Best Battery Backup for Lift Chairs: How to Keep Your Chair Running During Power Outages
If you rely on a lift chair, power outages can pose serious safety risks. The right battery backup keeps your chair running so you can stay mobile and independent.
Learn why backup power is so crucial for lift chairs and how to find the right fit for your situation.
Why Lift Chairs Need Backup Power During Outages
Lift chairs are an essential mobility tool. When the electricity goes out, a chair stuck in a reclined position can make it nearly impossible to stand safely without help. In the worst-case scenario, this could increase your risk of a fall.
Lift chairs are a necessity, and that’s why they need reliable backup power.
Solutions like the EcoFlow DELTA series ensure your chair functions when you need it most. It also gives your family more peace of mind during an outage.
An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
What to Look for in a Battery Backup for Lift Chairs
You need your lift chair to get around. It’s essential to your independence, which is why you need a reliable backup battery.
Still, not all battery backups follow the same quality standards.
Look for these features to find a reliable battery that keeps you mobile when it matters most:
Reliable Power for Low-Wattage Medical Devices
Lift chairs don’t need a lot of power, but they do need a stable output. Look for a battery that can handle low-wattage medical devices without interrupting the power supply.
If you’re planning for outages with medical equipment, it’s also smart to think beyond just your chair. Many people pair backup power with other essentials, like CPAP machines.
Indoor-Safe, Emission-Free Operation
Gas generators are a hard no for indoor use. For lift chairs, you need something that’s:
  • Safe to run inside your home
  • Emission-free
  • Quiet and non-disruptive
Simple, Plug-and-Play Setup
The last thing you want to do is manage a complex setup or wiring during an outage. The best portable power stations should be as simple as plugging the chair into the backup power source.
Runtime That Covers Short and Extended Outages
Some outages only last a few minutes, but others can last hours or days. Look for a battery backup that can handle lengthy outages. This way, you only need to buy a backup once and keep it on hand for any outage, short or long.
Types of Backup Power Options for Lift Chairs
There are several ways to power your lift chair when the grid goes down, although some are less convenient than others.
Built-In Battery Packs (Limited Backup)
Most lift chairs come with a small, built-in battery pack. They’re fine in an emergency, but they’re limited. They usually use small 9V battery packs and can only provide a few lift cycles.
UPS Systems (Short-Term Support Only)
Uninterruptible Power Supplies (UPS) are a great option for keeping your computer on during an outage, but you can also use them for a lift chair in a pinch. They can work for brief outages, but their runtime is usually limited to up to an hour.
Portable Power Stations (Best Overall Solution)
You have no way of knowing how long a power outage will last. Portable power stations can run for hours or days, so you can safely navigate your home even when the power goes out.
They act like a large, rechargeable battery that keeps your chair running without the limitations of a smaller system. Plus, they’re safe for indoor use and can power multiple devices at once.
Why Portable Power Stations Are Ideal for Lift Chairs
When it comes to safety and reliability, portable power stations check every box. They’re the best way to stay empowered during a blackout.
They provide consistent power output, so your chair operates smoothly every time. They also have enough capacity to handle repeated use, which is especially important if you rely on your chair throughout the day.
And during longer outages, they keep more than just your chair running. You can charge phones and run lights without worrying about running out of power.
Use the EcoFlow DELTA 3 Classic for Reliable Everyday Backup
You don’t need to spend weeks agonizing over which portable battery will work with your chair. The EcoFlow DELTA 3 Classic is a great fit that provides dependable, everyday backup power for lift chair users.
It’s compact and still powerful enough to run your chair through an outage. You can store it near your chair, plug your chair directly into it, and know it’s ready when you need it.
Use the EcoFlow DELTA Pro 3 for Extended Backup and Whole-Home Flexibility
If you want longer runtime or plan to power additional devices like lights or a CPAP machine, the EcoFlow DELTA 2 Max offers increased capacity and flexibility without adding complexity.
For extended outages or broader home use, the EcoFlow DELTA Pro 3 + 400W Solar Panel provides higher capacity and the ability to recharge during longer disruptions, helping you stay powered even when outages last for days.
An EcoFlow DELTA 2 Max Portable Power Station
How to Set Up a Battery Backup for a Lift Chair
You don’t need to call an electrician to set up a backup for your lift chair. It really is as easy as plug-and-play.
  • Keep your unit close to your chair so you can access it easily. This is crucial during an outage, when you may have trouble seeing in the dark to plug everything in.
  • Plug your lift chair into the AC outlet on the power station. That’s it: no special adapters are needed in most cases.
  • Portable power stations can be a lifesaver, but you do need to charge them. Make it a habit to keep your power station charged, especially when the forecast calls for storms.
Safety Tips When Using Backup Power for Mobility Devices
Opting for a battery backup is pretty safe, but these habits will make your setup more reliable:
  1. Test before you need it: Don’t wait for a power outage to test your battery backup. Plug your lift chair into the backup system and run it through a full cycle while the power is still on. This helps you confirm everything works properly before an emergency.
  2. Organize cords: Loose or tangled cords are a tripping hazard. Tuck cables away neatly along walls or behind furniture and avoid running them across walkways.
  3. Don’t overload the system: You can plug a few devices into a portable battery, but you can’t power everything with it. Check the unit’s capacity and make sure the devices you power with it are within its limits.
How Long Can a Battery Backup Run a Lift Chair?
It depends on how often you use the chair and your battery capacity. Smaller backups might only support a few cycles, while larger batteries can run your lift for hours or days. It’s usually better to go with a higher-capacity unit to give you more flexibility, especially if your area is prone to extended outages.
Can You Use a Portable Power Station Indoors With a Lift Chair?
Absolutely. Portable power stations are battery-powered and don’t use gas. They’re fumeless and silent. Just follow the basic safety guidelines you use with your other electronics, like keeping the unit dry and well-ventilated.
Do Lift Chairs Come With Built-in Battery Backups?
Some do, but they’re pretty limited. They’re for short-term emergencies and only support a few cycles. They can help in a pinch, but they’re not a dependable solution for longer outages or repeated daily use.
What Size Battery Backup Do You Need for a Lift Chair?
Most lift chairs are low-wattage, so portable power stations can usually power them without any problems. A mid-sized unit works well for basic backup, but if you want longer runtime or plan to power additional devices, a larger-capacity system is a better choice.
Reliable Backup Power Helps Lift Chair Users Stay Safe and Independent
A lift chair supports your independence, but a blackout can take that away. You never want to be left stuck when the power goes out, so plan for a backup solution just in case. Whether it’s a brief outage or something longer, the best battery backup for lift chairs can help keep you safe.
Explore EcoFlow's whole-home backup power solutions to find a reliable system that keeps your lift chair and essential devices running when it matters most.
Power Outages
