Tri-Fuel Electric Generator vs. Solar Generators: Which Backup Power Solution Is Right for You?
Power outages are common across Canada, especially during summer storms, wildfires, and severe winter weather. A reliable backup power system helps keep your home running when the grid goes down.
This guide looks at tri‑fuel generators and solar generators side by side. How they work, what they’re good at, where they fall short, and which one fits a home, a cottage, or an off‑grid setup best.
What Is a Tri-Fuel Generator?
A tri-fuel generator builds on the technology of conventional portable generators by offering multiple fuel options. It runs on gasoline, propane, or natural gas, so you can use whatever’s available when supplies get tight.
How Does a Tri-Fuel Generator Work?
Like a conventional portable generator, a tri-fuel model uses an engine to turn an alternator and generate electricity. The difference is that it can switch between three different fuel sources. It uses a fuel selector and regulator system that allows the engine to run on gasoline, propane, or natural gas without major changes.
What Fuel Sources Can It Use?
A tri‑fuel generator runs on three fuel types, each with its own trade‑offs:
Fuel TypeAdvantagesLimitations
GasolineWidely available and provides high energy output.Has a limited shelf life and requires a fuel stabilizer for long-term storage.
PropaneStores well, burns cleaner than gasoline, and performs reliably in cold weather.Requires propane tanks and may provide slightly lower power output.
Natural GasContinuous fuel supply through your home's gas line, making it ideal for extended outages.Only works if your home has a natural gas connection and the gas supply remains available.
Advantages of Tri-Fuel Generators
  • Fuel Flexibility: Choose between gasoline, propane, or natural gas.
  • Extended Backup: Natural gas can support longer runtimes when a reliable gas connection is available.
  • High Output: Designed for heavy power demands and high-wattage appliances.
Limitations of Tri-Fuel Generators
  • Outdoor Use Only: Gas generators must be operated outdoors to avoid carbon monoxide buildup.
  • Regular Maintenance: Oil changes and routine servicing are part of ownership.
  • Noise: Expect operating noise of around 68–78 dB, along with safe fuel storage requirements.
What Is a Solar Generator?
Solar generators are now a practical alternative to gas‑powered units, offering quiet, low-maintenance power without fuel storage or engine emissions.
How Does a Solar Generator Work?
A solar generator stores electricity in a rechargeable battery rather than burning fuel. It can be charged from solar panels, a wall outlet, or your vehicle, then used to power essentials like lights, refrigerators, Wi-Fi routers, and laptops during an outage.
What Can a Solar Generator Power?
Solar generators come in all sizes. Some are small enough to carry in one hand, others are built to power a whole home. Depending on the model, they can handle everything from phones and routers to LED lights, full‑size fridges, CPAP machines, power tools, even energy‑efficient appliances.
Advantages of Solar Generators
  • No Exhaust Emissions: Runs on stored battery power, so there is no gasoline to buy or exhaust to deal with.
  • Quiet Operation: Works without the engine noise associated with traditional generators.
  • Low Maintenance: No oil changes, spark plugs, or fuel system servicing are needed.
Limitations of Solar Generators
  • Weather & Sunlight Dependence: Solar recharging speeds depend on sunlight availability, cloud cover, and seasonal day lengths, a consideration during dark Canadian winter storms.
  • Higher Initial Upfront Cost: Premium battery chemistry and solar hardware require a higher initial investment per watt compared to traditional combustion units, though offset by zero fuel and maintenance costs over time.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
Tri-Fuel Generator vs. Solar Generator: What's the Difference?
Picking between the two comes down to what you actually need. Power draw, setup, and conditions all matter. The table below breaks it down.
Feature / FactorTri-Fuel GeneratorSolar Generator
Primary Power SourceGasoline, Liquid Propane (LPG), Natural GasSunlight (Solar Panels), AC Grid, Car Outlet
Indoor SafetyStrictly Prohibited (Toxic CO Exhaust)Safe for Indoor Use (Zero Emissions)
Noise LevelLoud (68 to 78+ dB at 7 metres)Low Noise Operation (<30 to 45 dB)
Running & Fuel CostOngoing fuel costs (gasoline/propane rates)No ongoing fuel costs (solar charging)
MaintenanceHigh (Oil changes, spark plugs, winterization)Minimal (Periodic battery top-ups)
Output CapacityVery High (5,000W to 12,000W+)Moderate to High (1,000W to 7,200W+)
Lifespan & Reliability5–10 years (depends on engine maintenance)10+ years (3,000+ to 4,000+ LFP battery cycles)
When selecting a generator for home, evaluating specific blackout scenarios helps determine whether a tri-fuel setup or a clean solar generator fits your lifestyle best.
For Short-Term Power Outages
Across much of Canada, summer storms, high winds, winter ice, or localized grid issues can knock out power for two to twelve hours. Dragging out a heavy tri‑fuel generator for a short outage is more hassle than it’s worth. You’re hauling a bulky machine outside in the rain or snow, running extension cords, checking oil, and dealing with gas or propane tanks just to keep a few lights and the fridge going.
A solar generator is a much simpler fit for short blackouts. No fuel, no noise, no setup. A compact option such as the EcoFlow DELTA 3 Classic (1024Wh) + 220W Solar Panel can be stored indoors and quickly set up to power essentials when the grid goes down. It can run your Wi‑Fi, laptop, phone, desk lamp, even a small kitchen appliance. Hook up the solar panel during the day and you can stretch that runtime without touching a drop of fuel. Plug it in, flip it on, and you’re back in business.
Lightweight for on-the-go adventures, charged with solar energy in approx. 5.8 hours using a 220W solar panel. * DELTA 3 Classic supports up to 500W solar input.
For Extended Power Outages
Rural homes, lakefront cottages, and off‑grid properties across Canada often sit at the end of a long line. When a storm hits, service can be slow to come back. Self‑reliance isn’t optional out there.
A tri-fuel generator running on propane or natural gas can provide high output when fuel supplies are available. However, it still requires outdoor operation, fuel management, and regular maintenance.
Solar generators offer a cleaner, lower‑maintenance alternative. The EcoFlow DELTA 3 Max Plus + 2 x 220W Solar Panel is built for remote spots. Big expandable battery, dual panels that recharge daily, and enough output to run a full‑size fridge, water pump, lights, and communications gear. No fuel trips or exhaust fumes, providing a quieter backup option for remote locations.
3000W Powerful Output: 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging.
What Factors Should You Consider Before Choosing a Backup Power Solution?
Before you pick a backup system, take a step back. Ask yourself how much power you actually need, how long outages usually last, where you are, and where you’ll be running the system. Those three things will steer you toward the right fit more than any spec sheet will.
Essential Power Requirements
An accurate calculation for wattage starts with adding up the total running and starting requirements of every appliance you intend to back up. Critical items like sumps, refrigerators, and heating controls require high startup surges, whereas laptops and LED lights consume minimal ongoing power.
Local Weather and Outage Risks
Seasonal weather conditions also matter. Winter storms can create challenges for fuel storage and generator operation, while summer storms and wildfires may require reliable backup power during extended outages.
Installation and Storage Requirements
Factor in physical space and installation costs. Tri-Fuel generators require outdoor storage sheds, heavy weatherproofing, and a manual transfer switch installation by a certified electrician. Solar generators are compact, portable, and require no permanent electrical retrofits unless integrating with a smart breaker panel.
Long-Term Energy Flexibility
Look at the long‑term costs too. A tri‑fuel generator is cheaper upfront, but fuel, oil changes, and maintenance add up over the years. Solar generators cost more to buy, but after that, there’s not much to spend. You avoid ongoing fuel purchases, oil changes, and in the summer, you can take it camping or to the cottage. So the higher sticker price can balance out pretty fast, depending on how often you use it.
Quick Backup Power Checklist: Which Solution Fits Your Needs?
There’s no single backup power solution that’s right for everyone.
  • Choose a solar generator if you want a quiet, low-maintenance system for keeping essential appliances running during short outages or while staying off the grid.
  • Choose a tri-fuel generator if you need higher power output for extended outages and have easy access to gasoline, propane, or natural gas.
EcoFlow DELTA 3 Max Plus Portable Power StationEcoFlow DELTA 3 Max Plus Portable Power Station
Both tri‑fuel and solar generators have their place, but they serve different priorities. A tri‑fuel generator delivers big power when you need it, especially hooked to a natural gas line. Just be ready for the noise, the maintenance, and the exhaust setup. It delivers strong output but requires more setup, maintenance, and fuel management.
Solar generators take a different approach. Clean, quiet, and you can run them indoors without worrying about fumes. The EcoFlow DELTA series is a good example. It uses renewable solar energy, requires minimal maintenance, and operates much more quietly than fuel-powered generators.
Figure out what you’re powering, how long outages tend to last, and what you’re willing to live with day to day. That’ll point you to the right system for your place.
What Kind of Generator Can You Use Indoors?
Solar generators can be used indoors because they rely on battery power rather than fuel combustion, meaning they do not produce carbon monoxide or exhaust fumes during operation. Always check the manufacturer’s instructions for safe placement and use.
What Size Tri-Fuel Generator Do I Need?
For most Canadian households, a 7,500 to 10,000‑watt tri‑fuel generator is what you need to keep the important stuff running during a power outage. That size gives you enough power to handle the startup surge from your fridge, sump pump, furnace blower, and a few kitchen essentials as long as the total load stays within the generator’s capacity.
Can a 3000 Watt Generator Run a Refrigerator?
Yes. A fridge uses about 100‑400 watts running, with a startup spike of 1,200‑1,500 watts. You’ll still have power left for other small things.
How Long Will a 3000 Watt Solar Generator Run?
About 16–18 hours for a typical 150-watt fridge (accounting for compressor duty cycles) on a full charge. Depends what else you’ve got plugged in and whether solar panels are charging it at the same time.
How Long Does It Take to Charge a Solar Generator?
Anywhere from 1.5 to 6 hours, depending on how you’re charging it. Plug it into a wall outlet and some models can top up in 60 to 90 minutes. With solar panels, you’re usually looking at 3 to 6 hours of good, bright sun.
Home Backup
