Winter Camping Alberta Guide: Campgrounds, Glamping and Cold-Night Safety
Alberta looks different once the summer crowds leave. Campgrounds go quiet, snow muffles every sound, and the night sky feels closer. Winter camping in Alberta rewards people who plan well. It can also punish small mistakes, like a damp base layer or a heater in the wrong place. This guide covers where you can camp from November to spring and what winter glamping looks like. It also explains how to dress for real cold and how to add light and warmth without burning fuel in your shelter.
Where to Go Winter Camping in Alberta
Only a handful of campgrounds stay open once the snow arrives. The easiest ones sit close to a townsite, so help and supplies are never far away.
Banff National Park: Tunnel Mountain Village II and Lake Louise
Parks Canada lists Tunnel Mountain Village II as open year-round, with electrical sites near the Banff townsite.
The Lake Louise hard-sided campground is also open year-round with electrical sites, but tents and soft-sided trailers are not allowed. Most other Banff campgrounds worth booking early close in fall. The Banff camping dates on Parks Canada show which ones.
Winter Camping Jasper Alberta: Wapiti Winter Campground
For winter camping Jasper Alberta options, Wapiti is the one to know. The Parks Canada winter camping page for Jasper lists it from October 28, 2026 to early May 2027, with the closing date to be confirmed.
Sites: 40 electrical sites for RVs and trailers in Loop AA.
Services: Flush toilets, showers, a cooking shelter and drinking water.
Booking: First come, first served, with self-registration.
After the 2024 wildfire, Parks Canada asks visitors to follow all posted safety measures and closures. Confirm dates with the Jasper Information Centre before you go.
Waterton and Provincial Park Options
In Waterton Lakes National Park, the Pass Creek winter campground runs November 1 to April 30, weather permitting. It takes tents and RVs, first come, first served. There is no electricity and only primitive washrooms, but an enclosed shelter has a wood stove.
On the prairies, Dinosaur Provincial Park campground lists year-round power sites, reservable through Shop.AlbertaParks.ca. Alberta Parks also keeps Loop C at Elkwater in Cypress Hills open year-round, weather permitting.
Campground | Park | Winter status (verify before travel) | Power | Booking |
Tunnel Mountain Village II | Banff | Open year-round | Electrical | Reservable |
Lake Louise Hard-sided | Banff | Open year-round, hard-sided units only | Electrical | Reservable |
Wapiti Winter | Jasper | October 28, 2026 to early May 2027 | 40 electrical sites | First come, self-registration |
Pass Creek Winter | Waterton Lakes | November 1 to April 30, weather permitting | None | First come, self-registration |
Once you know where to go, the next step is staying warm safely.
Gear, Layering and Staying Warm Safely
Good gear matters more in winter than at any other time of year. The goal is to stay dry, stay off the cold ground, and never trade safety for heat.
Layering That Manages Sweat
Health Canada's extreme cold advice is to dress in layers with a wind-resistant outer layer. It also notes that you lose heat faster when wet.
Base layer: Snug merino wool or polyester that moves sweat away.
Mid layer: One or two layers of fleece or wool for warmth.
Shell: A wind-resistant jacket and pants.
Skip cotton, because it holds moisture. Shed a layer before you start sweating.
Sleeping Warm Through a Long Night
A lot of overnight heat loss goes into the snow beneath you. Stack a closed-cell foam pad under an insulated air pad, and use a bag rated for the lows. Simple habits for staying warm overnight help too, like eating a hearty dinner and keeping sleep clothes dry.
No Fuel Heaters Inside Tents
Carbon monoxide has no colour, smell or taste. The Health Canada carbon monoxide infographic lists camping stoves and barbecues among common sources. Health Canada also says portable butane stoves should never be used indoors or in confined spaces.
A tent is a confined space, so keep stoves, propane heaters and charcoal outside it. The Government of Alberta's carbon monoxide care instructions add generators and fires as sources. In an RV or cabin, keep a certified CO alarm near where people sleep.
Watch for these Health Canada cold injury signs.
Severe frostbite: Skin becomes discoloured and can turn black. Seek medical help.
Hypothermia: Shivering comes first, then clumsy movement and trouble speaking. Call for help.
Safe warmth often comes down to electricity rather than flame, which raises a practical question about power.
Powering a Winter Campsite Without Combustion
Electric bedding and LED lights add comfort without fumes. The catch is that batteries have temperature limits.
What a Power Station Can Realistically Run
A portable power station can run a low-wattage electric blanket, string lights, a laptop and phone charging.
To estimate energy use, multiply wattage by hours. A 60W blanket used for 8 hours needs about 480Wh, before conversion losses.
A 1,500W space heater would drain a 3kWh battery in about two hours. For a full rig, sizing camper and RV power starts with your daily watt-hours.
Cold Limits You Need to Plan Around
The two DELTA Gen4 models below charge only between 0°C and 45°C. They can discharge down to -10°C, and they do not self-heat. Alberta nights often drop well below that.
Keep the unit inside a heated RV, cabin or vehicle that stays within those limits. Charge it while it is warm, such as inside your RV at an electrical site.
For modest loads like a blanket, lights and devices, the DELTA 3000 Gen4 is a practical size. It accepts up to 1,000W of solar input.
For longer RV stays, the DELTA 3800 Gen4 adds more stored energy and up to 2,000W of solar input.
Both models run 120V devices only, and runtime always depends on what you plug in. If managing your own heat sounds like a lot, winter glamping is an easier start.
Winter Glamping Alberta: Softer Ways to Sleep Outside
Winter glamping in Alberta gives you the scenery with less setup. Someone else handles the shelter, and often the heat.
Comfort Camping in Alberta Parks
Only some Alberta Parks comfort camping options stay open in winter.
The Sir Winston Churchill cabins near Lac La Biche are a good winter pick. Cabins 6 to 15 are open year-round, with electric heat, lights and outlets. The winter rate is $150 per night.
Common Types of Winter Glamping
Private operators offer more choice, usually in a few common styles.
Type | What to expect | Things to ask before booking |
Heated cabins | Roofed shelter with beds and electric or wood heat | What bedding to bring and how far you park |
Heated canvas tents | Wall tents with a stove or heater set up by the operator | How heat is vented and whether a CO alarm is inside |
Planning for cozy cabin camping trips in Canada applies here, like packing bedding, food, warm boots and a headlamp.
Wherever you sleep, the drive and the weather still need a plan.
Road, Avalanche and Weather Checks Before You Go
Mountain highways can change fast in winter. A few quick checks can save you a long night on the road.
Road Conditions and Closures
511 Alberta road conditions show highway surfaces, closures, cameras and advisories across the province. On the Icefields Parkway, the Parks Canada winter driving page says snow tires or chains are required from November 1 to March 31.
The Parkway has no winter services and no cell service between its ends. Carry a winter car kit with a shovel, warm clothing, food and water.
Avalanche Awareness
Avalanche Canada publishes avalanche forecasts for the mountain parks through winter. Campgrounds are generally lower risk, but nearby snowshoe and ski routes can cross avalanche terrain.
Take avalanche skills training before leaving groomed areas. Rules for backcountry camping permits in Alberta also differ from frontcountry sites.
Weather Forecasts and Cold Warnings
Environment and Climate Change Canada issues extreme cold warnings, and its wind chill and cold weather page explains why wind chill matters.
Check | Where | When |
Road conditions | 511 Alberta | Before leaving and before returning |
Avalanche danger | Avalanche Canada forecast | Each morning you plan to leave camp |
Cold warnings | Environment and Climate Change Canada | The day before and the morning of travel |
Winter camping in Alberta works best when you start close to services. Tunnel Mountain Village II, Lake Louise and Wapiti all offer electrical sites. Layer to stay dry, insulate yourself from the ground, and keep fuel heaters out of tents. Check roads, avalanche forecasts and cold warnings before every trip. For quiet light and warmth, an EcoFlow DELTA 3000 Gen4 or DELTA 3800 Gen4 can help, kept inside a heated space.
Can you camp in Alberta in winter?
Yes. Tunnel Mountain Village II, Lake Louise hard-sided, Wapiti and Pass Creek all operate in winter. Some provincial parks also list year-round sites, often with reduced services.
Do you need a reservation for winter camping in Jasper?
No. Wapiti winter sites are first come, first served, with self-registration. Arrive early on busy weekends.
Is it safe to use a propane heater in a tent?
No. Fuel-burning heaters can produce carbon monoxide, which you cannot see or smell. Rely on insulated sleep gear or hot water bottles instead.
Will a power station work in freezing temperatures?
It depends on the model. The DELTA 3000 Gen4 and DELTA 3800 Gen4 charge from 0°C and discharge down to -10°C. On colder nights, keep them in a heated RV, cabin or vehicle.
What is winter glamping in Alberta?
It means staying in a heated cabin, wall tent, dome or hut instead of pitching your own shelter. Most options supply heat and bedding, but ask the operator how heat is vented and whether a CO alarm is installed.
