Backpacking Checklist: Essential Gear, Packing Tips, and Trail Power Options
Most backpacking trips don’t go wrong because of one big mistake. They go wrong because of a small one: a water filter left on the kitchen counter, a rain layer that stayed in the car, a headlamp with dead batteries. Out on the trail, one missing item can turn a good weekend into an unsafe one. On the flip side, a pack stuffed with “just in case” gear makes every kilometre harder than it needs to be.
That’s the case for packing smart: carry what you need, and not much more. This guide gives you a complete backpacking checklist covering shelter, clothing, food, water, navigation and safety.
Why You Need a Backpacking Trip Checklist
A checklist keeps you from forgetting what matters and from hauling what doesn’t. Writing out your backpacking trip checklist before you pack does two things. It catches the critical items while you’re still at home, and it makes you question every extra item before it goes in the bag. That second part is how most people end up with a lighter pack.
No two trips need exactly the same list. Trip length, terrain, season and distance from help all change what you carry. A July overnight near a trailhead is a different job from a shoulder-season route in the mountains, where nights can get frosty even when the days feel warm. Check your route and the forecast, then adjust the list below to fit.
Canada’s AdventureSmart program boils trail safety down to three steps: plan your trip and leave the plan with someone, get the training that matches what you’re doing, and carry the essentials. A good checklist covers that third step. If your trip is closer to a drive-in campground than a true backcountry route, our camping checklist is a better starting point.
Backpacking Gear Checklist: The Essentials
This backpacking gear checklist covers the core kit, grouped by category so you can tick items off as they go into the pack.
Backpack, Shelter, and Sleep System
  • Backpack: Size it to the trip. A smaller pack is often enough for one night, while multi-day trips usually call for something in the 50 to 65 L range.
  • Tent, tarp or hammock: Pick the lightest shelter that still handles the weather you expect.
  • Sleeping bag: Choose a temperature rating comfortably below the coldest night in the forecast.
  • Sleeping pad: It insulates you from the ground, so check the R-value. A higher R-value indicates greater resistance to heat loss into the ground.
  • Pack a rain cover or liner: Keeping your sleeping bag dry is especially important for warmth and comfort overnight.
Clothing and Footwear
  • Base layer: Wool or synthetic, worn next to the skin. Skip cotton because it holds moisture.
  • Insulating layer: A fleece or light puffy jacket for camp and cold mornings.
  • Rain shell: Pack it even when the forecast looks clear.
  • Hiking boots or trail shoes: Broken in well before the trip, not on it.
  • Moisture-wicking socks: Bring at least one spare pair.
  • Hat and gloves: Small items that make a big difference at night.
  • Spare dry layer: Keep it for camp and sleeping only, so you always have something dry to change into.
Adjust all of this for the season. Summer in much of Canada can also mean bugs, so a head net or bug repellent earns its space.
Camping-gear-at-a-hiking-trail-taken-by-two-personsCamping-gear-at-a-hiking-trail-taken-by-two-persons
Food, Cooking, and Water
  • Lightweight meals and snacks: Pack enough for every day, plus a little extra in case the trip runs long.
  • Stove, fuel, pot and utensils: Add a lighter as a backup to any built-in igniter.
  • Water bottles or a hydration bladder: Carry what the route’s water sources require.
  • Water filter or purification tablets: Treat water from lakes and streams, even when it looks clear.
  • Bear-safe food storage: Where it applies, use a canister, a food locker or a proper hang. Check what the park requires before you go, because rules differ by area.
Navigation and Safety
  • Map and compass: They don’t need batteries, and they back up your phone.
  • GPS or phone with offline maps: Download maps before you leave. Cell coverage is patchy or absent in much of the backcountry.
  • Headlamp with spare batteries: Carry it on every trip, including day-long ones that might run late.
  • First aid kit: Add blister care, since blisters are the most common trail complaint.
  • Multitool: Handy for repairs, food prep and first aid.
  • Fire starter: Keep it dry, and check for fire bans before you plan on using it.
  • Emergency whistle: Small, light and useful if you need to signal for help.
  • Sun protection: Sunscreen, lip balm and sunglasses.
On remote routes, a satellite messenger is worth considering as an optional extra.
Hygiene and Personal Items
  • Toilet kit and trowel: Follow the rules for where catholes are allowed. Some areas require you to pack waste out.
  • Hand sanitizer and toothbrush.
  • Biodegradable soap: A small amount, used well away from lakes and streams.
  • Trash bags: Leave No Trace means everything you carry in comes back out.
  • ID and permits: Many backcountry sites in national and provincial parks need a permit or reservation, so sort it out before the trip.
Ecoflow-portable-power-station-outdoor-camping Ecoflow-portable-power-station-outdoor-camping
How to Keep Your Devices Powered on the Trail
Your phone, GPS and headlamp are part of your safety kit, so it’s worth deciding how they’ll stay charged.
For most backpackers, a small power bank covers it. Portable power stations are a different category: they suit light camping, base camps and vehicle-based trips, not a pack you’re carrying for days. Think of them as an optional upgrade for the right kind of trip.
Portable Power for Light Camping and Short Trips
If you’re setting up a base camp, paddling or driving into a site, or heading out for a short trip where weight isn’t the main concern, a compact power station can keep phones, headlamps and cameras topped up. The EcoFlow DELTA 3 Classic fits that role. It’s built to be lightweight and portable, but at about 12 kg it still isn’t something to carry on a trek. If everything has to ride on your back, a power bank is the right tool.
EcoFlow DELTA 3 Classic (1024Wh)
1. 4 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging. 2. 1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2600W such as microwaves, refrigerators, laptops, and heated blankets. 3. 10ms Auto-Switch: Keep critical devices like NAS systems and servers running smoothly. 4. 30dB Whisper-Quiet Operation: Ultra-low noise ≤30dB at 600W. 5. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
Higher-Capacity Power for Car Camping and RV Trips
Some trips need more capacity: a week at a campground, an RV stop without hookups, or a longer base-camp stay with several people charging devices. The EcoFlow DELTA 3 Max Plus offers 2048Wh that can be expanded, and it can be charged with solar panels or an 800W Alternator Charger, both of which appear as bundle options on the product page. It’s vehicle and base-camp gear, not something to carry on the trail. For a fuller list of what to pack for this style of trip, see our best camping gear checklist for Canada.
EcoFlow DELTA 3 Max Plus (2048Wh)
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. 3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. 4. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
Backpacking Equipment Checklist by Trip Length
This backpacking equipment checklist is a toolbox, not a shopping list. Here’s how much of it you need as the trip grows.
Overnight Trip
Your backpacking trip packing list for one night stays short: shelter, sleep system, dinner, breakfast and a snack, a way to treat water, a headlamp, first aid, navigation and a rain layer. Add one dry layer for sleeping.
Leave the camp chair, the extra outfits and the full-size toiletries at home. If your overnight is really a drive-in campground stay, our guide on what to take camping covers that style better.
2-3 Day Trip
Add food for each extra day, plus a small buffer. Bring a spare pair of socks, a warmer layer, more blister care, and a paper map even if your phone has offline maps. Check your fuel for the extra meals.
A small power bank starts to make sense here if you’re navigating by phone and shooting photos. Many hikers end up carrying roughly 9 to 16 kg on a three-day trip, including food and water.
Multi-Day or Wilderness Trip
A wilderness backpacking checklist adds three things to the basics: resupply planning, redundancy and a power plan. Work out where food comes from after the first few days, whether that’s a town, a drop or just careful rationing. Double up on the critical items, such as a second way to treat water, a backup light and a backup way to navigate.
Add a repair kit and consider a satellite messenger. For power, size a power bank to cover your devices for the whole route, and leave a detailed trip plan with someone you trust. That’s why your backpacking trip packing list for a long route looks very different from an overnight one.
A good backpacking trip checklist covers shelter, clothing, food, water, navigation and safety, then trims itself to the trip in front of you. Pack for the route and the forecast, test your load at home, and cut anything that doesn’t earn its place.
If your trips include a base camp, a car-camping weekend or an RV stop, the EcoFlow DELTA 3 Classic and the EcoFlow DELTA 3 Max Plus are optional ways to keep your devices powered. Neither is gear to carry on the trail. Compare the two on our portable power stations page and pick the one that fits the way you travel.
What should be on a backpacking checklist?
A backpacking gear checklist should cover six areas: shelter and sleep system, clothing and footwear, food and cooking gear, water treatment, navigation and safety items, and hygiene essentials. Add permits and ID, then adjust the list for trip length, season and distance from help.
What are the 10 essentials for backpacking?
The 10 essentials are a standard safety checklist: navigation, sun protection, insulation, light, first aid, fire, repair tools, extra food, extra water and emergency shelter. Canada’s AdventureSmart program encourages carrying them on every outing, along with a trip plan and the right training.
How much should my backpack weigh?
A common rule of thumb is about 20% of your body weight, loaded. Many hikers on a three-day trip land between roughly 9 and 16 kg, including food and water. Bear canisters, cold weather and long dry stretches all push that number up.
What should I pack for a 3-day backpacking trip?
Your backpacking packing list for three days should include shelter, sleep system, stove and fuel, three days of food plus a buffer, water treatment, a rain shell, an insulating layer, spare socks, first aid, navigation tools, a headlamp, hygiene items and permits. Keep clothing to one hiking outfit and one dry set for camp.
What do I need for a wilderness backpacking trip?
A wilderness backpacking checklist starts with everything on the standard list, plus backups. That means a second water treatment method, extra light, a repair kit, paper maps and a way to call for help if you’re out of cell range. Plan resupply points, check park rules for food storage and fire restrictions, and leave a trip plan with someone.
What should I not bring on a backpacking trip?
Skip camp chairs, extra outfits, full-size toiletries, glass containers and heavy electronics. Strongly scented items can attract wildlife, so keep them out of camp or sealed up. Leave fireworks and anything else your park prohibits at home.
