Liquid Air Energy Storage in 2026: How LAES Works, Benefits & Future Potential
As renewable energy becomes more prevalent, storing electricity becomes ever more crucial. Liquid air energy storage serves as a method that is capable of storing electricity for long periods of time through transforming electricity into liquid air and returning to electric power at times of need.
There are many uses for LAES - from enabling grid flexibility to improving renewable energy use.
1. What Is Liquid Air Energy Storage and How Does LAES Work?
With renewable energy production through solar and wind energy expanding, the question of how to easily store excess electricity has become more relevant. The answer to this dilemma is liquid air energy storage systems, a long-duration energy storage system, the primary aim of which is to store electrical energy.
Technology operates differently from traditional storage systems because it employs air as the principal storage material instead of batteries, which makes it an attractive option to be used by large energy systems in the future.
What Is Liquid Air Energy Storage?
Liquid air energy storage technology allows for long-term energy storage of electricity in the form of cooled air. The core principle of this technology is the following: as long as there is electricity generated, the process of turning air into liquid happens to be possible, and that is when liquid air is being stored. In this way, oxygen-rich liquid air can be stored in tanks, and, when the situation requires, heated and turned back into gas, which is an enormous storage option for future energy demand.
How Does Liquid Air Energy Storage Work?
Liquid air energy storage systems work in three major steps:
  1. Filling: When the compressor is driven by electricity to compress and cool the air until it turns into a liquid form.
  2. Storage: The liquid air is stored in insulated tanks until the time comes when electricity has to be produced.
  3. Dismantling: While the heat is induced in the liquid air, it expands and drives generators or turbines.
This process gives LAES the advantage of storing excess energy at some points and then being able to feed it back to the energy grid.
Key Components of a Liquid Air Energy Storage System
A standard LAES system consists of a variety of different components acting together for purposes of storing energy and retrieving it in the future.
  • Air intake and filtering system: Used to filter the air from the atmosphere.
  • Compressors: Increase air pressure during charging.
  • Cooling and liquefaction: Remove heat from the air until it is converted into a liquid.
  • Cryogenic storage tanks: Used to store liquid air.
  • Heat exchangers: Transfer the energy charged during charging and discharging.
  • Expansion turbines: Ensure that the pressurized gas creates kinetic energy during its expansion.
  • Generator: Used to create electricity from the energy of the turbine.
Therefore, all of the components listed determine whether the overall LAES system is capable of storing and generating electrical energy.
Liquid Air Energy Storage Efficiency and Round-Trip Performance
The effectiveness of liquid air energy storage varies depending on aspects such as the structure of the system, temperature of operation, need for compression, heat management and the usability of waste heat or cold.
One of the major indicators is the total efficiency of energy storage liquid air that compares the amount of electricity that is supplied at discharge to the one consumed at charging.
Efficiency is a very important concept but not the only one that matters when it comes to long-term storage. Additional factors that may influence if LAES is the perfect choice are duration of storage, ability to scale, working conditions, infrastructure in place and compatibility with renewable energy usage.
How LAES stores, charges and discharges energy and then describe its pros, costs and future potential.
2. Liquid Air Energy Storage Benefits, Costs & Future Potential
As the deployment of wind and solar systems increases, particularly those generating electricity through renewable sources, the importance of energy storage for long durations increases. LAES can be used to agree with this requirement through storage of electricity in the form of liquid air which can be reused at a later stage.
Therefore, LAES can be used beyond just storage for shorter durations. The technology is indicated as flexible thermo-mechanical energy storage which can also be applied with other sources of heat and cold.
Why Long-Duration Energy Storage Matters for Renewable Power
The production of renewable electricity involves wind and solar resources and depends on weather and time of the day. Long-term energy storage can help to transfer the excess of electricity at the time the generation is low and/or the demand for electricity is high.
LAES helps to differentiate between duration of storage and energy output, and, therefore, large amounts of energy can be stored for a long time.
This allows for the integration of renewable sources and helps to control the amount of produced energy.
Liquid Air Energy Storage Benefits for Grid Flexibility and Scalability
  • Long-term storing: Stores electricity for long hours or longer times.
  • Renewables integration: Helps attach surplus wind and solar energy for times of need.
  • Grid flexibility: Can assist in load switching or increase in decreasing grid applications.
  • Scalability: Can be constructed as massive utility scale energy infrastructure.
  • Locational flexibility: Like pumped hydro, the location of LAES is not determined by the same conditions of geography.
  • Possibility for thermal and cold integration: Heat and cold can also add something to the overall performance of the energy system.
Liquid Air Energy Storage Cost Per kWh: What Influences the Price?
Since project costs are subject to significant variations with several factors such as project design, infrastructure, efficiency, financing, scalability, and method of calculating storage costs, there is no single “liquid air energy storage cost per kWh" figure that is accepted worldwide.
As an example, one of the techno-economic studies found a levelized cost of storage at US$382–US$888/MWh, i.e. roughly US$0.382–US$0.888/kWh depending on the LAES configuration.
However, this number should not be regarded as the standard price of LAES.
Cost factor
How it affects LAES economics
Plant size
Larger projects can potentially spread infrastructure costs across greater storage capacity.
Power capacity
Turbines, generators and related equipment affect the cost of delivering electricity.
Energy capacity
Storage tanks and associated equipment influence the cost of storing energy.
Round-trip efficiency
Higher efficiency can reduce the amount of electricity required to recharge the system.
Heat recovery
Recovering compression heat can improve performance and economics.
Cold-energy integration
Access to suitable cold sources can potentially reduce cooling requirements.
Infrastructure
Grid connection, land, construction and site development can substantially affect total project costs.
Financing and project lifetime
Capital costs, financing conditions and operating life influence the levelized cost of storage.
Note: Do not state a fixed cost (e.g. “£X/kWh”) unless the cost is linked to a specific project, date, methodology and source. The published studies assume different values and cost criteria; Therefore, don't assume that LCOS is equivalent to capital cost.
Liquid Air Energy Storage Plants and the Growth of LAES in the UK
The UK has become a major player in the field of large-scale LAES development. Highview Power is establishing a LAES plant in Carrington, Manchester, with a maximum capacity of 300 MWh/50 MW and a design to deliver electricity for up to six hours. Construction started in November 2025 with plans to be operational by late 2026.
The project also enjoys strong backing from UK institutional investors. The UK Infrastructure Bank disclosed that it has made a £165 million investment as part of a funding round that will total £300 million in support of the Carrington project and the overall programme of Highview.
Highview also claims that its wider programme in the UK has identified more than 16 prospective sites, indicating the potential scale of LAES implementation in the future energy-storage sector of the country.
Note: Liquid air energy storage technology (LAES) is being pursued by the United Kingdom as Highview Power establishes a 50 MW/300 MWh site in Carrington, Manchester. The purpose of this initiative includes storing excess renewable energy and offering power flexibility during peak demand times.
Highview Liquid Air Energy Storage and the Development of LAES Solutions
Highview Power is an energy infrastructure enterprise in the United Kingdom that specializes in projects pertaining to grid stability and large-scale energy storage. Liquid air energy storage companies employ a technology that utilizes cryogenic liquid air storage as a means of supplying electricity when necessary.
The Carrington initiative is very important since it signifies that LAES has stepped out of the laboratory and demonstration stage and is now one step closer to becoming a commercial full-scale grid storage operation. The anticipated 50 MW output and a storage capacity of 300 MWh are indicative of the possibilities of LAES technology.
While big LAES facilities provide a practical example of how electricity can be stored, shifted, and supplied on a large scale, there is more. The same concept of storing idle electricity and using it when the demand arises can also function at the level of individual households.
3. Liquid Air Energy Storage vs Batteries & Pumped Hydro: Which Use Cases Fit Best?
There is not one energy-storage technology that can fulfill the energy-storage needs for all purposes. Liquid air energy storage Uk, lithium-ion batteries, and pumped hydro differ from one another with respect to energy storage time, requirements for their location, response time, scalability, and conditions of operation.
The analysis of their practical applications indicates the place of each of these technologies in modern renewable-energy systems.
Liquid Air Energy Storage vs Lithium-Ion Batteries
Liquid air energy storage and Lithium-Ion batteries can perform the functions of energy storage.
Feature
Typical focus
Long-duration energy storage
Short- to medium-duration storage
Response
Suitable for grid-scale dispatch
Very fast response
Best suited for
Multi-hour energy shifting and grid flexibility
Peak shaving, backup and rapid grid services
Storage medium
Liquefied air
Electrochemical cells
Scalability
Designed for large energy-storage projects
From small systems to utility-scale installations
Liquid Air Energy Storage vs Pumped Hydro Storage
LAES and pumped hydro are both able to provide long-duration storage, but differ in their physical needs.
Feature
Pumped Hydro
Storage medium
Liquid air
Water
Location requirements
Can be developed in a wider range of locations
Requires suitable elevation and water resources
Scale
Suitable for large-scale projects
Often very large-scale
Main application
Long-duration grid storage
Bulk energy storage and grid balancing
Key consideration
Cryogenic equipment and thermal management
Geography, reservoirs and infrastructure
When to Use Grid-Scale LAES, Batteries or Other Storage Technologies
Depending on energy-storage needs, a particular technology will be appropriate for use.
  • LAES: Good for long-duration storage of electricity at grid level and to shift renewable energy.
  • Lithium-ion batteries: Useful where quick-response and short storage duration is imperative.
  • Pumped hydro: Appropriate for use in large-scale applications where suitable geological conditions exist.
  • Other technologies: Flow batteries, thermal storage and other new technologies can account for some storage needs related to the particular characteristics of the duration or the site.
Instead of excluding each other, these technologies can work together to develop a more flexible energy system.
From Grid Storage to Home Energy: Bringing Stored Power Closer to Consumers
The principle behind grid-scale energy storage is equally applicable to residential buildings: collect energy when it is available and use it later when there is an increased demand for energy. Battery and solar panel combinations enable storage of the energy generated during daytime hours to be used during nighttime hours for energy needs at home.
Residential energy storage systems can use the concept of flexible energy storage on a smaller scale in the everyday lives of consumers. Stored electrical energy can also be used for outdoor entertainment such as gatherings, camping and BBQs as well as road trips when there is a lack of grid connection.
While LAES illustrates on the grid scale, what homeowners actually need at home is a smaller solution designed to meet the everyday energy requirements. EcoFlow STREAM Series offers a way of getting this solution closer to consumers so that they can fully harness solar energy and make effective use of it for their outdoor and indoor needs.
4. From Grid-Scale Storage to Home Energy: EcoFlow STREAM Series
Even though LAES technology is designed for large-scale, long-term energy storage in industrial processes, this principle can also reveal significant benefits at the household level with compact solar battery systems. Through the EcoFlow STREAM Series, the technology applies to home energy storage and everyday usage scenarios by capturing solar energy on demand.
Let's use liquid air energy storage solutions and examine how the devices will suit your practical needs. The STREAM 5000 and STREAM AC 5000 can help with energy storage at home during the evening hours and for entertaining purposes.
EcoFlow STREAM 5000 for Flexible Home Solar Energy Storage
EcoFlow STREAM 5000 Solar Battery
5024Wh battery capacity 3000W maximum power going out of battery 4000W maximum power coming into the system 3000W charging input 3000W output 5000W input power from Solar panels using 4 MPPTs Max 12 solar panels Up to 90kWh and 18000W output Lifespan battery is 10000 cycles IP65 rating WiFi/Bluetooth/CAN compatibility Weight is 45.4kg
EcoFlow STREAM AC 5000 for Reliable Household Power
EcoFlow STREAM AC 5000 Solar Battery
5024Wh battery capacity  3000W maximum discharging power  3000W maximum charging power of the battery system  3000W AC charging input  3000W off-grid AC output  800W/3000W grid-tied AC output  100% usable 5kWh capacity  Expandable up to 90kWh and 18,000W output  10,000 cycles battery life  IP65 protection rating  Wi-Fi/Bluetooth/CAN connectivity  44.6kg weight
Using Stored Solar Power for Outdoor Living, Camping & Garden Setups
Outdoor energy storage with solar energy makes traveling easier and cheaper, such as camping trips, celebrations in the backyard, BBQ parties, and weekend adventures in places away from the mains power supply. EcoFlow STREAM 5000 is a device that allows storing solar energy for later use when electricity is necessary.
Powering Outdoor TVs, Lighting, Appliances and Other Devices When Grid Access Is Limited
On the list of activities that don’t need a plug, there are watching a movie with the help of TV in the backyard, and using lighting, kitchen gadgets, and other appliances without the supply from the grid. EcoFlow STREAM AC 5000 realizes the same concept of using energy stored in the device to ease the everyday life of people.
From powered liquid air electricity systems to ordinary home batteries, the basic idea remains the same: collect electricity when possible and use it when necessary.
LAES (liquid air energy storage) appears to be a new and advanced storage technology for the purpose of enhancing flexibility of the energy grid and enabling integration of variable renewable energy sources. The idea consists of the fact that electricity is converted into liquid air and stored until the time comes when it should be used.
Energy storage technologies are not only reserved for energy companies. In the context of home energy storage, for example, solar batteries operate on the same principle and store energy taken from the sun for future use.
What is liquid air energy storage round trip efficiency?
The round-trip energy efficiency of the liquid air energy storage UK system differs based on the design of the system and whether cold/heat energy is used. Highview claims an efficiency of between 50-55%, which can reach levels of about 70% through co-location and integration.
Scientific studies indicate that other applications of LAES have been proven to have higher efficiencies, so naturally, one must refer to the system being analyzed.
How much does liquid air energy storage cost per kWh?
There is no unique value for liquid air energy storage costs in kWh since the cost of energy storage depends on a great number of factors like the size of the plant, the configuration, efficiency, electrical prices and financial assumptions.
Note: Research states that LCOS for a specific 25MW/125MWh LAES was estimated to be in the range of £191-£590/MWh.
What companies are developing liquid air energy storage?
Highview Power is among the prominent companies that provide liquid air energy storage solutions on a commercial scale. Their Carrington facility in Manchester is currently being developed, with plans to deploy other long-duration facilities in the UK.
What is the role of liquid air energy storage in the UK?
LAES is necessary for the UK, and its use is part of the UK's long-term energy storage plan. The company plans that the Carrington facility will start operating in 2026 and operate with a capacity of 300 MWh and output of 50 MW for six hours to provide energy shifting and stabilize the grid.
The UK government specified LAES among the technologies capable of supporting more renewable energy operations.
