How Long Does It Take to Climb Snowdon Without Rushing
If you are wondering how long does it take to climb Snowdon, allow roughly 4–7 hours for a return hike, depending on the route, your fitness, weather, walking pace and how long you stop along the way. The mountain is known officially as Yr Wyddfa, although Snowdon remains the name most visitors use.
That estimate is for the whole outing, rather than simply reaching the summit. A route that looks manageable on paper can take longer when the weather turns, the ground gets slippery, or your group needs regular breaks. Your phone may also be working throughout the day for navigation, weather updates, photos and communication, so it is worth thinking about battery power before you set off. If the hike is part of a camping or longer outdoor trip, a portable energy system can also provide a convenient way to recharge several devices at your base.
So, how long does it take to climb Snowdon? There is no single answer for everyone. The route you choose makes a big difference, and so does the person walking it.
How Long Does It Take to Climb Snowdon?
How long does it take to climb mount Snowdon depends mainly on the route, conditions and the pace you can comfortably maintain. Eryri National Park currently lists the six main summit routes as hard or strenuous, with return times of around six hours for most routes and seven hours for the Llanberis Path.
That means the better question is not simply how long does it take to climb Snowdon, but how long you should realistically allow for your own day.
How Long Does a Snowdon Return Hike Take?
If you are asking how long does it take to climb Snowdon Wales, a typical return hike takes around 4–7 hours, although the official estimates for the main routes sit towards the upper end of that range. Reaching the summit is only half the job. You still have to get back down.
Reaching the summit is only half the job. If you are wondering how long does it take to climb up Snowdon, remember that the ascent is only one part of the day. You still have to get back down.
How Long Does It Take to Climb Snowdon for Beginners?
For anyone asking how long does it take to climb Snowdon for beginners, the safest approach is to allow more time than the headline estimate.
A first mountain walk involves more than fitness. You are also learning how to pace yourself on steep ground, read the terrain, navigate and manage food and water. Poor weather can add another layer of difficulty.
Do not plan your day around the fastest possible finish. Give yourself enough daylight for the return.
What Can Make a Snowdon Hike Take Longer?
Several things can stretch the timetable:
  • Rain, wind, cold or poor visibility
  • Wet and slippery rock
  • Crowded sections on popular routes
  • Navigation mistakes
  • Longer food and water breaks
  • Fatigue towards the summit
  • A slower descent
The descent deserves proper planning. Finishing the uphill section does not mean the difficult part of the day is over.
How Long Do the Main Snowdon Routes Take?
Route choice is one of the biggest factors when working out how long does it take to climb Snowdon. Eryri National Park identifies six main paths to the summit, and all are graded hard or strenuous.
Llanberis Path
The Llanberis Path is the longest of the six main routes at around 14.5 km there and back, with an official estimated duration of 7 hours. That makes it particularly relevant to searches for how long does it take to climb Snowdon Llanberis Path and how long does it take to climb Snowdon easy route. Its reputation as a more straightforward route can sometimes give people the wrong impression about the length of the day. It is still a serious mountain walk.
Pyg Track
The Pyg Track is around 11 km return, with an estimated duration of 6 hours. But six hours does not mean six easy hours. Eryri says the Pyg Track is difficult, much steeper than its distance and is difficult and rocky. If you're contemplating this option, keep in mind the terrain and the time. It's important to wear suitable shoes and pace yourself.
Miners’ Track
The Miners' Track is about 13 km round trip and is estimated to take about 6 hours to walk. Six hours is a handy guideline for anyone searching how long does it take to climb Snowdon Miners Track, but should not be treated as a guaranteed end time. The route includes steep, rocky ground, particularly higher up. Keep some energy in reserve rather than treating the summit as the only objective.
Snowdon Ranger Path
The Snowdon Ranger Path is around 13 km return and is listed at approximately 6 hours. Eryri categorises it as hard or strenuous and says good fitness and navigation skills are required. This makes it difficult to gauge its difficulty just by its time estimate. A 6-hour drive can be very arduous. Please refer to current route details before leaving, especially if any changes have occurred.
Rhyd Ddu Path
The Rhyd Ddu Path is another established route to the summit, covering around 12 km return with an estimated duration of 6 hours. If you are less familiar with the route, allow time for navigation rather than assuming you will maintain a constant pace. Visibility, weather and terrain can all change the experience.
Watkin Path
The Watkin Path is approximately 13 km return and is also given an estimated duration of 6 hours. For anyone asking how long does it take to climb Mt Snowdon, the same point applies: time cannot be answered from distance alone. You need enough time and energy for the full return, especially if conditions deteriorate.
What Changes How Long Your Snowdon Hike Takes?
Two people can walk the same route and finish at noticeably different times. That is normal.
Fitness and Walking Experience
Someone used to steep mountain paths will usually move differently from someone whose walking experience is mostly on flat ground. If you are new to mountain walking, build in extra time. Keep a steady pace instead of trying to match a faster group. The aim is to arrive back safely with enough energy left for the descent. This is why how long does it take to climb Snowdon should be treated as a planning question rather than a race target.
Weather and Mountain Conditions
Rain, wind, cold, cloud and poor visibility can all slow progress. Wet rock demands more care, while strong wind can make exposed sections uncomfortable. Mountain weather can change quickly. Check conditions before setting out and keep an eye on them throughout the walk. Eryri also advises hikers to research their chosen route and make sure they have adequate fitness and suitable equipment.
Breaks, Food, and Hydration
The break time is included in your schedule. They're not a time suck. Bring sufficient water and food for the planned activity, and something easy to consume if energy begins to wane. Trying to push through without eating can leave you struggling later. If you are calculating snowdon how long does it take to climb, include these stops in your estimate.
Daylight and Your Return Time
Always plan around the full return journey. Underestimating the descent is an easy mistake to make. A torch or headlamp is worth carrying even if you expect to finish in daylight. If the walk lasts longer than planned, a charged mobile phone is also helpful, for example, for navigation or weather forecasts or emergency communication.
What Do You Need for a Long Day on Snowdon?
Knowing how long does it take to climb Snowdon mountain is only useful if you prepare for the time you will actually spend outside.
Navigation and a Charged Phone
Your phone can provide GPS navigation, weather information and communication when you need it. Photography also uses battery, as does prolonged GPS use and searching for a mobile signal. Start with a full charge. Keep your phone somewhere protected from rain and cold, and avoid wasting battery unnecessarily.
Food, Water, and Warm Layers
Bring enough water and high-energy food for the entire walk. Pack and wear appropriate walking boots and warm and waterproof clothing even when the temperature seems comfortable at the trailhead. Every bottom is not necessarily every top.
Torch, First-Aid Supplies, and Backup Power
A torch or headlamp is useful if the return takes longer than planned. A small first-aid kit is sensible too. Backup power can become useful on longer outdoor trips, particularly when a phone is doing several jobs at once. Portable power is more practical at a campsite, campervan or base than carried during the actual climb.
By this point, you have a working checklist for the mountain itself: navigation, food, water, layers, a torch. But a Snowdon day rarely stands alone. It is often one stretch of a longer outdoor trip — a camping weekend, a campervan stopover, or a few days away from a wall socket — and that wider trip is where phone and device battery life becomes a bigger question than a single hike would suggest.
Keeping Essential Devices Powered on Longer Outdoor Trips
For many hikers, the question of how long does it take to climb Snowdon eventually becomes a question about battery life too.
Why Phone Battery Matters on a Mountain Day
A phone may be handling navigation, weather checks, emergency calls and photographs throughout the day. Six or seven hours outside can put a noticeable demand on its battery. Starting with 100% helps, but it does not remove the problem completely. Cold temperatures and heavy GPS use can also affect battery performance.
When Portable Power Makes Sense Outdoors
A portable power station is generally more useful for the wider trip than for carrying up Snowdon itself. For example, someone combining the climb with camping could use stored power to recharge phones, cameras, lights and other equipment at a campsite or base. The same idea applies to campervan trips and multi-day outdoor adventures.
Choosing Portable Power for Outdoor Adventures
Look at four things: capacity, output, portability and how long you will be away from mains electricity. A single-day hike may need very little backup power. A weekend camping trip with several phones, cameras and lights is different. That is where larger DELTA models can make sense.
Portable Power Stations for Snowdon Trips and Outdoor Adventures
A High-Capacity Option for Extended Outdoor Trips
For example, the EcoFlow DELTA 3 Max Series (2048Wh) Portable Power Station provides 2048Wh of stored energy, making it more suited to a wider outdoor setup than simply topping up one phone. EcoFlow lists a 3000W AC output and LFP battery technology for the DELTA 3 Max. The capacity gives you room to recharge several types of equipment during a camping trip, including phones, cameras and lights. It is worth thinking of it as trip power rather than hiking equipment—the unit is substantial and is not something you would normally carry up the mountain.
Delivers massive 3000W output so you can run heavy appliances effortlessly. Uses durable LFP cells for a safe and reliable battery. Recharges extremely fast in 47 minutes to minimize any downtime. Switches instantly during power outages to prevent any computer data loss. Expands up to 10kWh to easily survive multi-day power outages. Prioritizes essential home circuits to stretch your battery life further. Automatically charges during cheap hours to lower your monthly electricity bills. Combines solar and alternator inputs to charge rapidly while traveling.
A Larger Power Solution for Multi-Day Adventures
For longer stays with greater power demands, for example, the EcoFlow DELTA Pro 3 Portable Power Station offers a 4096Wh capacity and 4000W maximum AC output. Its LFP battery chemistry and expandable capacity make it more relevant to a campsite, base setup or extended outdoor stay than a standard day hike. That extra capacity is useful when several devices need charging over multiple days. But bigger is not automatically better for every trip. For a normal Snowdon day walk, carrying a large power station would make little practical sense.
Huge 4kWh capacity stores enough energy for heavy household appliances. Powerful 4000W output runs demanding heavy-duty devices without any struggle. Expandable storage scales up to 12kWh for extended power outages. Ultra-quiet 30dB operation lets you sleep peacefully right next to it. Rapid 10ms backup switching protects your sensitive electronics from sudden outages. Massive 2600W solar input harnesses sunlight to charge rapidly and efficiently. Durable LFP battery chemistry delivers safe power lasting over a decade. Smart app connectivity lets you monitor and control energy usage remotely.
Snowdon Hiking Checklist Before You Set Off
Check Your Route and Estimated Hiking Time
  • Pick a route that fits well your experience and current conditions.
  • Check the estimated return time.
  • Leave enough daylight for the descent.
  • Tell someone where you are going and when you expect to return.
Check the Weather and Pack for Change
  • Check the mountain forecast before leaving.
  • Carry warm and waterproof layers.
  • Prepare for wind, rain, cold and poor visibility.
  • Wear footwear suitable for rocky and uneven terrain.
Check Your Essential Gear and Battery
  • Fully charge your phone.
  • Carry navigation equipment and a torch.
  • Pack enough food and water.
  • Take basic first-aid supplies.
  • Make sure cameras and other electronics have enough charge.
  • Consider backup portable power for camping or longer outdoor trips.
So, how long does it take to climb Snowdon? For the six main routes, a realistic return journey is generally around 4–7 hours, with Eryri's current route estimates ranging from about six hours on five routes to seven hours on the Llanberis Path. Your actual time can change with fitness, route choice, weather, breaks, navigation and the condition of the ground. Plan for the whole mountain day rather than just the climb to the summit.
EcoFlow portable power stations can also be useful beyond the mountain itself, particularly when a Snowdon trip becomes part of a camping weekend or longer outdoor adventure where mains electricity is limited. Explore EcoFlow UK to see portable power options for your next outdoor trip.
A return Snowdon hike generally takes around 4–7 hours, depending on the route, fitness, weather, walking pace and breaks. Eryri currently estimates six hours for most of the main routes and seven hours for the Llanberis Path. Individual times can vary considerably.
Beginners should allow extra time rather than planning around the quickest expected finish. Route difficulty, fitness, terrain, weather, navigation experience and rest stops can all affect the day. Plan around the complete return journey, not simply the ascent.
How Long Does It Take to Climb Snowdon via the Miners’ Track?
The Miners’ Track is generally estimated at around 6 hours for a return hike and covers approximately 13 km. The actual time can be shorter or longer depending on fitness, weather, terrain, breaks and walking experience.
Home Solutions
