Split-Phase Inverters Explained: Understanding 120V/240V Output and Top Options
What is a split phase inverter? It's the piece of hardware that decides whether a battery system can run your whole breaker panel, or just a handful of outlets. If you've shopped for backup power, you've probably hit that term and wondered what it means. This guide walks through how 120V/240V split-phase output works. It covers where that shows up in EcoFlow's TITAN lineup, how it compares to a standalone DIY inverter, and how to size one for your home.
Mechanics of Dual-Leg 120V/240V Utility Distribution
What Split Phase Actually Means
A split phase inverter puts out two separate 120-volt AC legs running 180 degrees out of phase with each other. Each leg powers your regular wall outlets on its own; combined, they add up to 240 volts for heavier equipment. That two-leg setup isn't a niche design choice: it's how the power company already wires your house. The USDA's Rural Utilities Service lists 120/240V, three-wire, single-phase service as the standard setup for residential customers nationwide. An inverter that skips split-phase design can't feed a home's full breaker panel, only the 120V side.
Split PhaseSplit Phase
Split-Phase vs. Single-Phase-Only
A single-phase-only inverter puts out one 120V leg and stops there. That's plenty for smaller electronics, a travel trailer, or a handful of lights, but it can't run anything that needs 240V — a list that includes the appliances homeowners lean on most: central air conditioners, water pumps, electric dryers.
Type
Single-Phase-Only Inverter
Output
120V and 240V from one unit
120V only
Runs 240V appliances
Yes
No
Best fit
A full home breaker panel
RVs, smaller 120V-only setups
Why 240V Loads Demand Two Legs
Motors are usually the reason a home needs 240V at all. A well pump or central AC compressor pulls far more current at startup than a standard 120V circuit can handle, and using two 120V legs together, instead of one leg carrying the whole load, lets an inverter supply that circuit safely. Your breaker panel already reflects this design: two hot bus bars run down the middle, a 240V breaker taps both at once, and a regular 120V breaker taps only one. A split-phase inverter mirrors that structure instead of faking it with a single leg stretched thin.
For the wiring side of this inside a battery system, How EcoFlow systems support 120V/240V split-phase power goes deeper. Next, here's where split-phase capability shows up in EcoFlow's current lineup.
EcoFlow's TITAN Lineup: Matching a Tier to Your Split-Phase Needs
Not every household needs the same amount of split-phase coverage, and EcoFlow's TITAN series is divided along that line. The EcoFlow TITAN and EcoFlow TITAN Plus both deliver 120V/240V split-phase output. The EcoFlow TITAN Classic sticks to essential 120V loads, which makes it the lowest-priced model for households that don't need to run 240V equipment during an outage.
EcoFlow TITAN 5000 Classic
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Once a 240V load enters the picture, the EcoFlow TITAN is the starting point. It supplies 7.2kW across both 120V legs, so a 240V breaker and ordinary 120V circuits can be backed up together, within the circuits you select.
EcoFlow TITAN 5000
The EcoFlow TITAN Plus has the same 7.2kW split-phase battery output and adds on the solar side. Its 8kW input across two channels is double the EcoFlow TITAN's, and output rises to up to 10kW only when compatible solar is connected and producing.
EcoFlow TITAN 5000 Plus
Picking between the three tiers comes down to two questions. Which circuits do you need covered? And how much solar do you plan to connect? A household focusing purely on essential 120V circuits doesn't need much headroom, and the EcoFlow TITAN Classic fits that case. A house with 240V equipment such as central air or a well pump needs a split-phase setup: the EcoFlow TITAN and EcoFlow TITAN Plus supply 7.2kW of 120V/240V output to up to 10 selected circuits through Smart Home Panel 10. What runs at the same time depends on those circuits and each appliance's starting requirements. The EcoFlow TITAN Plus adds the larger solar input, at 8kW. All three expand from 5kWh to 30kWh.
These are complete, pre-built systems. It's worth seeing how that compares to the standalone all-in-one inverter chargers a lot of DIY solar builders shop for instead.
Factory-Integrated Power Ecosystems Versus Modular DIY Inverters
Split Phase Inverter vs. Standalone solar chargersSplit Phase Inverter vs. Standalone solar chargers
Something like the LiTime 48v 5kw split phase all-in-one solar inverter charger is a completely different animal. It's a standalone inverter and charger, not a full system. You're on the hook for sourcing a separate battery bank. You wire it all together yourself, and pair solar panels on your own too.
Going the DIY route can save money on the inverter itself, no question. But that savings comes with a catch. You take on the job of matching components, staying inside electrical code, and running wiring correctly. A pre-built TITAN system asks none of that of you.
Voltage matching is one of those hidden headaches with any 48V split phase inverter you buy standalone. Its DC input needs to be matched carefully to whatever battery bank you buy separately. Get that wrong, and the system either underperforms or won't run at all. An all-in-one unit skips that step entirely, since the battery and inverter already come matched from the factory.
Standalone Inverter/Charger
Pre-Built System
Battery
Sourced and matched separately
Already integrated
Wiring and code compliance
Falls on the installer
Handled as one unit
Voltage matching
Required against the battery bank
Not needed
Usually split across components
One warranty for the whole system
That warranty line matters more than people expect. If something goes wrong on a standalone setup, you're often dealing with separate manufacturers for the inverter, the battery, and whatever else you sourced yourself. A pre-built system keeps that under one roof.
Working through the fuller category breakdown between standalone and all-in-one systems is worth doing before you commit either way. That's especially true if this is your first time buying an inverter, not replacing one. Whichever route you go, sizing the inverter correctly is what actually determines whether it works for your home.
Calculating Accurate Load Specifications for High-Voltage Appliances
Do the Math on Your 240V Loads
Start by totaling the running watts of everything you'd want powered at the same time, then check the single largest startup surge among your 240V appliances. That combination determines whether an inverter fits your home: the inverter's continuous output must handle the combined running load, while its surge capacity absorbs that brief, intense startup spike.
Size to the Continuous Rating, Not the Box Number
A unit can look great on paper for 120V loads and still come up short on a single demanding 240V appliance, which is why the 240V-specific continuous rating matters more than the total wattage printed on the box. Surge rating and continuous rating aren't the same thing, and mixing them up is an easy way to undersize a system: surge covers a spike of a second or two, while continuous is what the inverter sustains for as long as the appliance keeps running.
Size to the continuous number for anything running more than a few seconds, and build in headroom above your bare minimum—a system sized exactly to today's needs turns undersized fast the moment you add a new appliance to that circuit. For a full walkthrough, our generator sizing guide steps through math for your own home.
A split phase inverter lets a battery system run both your 120V outlets and 240V appliances, matching how most American homes are wired. EcoFlow's TITAN Classic, TITAN, and TITAN Plus cover that need at different capacity tiers, all as complete, pre-built systems rather than parts you assemble yourself. Nail down your 240V load requirements first. Then size to your highest startup spike, and the right tier in EcoFlow's TITAN lineup should be an easy call.
What defines a split-phase inverter in modern home electrical design?
A split-phase inverter produces two 120V AC legs, 180 degrees out of phase with each other. They combine to deliver 240V for larger appliances, while still powering standard 120V outlets on their own.
How do split-phase units structurally differ from basic single-phase hardware?
A single-phase-only inverter outputs just one 120V leg, which is fine for smaller electronics and RVs. A split-phase unit adds a second 120V leg, so the two can combine into 240V for equipment like a well pump or electric dryer.
Can an integrated split-phase inverter successfully support an entire residential property?
It depends on the model you choose. The EcoFlow TITAN Classic is built strictly for essential 120V circuits and cannot support 240V appliances. The EcoFlow TITAN and EcoFlow TITAN Plus deliver 120V/240V split-phase output and, with Smart Home Panel 10 installed by a qualified electrician, back up to 10 selected circuits rather than an entire panel. The EcoFlow TITAN Plus adds an 8kW solar input and up to 10kW of output only when compatible solar is connected and producing.
What trade-offs exist between modular DIY inverter chargers and pre-built backup systems?
A standalone inverter like the LiTime 48V unit can cost less up front. But you take on sourcing the battery, wiring everything correctly, and matching voltage yourself. A pre-built system like TITAN handles all of that as one integrated, single-warranty unit.
How do you accurately determine the right split-phase capacity for your home?
Add up the running watts of everything you'd power at once. Then add the single highest startup surge among your 240V appliances. Confirm the inverter's continuous output covers that 240V load specifically, not just its total wattage rating.
Home Solutions
