A Complete Guide on Calculation for Wattage
Whether you’re getting your cabin in Whistler ready for a long winter or planning an RV trip across the Maritimes, understanding calculation for wattage is what keeps everything running smoothly. It tells you if your heater can run safely, whether your generator can handle the load, and how much power your setup really needs.
In this guide, we’ll explain what wattage actually means, walk through the key formulas in plain terms, and show you how to calculate power requirements for everything from a kitchen toaster to a high capacity home backup system.
What Is Wattage?
Wattage is simply how fast electricity is being used or produced. An easy way to think about it is with water: voltage is the pressure, amps are the flow, and watts are the actual work happening every second.
Once you get that, things start to make more sense. You’ll know whether your portable power station can handle a hair dryer at the cottage, or if your home’s panel is getting pushed a bit too hard during a deep January freeze.
What Power Units Are Commonly Used?
Before getting into formulas, it helps to understand the basic terms you’ll see on appliance labels and spec sheets. If you're new to electrical basics, a quick explanation of what do volts, amps, and watts mean can make these labels much easier to interpret. Different units show up depending on what kind of equipment you’re dealing with.
Watts (W) as the Standard Electrical Power Unit
Watts are the standard unit for real power. In Canadian homes, almost everything, from LED bulbs to coffee makers, is rated in Watts. It tells you how much power the device is actually drawing from the wall or a battery at any moment.
Horsepower (HP) for Motors and Mechanical Systems
You’ll usually see horsepower on equipment with motors, like sump pumps, air compressors, or table saws. One horsepower equals about 746 Watts. So if you’re running a 1 HP pump during a heavy rainstorm, your power source needs to handle that steady load, plus the extra surge when it first kicks on.
Volt-Amperes (VA) for Apparent Power Ratings
Volt-Amperes (VA) refer to apparent power. Watts measure the power doing real work, while VA reflects the total power flowing through the circuit. For simple devices like heaters, Watts and VA are basically the same. For electronics with motors or circuit boards, the VA rating can be slightly higher than the listed wattage.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
What Are the Core Formulas for Power Calculation?
You don’t need an engineering degree to figure this out. A few basic formulas will cover most real life situations at home or on the road.
Basic Formula: W=V×A
This is the one most people use. Watts equal volts multiplied by amps. In Canada, most standard outlets are 120 V.
Example: If a vacuum is rated at 120 V and 10 A:
120 × 10 = 1200 W
That tells you the vacuum pulls 1200 watts while running.
Resistance Formula: W=V²÷Ω
If you know the voltage and the resistance (measured in ohms, Ω), you can calculate wattage that way. This is common with heating elements like baseboard heaters or electric blankets.
Example: A heater running on 120 V with 24 Ω resistance:
120² ÷ 24 = 600 W
Real Power Formula: W=V×A×Power Factor (cos⁡ϕ)
For appliances with motors or compressors, like fridges or freezers, efficiency matters. These devices have a power factor (usually between 0.8 and 1.0). To get the real wattage, multiply volts by amps and then by the power factor.
Typical household appliances sit around 0.85-0.95.
Example: A fridge rated at 120 V, 5 A, with a power factor of 0.9:
120 × 5 × 0.9 = 540 W
For these appliances, understanding the difference between starting and running watts also matters, since compressors and motors often draw a higher surge of power when they first start up. Once you know these three formulas, you can size most household loads without overthinking it.
How Do You Calculate Wattage from Voltage and Amps?
Once you have the specs, the math is simple. Most appliances have a small silver label on the back or underneath that lists their electrical details.
Step 1: Find the Voltage.
In a Canadian home, that’s usually 120V. Larger appliances like stoves or dryers often run on 240V.
Step 2: Find the Amps.
Look for a number followed by “A.” That tells you how much current the appliance draws.
Step 3: Multiply Them.
Watts = Volts × Amps.
So if your vacuum is rated at 10A on a 120V outlet:
120 × 10 = 1200W
That means it pulls 1200 watts while running. Once you get used to this formula, checking appliance loads becomes second nature.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
How Do You Figure Wattage in Different Scenarios?
Wattage isn’t one-size-fits-all. What works at home isn’t the same as what you need at a campsite or for an EV charger. It really depends on where you are and what you’re running.
Home Applications and Appliance Load Calculation
At home, total wattage matters for safety. A typical Canadian household might have a fridge (150-800W), a portable AC (1000-3500W), and a microwave (around 1000W). If those run at the same time, your peak load can quickly climb past 3000W, sometimes even 8000W. That’s when breakers trip if you’re not careful.
Always follow the Canadian Electrical Code (CEC) and use a licensed electrician for permanent installations. For continuous loads, stick to the 80% rule, don’t exceed 80% of a circuit’s rated capacity.
If you’re looking at whole-home backup, systems like the EcoFlow DELTA Pro Ultra Whole-Home Backup Power are built for heavy loads. With high output capacity, it can handle central AC, multiple fridges, and lighting, useful during a long Ontario ice storm or a BC outage.
One unit covers every appliance. With a 7.2kW output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items, like a 3-ton central air conditioner. For more power, pair 3 inverters with the EcoFlow Smart Home Panel 2 to unlock a 21.6kW AC output.
Camping and RV Power Planning
When you’re boondocking in the Rockies, every watt matters. A typical RV setup might include a small fridge (100-200W), a space heater on a cold night (around 1500W), and water pumps (50-200W). Altogether, you’re often looking at 1000-4000W, especially once you factor in surge power when the AC kicks on.
To stretch runtime, many RVers try to use DC power directly instead of converting to AC, since every conversion wastes a bit of energy. The EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) includes a built-in Anderson port that connects straight to 12V RV panels. That means you can run essentials like your fridge and water pump more efficiently on longer trips, without relying on an extra converter.
EcoFlow DELTA 3 Max Plus (2048Wh) delivers 3000W AC rated output (6000W surge). With X-Boost™ 3.0 technology, it supports devices up to 3800W—effortlessly taking on your heavy-duty appliances.
Solar System Output and Inverter Matching
If you’re setting up solar panels on your roof, your inverter needs to match your total panel wattage. If you have 800W of panels, your inverter should be rated for at least 800W of input. If it’s undersized, excess power will be clipped during peak sun hours. Proper matching ensures you use the full output of your panels without wasting available energy.
Electric Vehicle and Generator Power Requirements
Level 1 EV charging usually draws around 1.4kW (1400W). Level 2 can range from 7kW up to 19kW. If you’re using a generator or battery backup to charge an EV, make sure the continuous output rating exceeds the charger’s demand. Undersizing can strain equipment and cause shutdowns. The key in every scenario is knowing your peak load, and giving yourself a safe margin.
Calculation for wattage isn’t just about numbers, it’s about knowing your setup will handle what you throw at it. Once you understand how Volts, Amps, and Watts work together, you can manage your home’s power safely, plan an off grid trip with confidence, and choose the right whole home battery backup that actually fits your lifestyle.
1. Can I run 3000 watts on a 20 amp circuit?
No. On a 120V circuit, a 20-amp breaker has a maximum of 2400W (120 × 20). Under the Canadian Electrical Code (CEC), you should only use 80% of that for continuous loads, about 1920W. Running 3000W would overload the circuit.
2. How many watts can a 50 amp breaker handle?
A 50 amp breaker at 240V can handle up to 12,000W (240 × 50). This setup is common for electric ranges, hot tubs, and Level 2 EV chargers in Canadian homes.
3. How many amps will a 12000 watt generator run?
At 240V, a 12,000W generator can supply about 50 amps (12,000 ÷ 240). At 120V, it’s roughly 100 amps. Keep in mind this is theoretical, real output depends on power factor and startup surges from motors or compressors.
4. How big of a generator do I need to run a 200-amp house?
Most 200-amp homes don’t use the full capacity at once. For essential loads, a generator in the 15kW to 25kW range is usually enough. Actual sizing depends on what you plan to run during an outage.
5. What happens if a generator is too big?
An oversized generator can run inefficiently. With light loads, gas units may not reach proper operating temperature, leading to fuel waste and carbon buildup, sometimes called “wet stacking.” Proper sizing improves efficiency and extends lifespan.
Home Backup
