LiFePO4 vs. Lithium Ion Batteries: What’s the Best Choice for You?
The battery industry has advanced rapidly in recent years, making superior technologies more affordable. Lithium iron phosphate (also known as LiFePO4 or LFP) is the latest development in this rapidly changing industry.
The LFP battery type has come down in price in recent years — and its efficiency has dramatically improved. It’s surpassing lithium-ion (Li-ion) as the battery of choice for many applications, including off-grid and solar power — and even Electric Vehicles (EVs).
LiFePO4 batteries are similar to Li-ion but have significant advantages that make them the ideal option for consumer-grade backup power solutions.
How Do the Chemistries of LiFePO4 and Lithium Ion Batteries Differ?
LiFePo4 and Li-ion batteries are rechargeable batteries that use lithium ions to harness and release electrical energy. While they are similar in many ways, they also exhibit some glaring differences.
LiFePO4 (Lithium Iron Phosphate) Batteries
LiFePO4 batteries are a subtype of lithium-ion batteries that utilize unique chemistry to provide advantages over related lithium technologies. They’re becoming increasingly common in off-grid and home backup power solutions.
LFPs get their name from the chemical composition of the cathode, which consists of lithium iron phosphate (LiFePO4). The anode is typically carbon; the electrolyte is a lithium salt in an organic solvent.
The chemistry of LiFePO4 provides enhanced safety features compared to lithium-ion. The presence of iron, phosphorous, and oxygen atoms in the cathode creates strong covalent bonds. The result is that the battery is more stable and less prone to thermal runaway and overheating issues.
Crucially, LiFePO4 batteries do not use nickel or cobalt — two metals in dwindling supply and often questionably sourced.
Lithium-ion batteries comprise a variety of chemical compositions, including lithium iron phosphate (LiFePO4), lithium manganese oxide (LMO), and lithium cobalt oxide (LiCoO2).
These batteries all have three essential components: a cathode, an anode, and an electrolyte. The electrolyte for these batteries is lithium salt, whereas the anode is carbon. The cathode is where the chemistries differ—they consist of one of the lithium metal oxides that give them their respective names.
The charging and discharging processes are the same for all of these. As the lithium ions move from the cathode to the anode, the electrons migrate in the opposite direction. This movement creates an electrical current.
LiFePO4 vs. Lithium Ion Batteries: How Do They Compare?
Safety
LiFePO4 batteries are safer than Li-ion due to the strong covalent bonds between the iron, phosphorus, and oxygen atoms in the cathode. The bonds make them more stable and less prone to thermal runaway and overheating, issues that have led to lithium-ion batteries having a reputation for a higher risk of battery fires.
Stability is why LFPs are the standard in off-grid and solar power applications. When the batteries are in the home, there is no room for error concerning overheating and other issues. Homeowners can confidently store their LiFePO4 battery in the house without worrying about fire safety issues.
Energy Density
Li-ion batteries typically have a higher energy density than LFPs. The energy density of a battery is a measure of how much energy it can store per unit of volume or weight. Li-ion batteries can store more power per volume or weight unit than LFPs.
For example, the energy density of a typical Li-ion battery is around 45–120 Wh per lb (100-265 Wh per kg), while the energy density of a LiFePO4 battery is about 40–55 Wh per lb (90-120 Wh per kg). The expansive energy density range of Li-ion batteries is due to this statistic encompassing all types of Li-ion batteries, including technologies only suitable for electric cars and other applications.
For off-grid power solutions, LiFePO4 remains supreme, even when considering the slightly lower energy density. This difference is negligible as you move into larger stationary power solutions. For instance, the EcoFlow’s whole-home battery backup systems are set-it-and-forget-it solutions. You won’t notice a slight difference in energy density.
Weight
The weight of a battery bank has some correlation to energy density, as mentioned above. LiFePO4 battery banks may weigh slightly more than comparable Li-ion batteries, while some LFPs may be lighter because the metals used in their construction are lighter.
Either way, any slight variation in weight pales in light of the other enormous advantages of LFPs.
Li-ion batteries with higher energy densities—such as nickel-cobalt-aluminum (NCA) and nickel-manganese-cobalt (NCM)—are no longer considered ideal for off-grid and solar applications. Instead, home power solutions use safer, longer-lasting technologies like LiFePO4. A safer battery is more important than a slight difference in weight.
LFPs are still incredibly light, considering how much power they pack. EcoFlow DELTA 3 Max Plus portable power station offers 2048Wh of energy storage capacity. It weighs only 45 lbs (20.3 kg) — light enough to comfortably carry around the house or toss in the back of a car.
Temperature Range
LiFePO4 batteries offer a wider operating temperature range. They can function well in temperatures ranging from -4°F (-20°C) to as high as 140°F (60°C).
In contrast, Li-ion batteries have a much smaller temperature range of 32°F (0°C) to 113°F (45°C). Users need to store Li-on batteries in climate-controlled spaces during the depths of winter or the heat of summer.
LiFePO4 batteries are safe to store in the house, shed, garage, or other indoor space without air conditioning. They’re less susceptible to temperature changes, giving you more options for locating the battery without potential damage or reduced efficiency.
Lifespan
Many Li-ion batteries can go through around 500 charge and discharge cycles before degrading in performance. LiFePO4 batteries can go through thousands of cycles before their performance begins to drop.
For example, the EcoFlow DELTA 3 Ultra Plus portable power station has a charge cycle rating of 6500 cycles before it reaches 50% capacity. Smaller options have similar lifespans, such as the EcoFlow RIVER 3 Plus portable power station, which has a cycle life rating of 80%+ capacity after 3000 cycles. After this time, the battery will still function at a minimum of 80% of the original 286Wh capacity. Even after this slight drop in performance, you may still receive years of use from your LFP battery bank!
This much longer lifespan means that LiFePO4 will reduce the environmental impact resulting from e-waste. The lack of nickel and cobalt also makes them more environmentally friendly.
You can use your LFP battery bank for 5 or 6 times longer than a Li-ion model, and you won’t waste money on replacements.
DELTA 3 Max Plus Portable Power Station
The EcoFlow DELTA 3 Max Plus delivers 3000W of reliable power (6000W surge) with X-Boost™ to handle heavy-duty appliances. Charge to 80% in just 43 minutes, expand up to 10kWh, and control circuits smartly via the app. Durable, whisper-quiet, and backed by up to 5 years of warranty, it’s power you can count on anywhere.
Cost
The cost per watt-hour of LiFePO4 vs. Li-ion batteries can vary widely depending on the manufacturer, market demand, and capacity. LiFePO4 batteries don’t use nickel or cobalt, materials that can fluctuate dramatically in supply and price.
LiFePO4 is still a relatively new battery chemistry, meaning there are fewer manufacturers and less supply, which can make LiFePO4 batteries slightly more expensive Wh for Wh.
However, it is possible to find affordable options for LFP batteries. EcoFlow’s DELTA 3 Classic is one example. With a 1024Wh LiFePO4 battery, the cost is less than $0.40 per Wh.
Even if there is a slightly higher cost than comparable Li-ion battery packs, the advantages of LFP outweigh the price difference. Any extra costs go toward added safety, longer lifespan, and other invaluable benefits.
Self-Discharge Rate
LiFePO4 batteries have a self-discharge rate of around 1-3% per month, depending on usage, temperature, and other factors. The low self-discharge rate means you can leave the battery in storage for months. It will still supply substantial power even after a period of disuse.
To follow best practices, top off your battery at least every few months to keep it optimized for use.
Voltage
LiFePO4 batteries have a lower nominal voltage than Li-ion batteries, typically around 3.2V per cell, compared to 3.6V to 3.7V per cell for Li-ion batteries.
The voltage can impact the design of battery packs and the voltage requirements of devices that use them.
Is LIFEPO4 Better Than Lithium-Ion?
LiFePO4 surpasses lithium-ion in safety, boasting a longer lifespan and greater thermal stability, making it ideal for prolonged use. While lithium-ion may be initially cheaper and require less upkeep, its susceptibility to overheating poses risks. Choose LiFePO4 for durable, safe off-grid power solutions with minimal environmental impact.
LiFePO4 vs. Lithium Ion Batteries: Which One Is Right for You?
If you want to invest in a battery bank that you can use off-grid regularly, LiFePO4 is the right choice. The added safety features alone make it worth the investment — you won’t have to worry about the thermal runaway and overheating risks associated with Li-ion batteries.
The longer lifespan also makes LFP batteries the clear frontrunner. With a cycle life over five times as long, your LiFePO4 battery banks will still be running long after comparable Li-ion batteries have reached the end of their lifespan. You will save yourself money in the long run and minimize battery e-waste.
Plus, you can turn any LiFePO4 portable power station from EcoFlow into a solar generator by adding one or more solar panels!
Is a Lithium Ion Battery the Same as a Lithium Iron Battery?
No, a lithium-ion (Li-ion) battery differs from a lithium-iron-phosphate (LiFePO4) battery. The two batteries share some similarities but differ in performance, longevity, and chemical composition. LiFePO4 batteries are recognised for their longer lifespan, increased thermal stability, and enhanced safety. Additionally, LiFePO4 batteries do not utilize nickel or cobalt.
LiFePO4 is a subtype of Li-ion battery that improves the safety, lifespan, and optimal temperature range of off-grid power solutions and home battery backup systems.
LiFePO4 batterries are the clear choice for anyone wishing to power devices and appliances off-grid while saving on long-term costs and limiting the negative environmental impacts of manufacturing, recycling and disposal.
Portable Power Stations
