What Is a Semiconductor? How It Works, Types & Uses
From mobile devices and computers to solar power equipment and energy accumulator systems, semiconductors are the core technology of the modern world. But what is a semiconductor and what exactly makes semiconductors capable of controlling electricity? Thanks to their electrical conductivity properties, which lie between conductors and insulators, semiconductors are applied in the field of power control, signal processing, and energy efficiency improvement, among others.
This article covers the topic of semiconductors from the perspective of how they work, their types, typical applications, and their contribution to modern power systems.
What Is a Semiconductor? Definition & Simple Explanation
A semiconductor is defined as a type of block, which is neither a good electric conductor nor an insulator. In this case, the characteristics of semiconductors make it possible to easily control the ability of semiconductors to conduct electricity, which makes semiconductor technology very important in modern electronic units as well as power systems.
For example, semiconductor technology can be found in every device, from a modern computer processor to solar converters and storage systems.
What Is a Semiconductor Simple Definition?
So the question is, what is a semiconductor definition? In simple terms, a semiconductor is a material that can conduct electricity in certain situations, but this ability of the semiconductor is not similar to conductors. In addition, its electricity conducting abilities can be influenced by many external factors, such as temperature, impurities, visible light, and influenced voltage.
The most important types of semiconductors are silicon. By improving different kinds of silicon and using other materials, engineers receive semiconductor components allowing them to regulate the flow of electricity.
What Exactly Is a Semiconductor?
What is a semiconductor? It is a kind of material that has an electrical conductivity level that falls between conductors, such as copper, and insulators, such as glass or rubber.
While a simple wire can conduct current, chemical engineering allows semiconductor materials to be designed in such a way that they can also be switched, moderated, amplified, or converted, hence enabling them to act as the basic components of transistors, diodes, integrated circuits, sensors, and power control devices.
Semiconductors are used not only in electronics today but also in other technical areas such as solar energy, electric vehicles, inverters, battery systems, and similar energy solutions.
Semiconductor vs. Conductors and Insulators
The most significant difference between the three groups of materials is how well they can carry electric current.
Property
Conductors
Semiconductors
Insulators
Electrical conductivity
Very high
Moderate and controllable
Very low
Current flow
Flows easily
Can be controlled
Strongly restricted
Common examples
Copper, aluminium, silver
Silicon, germanium
Glass, rubber, plastic
Main role
Carry electricity
Control and process electricity
Prevent unwanted current flow
Typical applications
Wires, cables, electrical contacts
Chips, sensors, transistors, power electronics
Insulation, protective coatings
The ability to manipulate conductivity gives semiconductors their unique property compared to regular conductors or insulators, which allows engineers to fabricate more compact and more effective electronics.
Common Semiconductor Materials, Including Silicon
Various materials can be classified as semiconductor materials, but silicon remains the most popular and known material on the market. This is due to the fact that its electrical properties can be accurately regulated.
The list of semiconductor materials also includes germanium, gallium arsenide, gallium nitride (GaN), and silicon carbide (SiC). The choice of certain semiconductor materials depends on the application and requirements such as switching speed, operating temperature, voltage, and efficiency.
Having established the main idea, it is now possible to consider how semiconductors perform the electric control process. Their ability to respond to voltage, light, temperature, or changes in material allows semiconductors to perform their switching and conversion functions.
How Do Semiconductors Work? From Conductivity to Electronic Components
Semiconductors have a significant advantage that goes beyond the fact that they can conduct electricity. Instead, they have gained the ability to control their conductivity.
The introduction of different conditions like changing temperature, putting charge impurities in a semiconductor, and applying the electric field enables engineers to control the movement of electrons through the semiconductor.
How Semiconductor Conductivity Can Be Controlled
The conductivity of a semiconductor is based on the movement of electrons and holes which are considered carriers of electric charge within the substance.
In pure semiconducting materials, the amount of electric charge carriers available under normal conditions is low and thus their conductivity can be increased and controlled through the introduction of a considerable number of certain impurities that are added in a process known as doping.
There are two major categories of semiconductors which are formed when doping is done:
  1. N-type semiconductors: Formed by the addition of some elements that help secure more electrons.
  2. P-type semiconductors: Formed when elements are added to create more positively charged holes.
Once these two types of materials are combined, they form p-n junctions, which are crucial for semiconductor devices. The electrical flow through such materials may additionally be altered by outside factors, such as voltage, light, and temperature.
It is the ability to control the conductivity level of semiconductor materials that distinguishes them from regular materials.
What Happens When a Semiconductor Is Heated?
Semiconductors exhibit an increase in their conductivity upon heating, as the increased thermal energy provides additional energy to electrons for conduction. This is in contrast to metals, as their resistance increases with temperature.
However, the response of any semiconductor will depend on various factors including the material of the semiconductor, purity, structure, and condition of operation. Thus, temperature should be an important factor taken into account in designing electronics and power systems where the components need to operate efficiently in a variable environment.
Moreover, understanding this temperature behaviour helps to explain the possibility of tailoring semiconductors for various electrical functions.
How Transistors, Diodes and Integrated Circuits Work
The semiconductor materials provide the basis for various crucial electronics:
  • Transistors are used to operate like electronic switches/amplifiers controlling current and signals in the circuits
  • Diodes let the current flow in one direction only; they are mainly used for rectification and providing protection and voltage
  • Integrated circuits combine various semiconductor components into a single microchip giving it the ability to perform complex processing and controlling functions.
These devices are the basis for processors, communication devices, old chargers, and power management systems.
The Role of Semiconductors in Sensors and Power Electronics
Semiconductors are vital components of sensors and power electronics as semiconductor sensors help detect various changes in certain parameters (light intensity, temperature variation, pressure change, motion, etc.) and further convert them into electrical signals.
In power electronics, the role of semiconductor devices is to switch, control, rectify and convert electricity. In order to ensure effective switching and electricity conversion, end-users have been increasingly utilizing power semiconductors such as silicon carbide (SiC) and gallium nitride (GaN) over recent years.
Semiconductors find their way to energy systems that people face every day. Semiconductor-based power electronics provide energy management solutions for solar generation, electric vehicle charging, inverters, home energy storage, etc.
Today, it has become essential to control electricity effectively. It means that semiconductor technology finds its place among modern solutions for energy storage, conversion, and delivery.
3. What Is a Semiconductor Used For? Everyday Technology & Energy Systems
Having learned about the way semiconductors act as a supervisor of electrical current, it is now much easier to comprehend the notion of being a semiconductor. Thus, these materials are crucial in today’s electronics and play an enormous role in the functioning of many devices.
This technology is widely used in several fields, starting with everyday consumer devices and finishing with electric automobiles and other systems producing renewable energy.
Semiconductors in Smartphones, Computers and Consumer Electronics
It is impossible to imagine a modern electronic device without semiconductor components. In particular, both smartphones and computers are equipped with integrated circuits that consist of billions of transistors.
  • Smart TVs and gaming consoles for image and video.
  • Cameras and sensors for image capturing and imaging.
  • Smartwatches and wearables for movement monitoring.
  • Home appliances for controlling operations.
  • Chargers and adapters for controlling electricity usage.
With semiconductor components becoming smaller and smaller, manufacturers have been able to produce more powerful and energy efficient devices.
Semiconductors in EVs, Solar Panels and Inverters
Semiconductors play an important role not only for consumer electronics but also when it comes to several cases of electrification and renewable energy sources. They may play an important role in generating, converting electricity, controlling it, and using electricity.
In electric automobiles, semiconductors control battery energy and perform several vital functions. Solar cells are composed of semiconductors to transform sunlight into energy while inverters convert energy and regulate it.
Inverters are important because they allow changing energy from one form to another and regulate voltage, current, and frequency. That is what makes semiconductor technology very important in connecting sources of renewable energy with electrical appliances.
Power Semiconductors for Efficient Energy Conversion
Power semiconductor devices play a critical role in controlling and converting large amounts of electricity. Power MOSFETs, IGBTs, SiC and GaN devices are capable of switching electrical energy from a source into various applications such as EV chargers, photovoltaic inverters and energy-storage devices.
This efficient switching leads to minimal energy losses and heat generation, thus helping in development of compact and efficient power-conversion devices. Moreover, as more households are combining solar energy, battery storage and electric equipment into smart energy management systems, switching becomes especially relevant.
When semiconductor technology evolves from operation of individual appliances to controlling entire systems, its role becomes integrated with the way electricity is used and consumed by households.
Modern methods of energy storage in homes employ sophisticated power electronic devices to regulate electricity flow between batteries, solar energy generation, household loads and the grid, thus paving the way to the next generation of smarter home energy systems.
EcoFlow STREAM 5000: Semiconductors in Modern Home Energy Storage Systems
EcoFlow STREAM 5000
Capacity of battery: 5024Wh (5.024kWh). Life cycle of battery: 10,000 cycles. Max charging power of battery system: 4000W. Max discharging power of battery system: 3000W. Max power for main unit charging/discharging: 2500W. Charging input using AC: 3000W. Using AC, output being 3000W off-grid and 800W/3,000W tied to grid. Power source from sunlight: 5000W (1250W × 4 units). Maximum strength of PV input voltage: 60V. Operating temperature: -20°C to 55°C. Weight of this machine: 45.4kg.
EcoFlow STREAM AC 5000: Power Electronics for Smarter Home Energy
Battery capacity: 5024Wh (5.024kWh) Cycle life: 10000 cycles. Maximum battery system charging power: 3000W. Maximum battery system discharging power: 3000W. Maximum main-unit charging/discharging power: 2500W. AC charging input: 3000W. AC output: Off-grid 3000W and 800W/3000W grid-tied. PV input: Not supported. The AC 5000 version does not feature MPPT or direct PV input. Bypass output: allows devices up to 3000W. Connection: Wi-Fi, Bluetooth and CAN. Protection against ingress: IP65. Operating temperature: -20 degrees to 55 degrees. Battery self-heating: Low-temperature charging activates ≤10 degrees celcius
So, what is a semiconductor? It is a substance that possesses conductivity that is intermediate to that of a conductor and an insulator. However, the true virtue of a semiconductor is its ability to manipulate conductivity as required. For instance, silicon may be processed to form semiconductors such as transistors, diodes, integrated circuits, sensors, and other power semiconductor devices that will effectuate electrical signals and energy.
From smartphones and computers to electric vehicles, solar panels, electric inverters, and energy-storage systems, semiconductors are present everywhere in our digital lives. As energy systems evolve and get more interconnected, the importance of power electronics based on semiconducting materials keeps growing.
Thus, exploring the semiconductor industry is a way to discover a secret behind many accomplishments of modern life.
Why Semiconductor Technology Is Fundamental to Modern Electronics?
The electric properties that are adjustable to build vital components including transistors, diodes, sensors and integrated circuits are provided by semiconductors. These components assist in the processing of information through electronic devices and in controlling electrical signals as well as handling power in an effective manner.
How Semiconductors Support Efficient Energy Management?
With the help of power semiconductors, electricity can easily be switched, regulated and converted. Power conversion can help minimize losses associated with electric energy and achieve efficiency in energy management in systems such as solar inverters, EV chargers and battery systems.
Heating a semiconductor normally results in the generation of more charge carriers, which in turn increases its electrical conductivity. However, the exact behaviour might differ based on the semiconductor and the condition in which it is used.
Why Is Silicon Commonly Used in Semiconductors?
Silicon is used because of its various electrical characteristics, its availability, and ease of fabrication in the electronics industry. Other aspects that make it a desirable material include its ability to be customized for various types of semiconductors.
Are Semiconductors Used in Solar Energy Systems?
Yes, semiconductor technology is essential to solar energy technology. Solar cells require semiconductor materials to turn sunlight into electric energy, while semiconductor-based electronic controllers perform necessary conversions.
In the world of technology, semiconductors play a vital and active role in making sure that electricity is under control for a wide range of applications ranging from compact circuits to energy-saving systems that are effective.
