How Much Do Electric Workshop Heaters Cost to Run in the UK?
Keeping a workshop cosy during the winter months in the UK can dramatically raise your electricity bills, especially if you have the heater on for hours each day. Whether you are using your garage to work on DIY projects or running a workshop at home to start a small business, picking the right type of electric workshop heaters allows you to stay comfortable while keeping your costs down. However, how can you identify which type of heater is the most effective in terms of energy consumption and heat output? From fan and electric workshop heaters to infrared and oil-filled types, it is crucial to find out how much electricity these heaters use to make an informed choice.
Read on to find out the costs of operating various heaters, ways of minimising energy consumption, and the usefulness of portable power stations for your workshop.
1. Electric Workshop Heaters: Types, Features and How to Choose
It is important to choose the correct electric workshop heater to achieve the desired temperature while controlling your electricity costs. Knowing the functioning of various heaters and their working characteristics will enable you to choose an ideal model for your garage or workshop.
What Are Electric Workshop Heaters and How Do They Work?
Electric workshop heaters are able to provide their services in different places, provided that there are other fast ways to use their power sources conveniently. Electric heaters of different types might be employed in garages, garden workshops, sheds, and small commercial workplaces. Without gas connections and central heating, electric heaters can transform electric energy into heat, which can allow people to live in comfort during cold days.
Electric heaters do not work the same way depending on the model. The heater may heat the surrounding air, heat surfaces or objects in its surroundings or disperse warm air to work through the workspace. Some types of electric workshop heaters in the UK might also be provided with thermometers, timers, temperature control, and other features, thus allowing users to save on costs and automatically adjust heaters to the required heating levels.
When looking for the electric heater that is best for your workshop, it is essential to consider some factors, like how fast you need the workspace to be heated or how long you plan to spend there.
Fan, Infrared, Ceramic and Oil-Filled Heaters: Key Differences
Electric workshop heaters do not work similarly. Fan heaters can effectively heat a small area quickly. Infrared heaters, on the other hand, produce radiant heat directly. Ceramic heaters can be used to compactly produce heat, while oil-filled radiators can produce consistent heat over a longer period.
The comparison chart below is intended for you to understand how the various workshop heaters vary feature-wise.
Heater type | How it works | Main advantages | Best suited for |
Fan heaters | Use an electric heating element and fan to circulate warm air | Quick heating, portable and compact | Small garages and occasional workshop use |
Infrared heaters | Emit radiant heat that warms people and objects directly | Targeted warmth, less reliance on heating all the surrounding air | Outdoor workshops, workbenches and draughty spaces |
Ceramic heaters | Heat ceramic elements and distribute warmth, often using a fan | Rapid heating, compact design and adjustable settings | Small workshops and hobby spaces |
Oil-filled radiators | Heat internal oil, which transfers warmth to the radiator surface | Quiet operation and gradual, consistent heat | Enclosed workshops and longer working sessions |
Which type should you choose?
Quick heating: Fan and ceramic heaters are helpful for heating up your workspace fast, as you enter the workshop and require warmth instantly.
Focused heating: Infrared heaters come in handy when you are working at a particular workbench or workstation most of the time.
Long working hours: Oil-filled radiators perfectly suit the purpose of providing warmth in a closed space that is properly insulated.
Be aware that real energy consumption is always tied to the specific heater's wattage, work duration, and the thermostat settings. An appliance that claims to be energy-efficient still may require the same amount of energy to generate the same amount of heat.
How to Choose the Best Electric Heater for a Garage or Workshop
When looking for the best electric heater for the garage or workshop, you must assess more than pricing and maximum heat produced. The right choice depends upon the shop as well as space heating needs and how much insulation you have in the workshop.
Before buying, keep these points in mind:
Size of the workshop: Larger workshops will need heaters with higher power outputs. For a garage of a smaller size, you can ignore the power and settle for compact heaters.
Insulation and heat loss: Heating will be more effective if the heater is used in an insulated garage, with insulated walls, sealed doors and double-glazed windows.
Product type: Choose between fan or ceramic heaters if you want instant heat, infrared heaters to heat a specific area or an oil-filled radiator to get gentle heat.
Wattage and electricity consumption: Compare wattages of the heaters and determine how much power you will need to run them in your garage.
Thermostat and timer: It is better to invest in heaters with timers and adjustable thermostats that allow varying the temperature as needed.
Safety: It is vital to select heaters that are equipped with safety features like overheat protection, stable construction, and a safety rating suitable for the relevant application. Check the manufacturer's manual for any restrictions regarding operating heaters near dust, fires, flammable materials, and in wet conditions.
Portability and installation: Choose the right type of heater. Decide whether it should be a standalone unit, which you can take away with you, or a fixed heater on the wall of your workplace.
If the workshop is outdoors or in a detached garage, consider the amount of heat escaping through the walls, ceilings, and doors. Before upgrading the heater, make improvements to the insulation of the workplace, which will require less electricity to heat up the premises.
What Size Electric Workshop Heater Do You Need?
Determining the right heater size depends on several factors, including the size of your workshop, insulation, height of the ceiling and the temperature you wish to achieve. A small garage that is fully insulated may require much less power than a large workshop with a high ceiling and unsheltered walls or doors that frequently open.
To get a rough idea, here are some heater capacities:
Workshop size | Suggested heater capacity | Typical application |
Up to 10 m² | 1–1.5kW | Small hobby rooms and compact garages |
10–20 m² | 1.5–2kW | Standard single garages and garden workshops |
20–30 m² | 2–3kW | Larger garages and workspaces |
30–40 m² | 3–4kW | Larger workshops with suitable electrical provision |
These values merely serve as guide estimates and not fixed heating needs. Actual output depends on the insulation, height of the ceilings, ventilation, outside temperature, and heat loss.
As an illustration, a 2 kW electric workshop heater working at full capacity for four hours consumes 8 kWh of electricity, while a 3 kW unit over the same hours consumes 12 kWh. This difference can have a significant effect on weekly and monthly kilowatt-hour consumption, especially in winter.
Thus, it is advisable to calculate the electricity requirements beforehand if you intend to use a more powerful device. Once you know the heating requirements of your workspace, you need to study the electricity consumption of the different models available in the UK and their running costs.
2. How Much Electricity Do Electric Workshop Heaters Use in the UK?
Generally, electric workshop heaters use between 1 kWh and 3 kWh of energy per hour, depending on power output and settings. Understanding their energy usage per hour, daily usage, and electricity prices in the UK will enable you to accurately estimate the running cost and find ways to save energy as well.
Electricity Consumption by H+eater Wattage: 1kW, 2kW and 3kW
The amount of electricity used by a heater depends solely on its power rating and its usage time. A 1kW heater will consume 1kWh of energy, while using a 2kW or a 3kW heater will mean using two to three times more energy than that of a 1kW heater when being used.
Heater power rating | Hourly consumption | 2 hours | 4 hours | 8 hours |
1kW | 1kWh | 2kWh | 4kWh | 8kWh |
2kW | 2kWh | 4kWh | 8kWh | 16kWh |
3kW | 3kWh | 6kWh | 12kWh | 24kWh |
These figures are based on operation around the clock at rated power. Thermostat-controlled heaters could cost less if they turn off after they reach the desired temperature.
Hourly, Daily, Weekly and Monthly Electricity Consumption
Your average monthly electricity consumption rises with the number of hours you run your workshop heater. The estimates below assume four hours on every working day, five days in a week, and four weeks in a month.
Heater rating | Hourly | Daily (4 hours) | Weekly (5 days) | Monthly (20 days) |
1kW | 1kWh | 4kWh | 20kWh | 80kWh |
2kW | 2kWh | 8kWh | 40kWh | 160kWh |
3kW | 3kWh | 12kWh | 60kWh | 240kWh |
For example, a 2kW electric workshop heater runs for 4 hours on each working day and consumes about 160kWh a month. Using a properly sized heater and reducing unnecessary operating hours can help you reduce this consumption.
Electric Workshop Heater Running Costs: 2, 4 and 8 Hours a Day
The cost of running an electric workshop heater is calculated based on the total watts, the number of hours it is functional in a day, and the cost per kWh of electricity in the region. The estimate is prepared based on the average cost of electricity in the UK at 26.32 per kWh, and the difference in costs for different heaters has been shown in the table below.
Heater rating | 2 hours/day | 4 hours/day | 8 hours/day |
1kW | £0.53 | £1.05 | £2.11 |
2kW | £1.05 | £2.11 | £4.21 |
3kW | £1.58 | £3.16 | £6.32 |
Note: Costs are estimated daily and rounded to the nearest cent. Based on 26.32p/kWh and running at full power constantly. Energy Price Cap Unit Rates and Standing Charges (Ofgem) |
For example, if a 2 kW workshop heater is used for 8 hours a day, it will cost about £4.21 to operate it for a day, which will accumulate to £84.22 for 20 working days. Therefore, using a less powerful heater or operating it for fewer hours will lead to lower electricity bills.
How Workshop Size, Insulation and Thermostat Settings Affect Energy Use
The real power consumption of the heater depends not only on its wattage, but also on several parameters. Here are some factors that can impact the energy requirements in your workshop:
Workshop size: The larger the garage or workshop, the more heat is needed to keep the temperature appropriate.
Insulation: Poorly insulated surfaces make the heat escape, resulting in longer operation of the device.
Ceiling height: The higher the ceiling is, the more air needs to be heated.
Doors and windows: The more openings there are, the more draughts and poorly sealed windows influence energy losses.
Thermostat: Setting the right temperature can also help to avoid the unnecessary heating of the workshop. Such heaters can switch off or reduce their operation if the correct eco-friendly temperature is reached.
Weather: The colder the season is, the more heating you need to heat your workshop.
A garden workshop with good insulation can keep the temperature warmer than a poorly insulated detached garage, for instance, when both have a 2kW heater.
UK Electricity Prices: How Much Does It Cost to Heat a Workshop?
The costs of workshop heating are heavily impacted by electricity rates. The average electricity price from Ofgem for the period from October 2026 to December 2026 is £26.32kWh across the UK.
Electricity pricing | Rate |
Electricity unit rate | 26.32p/kWh |
Electricity daily standing charge | 54.83p/day |
Price-cap period | 1 October–31 December 2026 |
Note: The figures mentioned represent the average Direct Debit costs (Ofgem). The actual charges vary from region to region, type of payment, and tariff. There are no extra charges imposed in this period. |
Your actual workshop heating costs may differ if you have a fixed tariff, business electricity contract or time-of-use tariff. You can also compare tariffs and take advantage of flexible electricity used to help control costs.
Practical Ways to Reduce Electric Workshop Heating Costs
Minimising heat loss and controlling appliance operation are both ways to cut down on energy consumption without affecting comfort levels. Here are some useful suggestions for saving energy:
Improve workshop insulation: Insulate walls, roof and floor to retain heat efficiently.
Seal draughts: Use weather strips on doors and windows in order to keep out cold air.
Use a specific heating source: Consider using infrared heaters to heat workbenches and areas that are occupied rather than trying to heat the entire workshop.
Use controls: Establish a comfortable temperature, and do not keep heaters on when not needed.
Heat only when necessary: Your heating will be more efficient by using timers and programmable appliances.
Service your appliance regularly: Clean vents and filters and follow guidelines provided by the manufacturer.
Start utilising solar energy to your advantage: Generate electricity using solar panels and store the surplus in battery banks for later use.
For workshops in the garden, free-standing garages, and outdoor working areas, solar energy combined with a battery system is another way of dealing with regular electricity demands. You can see how stored solar energy helps run workshop appliances and heating equipment rather than solely depending on the electricity from the grid.
After knowing the heating needs of your workshop as well as the potential operating costs, the next step is checking how solar generation and battery storage can help you reduce electricity consumption. EcoFlow STREAM offers alternatives for households keen on utilising solar energy for their households and outdoor jobs.
3. Powering Workshop Heating with EcoFlow STREAM Solar Battery Storage
Solar panels and battery systems aid in mitigating dependence on electricity from the power grid to run the workshop, garage and garden outbuildings. The EcoFlow STREAM system will store excess solar energy and will allow homeowners to use this energy to reduce energy use by the heating systems and appliances in the garden shed and other facilities, thus greatly increasing the efficiency of the system used.
Heating Garden Workshops and Outdoor Workspaces with Solar Energy
The cost of energy for electric heaters for garages and workshops can be quite high, especially if the garage is used during the winter months in the UK. Using solar panels with battery storage offers an alternative power source, as they allow capturing energy from the Sun during daylight hours.
An example of solar energy usage could be powering lighting, tools and electric heaters in the workshop by using stored energy. This is useful especially compared to garden studios, DIY workshops and other outdoor facilities, where there is a considerable need for electricity throughout the year.
It is important to get the right battery storage system, which will be compatible with existing solar panels and the energy needs of the workshop. EcoFlow STREAM provides two options to consider: STREAM 5000, designed for solar generation and battery storage and STREAM AC 5000 for installation with already existing solar systems.
EcoFlow STREAM 5000 Solar Battery 5kWh: Storing Solar Energy for Regular Workshop Heating
EcoFlow STREAM AC 5000: Using Stored Solar Power in Existing Solar-Powered Workshops
How to Combine Solar Panels, Battery Storage and Electric Workshop Heaters
The use of solar panels in combination with battery storage, when it comes to heating the garage, garden workshops, and outdoor spaces, can lower the use of grid electricity. Solar panels function as a source of energy during the day, as batteries store excess energy for later use.
Here is how the system works.
Solar energy production: Solar panels produce electricity to power the electricity around the garage and household.
Energy storage: Battery storage is used to store surplus energy produced by solar energy.
Powering heating devices: Stored energy is used to power heating appliances, lighting, and tools.
Energy management: Energy usage is monitored and scheduled around the use of solar energy and energy tariffs.
For example, a homeowner stores the solar energy produced during the day and using it will be able to use his garage heater in the evening.
The device must have capacity equal to or greater than the needed power for the proper operation of the system.
The best electric heater for a workshop depends on the space, insulation, heating needs, and budget. If the wattage and power consumption of various heaters are known, a comparison between fan, ceramic, infrared and oil-filled heaters can help select the best electric workshop heater.
If you have electric heaters for garages and workshops, you can combine solar panels with a battery in order to secure an alternative method of managing energy needs. Look at the EcoFlow STREAM 5000 Solar Battery 5kWh option if you are yet to obtain a battery or solar source. Alternatively, look at the EcoFlow STREAM AC 5000 option if you already have the panels and are aiming to purchase a battery.
Find out how EcoFlow STREAM products can help you make use of renewable sources, minimise daily energy consumption, and save money on bills.
How Many Watts Do I Need to Heat a Workshop?
Heaters with a power of 1-1.5 kilowatts are enough for small insulated workshops. 2-3 kW is usually sufficient for ordinary garages or middle-sized workshops. Larger workshops require more powerful models based on some features, such as the height of the ceilings, insulation, and heat release.
Can I Run an Electric Workshop Heater on Solar Power?
Yes! Electric workshop heaters can work thanks to solar energy during the day, where the electricity produced by solar panels can be used for their operation. If batteries are added to the installation, excess energy will be accumulated for constant use. However, solar panels and batteries should correspond to the power consumed by the heater.
What Is the Cheapest Way to Heat a Workshop in the UK?
Using insulation, sealing draughts, thermostatic controls, and heating only the necessary areas are among the most efficient methods to save on workshop heating. Infrared heating could be beneficial for heat application, while solar energy systems may come in handy as a means of reducing the need for electricity from the grid.
Can a Portable Power Station Run an Electric Workshop Heater?
Yes, provided the power station can deliver sufficient continuous AC output, usable battery capacity, and the necessary connections. For example, a 2000W run for two hours means that 4 units of electricity must be generated. Always check the specifications of the equipment to be used and heaters.
Are Electric Heaters Safe for Wooden Workshops and Garages?
Yes, electric heaters can be operated in wooden workshops and garages without risk of hazards as long as the device is operated as per the manufacturer's instructions. Choose the equipment with a built-in overheat protection system that has both safety features and maintains a safe distance from wood and other combustible materials.
