How to Figure Watts for Any Appliance
You're staring at a charger, a kettle, or a spec sheet, trying to work out what it actually draws — and the label either doesn't say "watts" or it gives you numbers that don't obviously add up. Knowing how to figure watts isn't complicated once you see the relationship between voltage and current, and it is actually very useful and even useful for comparing appliances, planning an extension lead or determining whether a battery system will actually power what you want it to power. This guide walks through the core formula, several ways to calculate it depending on what information you've got, the difference between watts and watt-hours, and how all of that feeds into sizing a home energy storage system.
Understanding Electrical Power and Why We Measure It in Watts
What Watts Actually Measure
A watt is a measure of power — the rate at which energy is used or delivered at a given moment, not the total amount consumed. Think of it like speed versus distance: a car travelling at 60mph tells you nothing about how far it's gone unless you also know how long it's been driving. Watts work the same way. A 2000W heater isn't "2000 watts" of stored energy; it's drawing energy at that rate for as long as it's switched on.
Why Watts Are Used to Describe Power Consumption and Output
Manufacturers rate devices in watts because it's the one figure that captures both voltage and current in a single number — useful when comparing a 12V device to a 230V one, since volts or amps alone don't tell you the full story. A hairdryer and a phone charger might both run on mains voltage, but their watt ratings instantly show which one is pulling far more power. It's also why appliance energy labels, extension lead ratings, and inverter specifications are all expressed the same way — a single unit that works across completely different types of equipment, from a 5V USB charger to a 230V oven.
The Basic Formula: Watts = Volts × Amps
Every calculation in this article comes back to one relationship: Watts = Volts × Amps. Multiply the voltage supplied by the current flowing through the circuit, and you get power in watts. It's the first step when using a charger, sizing a generator or calculating battery run time.
How to Figure Out Watts From Volts and Amps
How to Figure Out Watts When You Know Volts and Amps
This is the most direct version of the calculation. Say you've got a device running on a 230V UK mains supply and drawing 2 amps — multiply the two, and you get 460 watts. That's how to figure out watts from volts and amps in practice: it's one multiplication, no conversion tables required. A kettle pulling 10 amps at 230V, by comparison, works out to 2300W, which is roughly why kettles are one of the more demanding things you'll plug in.
Note: When connecting home energy storage or large-scale battery systems to a UK property, remember to check current Distribution Network Operator (DNO) for your area (e.g. G98/G99 compliance) as well as guidance from Ofgem to ensure your installation is compliant with local requirements.
How to Figure Watts to Amps When Voltage Is Known
Sometimes you've got the wattage — printed on the box — and need the current instead, maybe to check a fuse rating or a cable's capacity. Here's how to figure watts to amps: divide watts by volts. A 1150W device on a 230V supply draws 5 amps. This is also how to figure watts into amps when you're checking whether a circuit or extension lead can handle a specific load; getting this backwards is a common way people undersize their cabling, so it's worth double-checking rather than guessing. Knowing how to figure watts and amps together, rather than treating them as separate mysteries, makes reading any spec sheet considerably less confusing — and it's the same question whether you phrase it as how to figure out watts to amps or how to figure watts to amps, since both describe the identical division.
Everyday Examples: Phone Chargers, Refrigerators, and Heaters
A typical phone charger runs at 5V and 2-3A, or 10-15W, which is small in comparison to a fridge, which typically operates at 100W-400W depending on size and age (and turns on and off instead of running all the time). A fan heater, by contrast, can sit at a steady 2000W or more, and an electric shower can briefly pull upwards of 8000W, which is why it's usually wired on its own dedicated circuit rather than sharing a socket ring with everything else in the house. This is how to figure out watts from amps and volts for almost anything with a rating plate: find the two numbers, multiply, and you've got a figure you can actually compare across devices, whether you're deciding what to plug into a travel adaptor or working out which appliances a generator can realistically run at the same time.
Calculating Watts From Other Information You Already Have
Working Out Watts When You Know Amps and Resistance
Not every label gives you voltage directly. If you know the current and the resistance of a circuit, Ohm's Law (V = I × R) lets you find voltage first, then apply the watts formula from there. It's a two-step process rather than one, but it covers the situations where a straightforward volts-and-amps reading isn't available — some older appliances and DIY electronics fall into this category.
Working Out Amps When You Know Watts and Voltage
This is the reverse problem, and it comes up constantly when sizing fuses, cables, or battery output. Divide the wattage by the voltage and you've got your answer. If you're wondering how to figure amps from watts and voltage, that's the whole calculation — a 3000W appliance on a 230V circuit needs roughly 13 amps.
The same logic applies if you're asking how to figure amps from watts and volts, since volts and voltage mean the same thing here; it's just phrasing. It's also how to figure out amps from watts and volts when you're cross-checking a spec sheet against a circuit's rated capacity. And if you're starting from scratch with just the watt rating on a device, how to figure out amps from watts follows the identical formula — you just need the voltage of whatever it's plugged into to complete the sum.
Reading Watts Directly Off an Appliance's Power Label
Before reaching for a calculator, check the label — most appliances, chargers, and adaptors already print wattage, or volts and amps, directly on the rating plate or base unit. It's often faster than doing the maths yourself, and it's how to figure out watts with volts and amps without any guesswork when the manufacturer's already done the multiplication for you. That's also how to figure out amps with volts and watts in reverse, since a plate showing all three figures lets you sanity-check that they actually agree with one another.
Watts vs Watt-Hours: Why the Difference Matters
What a Watt-Hour Actually Measures
A watt-hour (Wh) measures energy used over time, not power at an instant — it's the "distance travelled" to a watt's "speed." A 100W device running for one hour uses 100Wh. Run it for five hours and it's used 500Wh. This distinction trips a lot of people up when they're trying to estimate a bill or a battery's runtime.
How to Figure Out Watt-Hours From Power and Time
The calculation is simple once you know both figures: watts multiplied by hours. A 1500W heater running for two hours uses 3000Wh, or 3kWh. This is how to figure out watt hours for essentially any appliance, provided you know roughly how long it's switched on for during the day — which is the number that actually determines your electricity use, not the wattage alone.
Why This Distinction Matters for Household Electricity Demand
Watts tell you what a device draws right now; watt-hours tell you how much energy it's used by the end of the day. Both numbers matter for different reasons — watts for whether your circuit or inverter can handle the load, watt-hours for how much total capacity you need to cover a day's use. Mix the two up and you'll either undersize a battery (fine on paper, flat by evening) or oversize one unnecessarily and pay for capacity you never draw on. That second question — total daily watt-hour demand — is exactly where sizing a home battery system comes in.
Sizing a Home Battery Storage System Around Your Appliance Loads
Matching Total Household Watt Demand to a Storage System
Working out watts and watt-hours for every appliance in the house is only useful if you then know what to do with that number — otherwise you're left guessing whether any given battery is actually enough. Once you know how to figure watts for your real daily load rather than a rough estimate, sizing a system stops being guesswork and becomes a straightforward comparison. The STREAM 5000 is one option for households starting from zero, giving you something concrete to check your calculated demand against. It solves the specific problem of translating a number on paper into an actual purchase decision.
EcoFlow STREAM 5000
5024Wh capacity supports all-night home power use, expandable to 90kWh Up to 3000W AC output, ready for high-demand appliances like stoves, dryers, or kettles 4000W solar input makes full use of your solar generation 3000W AC charging for fast recharge True Plug & Play+ setup — every part of the system, from smart meter to main unit to solar panels, connects easily Compact 45.9kg body with a built-in handle for easy moving Residential-grade safety: pressure-release and fire-resistant materials, no overheating even at high voltage 10,000-cycle lifespan — charge to 100% or discharge fully without affecting battery health Local Mode keeps the system running and communicating even if the network drops
Adding Storage Once You Know Your Power Requirements
For households that already have solar panels, the frustration usually isn't sizing — it's watching daytime generation go to waste because there's nowhere to store it. Even once you've learned how to figure watts and matched your appliance loads correctly, that calculation doesn't help if surplus power still has nowhere to go. The STREAM AC 5000 is built to close that specific gap, adding storage onto a system you already have rather than requiring you to start over. It turns a calculated surplus into something you can actually use later, rather than exported for a fraction of its value.
EcoFlow STREAM AC 5000
100% compatible with existing rooftop PV systems, home battery systems, and leading third-party meters 5024Wh capacity covers overnight home needs, expandable to 90kWh Up to 3000W AC output powers heavy household appliances 4000W solar input captures maximum solar energy from an existing setup AC coupling adds storage to your current solar setup — no rewiring needed to expand later Compact 45.1kg body, easy to fit into any indoor space 10,000 cycles for durable, long-term battery health Pair with Gateway for straightforward system expansion
A Simple Guide to Reading Power Ratings on Everyday Equipment
Quick Reference: Calculating Watts in Any Scenario
Three formulas cover nearly every situation: volts × amps for watts, watts ÷ volts for amps, and watts × hours for watt-hours. Add Ohm's Law (V = I × R) as a backup for the rare case where voltage itself isn't given. Whichever two figures you've already got, one of those relationships gets you the third. It's worth keeping these somewhere handy — a phone note works fine — because sooner or later a label will only give you two of the three numbers you actually need.
How to Read the Power Label on Your Equipment
Most rating plates list voltage (V), current (A), and sometimes wattage (W) directly — check the base, back panel, or plug of the device. If only two figures are given, the formulas above fill in the third in seconds. Chargers and adaptors often show a range (e.g. 100-240V) to reflect that they work across different countries' mains supplies, and some list a maximum current per output rather than a single fixed figure — worth checking if you're running more than one device from the same charger at once.
Figuring out watts comes down to one relationship used a few different ways: multiply volts by amps if you have both; divide to work out the missing value; bring in resistance or time if you have the other one. Reading appliance labels, sizing cables, and figuring out how much energy an appliance uses in a day, not just at that moment, all become much easier once that "clicks.
If you're weighing up a home battery or solar storage setup, EcoFlow's STREAM 5000 and STREAM AC 5000 are worth a look once you've worked out your own household's watt and watt-hour demand — sizing a system properly starts with knowing what you're actually trying to power.
How do you figure out watts?
Calculate the power in watts by multiplying volts by amps. If the wattage is already listed on the device label, there is no need to calculate; read it directly from the label.
How do you figure out watt-hours?
Multiply the device's wattage by the number of hours it runs: a 200W device running for 3 hours uses 600Wh. This figure is what actually determines total energy use, not the wattage alone.
How do you figure out amps from watts and volts?
Divide watts by volts: Amps = Watts ÷ Volts. A 2300W kettle on a 230V UK supply, for example, draws 10 amps.
Home Solutions
