Generac Generator Cost: What You'll Actually Pay in 2026
A Generac home standby generator typically costs $8,000 to $16,000 fully installed, depending on size, fuel type, and site conditions. The unit itself is often less than half of that total. This guide breaks down cost by generator size, what installation actually adds on top of the unit price, and ongoing fuel and maintenance costs. It also covers the factors that drive the price up or down, and a battery-based backup option worth comparing before you commit to a fuel-based standby system.
Generac Generators Cost by Size
Unit prices for Generac Guardian air-cooled models give a clear starting point. They don't include the transfer switch, pad, labor, or fuel connection.
Current MSRP figures for popular residential sizes land in these ranges:
Size
Approximate MSRP
Best fit
14kW Guardian
~$5,139
Smaller homes or essential-circuit backup
18kW Guardian
~$6,229
A common mid-size residential pick
22kW Guardian
~$6,979
Larger homes or more circuits
26kW and up
~$7,899 and climbing
Larger liquid-cooled units can exceed $15,000 for the unit alone
These figures are equipment prices, not complete installation costs. The generator size you need depends on the electrical load you want to support, including large starting loads from equipment such as air conditioners, well pumps, and refrigerators. A detailed look at home generator size can help put the equipment price into the context of your home's actual power needs.
The unit price is just the starting point. Installation is where the real cost usually shows up.
The Real Installed Cost, Not Just the Unit Price
The generator sticker price represents only a portion of the total project. Complete, turnkey installation by licensed trades typically places the all-in investment between $8,000 and $16,000 for standard residential projects.
Generator installationGenerator installation
Installation expenses combine several distinct site preparation, electrical, and plumbing elements.
Project component
Estimated cost range
Concrete pad
$300 to $800
Automatic transfer switch
$800 to $2,200
Electrical labor
$1,500 to $3,500
Gas line plumbing
$500 to $2,000
Permits and inspections
$200 to $600
Real-world totals give a sense of what that adds up to. A basic 1,400 sq ft home with nearby gas service and a modest transfer switch often lands near $8,100 all-in. A mid-size 2,400 sq ft home with more circuits and a longer gas run averages around $13,600. Larger 3,800 sq ft homes that need panel work or longer trenching can reach $21,000.
Distance to the gas meter and whether the electrical panel needs upgrading are the two variables that most often surprise homeowners. Extra trenching, wiring, or panel work can add thousands to the bill, and standby generator installation costs can vary significantly from one home to the next.
Before locking in a fuel-based standby generator, it's worth knowing what a battery-based alternative actually looks like.
A Lower-Cost Way to Think About Backup Power
A battery-based home backup system approaches the cost breakdown above differently. Depending on your home's setup, it can reduce or remove several of those line items rather than eliminating all of them automatically.
There's typically no gas line to trench and connect, and no combustion equipment involved, which can mean less permitting than a fuel-based system requires. Whether a concrete pad or other site prep is needed still depends on the specific installation and local code, so it's worth confirming with an installer rather than assuming it's never required. A battery system also recharges from grid or solar power instead of burning fuel, which removes the per-hour fuel cost that comes with a generator running on natural gas or propane. Actual savings and installation requirements vary by home, so it's worth getting a specific quote rather than assuming a battery system is automatically cheaper across the board. A side-by-side look at home battery versus propane shows how those differences tend to play out in real ownership costs.
If a generator's all-in price is the sticking point, EcoFlow TITAN Plus is worth comparing. It delivers 7.2kW from the battery alone, rising to up to 10kW only when compatible solar panels are producing, and its 5kWh base capacity expands up to 30kWh with additional TITAN batteries (sold separately). Circuit backup requires Smart Home Panel 10, installed by a qualified electrician.
EcoFlow TITAN 5000 Plus
For homes with more moderate power needs, the standard EcoFlow TITAN offers a streamlined alternative. It delivers reliable 7.2kW split-phase backup output and supports up to 4kW of solar input, making it ideal for essential-circuit coverage without paying for excess capacity.
EcoFlow TITAN 5000
Whichever path a homeowner chooses, it helps to know what a standby home generator costs to actually run and maintain year after year.
Ongoing Costs — Fuel and Maintenance
Owning a standby generator means ongoing operating expenses, regardless of how often power outages actually happen. Routine mechanical maintenance is still necessary to keep the engine ready to start when severe weather hits.
Maintenance costMaintenance cost
Annual service contracts generally run between $200 and $500 per year, covering synthetic oil changes, spark plug replacements, fluid checks, and automated exercise cycles.
Operating costs accumulate steadily while the unit runs:
  • A 14kW generator at 50% load consumes roughly 1.8 to 2.2 therms/hr (~$2.65 to $2.75/hr under typical residential utility pricing of ~$1.30/therm).
  • A 22kW generator at 100% load consumes up to 3.2 to 3.5 therms/hr (~.56/hr during demanding whole-home operation based on average gas rates).
  • Connecting to an existing natural gas supply costs $500 to $1,500. Installing a dedicated above-ground or buried propane tank costs $1,500 to $3,500.
Over years of ownership, these expenses add up alongside the initial purchase and installation price. Routine servicing, oil and filter changes, inspections, and other upkeep all contribute to the cost of maintaining a home generator, particularly over a long service life. According to the U.S. Energy Information Administration, residential natural gas prices shift with seasonal demand, which changes the real cost of running a generator during a prolonged winter outage.
With the full cost picture in view, a few specific factors explain most of the variation homeowners actually see.
What Actually Drives the Price Up or Down
The generator's sticker price is only part of what homeowners pay. Home size, electrical demand, fuel connections, optional features, and the type of backup system can all shift the final installation cost considerably.
  • Home size and load. The more circuits and appliances you want to keep running, the more generator capacity you need. Larger systems typically cost more, but covering only essential circuits can reduce both equipment and installation costs.
  • Fuel type and gas line distance. Natural gas is convenient if you already have a meter nearby. If your generator sits farther away, you may need additional piping and trenching, which adds labor and can add hundreds or thousands to the bill.
  • Smart features. Wi-Fi monitoring and remote controls can make it easier to check generator status and receive alerts, but they also add to the equipment price. Whether they're worth it depends on how much remote monitoring you actually want.
  • Portable or standby. A portable unit costs less upfront. A standby system costs more but delivers automatic backup once it's installed. The cost differences between portable and standby systems can be significant depending on how much backup power you actually need.
With all the numbers on the table, the last question is simply whether the investment makes sense for a given home.
Is a Generac Generator Worth the Cost?
Whether a Generac standby generator makes sense depends on how often the power fails, what you need to keep running, and how you feel about ongoing fuel and service costs. The numbers above give the price range. The value question is more personal.
Generac units typically carry 3 to 10 years of warranty coverage and can run effectively for 10 to 30 years with proper maintenance. That long service life spreads the initial investment over decades for owners who stay on top of oil changes and annual checks.
Many households don't need full whole-home coverage. A smaller, less expensive unit that keeps essential circuits alive is often enough. Lights, the refrigerator, the furnace blower, and a few outlets cover the basics for a lot of families, and that keeps both the equipment and installation bills lower.
Homeowners still weighing fuel-based versus battery-based options can see the tradeoffs more clearly once the full standby generator installation cost sits next to the battery alternative.
A Generac standby generator typically costs $8,000 to $16,000 fully installed. Installation, fuel type, and site conditions often add as much to the bill as the unit itself. Get quotes based on your actual home size and circuit needs rather than the sticker price alone, and factor in gas line distance and permitting before you commit. EcoFlow TITAN and TITAN Plus offer expandable capacity and 120V/240V support as a battery-based alternative worth comparing against a generator's total cost.
How much does a Generac generator cost including installation?
Most homes land between $8,000 and $16,000 fully installed, depending on unit size, gas line distance, and whether the electrical panel needs upgrading before the transfer switch goes in. An accurate quote requires seeing the site first.
What size Generac generator do I need for my home?
A 14kW unit often covers essentials in a modest home. Many average homes land at 18 to 22kW for broader coverage. Add up the wattage of the circuits or appliances you want to keep running rather than relying on square footage alone.
How much does it cost to run a Generac generator on natural gas?
At early 2026 residential rates, a 14kW unit at half load costs roughly $2.65 to $2.75 per hour. A 22kW unit at full load runs closer to $4.40 to $4.60 per hour. Actual cost scales with local rates and real load.
Is a battery backup system cheaper than a Generac generator?
It depends on your home's setup and power needs. A battery system can avoid fuel line plumbing, dedicated concrete pads, and combustion-related permits, while recharging from existing grid or solar power rather than burning gas. However, overall savings vary based on equipment capacity and whether panels or electrical upgrades are needed, so comparing site-specific quotes is essential.
How long does a Generac generator last?
With recommended maintenance, most units deliver 10 to 30 years of service. Warranty coverage is typically 3 to 10 years depending on the model and registration. Proper annual care is the biggest factor in reaching the upper end of that range.
Home Solutions
