What Is Hydropower and How Does It Actually Generate Electricity?
Hydropower is one of the oldest and largest renewable energy sources on the planet, and Canada is one of the biggest producers of it in the world. Yet if someone asked you to explain exactly how a river turns into electricity, most people would struggle to answer.
This guide breaks down what is hydropower in plain language, walks through how it works step by step, looks at why it plays such an outsized role in Canada's electricity mix, and answers the question a lot of homeowners eventually ask: could you ever generate something like it at home?
What Is Hydropower?
At its simplest, hydropower is electricity generated by turbines that convert the energy of moving or falling water into mechanical energy, and then into electrical energy. Water flows or falls through a structure, spins a turbine, and the turbine drives a generator that produces power.
It is also one of humanity's oldest energy technologies. Long before anyone thought about electricity, moving water was used to turn wheels that ground grain and powered early machinery. Hydropower simply took that same basic idea, a wheel spun by water, and connected it to a generator instead of a millstone. That same core principle, storing and converting energy to power a home or a grid, is also what modern portable power stations do on a much smaller, personal scale. If you have ever wondered what hydropower energy actually is at its core, that is it: kinetic energy from water converted into usable electricity.
That simple idea, moving water spinning a turbine, is the basis for every hydropower plant, so it is worth walking through the actual process.
How Hydropower Actually Generates Electricity
The mechanics behind hydropower are more straightforward than most people expect:
  1. Water is stored or collected at elevation. A reservoir, dam, or natural river gradient holds water at a height above the powerhouse.
  2. The water is released through a penstock. This is a large pipe or tunnel that channels the water downward under pressure.
  3. Falling or flowing water spins turbine blades. The force of the moving water pushes against the blades, causing the turbine to rotate.
  4. The turbine drives a generator. That rotation is converted into electrical energy, which then flows into the grid.
Not every hydropower plant looks the same, though. There are four common types worth knowing:
  • Run-of-river: Uses the natural flow of a river with little to no storage, generating power continuously as water passes through.
  • Storage (dam or reservoir): Holds back large volumes of water behind a dam, allowing operators to control output based on demand.
  • Pumped storage: Works like a giant rechargeable battery, pumping water uphill during low-demand periods and releasing it to generate power when demand rises. If that idea of storing energy for later sounds familiar, it is the same logic behind choosing the right inverter battery for a home energy setup, just built at a massive, grid-scale level.
  • Offshore or tidal: Captures energy from ocean tides and currents rather than rivers, an emerging category in the renewable space.
So what is hydropower energy used for in practical terms? Mostly large-scale electricity generation for homes, businesses, and industry, delivered through the regular grid rather than anything a household manages directly.
Understanding the mechanics also explains why hydropower plays such an outsized role in Canada specifically.
Hydropower in Canada
what is hydropower energy used forwhat is hydropower energy used for
Canada is one of the largest hydropower producers on Earth, consistently ranked among the top three globally. According to Statistics Canada, hydroelectricity remains the country's single-largest source of generation, supplying just over half of Canada's total electricity in 2025. In a typical year without drought conditions, that share has historically run closer to 55 to 60 percent, according to Natural Resources Canada, though exact figures shift year to year with rainfall and snowpack.
Geography is the main reason this works so well here. Canada has an enormous network of rivers, along with the elevation changes needed to create the kind of pressure that spins large turbines efficiently. Provinces like Quebec, British Columbia, and Manitoba, in particular, sit on terrain that makes large-scale hydro development far more viable than in flatter, drier regions of the world.
That heavy reliance on hydro also shapes how Canadians experience electricity pricing day to day, since supply, demand, and even seasonal water levels can influence what shows up on a power bill. If you want to see how that plays out in a specific province, our breakdown of time-of-use hydro rates in Ontario walks through how billing periods actually affect what you pay.
Hydropower is clearly powerful at the utility scale, but it raises a natural question for anyone thinking about
Can You Generate Hydropower at Home?
The honest answer is no, not realistically, for the vast majority of homeowners. Residential "micro-hydro" systems exist, but they require significant water flow, meaningful elevation change on your property, and regulatory approval from local authorities. For most people, especially anyone living in a city or suburb, none of those conditions are in place, which makes home hydropower a rare niche rather than a mainstream option.
That said, the underlying goal many people have when they ask about home hydropower is not really about water at all. It is about wanting the same thing hydropower represents at the grid level: renewable, always-available energy independence. For Canadians chasing that same outcome at home, solar paired with battery storage is the realistic equivalent. You capture energy when it is available and store it for use whenever you actually need it, without relying on rivers or dams.
This is where a portable power station fits in. Instead of moving water, you are storing energy from solar panels or the grid in a battery you control directly.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
Engineered for higher power demands, the EcoFlow DELTA 3 Ultra Plus features a 3,072Wh base capacity expandable up to 11kWh. It delivers 3,600W continuous output (7,200W surge) and supports rapid 0 to 80% charging in 48 minutes via dual solar and generator input. Operating at a quiet 25dB with a 10ms automatic switchover and up to a 5-year warranty, it provides uninterrupted energy storage to run larger appliances during outages.
EcoFlow DELTA 3 Max Plus (2048Wh)
For apartments, condos, or any home where a whole-home setup would be overkill, the Max Plus is the more sensible pick. It holds 2,048Wh out of the box and can grow to 10kWh as your needs change, with 3,000W of continuous output and a 6,000W surge for anything that needs an extra kick to start up. A full charge from empty to 80% takes about 43 minutes. It carries over the same quiet 25dB operation and 10ms switchover as its bigger sibling, plus the same up to 5-year warranty, so you are not giving up reliability just because you are working with a smaller footprint.
Hydropower is a mature, large-scale renewable technology that plays an especially significant role in Canada's energy mix, and it is not something the average homeowner can realistically replicate. What you can do is capture the same underlying benefit, clean, reliable, on-demand power, through solar and battery storage at home.
If energy independence and renewable backup power matter to you, a portable power station is the practical starting point. Whether that means the whole-home capable Ultra Plus or the more compact Max Plus, either one gives you a real answer the next time you lose power during a storm.
What is hydropower and how does it work?
Hydropower is electricity generated when moving or falling water spins a turbine connected to a generator. Water flows through a penstock, drives the turbine blades, and that mechanical energy is converted into electrical power sent to the grid.
Is hydropower renewable?
Yes. Hydropower relies on the natural water cycle, rainfall, snowmelt, and river flow, none of which are depleted by generating electricity, which is why it is classified as a renewable energy source.
How much of Canada's electricity comes from hydropower?
Hydropower supplies just over half of Canada's total electricity generation as of 2025, according to Statistics Canada, though the exact share shifts yearly with rainfall, snowpack, and drought conditions.
What are the different types of hydropower plants?
The main types are run-of-river, storage (dam or reservoir), pumped storage, and offshore or tidal systems. Each uses a different method to control and capture the energy of moving water.
Can homeowners generate their own hydropower?
Realistically, no, for most people. Home-scale "micro-hydro" needs significant water flow, real elevation change, and regulatory approval, making it a rare niche rather than a mainstream home energy option.
What's the closest thing to hydropower for home energy storage?
Solar power paired with a battery, like the DELTA 3 Max Plus mentioned above, is the practical home equivalent. Both capture renewable energy and store it for on-demand use, without needing a river or dam.
Home Backup
