Ice Fishing in Saskatchewan: Best Lakes, Fishing Rules, and Winter Essentials
Saskatchewan is home to some of the most celebrated ice fishing waters in the world. Tobin Lake produced a world-record walleye, and that kind of reputation draws anglers from across the country every winter. Wide prairie lakes,a wide variety of fish species, and affordable shack rentals make the province easy to love, whether you're a seasoned angler or planning a first trip.
This guide covers the best ice fishing spots, the key regulations to know, how to find derbies, and how to stay warm and keep your electronics running through a long day on the ice. If you're still building your kit, our ice fishing gear guide for Canada is a good companion read.
Why Ice Fish in Saskatchewan?
Saskatchewan's reputation rests on its records and its variety. Beyond the Tobin Lake walleye, Lake Diefenbaker has produced world records for both rainbow trout and burbot. Anglers can chase walleye, perch, pike, burbot, whitefish, and more, often within a short drive of Regina or Saskatoon.
If you don't own a shelter, rentals are a practical way to fish in comfort. A heated hut lets you focus on the bite instead of the wind chill, and it keeps costs reasonable for families and groups.
Best Ice Fishing Spots in Saskatchewan
The lakes below offer a good mix of species, scenery, and access. Each one suits a slightly different kind of trip, from a quick day outing to a weekend away. Looking at other provinces too? See our Lake Winnipeg ice fishing guide.
Tobin Lake
Tobin Lake is a reservoir about 34 km northeast of Nipawin and the site of the 2005 world-record ice-fishing walleye catch, which weighed 18.30 lb. Anglers can target walleye, sauger, yellow perch, northern pike, lake sturgeon, goldeye, whitefish, and burbot. Shack rentals run around $70 per person per night, so it works well for an overnight stay.
Lake Diefenbaker
Lake Diefenbaker stretches about 225 km with roughly 800 km of shoreline, sitting 133 km south of Saskatoon. It is the largest body of water in southern Saskatchewan and holds 26 native and stocked species. It's also the source of the world records for rainbow trout and burbot, so there is real trophy potential.
Qu'Appelle Lakes
The four Qu'Appelle lakes, Pasqua, Echo, Mission, and Katepwa, sit only 75 km from Regina, which makes them ideal for a day trip. Expect walleye, yellow perch, northern pike, tullibee, and burbot. Their closeness to the city means you can be on the ice shortly after breakfast.
Last Mountain Lake
Last Mountain Lake, also called Long Lake, is a 93 km prairie lake about 40 km northwest of Regina. It is one of the better walleye fisheries in the area, with perch, pike, burbot, whitefish, and cisco rounding out the catch. Winter shack rentals run around $90 a night.
Person-ice-fishing-on-a-snow-covered-frozen-lake-with-fishing-equipment Person-ice-fishing-on-a-snow-covered-frozen-lake-with-fishing-equipment
Saskatchewan Ice Fishing Regulations
Know the rules before you drill your first hole. The main points are:
  • A valid Saskatchewan angling licence is required, with exceptions for youth under 16, resident seniors, and treaty food fishing.
  • Respect catch limits, closed waters, and closed seasons.
  • Anglers may use up to two lines while ice fishing in Saskatchewan. Both lines must remain within sight and within 25 metres of the person using them.
  • Do not use lights, firearms, or chemicals to catch fish.
Regulations change, so check the official Saskatchewan angling regulations for the current season's details before you go.
Ice Fishing Derbies in Saskatchewan
Derbies are an important part of the culture of ice fishing in Saskatchewan, mixing friendly competition with community spirit. Watch local tackle shops, tourism websites and community postings as events are announced to find out ice fishing derby Saskatchewan dates 2026, locations and how to enter. Check with the organizers before heading over.
Staying Warm and Powered on the Ice
Long hours on the ice demand both warmth and power. Fish finders and sonar run all day, and phones, GPS units, lights, and heaters add to the load. Cold also cuts battery efficiency, so plan for 20-30% more capacity than you think you need, and keep batteries insulated and off the ice. For a deeper look at the electronics side, read how to power ice fishing electronics.
Powering Heated Ice Fishing Shelters and High-Demand Equipment
For shelter-based fishing, the EcoFlow DELTA 3 Max Plus is a high-capacity option. It offers 2,048Wh of capacity and 3,000W of rated output, with expandable capacity from 2 to 10kWh and fast recharging through several methods. That headroom suits electric heaters, fish finders, lights, and kettles across a full day, and solar panels can provide top-ups on bright winter days.
It weighs around 22kg, so it's best suited to vehicle-based setups rather than long hikes. Size the unit to your actual loads, and have heating appliances checked for compatibility. Runtime depends on what you connect, so avoid assuming a fixed number of hours.
1. 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W 2. Expandable with compatible EcoFlow extra batteries and supports up to 1,000W solar input. 3. 2-10kWh Expandable Capacity: Easily scale up and achieve longer runtime with an EcoFlow Smart Generator
Keeping Fish Finders and Essential Electronics Charged on Day Trips
For day trips and lighter setups, the EcoFlow DELTA 3 Classic is the more portable choice. It provides 1,024Wh of capacity and 1,800W of output, with a 3,600W surge and X-Boost support up to 2,600W. At 12.1kg, it's easy to carry to the ice, and it charges by AC, solar, car, or generator.
It's a good match for fish finders, phones, cameras, and LED shelter lights. As always, match the unit to your devices' real power draw instead of expecting a set runtime.
1. 1,024Wh LFP battery, 1,800W rated AC output (3,600W surge), and a lightweight 12.1kg design. 2. Supports X-Boost technology for compatible appliances up to 2,600W. 3. Charges through AC, solar (up to 500W), car, or compatible generator connections.
Ice Safety Tips
No ice is ever completely safe, so build good habits:
  • Check ice thickness near shore and along your walking routes before heading out.
  • Carry ice picks, a throw rope, and flotation aids.
  • Wear high-visibility clothing.
  • Never fish alone as a beginner.
  • Tell someone where you're going and when you plan to return.
  • Dress in warm layers with insulated boots.
Saskatchewan delivers world-class ice fishing, from Tobin Lake's record walleye to the easy day trips of the Qu'Appelle Lakes. Follow the regulations, check ice conditions, and plan for warmth and power so your time on the ice is comfortable and safe. When you're ready to build your setup, explore the DELTA 3 Max Plus and DELTA 3 Classic to find the EcoFlow portable power station that suits your ice fishing setup.
Where is the best ice fishing in Saskatchewan?
Tobin Lake, Lake Diefenbaker, the Qu'Appelle Lakes, and Last Mountain Lake are all top picks. The best choice depends on your target species and how far you want to travel.
Do I need a licence for ice fishing in Saskatchewan?
Yes, most anglers need a valid Saskatchewan angling licence. Exceptions include youth under 16, resident seniors, and treaty food fishing. Check the official regulations.
What fish can I catch ice fishing in Saskatchewan?
Walleye, perch, northern pike, burbot, and whitefish are common. Some waters also offer sauger, sturgeon, tullibee, and rainbow trout.
Are there ice fishing derbies in Saskatchewan in 2026?
Derbies are a popular tradition. Check local tackle shops, tourism sites, and community listings for dates and entry details as they're announced.
How thick should the ice be for ice fishing?
Thickness needs vary with ice quality, weather, and what you're bringing onto the ice. Check conditions locally, test as you go, and follow current guidance from local authorities.
How do I stay warm while ice fishing?
Wear warm layers and insulated boots, and use a shelter out of the wind. A heater can help if it's used safely and matched to your power source.
What power do I need for ice fishing electronics?
It depends on your devices. Add up their real power draw, allow 20-30% extra for cold-weather losses, and choose a power station that fits. You can check the electronics power guide for more information.
Outdoors
