity
Cons
  • Insufficient AC output to power multiple high-wattage appliances at once
Best for Essential Home Appliances: EcoFlow DELTA 3 Max Plus (2048Wh) + 400W Solar Panel
EcoFlow DELTA 3 Max Plus (2048Wh) offers more AC Output and solar battery backup than DELTA 3 Classic.
And, unlike DELTA 3 Classic, the DELTA 3 Max Plus solar generator’s storage capacity is expandable, so it can grow with you if your house battery backup needs increase.
Out of the box, it offers 2048Wh of storage, but you 5X that by adding up to 2 x EcoFlow DELTA 3 Max Plus Smart Extra Batteries for a maximum 10kWh capacity.
With AC Output of 2400W (3400W X-Boost/4800W Surge) you’ve got 2.4kW continuous power and almost 5kW of starting wattage to fire up engine-driven appliances like refrigerators, air conditioners, freezers, and dishwashers, all of which require a short surge of additional power to start.
Conventional gas and inverter generators often output as little as 10-20% of their maximum continuous power capacity as surge power, meaning EcoFlow DELTA 3 Series portable power stations and solar generators punch way above their weight with double their operating output available as surge wattage.
Thanks to EcoFlow’s proprietary X-Boost technology, EcoFlow DELTA 3 Max Plus can run up to 3400W of high wattage appliances thanks to smart energy management.
EcoFlow DELTA 3 Max Plus Portable Power Station Specifications
2048Wh
10 kWh (w/Extra Batteries)
N/A
Weight:
500 W
Dimensions:
45 lbs (20.3 kg)
19.45 in×9.41 in×12.01 in (494mm×239mm×305mm)
Charging Options:
~30 dB
AC; Solar; Alternator; Generator; AC+PV
Battery Chemistry:
Yes (multi-charge)
UPS
LFP (LiFePO4)
Warranty:
<10ms Auto-Switchover
5-year
400W Portable Solar Panel Specs
Rated Power
400W
Efficiency
22.6 %
Solar Cell Type
Monocrystalline
Weight
35.3 lbs (16.0 KG)
Folded Dimensions
41.7×24.4×1.0 in (105.8×62.0×2.5 cm)
Unfolded Dimensions
41.7×93,1×1.0 in (105.8×236.5×2.5 cm)
Open CircuitVoltage
48V (Vmp 41V)
11A (lmp 9.8 A)
EcoFlow DELTA Series
Pros
  • Runs 99% of appliances
  • Lightning-fast multi-charging (0-80% in 43 mins w/AC and solar)
  • 2-6kWh expandability
  • 10 years of daily use until hitting 80% capacity
  • 99% solar charging efficiency
Cons
  • Insufficient AC output to run multiple high-wattage appliances and HVAC systems
Best Home Backup Generator for Apartments and Small Homes: EcoFlow DELTA 3 Ultra Plus (3072Wh) + 500W Solar Panel Kit
EcoFlow DELTA 3 Ultra Plus (3072Wh) + 500W Solar Panel Kit is our most affordable solar generator that meets IRS guidelines for solar tax credit eligibility.
The 30% Federal Solar Tax Credit — officially known as the IRS [25D] Residential Clean Energy Credit — can save eligible US homeowners 30% of the total purchase and installation costs of qualified solar and home battery systems installed at their primary or secondary residence in the United States.
As of October 14th, 2025, the Residential Clean Energy Credit could save eligible US taxpayers close to $1,900 on a fully maxed out EcoFlow DELTA 3 Ultra Solar Generator in the following configuration.
Product
Number of Units
Direct-to-Consumer E-Commerce Price**
30% Residential Clean Energy Credit Savings
EcoFlow DELTA 3 Ultra Plus Portable Power Station (3072Wh) + Transfer Switch* 306A1 - 125V 30A
1
$1,599.00
$479.70
EcoFlow DELTA 3 Max Plus Series Smart Extra Battery
2
2 @ $799 = $1,598
$479.70
EcoFlow 400W Rigid Solar Panel
4
$1,998 (Bundle of 4)
$599.40
Qualified Installation Costs
N/A
$1,000
$300.00
Totals
$6,195
$1,858.50
Net Cost After Credit
$4,336.50
* For home circuit board/ wiring integration
** As of October, 2025. All prices subject to change
It’s easy to see why so many solar panel and home battery buyers are taking advantage of expiring clean energy credits before it’s too late.
Even If you don’t owe any income tax this year, or the amount of your credit exceeds your current tax bill, you can apply the non-refundable tax credit to future liabilities.
And the government incentives don’t stop there. Depending on your location, there are many state solar incentives, as well as those offered by utility companies and municipalities.
Make sure to take full advantage of the available programs that reward your family for switching to clean, renewable solar power.
The Residential Clean Energy Credit was originally scheduled to run until 2032.
However, the One Big Beautiful Bill Act now ends Federal solar tax credits as of December 31st of 2025.
Qualified Clean Energy Property purchased and installed on or after January 1st, 2026 will no longer receive the credit, even if it meets all the previous eligibility criteria.
Many US homeowners are rushing to install solar in 2025 so they don’t miss out on the substantial savings and maximize their return on investment.
EcoFlow DELTA 3 Ultra Plus (3072Wh) Portable Power Station Specs
3072Wh
10 kWh
AC Output):
3600W (4600W X-Boost/7200W Surge)
1600W
Weight:
75 lbs (34kg)
Dimensions:
24 in × 13 in × 15.55 in (613 mm × 328 mm × 395 mm)
~30 dB
Charging Options:
Yes (multi-charge)
Battery Chemistry:
LFP (LiFePO4)
UPS
Warranty:
5-year
Yes
EcoFlow 400W Rigid Solar Panel Specs
Rated Power
400W
Efficiency
23%
Solar Cell Type
Monocrystalline
Weight
48.1 lbs (21.8 KG)
67.8 x 44.6 x 1.38 in (1722 x 1134 x 35 mm )
37.10 V (±3%)
13.79 A (±5%)
Pros
  • Residential Clean Energy Credit eligibility (until December 31st, 2025)
  • Hours of whole-home backup power for apartments and small houses
  • Enough AC output to start and run high wattage appliances
  • Expandability: 3kWh – 10kWh capacity
  • Connect up to 4 x 400W solar panels
Cons
  • Not the best option for extended power outages and full-time off-grid living
  • Limited weatherproofing
Best Whole-Home Generator: EcoFlow DELTA Pro Ultra X
The 2024 launch of the award-winning EcoFlow DELTA Pro Ultra was a game-changer for whole-home solar generators and home battery backup solutions.
Now EcoFlow kicks it up a notch with EcoFlow DELTA Pro Ultra X — the most powerful DELTA Series whole home generator.
With up to double the maximum storage capacity and 15kW of additional AC output, EcoFlow DELTA Pro Ultra X provides enough electricity to operate almost any home entirely off-grid.
It also offers unparalleled versatility, with multiple charging methods including grid power, fossil fuel generators, solar panels, and more.
EcoFlow DELTA Pro Ultra X has a massive solar charge input capacity: 10kW per inverter for a maximum of 30kW total for 3 inverters, enough to support up to 75 x 400W solar panels.
Modular design adds to the system’s flexibility. Start with one EcoFlow DELTA Pro Ultra X Inverter and a 12.288kWh home battery backup and scale up as needed.
You can add up to 3 x EcoFlow DELTA Pro Ultra X inverters and Smart Extra Batteries to fully max out at 36kW of continuous AC output and 184kWh of solar battery storage.
EcoFlow matches you with a licensed installer and within 7 days, you can have a fully functional whole home generator integrated with your existing circuit board and wiring using Smart Home Panel 3.
EcoFlow DELTA Pro Ultra X features proprietary X-Core 3.0 tech architecture, providing industry-leading performance, safety, and intelligence.
With a hybrid solar system, you get solar power and storage giving you all the benefits of a grid-tied system with none of the disadvantages.
Traditional on-grid solar systems DON’T WORK in a blackout.
If you elect to continue consuming electricity from your utility provider, maximize your solar return on investment by only using grid power during off-peak hours. The Ecoflow app and Smart Home Panel 3 offer you the ability to specify exactly when you want to use utility power (and how much).
By taking advantage of dynamic electricity pricing and Time-of-Use rates, you can ensure you pay the lowest price per kilowatt-hour of grid electricity by using stored energy during peak demand hours.
By leveraging all available solar power incentives — such as the Residential Clean Energy Credit — and only using grid power off-peak, you can shorten your solar payback period significantly.
EcoFlow DELTA Pro Ultra X Portable Power Station Specs
12.288kWh (6144Wh x 2)
Maximum Capacity with 1 inverter
61.440kWh (6144Wh x 10)
Maximum Capacity with 3 inverters
184.32kWh (6144Wh x 30)
12kW, 120/240V, 60Hz
Up to 36kW in 3 parallel units
2 x 5kW solar charge input per inverter for total of 10kW. Maximum solar charge input with 3 inverters = 30kW
Weight:
Inverter: 34.5±0.2kg(70.06±0.44 lb)
Battery: 50.5±0.2kg(111.3±0.44 lb)
Dimensions:
Inverter: 675 × 475 × 230 mm (26.6 × 18.7 × 9.06 in.)
Battery:660 × 455 × 204 mm (26 × 18 × 8 in.)
Noise level <30 dB at 0.5 m (ambient temperature 25 °C, 4 kW output)
Charging Options:
TBC
TBC
Battery Chemistry:
Lithium Iron Phosphate (LFP/LiFePO4)
UPS
<10ms standalone, <20ms with Smart Home Panel 3
Warranty:
5-year
Yes
Federal Solar Tax Credit Eligibility?*
Yes
*Eligibility based on current Internal Revenue Service Guidelines for the Residential Clean Energy Credit. Subject to change and individual eligibility. Consult a tax professional before making a purchase.
Rated Power
400W
Efficiency
23%
Solar Cell Type
Monocrystalline
Weight
48.1 lbs (21.8 KG)
37.10 V (±3%)
13.79 A (±5%)
Pros
  • Hybrid solar system maximizes energy security and electricity bill savings
  • Up to a month of home backup power during a blackout
  • Modular expandability
  • Out-of-the-box Residential Clean Energy Credit eligibility
  • IP54 rating (dustproof and splashproof)
Cons
  • Limited portability
What Is a Solar Generator?
A solar generator consists of photovoltaic (PV) modules — typically solar panels — and a balance of system that converts (and sometimes stores) AC and DC electricity.
A balance of system can be made up of discrete but compatible components or housed in an all-in-one unit like EcoFlow’s portable power stations.
A typical off-grid or hybrid residential solar power system includes:
An on-grid system has less components, but it won’t work in a blackout without battery storage.
Speaking of on and off-grid, there are three basic types of solar generators.
Off-Grid
Off-grid solar power systems generate electricity solely using solar panels and do not connect directly to the grid.
Solar power is intermittent by nature. You’ll generate less power on cloudy days and solar panels don’t work at night.
Off-grid solar solutions like EcoFlow DELTA Pro Ultra X store electricity in a solar battery to draw on during hours when little or no power is produced.
Although off-grid solar power systems don’t connect directly to the utility grid, many offer AC and DC charging capabilities.
Grid-Tied
Grid-connected solar power systems do not require storage.
A traditional on-grid solar system utilizes solar panels and an inverter, and a bidirectional meter to transmit and receive electricity from the utility grid.
A solar inverter is a necessity in all solar power systems because photovoltaic modules capture photons from sunlight and convert them into DC electricity. The inverter converts DC electricity to AC for use in your home and for the grid.
On-grid systems have their advantages. However, without storage, a grid-tied system won’t work during a power outage.
Hybrid
A hybrid solar power system, like EcoFlow DELTA Pro Ultra X, offers on-grid connection for charging and solar battery storage.
With a hybrid system, you get all the benefits of grid connectivity and the energy security of off-grid.
How Do Solar Generators Work?
All modern residential solar generators that produce electricity operate using the same basic principles.
Photovoltaic modules — typically solar panels — capture photons from sunlight and convert them into DC electricity.
The active component in solar panels are photovoltaic cells — usually monocrystalline or polycrystalline silicon — that generate electricity from solar irradiance (sunlight) using the photovoltaic effect.
PV modules transmit power to the solar inverter which converts DC electricity to AC for use in your home — and potentially for transmission back to the grid through a net metering program
If your solar generator stores electricity, DC power is sent to a charge controller and solar battery.
A hybrid solar power system offers both storage and grid connectivity so you benefit from the advantages of both.
What To Consider When Shopping for the Best Solar-Powered Generator for Home Backup
No matter what type of residential solar generator you’re looking for, there are numerous factors to consider before making a purchase decision.
Here are the most crucial:
Household Electricity Consumption
It is essential to accurately determine the total running and starting wattage of all the devices and appliances you want to run simultaneously with electricity produced by your solar generator.
You can get a ballpark estimate of your daily electricity consumption by dividing a recent electricity bill by 30 days. However, this is not something you want to guesstimate.
Learn how to calculate kilowatt-hour consumption for your home.
On-Grid, Off-Grid, or Hybrid?
Next, you need to make a decision about what kind of solar power system you want.
If you’re unconcerned about power outages and live in a location that offers net metering, you might consider a traditional on-grid solar power system.
However, with extended power outages occurring ever more frequently, investing in an off-grid or hybrid solar power system offers far more energy security.
AC Output refers to the maximum amount of electricity a generator can produce on demand.
At a bare minimum, the AC output of your solar generator should exceed the combined wattage of all the appliances you want to operate simultaneously by at least 10%
Don’t forget to consider starting watts!
Many high-wattage appliances — particularly ones that use motors like refrigerators and washing machines — require significantly more power to turn on than they do to operate.
Thanks to proprietary X-Boost technology, EcoFlow’s solar generators offer up to double their operating AC output as surge power.
Storage Capacity
If you have an off-grid solar power system, battery storage capacity will determine how long you can run your appliances during the night or other times of day where your consumption exceeds your production of electricity.
Capacity is less of a concern for hybrid and grid-tied systems because they can access grid power during a shortfall. Except during a blackout.
Number of Solar Panels, Rated Power, and Efficiency
Every solar panel comes with specs for rated power in watts and efficiency.
For example, EcoFlow’s 400W rigid solar panel produces 400 watts of electricity per hour under Standard Test Conditions and offers industry-leading 23% efficiency.
Standard Test Conditions for Solar Panels
Condition Type
Real-World Conditions
Solar Incident Angle
Always zero, irradiation beam always normal to the PV panel*
Variable, and depends on time, date, and site latitude. In the case of rooftop systems, roof orientation, and inclination govern system capacity.
Solar Irradiation
Always equal to 1000 Watts/m²*
Variable and depends on the time, date, and site latitude. Limited sunshine hours bound system capacity.
Ambient Temperature
Always 25°C*
Variable and depends on the time, date, weather condition, and site latitude. Higher ambient temperature degrades PV panel efficiency and reduces system output.
Air Mass Coefficient (AM)
Always equal to 1.5*
Variable and depends on the time, date, and site latitude. Higher AM with higher latitudes.
System Losses
(e.g., Wiring, Inverter)
Always Zero*
Variable and depends on the design and location of PV panels, inverter, and grid meter.
*Cannot be achieved in real-world operation (Source: ResearchGate)
Real-world conditions rarely (if ever) match Standard Test Conditions. Even highly efficient solar panels will produce less than their maximum rated power for many hours of the day.
Learn how to calculate how many solar panels you need here.
(Source: NREL)
Peak Sunlight Hours
The number of hours of peak sunlight your solar panel installation receives has a significant impact on your electricity generation potential and varies widely based on location.
Estimate your peak sun hours here.
Available Surface Area for PV Module Installation
To maximize electricity production, you must install your solar panels in direct sunlight.
For most homeowners, a rooftop installation makes the most sense. However, ground installations can also be viable.
Ensure that you position your solar panels facing south. Carefully determine the ideal angle and tilt relative to your location relative to the position of the sun.
Budget
Last but not least, you need to weigh up how much you can afford to spend on a solar generator vs. your long-term return on investment.
With many government solar incentives available, it’s possible to substantially reduce your purchase cost.
Additionally, there are often low-to-no interest rate financing options if you purchase your solar generator direct from the manufacturer.
The sooner you achieve solar payback by recouping your initial purchase and installation costs, the sooner you start making money on your investments.
Solar panels last for decades.
Make sure to invest wisely, and you’ll reap the benefits for many years.
Can Solar Generators Power a House?
Yes. If you purchase a solar generator with enough AC output and storage, it can power your home off-grid indefinitely. You also need to buy enough solar panels to meet your electricity production needs. Make sure to carefully assess any photovoltaic modules’ rated power wattage and efficiency. Factor in the peak sunlight hours at your location.
Thanks to rapidly improving technology, government incentives, and falling prices, there’s never been a better time to invest in clean, renewable solar energy.
Whether you want to go off-grid or enjoy the additional benefits of grid connection and smart energy management with a hybrid solution like DELTA Pro Ultra X, EcoFlow has a solar generator that’s right for you.
Check out our award-winning selection of solar generators and panels today!
*Under 2000W output
Solar Generators
