Humidifier for Winter: Benefits, Best Settings & Usage Guide
Canadian winters can bring dry indoor air, especially when cold outdoor air enters your home and is heated by your furnace. As the air warms, its relative humidity decreases, which can leave your skin and nasal passages feeling dry. You may also notice static shocks when touching metal doorknobs or other surfaces.
A humidifier adds moisture to indoor air and can improve comfort when your heating system is running. However, choosing the right setting is important. If the humidity is too low, the air may remain uncomfortably dry. If it is too high, you may notice condensation on windows, fogged-up mirrors and mould growth in damp areas.
Why Should You Use a Humidifier during Winter?
In winter, houses usually lack relative humidity. Cold air holds less moisture, but once it is heated, its moisture-holding capacity increases, keeping the moisture content almost the same. But it makes relative humidity levels decrease, so a humidifier will help in this regard.
However, a humidifier is simply a comfort device. It will not act as a solution to poor heating, ventilation or indoor air quality. It will work better if you combine it with a well-maintained home.
How Does a Humidifier Help With Dry Winter Air?
A humidifier during winter will add steam or mist to your room, which will raise the relative humidity. Many people will notice less dryness inside once the moisture in the air is adequate. This can include dry skin, sore noses and static electricity.
But keep in mind that a humidifier is a comfort device that will maintain humidity levels but doesn't work for respiratory problems. If you continue to have concerns about your breathing, please talk to your health care provider.
Can a Humidifier for Winter Improve Home Comfort?
Yes! Balanced Humidity offers a subtle feeling of warmth and comfort to the living space. Many homes won't require a higher setting.
But excess humidity can lead to condensation on your windows. That is why it is essential to take care of your humidifier.
Humidifier-for-winters-settings-according-to-roomHumidifier-for-winters-settings-according-to-room
How Do You Set Your Humidifier in Winter?
There is no perfect setting. The correct setting will depend on how warm your home is, the weather outside, how well your home is insulated, how efficient your windows are, and how much moisture is in the air.
Instead of the dial on a humidifier, you can use a hygrometer. This is a cheap device that can tell you the relative humidity inside your home.
What Is the Ideal Indoor Humidity Level During Winter?
As a general rule, Health Canada recommends keeping your relative humidity between 30-50%. However, in colder months, try to maintain the humidity level of your space. Around 30-35% will help to avoid condensation on cold surfaces.
These are general recommendations, and you might have to make adjustments to your home, based on its construction and the temperature outside.
How Should You Adjust Humidifier in Winter Settings in Cold Weather?
If you are getting foggy windows, condensation on the glass, or damp window frames, then you are likely having too much humidity inside. Try adjusting the settings on your humidifier slowly. Over the next day or so check your hygrometer to see how your room is reacting.
What Happens if Indoor Humidity Is Too High or Too Low?
Low humidity can cause dry skin, irritation in the nasal passages and static. Too much humidity can cause condensation, mould and dust mites.
You want to try to get a balance. If you are having consistent issues with humidity, then look to improve your ventilation and the source of the humidity. To prepare for unexpected blackouts, consider these simple tips for preparing for a winter power outage while keeping essential household devices powered.
Can You Run a Humidifier During Winter Power Outage?
In Canada, winter storms, freezing rain and high winds can sometimes cause power outages. When electricity is interrupted, electric humidifiers, Wi-Fi routers, lights and other household devices may stop working. A portable power station can provide temporary backup power for compatible devices during an outage.
In this case, a portable power supply can help power the humidifier temporarily. But before purchasing, calculate the expected wattage your devices will draw using the power station, then check the maximum output capacity it provides and then calculate the battery hours given the load.
If you are not familiar with calculations for battery time, just divide the watt-hours by the total wattage of the desired devices you intend to power. Power losses of around 10-20% should be kept in mind so expect the battery time to be a little lower than the calculated one. To make it simple, let's take an example. If you are intending to use devices with a power consumption of around 100 watts and have a 1024 Wh battery, it will last almost 8 to 9 hours instead of 10 h.
Calculate the duration of your backup based on the size of the battery, the wattage of your appliances and the amount of energy you use in your backup power station.
Backup-battery-as-reliable-support-during-power-outageBackup-battery-as-reliable-support-during-power-outage
When You Need Higher-Capacity Backup During Extended Winter Outages
A high-capacity power supply will be required to run your basic devices like a fridge, humidifier, internet, light or phone chargers in case of longer power outages.
For higher wattage requirements at home the EcoFlow DELTA 3800 Gen4 is a great option. This has a large 3763Wh battery, 3600W continuous AC power and can be expanded to power multiple compatible devices.
This depends solely on the wattage of your appliances, the total wattage of the power supply and the battery. During a serious Winter Power Outage, you will always want to keep your home at a safe indoor temperature first.
1. Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
When You Need Backup Power for a Humidifier During Winter Short Outages
If you are out of town for a few hours and the power goes out for a short period. And you want to keep your small humidifier on, along with your Wi-Fi router, phones and lighting.
A great portable option for short power outages is the EcoFlow DELTA 3 Classic (1024Wh). It offers a 1024Wh battery and delivers up to 1800W AC. This can charge the devices of your choice.
1. 4 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging. 2. 1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2600W such as microwaves, refrigerators, laptops, and heated blankets. 3. 10ms Auto-Switch: Keep critical devices like NAS systems and servers running smoothly. 4. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
To spend your winter comfortably, install a humidifier in your place to avoid dryness. And make sure to have a hygrometer for adjusting the relative humidity levels when the weather changes. Regulate the humidifier regularly to guarantee that it is working safely and effectively.
Electric humidifiers require a power source. Having a suitable backup power source will be helpful during the winter months. The EcoFlow DELTA 3 Classic will work well during short disruptions. The EcoFlow DELTA 3800 Gen4 is perfect for high-capacity backup.
Get your home ready for the next winter storm with EcoFlow Canada’s portable power stations.
Should I use a humidifier in winter?
Yes. If your place is feeling dry, using a humidifier for winter helps. Often during the winter months the air is quite dry (low relative humidity) so adding some moisture back into the air will make it more comfortable. You can use a hygrometer to check if you actually need one, and keep your humidity levels at a balanced level.
How do I know if I need a humidifier in my house?
Signs you may need one are dry skin, a sore nose, static shocks and cracking wooden furniture. Use a hygrometer to measure the humidity levels in the most practical way. If your levels are consistently under 30% then your air is too dry.
How to tell if a house needs a humidifier?
Common signs include dry skin, scratchy nasal passages, frequent static shocks and cracking wood furniture. The most reliable method is to measure indoor humidity with a hygrometer. Below 30% humidity level in the air is considered too dry.
Is it okay to sleep with a humidifier every night?
Many people do as long as you keep your humidity at a balanced level and clean your humidifier regularly. Monitor the room to ensure you are not adding too much moisture. If you notice condensation on your windows then turn your humidifier down.
When should you not use a humidifier?
Don’t use your humidifier if there is already a suitable amount of humidity in your home, if you can see condensation on your windows or mould, or if you haven’t cleaned your humidifier.
How do I humidify my room without a humidifier?
Yes. You can hang your laundry to dry inside, put a bowl of water near a heat source or have a few houseplants. This will only add a little bit of moisture so it won’t be as controllable as a humidifier. Keep an eye on your hygrometer.
Home Solutions
