The Best Portable Generator for Home: A Practical Buying Guide
Start with the number most buying guides bury: portable generators were tied to an estimated 765 non-fire carbon monoxide deaths in the United States over the 2009 to 2019 decade alone, averaging out to more than 75 deaths a year, which is why the safety basics belong before the wattage comparison, not after it. This guide covers what to check before you shop, how to size a generator to your actual needs, the real tradeoff between fuel-based and battery options, how to match capacity to realistic outage lengths, whether you need a transfer switch, and how to think about your home's specific layout.
The Safety Basics Come Before the Shopping List
Before comparing wattage or brands, it helps to understand the one risk that shapes almost every other recommendation in this guide.
  • The real risk: carbon monoxide poisoning tied to portable generators has averaged more than 75 deaths a year in the United States, most often from running one too close to a home.
  • Placement rules: run a fuel-based generator outdoors only, at least 20 feet from the house, with exhaust directed away from vents, windows, and doors.
  • Backup detection: battery-operated CO alarms on every level of the home are recommended regardless of how carefully a generator is placed.
For households that want to remove this risk from the equation entirely, carbon monoxide safety and gas generator alternatives cover what changes with a battery-based setup. With the safety ground rules set, the next question is simply how much capacity your home actually needs.
What Size Do You Actually Need?
Sizing a generator starts with an honest list of what you actually want running during an outage, not the biggest number on the shelf.
  • 3,000 to 5,000 watts: covers the essentials, a refrigerator, lights, phone chargers, and a router.
  • 6,000 to 8,000 watts: covers critical circuits with some 240V capability, such as a well pump or window AC unit.
  • 10,000 watts and up: covers broader whole-home circuits for multi-day outages.
  • Build in headroom: industry guidance generally recommends about 20% extra wattage above your calculated load, to safely absorb motor starting surges.
For a full walkthrough of the running-watts-plus-starting-watts math behind these tiers, the difference between starting and running watts breaks it down step by step.
Once you know your target wattage, the bigger decision is what kind of generator delivers it.
Fuel-Based vs. Battery: The Real Tradeoff
portable generators for power outagesportable generators for power outages
Wattage tells you capacity, but the fuel-based versus battery decision changes almost everything else about how that capacity gets delivered.
  • What to compare either way: running versus starting watts, 120V-only versus 120/240V output, and whether the unit is transfer-switch ready.
  • The fuel-based tradeoff: gasoline, propane, or natural gas units offer high wattage and long runtimes, but come with fuel storage, noise, exhaust placement rules, and the CO risk covered above.
  • The battery-based tradeoff: indoor-safe, quiet operation with no exhaust or fuel logistics, in exchange for a capacity that depends on battery size rather than a fuel tank.
A direct side-by-side of what each approach actually delivers is covered in backup battery versus gas generator.
If the battery side of that tradeoff fits your home, the questions above still apply: output, voltage, and how it connects to your panel. The EcoFlow TITAN answers them with 7.2kW of 120V/240V split-phase power and a 5kWh base that expands to 30kWh. It runs indoors with no fuel or exhaust and connects through Smart Home Panel 10, installed by a qualified electrician.
EcoFlow TITAN 5000
If you plan to recharge from a larger solar array during long outages, the EcoFlow TITAN Plus gives you more room. It adds a second 4kW solar input, and its output rises to up to 10kW only when compatible solar is connected and producing.
EcoFlow TITAN 5000 Plus
At the other end of the lineup, the EcoFlow TITAN Classic is for homes that only need the basics during an outage. It supplies 4kW of 120V power for a refrigerator, lights, and a Wi-Fi router, and it does not run 240V appliances.
EcoFlow TITAN 5000 Classic
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Whichever type you lean toward, it helps to size that decision against outages you're actually likely to face.
Matching Capacity to Real Outage Durations
The wattage tiers above assume a typical outage. Real outages vary widely, and that variation matters as much as the appliance math.
  • Multi-day outages aren't rare: Winter Storm Fern left roughly 1.1 million customers without power at its January 2026 peak, with some of the hardest-hit areas taking close to two weeks to reach full restoration.
  • Major hurricanes stretch even longer: Hurricane Helene left a peak of 4.6 million customers without power across the Southeast, with utilities still identifying customers facing longer-term rebuilds well after the storm passed.
  • Short, repeated outages matter too: brief grid cycling during storms like Hurricane Milton meant fast-recharging setups mattered more than raw capacity for some households.
The US Department of Energy tracked that 4.6 million figure in its own storm situation reporting, underscoring how far outage impacts can extend beyond a single neighborhood or utility territory.
Do You Need a Transfer Switch?
Transfer SwitchTransfer Switch
A generator sized correctly still needs the right connection method to actually power your home safely.
  • Why it matters: a transfer switch lets a generator power your home's wiring directly and safely, instead of running extension cords to individual devices.
  • Backfeeding risk without one: connecting a generator to household wiring without a transfer switch can send power back into utility lines, endangering utility workers.
That backfeed danger is documented directly by federal safety guidance. OSHA warns that a generator should never be connected to a structure's electrical system unless a qualified electrician has installed it with a transfer switch. The setup and installation basics are covered in the automatic transfer switch home backup guide.
Does It Fit Your Home's Layout?
Two homes with identical square footage can still need very different generator setups once the actual layout comes into play.
  • Square footage isn't the only factor: multi-story homes often need circuits split differently than single-story homes of the same size.
  • Panel location matters: where your electrical panel sits relative to where a generator can safely run affects cord length and setup complexity.
For homes with more than one floor specifically, the best generators for two-floor houses covers layout-specific considerations.
Choosing the best portable generator for a home starts with safety and correct sizing, not brand or wattage alone, and the choice between fuel-based and battery options changes noise, fuel logistics, and CO risk as much as it changes capacity. Size your generator to both your appliance list and your region's realistic outage length, and confirm transfer switch and placement requirements before you buy. The EcoFlow TITAN, EcoFlow TITAN Plus, and EcoFlow TITAN Classic are worth comparing against a fuel-based generator for home backup.
What is the best portable generator for home use?
The right choice depends on your appliance list, your region's typical outage length, and whether you prioritize fuel-based runtime or battery-based safety and quiet operation. Battery options like the EcoFlow TITAN Classic, EcoFlow TITAN, and EcoFlow TITAN Plus cover different capacity tiers within the same fuel-free lineup.
What size generator do I need for my house?
Most homes fall into one of three tiers: 3,000 to 5,000 watts for essentials, 6,000 to 8,000 watts for critical circuits with some 240V capability, or 10,000 watts and up for broader whole-home coverage. Add roughly 20% headroom above your calculated load to safely absorb starting surges.
Is a battery generator safer than a gas generator?
Yes, in the sense that matters most: a battery-based system has no exhaust and no carbon monoxide risk, which eliminates the leading cause of portable generator deaths. It trades that safety advantage for a capacity that depends on battery size rather than a refillable fuel tank.
Do I need a transfer switch for a portable generator?
If you want to power your home's wiring directly rather than running extension cords to individual devices, yes. Skipping a transfer switch also risks backfeeding power into utility lines, a hazard OSHA specifically warns against.
How long can a portable generator power a home during an outage?
For fuel-based units, it depends on tank size and how much load is running, often requiring refueling every several hours at higher loads. Battery-based systems like the EcoFlow TITAN lineup depend on stored capacity and how quickly that capacity can be recharged, which matters most during the short, repeated outages some storms cause.
Power Outages
