5500 Watt Generator: What It Runs, and Who It's Actually For
A 5,500-watt generator is versatile enough to cover home essentials, an RV, a construction site, or an off-grid setup, but which of those it is actually good for depends on what you are trying to run. This guide covers exactly what a generator this size can power, the different ways people actually use one, whether it is enough for home backup specifically, the starting-watts math behind its limits, what it cannot handle, and whether it is the right size or you should go bigger.
What a 5,500-Watt Generator Can Run
At this size, a generator has enough range to cover a genuinely different mix of loads depending on who is using it and for what. Here is what typically fits.
  • Household basics: a refrigerator (200W running, 1,200W starting), air conditioner (1,500W running, 2,200W starting), microwave (1,000W), and washing machine (500W) fit comfortably together.
  • Tools: a circular saw (1,200W), power drill (600W), air compressor (1,400W), and table saw (1,600W running, 2,400W starting) can run for job-site use.
  • Medical equipment: low-draw home devices such as a CPAP machine fit easily within this capacity. Anyone who relies on life-sustaining equipment, such as a ventilator, should follow the backup plan set by the device maker and their care provider rather than depend on a general-purpose generator or battery.
Planning backup power around medical equipment specifically deserves its own checklist, covered in a medical equipment power outage plan worth building before you actually need it.
According to FEMA's Ready.gov, anyone who depends on an electric medical device should talk with their doctor ahead of time about a specific plan for powering that equipment and refrigerating medication during an outage, rather than assuming a generator alone covers it.
That range of appliances hints at something worth calling out directly: this size serves several genuinely different use cases.
Four Ways People Actually Use a 5,500-Watt Generator
generator 5500 watt can handlegenerator 5500 watt can handle
The same 5,500-watt rating gets used for very different purposes depending on the household or job. Here is how that plays out in practice.
  • Home backup: comfortably powers essential household appliances and tools together, though large appliances running simultaneously can push it close to its limit.
  • RV and camping: sufficient for popup campers and Class A/B RVs running AC, a refrigerator, microwave, TV, and laptop at the same time.
  • Construction sites: handles multiple mid-range power tools alongside work lights simultaneously.
  • Off-grid living: viable as part of an off-grid setup when paired with solar panels and careful load management.
For the RV and camping use case specifically, sizing a generator for different camper and RV classes goes into more depth than a single wattage number can.
Of those four uses, home backup is where most buyers researching this size actually land, and it is worth a closer look.
Is 5,500 Watts Enough for Home Backup?
Home backup is the tightest fit of the four use cases above, and it is worth understanding exactly where the ceiling sits before you count on this size.
  • The baseline combination: running a refrigerator alongside a medium air conditioner typically requires a minimum of 4,000 to 5,500 watts, putting this size right at the edge for that pairing alone.
  • Room shrinks fast: once you add a microwave, washing machine, or additional tools to that baseline, available headroom for anything else gets tight.
For households that want more headroom without juggling which appliances can run together, it is worth comparing against the tier just above this one, which covers noticeably less on paper but frames the tradeoff clearly.
A home battery is another way to get that headroom. The EcoFlow TITAN Plus delivers 7.2kW from the battery, above a 5,500-watt generator's rating, for up to 10 selected circuits through Smart Home Panel 10, installed by a qualified electrician. How long it runs depends on stored energy: the 5kWh base expands to 30kWh, and solar can recharge it.
EcoFlow TITAN 5000 Plus
The standard EcoFlow TITAN gives the same 7.2kW of 120V/240V output with a smaller solar side. It has one 4kW solar input, and it does not have the EcoFlow TITAN Plus's boost to 10kW when solar is producing, which suits homes planning little solar.
EcoFlow TITAN 5000
The EcoFlow TITAN Classic sits below a 5,500-watt generator at 4kW and covers 120V essentials only, such as a refrigerator, lights, and a Wi-Fi router. It is the entry model for households that don't need 240V appliances running during an outage.
EcoFlow TITAN 5000 Classic
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
That right at the edge feeling comes down to a specific wattage detail worth understanding.
The Starting Watts Math Behind This Size
A 5,500-watt generator's real limit is not the number on the label. It is how that number interacts with the surge every appliance draws the instant it switches on.
  • Running watts: what an appliance draws once it is already on and operating normally.
  • Starting watts: the brief surge many appliances need just to switch on. A refrigerator alone can spike to 1,200W starting from just 200W running.
  • The correct formula: add up the running watts of everything you want on at once, then add only the single highest starting-watt appliance in that group.
This calculation is the difference between a safe combination and an overloaded one at any generator size, covered step by step here for anyone sizing their own appliance list.
Running that math consistently shows up as the same handful of limitations at this size.
What It Cannot Handle
5,500W generator cannot handle5,500W generator cannot handle
A few loads consistently exceed what a 5,500-watt generator has left over once the basics are already running. These are the ones to plan around rather than assume you can add.
  • Central air conditioning: a full central AC system draws far more than a 5,500-watt generator's capacity, unlike the smaller window or RV AC units it is built for.
  • Electric dryers and large water heaters: these high-draw appliances typically exceed what is left over after covering refrigeration and one AC unit.
RV-specific AC sizing has its own separate math worth checking before assuming this size covers it, laid out in a generator sizing guide for RV air conditioners.
With the limits clear, the last question is simply whether this size is the right fit or whether it is worth sizing up.
Is 5,500 Watts the Right Size, or Should You Go Bigger?
Deciding whether to stay at this size or size up comes down to what you actually need running at the same time, not what the generator is theoretically capable of.
  • Good fit for: essential home backup, RV and camping trips, job sites, and off-grid setups paired with solar.
  • Worth sizing up for: homes wanting central AC, an electric dryer, or more simultaneous headroom than this size comfortably provides.
For a sense of what a smaller size covers by comparison, what a 2,000-watt generator can realistically run shows how much capacity drops off below this size.
A 5,500-watt generator is genuinely versatile, covering home essentials, RV and camping trips, job sites, and off-grid setups. But home backup specifically sits close to its practical limit once a refrigerator and AC unit are both running. Calculate your own running-plus-highest-starting-watt total for your specific use case, and consider an EcoFlow TITAN, EcoFlow TITAN Plus, or EcoFlow TITAN Classic if central AC or an electric dryer needs to run alongside everything else.
What will a 5,500-watt generator run?
It can comfortably run a refrigerator, window or RV air conditioner, microwave, and washing machine together, or a mix of mid-range power tools on a job site. It can also support a medical ventilator, though total demand still needs to be calculated against your specific equipment.
Is a 5,500-watt generator good for home backup?
It works well for essential circuits, but it sits close to its limit once a refrigerator and a medium air conditioner are both running, since that pairing alone typically needs 4,000 to 5,500 watts. Adding a microwave or washing machine on top leaves little headroom.
Can a 5,500-watt generator run an RV air conditioner?
Generally yes, alongside a refrigerator, microwave, TV, and laptop in a popup camper or Class A or B RV. Larger RV AC units or multiple units running together may need more capacity, so it is worth checking your specific RV's AC rating first.
Can a 5,500-watt generator power a medical ventilator?
Yes, a 5,500-watt generator can support a medical ventilator unit. Households that depend on one should still build a specific backup plan with their doctor in advance, since running other appliances alongside medical equipment reduces the available headroom.
Should I get a bigger generator than 5,500 watts?
If you need central air conditioning, an electric dryer, or more simultaneous headroom than essentials plus one comfort appliance, yes. Otherwise, 5,500 watts covers essential home backup, RV and camping use, job sites, and off-grid setups reasonably well.
Home Solutions
