Propane Generator vs. Solar Generator: Which Should You Choose?
During a Canadian winter outage, the priority may be keeping the heat on. At a remote cottage, the challenge is finding reliable electricity where there is no grid connection. Propane and solar generators can help in both situations, but they work in fundamentally different ways. One burns fuel to produce electricity as you use it, while the other draws on energy stored in rechargeable batteries. To choose between them, compare the loads you need to power, how long they have to run, and how you will refuel or recharge. The sections below also cover noise, maintenance and everyday use at home, at the cottage and at a campsite.
How Do Propane Generators and Solar Generators Differ?
Because a propane electric generator burns fuel on demand while a solar generator draws on pre-charged batteries, the two perform quite differently in practice:
Feature
Propane Generator
Solar Generator
Energy Source
Liquid propane (LPG) tanks
Solar panels, wall outlets (AC), car chargers
Power Output
Output varies by model and connection
Output varies by inverter, battery and system design
Noise Level
Engine noise varies by model, load and placement
Low operating noise; fan sound varies with load
Emissions & Placement
Produces carbon monoxide; strictly outdoor use
No combustion exhaust; follow product instructions for location and ventilation
Maintenance
Regular oil changes, spark plugs, and filter checks
Minimal; keep battery charged and panels clean
Upfront vs. Ongoing Cost
Lower upfront cost; ongoing propane refills
Higher upfront cost; solar charging cost depends on the setup
Compare Power Output and Appliance Compatibility
Running wattage shows what a unit can supply continuously, while surge wattage covers the extra demand when appliances start. Propane generators can provide substantial running and surge output, making compatible models suitable for heavier loads. A properly sized high-wattage, dual-voltage model may support well pumps, central air conditioning or 240V electric heating equipment when its ratings and connection method match the load. Solar generators can handle refrigerators, Wi-Fi routers and smaller appliances, though several high-power devices running together may require a larger system.
Understand How Runtime and Recharging Work
With propane, runtime comes down to fuel supply, generator efficiency and electrical load. After a safe cylinder change or refuelling procedure, operation can continue while compatible fuel is available and the manufacturer’s instructions are followed. A solar generator is more like a reservoir, drawing on stored battery power until it needs recharging. Cloudy Canadian winter days can slow that refill.
Compare Fuel Requirements and Energy Availability
Planning propane for generators means considering cylinder availability, safe storage and refill access, which may be difficult during widespread outages. Solar panel recharging does not require combustion fuel, but it still depends on daylight, weather and the charging setup. Canada’s short winter days can sharply cut what your panels bring in.
Compare Noise Levels, Emissions, and Maintenance
Engine noise and carbon monoxide mean a propane generator must stay outdoors, at least 6 metres (20 feet) from homes and buildings, with exhaust directed away from doors, windows and vents or farther if the manufacturer’s guidance calls for it. Operating costs for gas and solar generators also differ: expect oil changes and other routine maintenance for combustion equipment. Solar units produce no combustion exhaust, generally create less operating noise and need battery care rather than engine maintenance; follow the product manual for indoor location and ventilation.
Evaluate Portability and Ease of Operation
Many propane generators are heavy enough to need a wheel kit, and cold-weather starting depends on the model, fuel system and manufacturer instructions. Portable solar generators may include handles or wheels and electronic starting, although weight and operating-temperature limits still vary by model.
EcoFlow DELTA 3000 Gen4 Portable Power StationEcoFlow DELTA 3000 Gen4 Portable Power Station
What Are the Advantages of a Propane Generator?
During a long Canadian winter outage, using a portable generator during a power outage requires planning for output, fuel and safe placement. A propane generator can deliver high output while compatible fuel is available. It may suit homes with larger electrical loads or properties where solar charging is unreliable for several days, provided fuel storage, outdoor placement and engine maintenance are managed correctly.
Supply Power for High-Wattage Appliances
When an ice storm hits and temperatures plummet, a properly sized propane generator may support high-draw equipment such as sump pumps, electric water heaters and full-sized deep freezers when the combined running and surge loads remain within its ratings and the electrical connection is appropriate.
Generate Electricity Without Relying on Sunlight
Canadian winters bring short days and heavy cloud cover, particularly from November through February. Because propane generators create electricity on demand from stored fuel rather than daylight, they can supply power at night or during cloudy conditions when the unit starts correctly and sufficient fuel is available.
Store Propane for Emergency Power Use
Propane can remain usable for long periods when approved cylinders are inspected, stored and handled according to supplier instructions and applicable rules. Store propane cylinders outdoors in an appropriate upright location away from living areas and ignition sources; never assume a cylinder is safe solely because it has been unused.
EcoFlow DELTA 3800 Gen4 Portable Power StationEcoFlow DELTA 3800 Gen4 Portable Power Station
What Makes a Solar Generator a Practical Alternative?
Not every power outage calls for a large fuel-powered generator. If your main concern is keeping the fridge cold, charging devices or running a few essentials overnight, a solar generator may be easier to live with. These units require less engine maintenance and produce no combustion exhaust. They can be used at a cottage or campsite when capacity, temperature limits, ventilation and placement follow the product instructions.
Operate Without Conventional Fuel
A solar generator avoids storing combustion fuel and produces no engine exhaust while supplying power. During an outage, it can support selected indoor essentials when the unit’s output, capacity, ventilation and placement requirements are met.
Recharge Through Multiple Power Sources
Beyond using solar panels, you can top up a solar generator’s battery directly from a standard household AC wall outlet. Take a setup like the EcoFlow DELTA 3800 Gen4 + 480W Portable Solar Panel as an example. On clear days, the panel can recharge the battery; once you are back home or connected to the grid, you can plug the unit into an AC outlet and recharge it for your next outing or storm. Having both options lets you skip ongoing propane refills and tank storage.
1. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 2. Compact Yet Powerful: The smallest and lightest portable power station in its class with 3-4kWh capacity and 3,600W output. 3. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery.
Support Camping and Outdoor Use
For weekend camping trips, provincial park stays, and RV travel, a solar generator offers low-noise power that complies with strict park quiet hours. A bundle such as the EcoFlow DELTA 3000 Gen4 + 2 × 160W Portable Solar Panel can suit trips like these when its capacity matches the planned loads. Having two separate solar panels lets you angle and reposition them around trees or shade at your site to capture the best available sunlight throughout the day. When camped far from electrical hookups, stored capacity and available solar input can support selected loads such as portable fridges, lights, coffee makers and camera gear.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output.
Can a Propane Generator and a Solar Generator Work Together?
Yes. During a longer Canadian outage, using both can give you more options. Run the propane generator to charge the power station, then turn it off and draw on that stored power without engine noise or burning extra fuel. Solar panels can provide additional charging whenever weather conditions allow.
Use a Propane Generator to Charge a Battery
Keeping a fridge and a few LED lights running does not mean the propane engine has to drone on all night. Run the fuel generator only for the time required by the power station’s charging specifications and the generator’s safe operating guidance. After charging, shut off the engine and use stored electricity for compatible indoor loads, following the power station’s placement and ventilation instructions.
Alternate Between Solar and Propane Charging
During multi-day outages, pairing the two gives you more ways to keep the battery charged. Use sunny afternoons to add solar charge; if snow or rain limits solar input, a compatible propane generator may recharge the power station when both products’ connection and safety instructions are followed.
Neither option is best for every situation. A propane generator may suit larger electrical loads or a Canadian winter storm that could leave you without power for several days, provided the model is correctly sized and sufficient fuel is stored and handled safely. For a shorter outage, a camping trip or a few essential appliances indoors, a solar generator is often the more convenient option: there is less noise and less maintenance to deal with. You can also pair them, using propane for an occasional battery recharge and stored electricity for routine backup power. Before deciding, add up the wattage of the appliances you want to run, estimate how long you will need them, and think practically about getting fuel or recharging during an outage.
How Long Will a 10,000 Watt Generator Run on Propane?
Runtime varies with generator efficiency, electrical load, ambient temperature, regulator requirements and cylinder or tank size. Use the manufacturer’s runtime table for the exact model and fuel setup, and ask a qualified propane supplier about cylinder sizing in cold weather. Plan safe shutdowns or cylinder changes rather than relying on a general hourly estimate.
Can a Solar Generator Power an Entire House in Canada?
Most standard portable solar generators cannot power an entire Canadian home simultaneously, especially with electric baseboards, furnaces or water heaters. High-capacity modular units can power critical circuits, such as those serving your refrigerator, gas furnace blower, sump pump, internet router and lights, through a properly installed transfer switch. Powering everything at once, rather than just selected circuits, calls for a permanently installed residential battery and rooftop solar array.
What Size Solar Generator Do I Need to Run a Refrigerator?
Choose a solar generator by checking the refrigerator’s measured energy use, compressor startup demand, required runtime and the power station’s continuous output, surge rating and usable battery capacity. Appliance labels are only a starting point; a plug-in energy meter can provide a more realistic daily consumption figure.
Do Solar Generators Work During a Power Outage?
They do, since their batteries already hold electricity when the grid goes down. Some units offer a UPS or backup mode, but transfer time and device compatibility vary by product. Check the manual for supported loads and do not treat a consumer power station as a substitute for a medically approved backup-power plan. Off-grid recharging still depends on available solar input or another compatible charging source.
Solar Generators
