Camper and RV Power Guide: Matching Your Rig to the Right Setup
Buying or renting a camper or RV in Canada means choosing between very different rigs, from compact camper vans to full-size fifth wheels. Each one has its own power needs. Some trips only need a weekend of battery power, while others call for solar, a generator, or a mix of everything. This guide explains how shore power, generators, solar, and batteries work together. It will help any camper and RV owner avoid dead batteries, wasted fuel, and an oversized system they never fully use.
Why Every Camper and RV Type Needs a Different Power Plan
A Class A motorhome and a tent trailer draw power in completely different ways. Bigger rigs run more appliances at once, while smaller campers often just need lights, a fan, and a phone charger. That is why a one-size-fits-all power plan rarely works.
Motorhomes Versus Towables
Motorhomes (Class A, B, and C) carry their own engine and often a built-in generator. Towables, including travel trailers, fifth wheels, truck campers, and tent trailers, rely on the tow vehicle, shore power, or whatever battery system you add. Knowing the different classes of recreational vehicles makes it much easier to estimate realistic power draw before you shop for equipment.
Rig Type
Typical Power Profile
Good Starting Point
Class A motorhome
Many appliances running at once, often AC and a residential fridge
Large, expandable battery plus solar or generator
Class C motorhome
Moderate loads, family use
Mid to large battery with solar
Class B camper van
Compact loads, frequent moves
Compact battery with solar or vehicle charging
Travel trailer / fifth wheel
Varies widely by size and appliances
Battery sized to the appliance list
Tent trailer / truck camper
Light loads: lights, fan, devices
Small battery, optional solar
Once you know roughly what kind of rig you are powering, the next step is understanding which power sources make sense for it.
Comparing Your Power Options: Shore Power, Generators, Solar and Batteries
Shore Power, Solar and BatteriesShore Power, Solar and Batteries
Most campers and RVs end up relying on more than one power source. Each one has a clear role. Shore power is simplest at a campground, a generator fills the gap away from hookups, and solar with a battery runs quietly with no fuel.
Shore Power
Serviced campsites supply power through a pedestal on the site. Service levels vary by campground. At Fundy National Park, for example, Parks Canada offers 15 to 30 amp service on two-way sites and 15 to 50 amp service on three-way sites. Check that your rig's plug matches before you book. An adapter lets a 30 amp rig plug into a lower-amp outlet, but you will need to run fewer appliances at once. Trying to run the air conditioner and microwave together on a reduced supply is the fastest way to trip the pedestal breaker.
Generators
Generators recharge quickly and handle heavy loads, but they need fuel and make noise. Many Canadian campgrounds now restrict when you can run one. Generator hours vary by campground. For example, some Alberta Parks locations allow generators only during designated daytime hours. Jasper National Park campgrounds may have restricted generator hours, so check current Parks Canada rules before travelling.
If you still want one, sizing a generator for your camper correctly matters as much as choosing it, since wattage should match your actual appliance list.
Solar and Battery
A solar and battery setup is silent, fuel-free, and unaffected by generator hours. Its limits are sunlight and battery capacity. Portable panels also have an edge over roof-mounted ones at the campsite. You can move them into the sun while the rig stays parked in the shade, and angle them at roughly 30 to 45 degrees toward the sun for better output.
Power Source
Best For
Limitations
Shore power
Serviced campgrounds and RV parks
Only available at hookup sites
Generator
Backup power, larger appliances, quick recharge
Fuel, noise, maintenance, and time restrictions
Solar + battery
Quiet, fuel-free power for boondocking
Depends on sunlight and battery size
Among these options, solar and battery systems are the quietest solution for overnight use when generator hours are restricted and shore power is unavailable. Its two limits, sunlight and battery size, are also the two you can plan around. An expandable battery like the EcoFlow DELTA 3 Ultra Plus handles the storage side, and the EcoFlow 400W Portable Solar Panel refills it each sunny afternoon.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•3,600 W Powerful Output: 7,200 W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4,600 W such as clothing steamers, lawnmowers, and electric frying pans. • Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. • 3-11 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • 6 Ways to charge, Ready in Just 48 Mins: Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging
The 400W Portable Solar Panel uses monocrystalline cells with up to 23 percent conversion efficiency. It folds into one piece, and its protective case doubles as an adjustable stand for angling toward the sun. An IP68 rating means it keeps working in rain, and the panel weighs about 16kg. It is the fuel-free way to recharge the battery above during multi-day dry camping.
•High-Input Solar Charging: Delivers up to 400 W of high-capacity solar input for significantly faster recharge times. •Up to 23% Conversion Rate: Utilizes premium solar cells to capture maximum sunlight and convert energy efficiently. •Durable & Weather-Resistant: Built with multi-layered protective materials and an IP68 waterproof rating for rugged outdoor use. • Self-Supporting Adjustable Design: Includes a protective carrying case that doubles as a kickstand to optimize sunlight angles. • Compact One-Piece Folding Frame: Folds down cleanly for convenient transport and seamless storage. • Included XT60 Cable: Comes bundled with the standard solar-to-XT60 charging cable for immediate plug-and-play setup.
With the core options and equipment covered, the next question is how much system you actually need.
Sizing Your Setup for Boondocking and Dry Camping
Dry camping without hookups is where power planning matters most. Every watt has to come from what you carry. The right size depends on days off-grid, what you run, and how much sun your route gets.
A Simple Three-Step Method
  1. Add up daily appliance use in watt-hours (watts multiplied by hours used).
  2. Compare that total with your battery's usable capacity.
  3. Size solar input to replace what you use on a sunny day.
Here is a worked example with round numbers:
Device
Watts
Hours per Day
Watt-Hours
LED lights
20
5
100
Roof fan
40
8
320
12V fridge
50
10
500
Phones and laptop
60
3
180
Daily total
1,100
A 3,072 Wh battery would cover this example for about two and a half days with no charging. Adding solar stretches that further on clear days. Real appliance draws vary, so check the labels on your own gear. For a closer look at maths, this breakdown of how many solar panels boondocking requires walks through the calculation step by step.
Sizing the system properly also means thinking beyond a single trip, especially with Canada's seasonal weather.
Seasonal and Practical Considerations for Canadian RV Owners
off-grid rv poweroff-grid rv power
Canadian camping season brings its own power challenges. Shoulder-season trips can start warm and end near freezing. Any system left unprotected over winter risks damage well beyond the electrical setup.
Cold-Weather Battery Performance
Battery output and charging efficiency both drop in the cold. Many lithium batteries also should not be charged below freezing unless they include built-in heating. Keep your power station inside the heated living space when temperatures drop, and check its charging temperature range in the manual.
Off-Season Storage
Treat the electrical system as part of your fall readiness checklist. Store your power station partly charged in a dry, temperate spot, and top it up every few months. Those steps pair naturally with winterizing an RV for Canadian conditions, which covers the tank and antifreeze side of the job.
Carbon Monoxide Safety
If your setup includes a fuel generator, keep it outside and away from windows, vents, and doors. Make sure your RV has a working carbon monoxide alarm. A battery-based system avoids that risk entirely.
The right camper and RV power setup comes from matching your rig, your trips, and your budget rather than copying someone else's system. Shore power, generators, and solar with a battery each solve different problems, and most owners use a mix. Campground generator limits make quiet power more valuable every year. Starting with an EcoFlow power station and solar panel gives you a flexible, fuel-free base that grows with longer, more remote trips.
Do I need solar panels if my camper or RV already has a battery?
Not always. A single battery works well for short trips or campgrounds with shore power. Solar becomes useful once you spend several days off-grid.
What size generator do most RVs and campers need?
It depends on your appliance list rather than the size of your rig. Add up the running and starting watts of everything you plan to use at once.
Is a generator or a solar and battery setup better for a camper?
Generators recharge quickly and handle heavy loads, but they need fuel and many campgrounds restrict their hours. Solar and battery setups run quietly at any hour, though they depend on sunlight and capacity.
Can I use the same power setup for a travel trailer and a Class A motorhome?
Not usually at full scale. A motorhome runs more appliances at once and benefits from an expandable battery like the EcoFlow DELTA 3 Ultra Plus. A smaller trailer can often run on a modest setup.
Does cold weather affect my RV's battery or power station?
Yes. Output and charging efficiency both drop in the cold, and many lithium batteries should not be charged below freezing. Keep your power station in the heated part of the rig.
RV and Motorhomes
