10kW Generator: What It Actually Runs, and Which Type to Buy
A 10kW generator provides enough power for a standard home, but it cannot run every high-demand appliance at the same time. And 10kW itself comes in portable gasoline, diesel, and inverter versions that behave very differently in daily use. This guide covers exactly what a 10kW generator can run, the practical differences between the generator types sold at this size, what it cannot handle simultaneously, whether it fits your specific home, and how to calculate your own load.
What a 10kW Generator Can Run
A generator this size covers most of a home's major systems comfortably, though it still has a ceiling worth knowing before you assume everything can run together.
  • Major appliances: central AC (3 to 4 ton, 3,500 to 5,000W running), an electric water heater (3,000 to 4,500W), and a well pump (1,000 to 1,500W running) can each run comfortably within a 10kW budget.
  • Everyday loads: a refrigerator (600 to 800W running) and microwave (600 to 1,200W) add relatively little on top of a major appliance like central AC.
  • Together, not everything: running central AC, a water heater, refrigerator, and washing machine at the same time can push total demand to roughly 11,900 to 12,200W, over a 10kW generator's limit.
A well pump is one of the more variable loads in this mix, worth checking specifically through how many watts a well pump actually draws before you count on it fitting alongside everything else.
Before deciding if that capacity fits your home, it helps to know that 10kW generator does not mean just one kind of machine.
Portable, Diesel, or Inverter: Which Kind of 10kW Generator?
Portable, Diesel, or Inverter generatorPortable, Diesel, or Inverter generator
The 10kW rating tells you the power output, not what kind of machine you are actually buying. The type behind that number changes runtime, noise, and daily usability quite a bit.
  • Portable gasoline models: typically run 8 to 12 hours at 50% load per tank, the most common option for home backup.
  • Diesel generators: offer longer runtime, typically 10 to 24 hours at 50% load, often at a higher upfront cost.
  • Inverter generators: run noticeably quieter, around 50 to 60 decibels versus 60 to 75 for conventional models, and produce cleaner power better suited to sensitive electronics.
Type
Typical runtime at 50% load
Noise level
Portable gasoline
8 to 12 hours per tank
60 to 75 dB
Diesel
10 to 24 hours per tank
60 to 75 dB
Inverter
Varies by model
50 to 60 dB
That noise gap is bigger than it sounds. The Occupational Safety and Health Administration notes that every 5 decibel increase in sound level cuts the safe daily exposure time roughly in half, which is one reason a generator running for hours at the louder end of that range is noticeably harder to be near than one at the quieter end.
Noise level alone changes the day-to-day experience of running a generator for hours, a comparison worth reading in more detail if that is a deciding factor for you.
Whichever type you are weighing, it is worth knowing what the alternative looks like before committing to fuel logistics at all.
Keeping Essentials Running Without the Fuel Logistics
Every version of a fuel-based generator shares the same underlying tradeoff, regardless of which type you pick. It is worth weighing that against what a battery-based system offers instead.
  • Every fuel-based option shares the same tradeoff: gasoline, diesel, and inverter generators alike all require fuel storage, ventilation, and manual refueling during extended outages.
  • Backup power priorities: refrigeration, well pumps, medical devices, and communication equipment top the list regardless of which backup path a household chooses.
According to the Consumer Product Safety Commission, any fuel-based generator, gasoline, diesel, or inverter alike, needs to run outdoors only, at least 20 feet from the home, since opening doors or windows does not provide enough ventilation to prevent a dangerous carbon monoxide buildup indoors.
A side-by-side look at how battery backup compares to a fuel-based generator is worth reading before committing to either path.
A battery-based system removes the fuel storage and refueling from that list. The EcoFlow TITAN Plus delivers 7.2kW from the battery, rising to up to 10kW only when compatible solar is connected and producing. It recharges from up to 8kW of solar instead of a fuel can, and its 5kWh base expands to 30kWh for longer outages. It is rated for indoor installation.
EcoFlow TITAN 5000 Plus
The standard EcoFlow TITAN is the choice when 7.2kW covers your selected circuits and solar plans are modest. It shares the 120V/240V output and expandable 5kWh base, with one 4kW solar input and no solar-boosted 10kW output.
EcoFlow TITAN 5000
Fuel type aside, the real question for most households is whether 10kW is actually enough capacity for their home.
Is 10kW Enough for Your Home Size?
10 kilowatt generator load capacity10 kilowatt generator load capacity
Home size plays a bigger role in this decision than most people expect going in, often more than the specific appliance list itself.
  • A solid fit for a standard home: 10kW is generally described as enough to power a standard-size home, covering major systems without running everything simultaneously.
  • Undersized for larger homes: homes larger than about 3,000 square feet typically need 15 to 20kW to run all appliances at the same time.
For a closer look at sizing against a specific home footprint, the math for a 2,000 square foot house walks through a common size in detail.
Even within the right home size, certain appliance combinations still push past what 10kW can handle.
What 10kW Cannot Run Together
Total wattage is not the only thing that trips people up. A handful of power tools alone can quietly exceed a 10kW budget faster than a full house of appliances does.
  • A working combination: central AC (7,000W surge) plus refrigerator (2,000W surge) plus lights, TV, and microwave (1,300W) stays manageable within a 10kW budget.
  • An overloaded combination: a table saw (5,000W surge) plus 3HP air compressor (6,000W surge) plus circular saw (4,200W surge) adds up to roughly 15,200W in surge demand, well past 10kW.
Power quality also matters for sensitive equipment sharing the load, a distinction worth understanding before mixing electronics with heavier tools covers in more depth.
Every one of these examples comes down to the same underlying math, worth running for your own home specifically.
How to Calculate Your Own Load
The same three-step process applies whether you are sizing a 7,500-watt unit or a 10kW one, and it takes only your appliances' listed wattage to run.
  • Step 1: add up the running watts of every appliance you want powered at the same time.
  • Step 2: identify the single highest starting-watt appliance in that group.
  • Step 3: add that highest starting wattage to your running total to get your real required capacity.
This is the same calculation that separates a safe load from an overloaded one at any generator size, covered step by step here for anyone sizing their own appliance list.
A 10kW generator covers a standard home's major systems, but running high-demand appliances like central AC, a water heater, and laundry together can exceed its capacity. The choice between portable, diesel, and inverter versions also changes runtime, noise, and cost. Calculate your own running-plus-highest-starting-watt total, check your home's square footage against 10kW's typical range, and compare an EcoFlow TITAN or TITAN Plus before committing to a fuel-based system.
What can a 10kW generator run?
It can comfortably run central AC, an electric water heater, or a well pump individually alongside everyday loads like a refrigerator and microwave. Running several major appliances together, such as central AC, a water heater, and a washing machine at once, can push past its 10kW capacity.
Is a 10kW generator enough to run a whole house?
For a standard-size home, generally yes, as long as you are not running every major system simultaneously. Homes larger than about 3,000 square feet typically need 15 to 20kW to cover everything at once.
What is the difference between a portable and a standby 10kW generator?
A portable 10kW generator is gasoline-powered or diesel-powered, needs manual setup and refueling, and typically runs 8 to 24 hours per tank depending on fuel type. A standby unit is permanently installed and starts automatically, usually running on natural gas or propane instead of a portable fuel tank.
What size home needs more than a 10kW generator?
Homes larger than roughly 3,000 square feet, or homes that need central AC, a water heater, and other major appliances running together at all times, typically need 15 to 20kW of capacity instead.
Is a diesel or gasoline 10kW generator better for home backup?
Diesel generally offers longer runtime per tank and can be more fuel efficient over a multi-day outage, though it often costs more upfront. Gasoline units are more common and easier to refuel locally. Either way, an EcoFlow TITAN or TITAN Plus is worth comparing if avoiding fuel logistics altogether matters to you.
Home Solutions
