Camping in the Gulf Islands, BC: Campgrounds and Trip Planning
For camping in the Gulf Islands, BC, choose your campsite by access, water, and booking rules. You can camp beside your vehicle, walk your gear from parking, or reach remote sites by water.
This guide covers the Southern Gulf Islands, including Salt Spring, Galiano, Pender, Mayne and Saturna. BC Parks, Parks Canada and private operators run different campgrounds, so one booking system won't cover them all.
Compare the sites below, then match your campsite dates with ferry sailings and the final journey to camp.
Where Should You Go Camping in the Gulf Islands, BC?
Plan Gulf Islands camping around how you'll reach the tent site, then choose an island. Road access helps when you bring bulky gear, while a walk-in site means carrying everything from the parking lot.
Water-access sites need a separate marine plan, suitable skills, and safe conditions. When choosing a tent campsite, weigh the full journey against the comfort you want. A shoreline view won't shorten a steep return climb.
Count your water and camping gear before adding power equipment to that carry. Phones and a headlamp may need only a compact power bank. Road access alone doesn't mean your site has electrical hookups.
For compatible plug-in gear on a vehicle-based trip, consider the EcoFlow DELTA 3 Classic (1024Wh). Its 1,024 Wh capacity stores energy, while its 1,800 W rated AC output sets the combined running-power limit.
At about 12.1 kg, it's a planned carry, not an ultralight backpacking choice. Keep it dry, leave its vents clear, and follow its operating limits.
1. 1,024Wh LFP battery, 1,800W rated AC output (3,600W surge), and a lightweight 12.1kg design. 2. Supports X-Boost technology for compatible appliances up to 2,600W. 3. Charges through AC, solar (up to 500W), car, or compatible generator connections.
Which Gulf Island Campgrounds Fit Your Trip?
Compare Gulf Island campgrounds by the last leg to your site, not just the island name. These options have different operators and water arrangements, which affect both booking and packing.
Campground
Island and Operator
Campsite Access
Booking Path
Water Plan
Ruckle Park
Salt Spring, BC Parks
Walk-in tent area and separate vehicle sites
BC Parks, chosen site category
Seasonal system, check notices
Montague Harbour Marine Park
Galiano, BC Parks
Vehicle and walk-in options
Confirm current supply
Prior Centennial
North Pender, Parks Canada
Road access
Parks Canada
Potable water listed, check notices
Mayne Island Camping
Mayne, private operator
Walk-in tents, separate parking
Private operator
Confirm drinking-water supply
Shingle Bay
Walk-in or water access
Parks Canada reservation
Bring drinking water
Narvaez Bay
Saturna, Parks Canada
Ruckle and Montague Harbour for Shoreline Camping
Choose Ruckle for its coastal meadow setting, but check where your vehicle must stay. The Ruckle Park map and notices distinguish the walk-in tent area from vehicle camping. Carrying gear to an ocean-facing tent site is different from unloading beside your car.
On Galiano, Montague Harbour Marine Park has vehicle-accessible and walk-in choices. Check the specific site before booking, and arrange transport from the ferry terminal. Stay on marked paths and leave shells and cultural features undisturbed.
Prior Centennial and Mayne Island Camping for an Island Base
Prior Centennial gives you a road-access base on North Pender. Parks Canada's campground details list potable water and pit toilets. Check service notices rather than assuming every facility runs throughout the year.
Mayne Island Camping is a private, walk-in tent campground with parking separate from the sites. Book through the operator, and confirm drinking-water arrangements before leaving. Even a short path becomes a bigger task when you carry water, food and wet-weather gear together.
Shingle Bay, Narvaez Bay and a Water-Only Alternative
Shingle Bay and Narvaez Bay suit trips where you're ready to bring drinking water and carry your kit. Parks Canada lists both backcountry campgrounds as reservable, with pit toilets but no potable water.
Shingle Bay has a steep 0.24 km descent from parking, which you'll climb on departure. Narvaez Bay has a 1.7 km walk from the gate. Pack for the actual route rather than treating both as the same walk-in experience.
Dionisio Point Park on Galiano is another option for experienced marine travellers. Access is by water only. Its private road is gated, and campsites aren't reservable. Check its seasonal water advisory and marine conditions before committing.
Campers carry backpacks and water along a forest path to a tent site.Campers carry backpacks and water along a forest path to a tent site.
How Do You Book Campsites and Plan Ferry Travel?
Book a campsite and ferry journey that work for the same arrival and return dates. Before camping in the Gulf Islands, check all four parts of the trip.
  1. Identify the operator and site type. BC Parks, Parks Canada, and private campgrounds use separate systems.
  2. Check campsite dates and terms. BC Parks frontcountry reservations use a three-month rolling window. Parks Canada sets its own reservation launches, while private operators set their own terms.
  3. Match the ferry route to your travel dates. Check both directions, any transfers, and whether your sailing accepts advance bookings.
  4. Arrange the final journey to camp. Allow time to collect gear, reach the site, and carry it in. Plan the return transfer too.
BC Ferries accepts advance foot-passenger bookings on Tsawwassen–Southern Gulf Islands routes. That doesn't mean every island route has the same booking options. Use the current sailing details for your itinerary, including its check-in requirements.
If ferry space is limited, let the available sailings shape your campsite dates. Read cancellation terms before paying, and save your confirmations offline.
A first-come, first-served plan still needs a lawful backup if the campground fills. Arriving on the island doesn't secure a site or make the walk from the terminal practical.
Campers with backpacks wait at a coastal ferry terminal.Campers with backpacks wait at a coastal ferry terminal.
When Can You Camp in the Gulf Islands?
Your Gulf Island camping dates must match the campground's season, services, and transport. Parks Canada lists its frontcountry season as May 15 to September 30. Provincial and private campgrounds need separate checks.
Backcountry access doesn't promise regular upkeep. Parks Canada says its backcountry sites aren't regularly maintained from October 1 to May 14. Closures still override general access dates.
Water can also stop before access ends. Ruckle's water system shuts down from November 1 to March 15. Check notices again before departure, and confirm the reservation launch for your trip year rather than using an old date.
What Should You Pack and Which Rules Apply?
Pack for camping on the Gulf Islands using the facilities and carrying distance you've confirmed. Put water, shelter, and a lawful cooking plan ahead of comfort extras.
Build your kit around these needs, then use a camping gear checklist to check the rest.
  • Water and food. Bring clean containers and enough drinking water for sites without a supply. Plan meals, food storage, and how you'll pack out waste.
  • Shelter and warmth. Pack a rain layer, a suitable tent, an insulated sleeping pad, and sleep gear for the forecast.
  • Cooking and lighting. Check stove rules and current restrictions, then bring a permitted cooking kit and headlamps.
  • Navigation and backup plans. Save maps, bookings, and contact details offline, and leave your trip plan with someone.
Don't assume that a nearby stream is safe drinking water, or that a camping filter treats seawater. Ask the operator if a water notice changes your plan.
An unserviced campsite still has rules. An app pin, empty beach, or parking space doesn't give overnight permission. Use designated sites, keep noise down, and protect plants and cultural features.
In Gulf Islands National Park Reserve, backcountry campfires are prohibited, including beach fires. Provincial parks and private campgrounds have their own restrictions. Check the rules for your site and cooking appliance before packing fuel.
 Water containers, rainwear, a headlamp, and camping gear ready for packing. Water containers, rainwear, a headlamp, and camping gear ready for packing.
How Should You Plan Power for Island Camping?
Start with the devices you need, then check their energy use and what you can carry. Watts (W) measure power, while watt-hours (Wh) measure energy used over time.
This hypothetical two-day example shows a small charging and lighting plan, not a product runtime test.
Device
Assumed Use
Two-Day Energy
Two Phones
15 Wh per recharge, once per phone daily
60 Wh
LED Lights
5 W for four hours daily
40 Wh
Total
Before losses or reserve
100 Wh
At an assumed 80% delivery efficiency, that needs about 125 Wh of stored energy before a separate reserve. Actual losses vary, and this modest plan may only need a compact power bank.
A fridge needs its own measured daily energy estimate, plus checks for startup power and other simultaneous loads. For a vehicle-based stay with greater needs, the EcoFlow DELTA 3 Max Plus (2048Wh) combines 2,048 Wh capacity with 3,000 W rated AC output. At about 22.1 kg, it needs a handling plan and dry, ventilated placement. Capacity alone doesn't promise a set runtime or an RV connection.
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. 3. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. 4. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
Charge before leaving, follow the unit's temperature limits, and confirm permission for any recharge stop. Don't count on a shop outlet or a panel's rating to supply daily energy. Shade, cloud, and placement affect solar charging.
Finalise Your Campsite and Ferry Plan
Choose one campground that matches your transport and carrying limits, then confirm its water supply and notices. Align your campsite booking, ferry sailings and final transfer before packing for the trip. Keep a lawful backup plan if your first choice depends on arrival-day availability.
If your trip needs more power than a pocket battery can provide, compare EcoFlow's portable power stations against your devices, carrying limits and planned setup.
What are some campgrounds located on the Gulf Islands?
Options include Ruckle on Salt Spring, Montague Harbour on Galiano, and Prior Centennial on North Pender. For walk-in tents, compare Mayne Island Camping with Narvaez Bay on Saturna, which also has water access.
What does FF mean in camping?
If a listing uses FF for first-come, first-served, sites are allocated on arrival rather than held by reservation. Check the listing's legend because FF isn't universal, and neither FF nor the common abbreviation FCFS guarantees a vacancy.
Is boondocking legal in BC?
It can be allowed on eligible provincial Crown land, subject to land status and restrictions. That isn't blanket permission to camp on Gulf Islands beaches, park land, or private property, so check the exact location's rules first.
Can you camp on the Gulf Islands without a car?
Yes, if you match ferry travel with confirmed local transport and a manageable final carry. Water-only sites need a separate marine plan, not just a foot-passenger ferry ticket, so check the whole route before booking.
Outdoors
