Powered by Solar: Match Supply to Your Devices
Panels make electricity while light reaches them. To keep devices powered by solar after sunset, you need a way to store some of that energy.
Your plan has to balance what you collect with what you use. A large battery can cover a gap, but it can't fix too little charging day after day.
In Canada, check the month you'll rely on solar, along with your devices and connections.
How Solar Power Reaches Your Devices
Getting useful power from solar panels takes more than the panels alone. Each part of the setup has a different job.
Panels produce direct current, or DC. An inverter changes it into alternating current, or AC, for many household devices, as CanREA's explanation of solar electricity describes.
These parts may be separate units or built into one power station:
Part
Main Job
What to Check
Solar panels
Turn light into DC electricity.
Sun exposure and compatibility with the equipment receiving power.
Control and conversion equipment
Manage incoming power and supply the type your devices use.
Solar-input limits, AC output, and connections.
Battery storage
Hold energy for later use.
Usable energy, planned device use, and the next recharge.
A battery stores energy rather than making it. Grid-connected rooftop solar can work without one, while storage adds a way to use collected energy later.
Watts, or W, describe power at one moment. Watt-hours, or Wh, measure energy over time: a steady 100 W load uses 100 Wh in one hour.
The details of how solar cells turn light into electricity explain generation. For choosing equipment, keep generation, storage, and device use separate.
Diagram separating solar generation, conversion, storage, and device use.Diagram separating solar generation, conversion, storage, and device use.
Keep Useful Energy for Later
Evening use creates a gap between making electricity and needing it. Choose storage for that gap, then check how much energy your panels can replace before the next one.
A Fixed Storage Plan for Checked Loads
Your plug-in fridge, lights, and laptop may need power after the sun goes down. Count their energy use over that time, including the fridge switching on and off.
The EcoFlow DELTA 3000 Gen4 Portable Power Station holds 3,072 Wh of nominal energy and accepts up to 1,000 W of solar input. Those ratings address two separate needs: energy in storage and the limit on incoming solar power.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Its capacity is fixed, so you can't add an extra battery later. Suitable solar panels and cables are also needed, and a 1,000 W input rating doesn't promise that collection rate.
At about 26 kg, this is a substantial unit to move. It makes more sense for a measured group of devices than for charging one phone.
Its total rated AC output is 3,600 W at 120 V. Check combined running power, each device's starting demand, and individual outlet limits before connecting your loads.
More Storage and Two Solar Inputs
A longer gap between charges may call for more stored energy. A larger suitable panel setup may also need more solar-input capacity.
The EcoFlow DELTA 3800 Gen4 Portable Power Station starts with 3,763 Wh and supports expansion up to 12 kWh with compatible extra batteries. Its two solar inputs accept up to 2,000 W total, with a 1,000 W limit per port.
1. Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Expansion needs additional compatible batteries and connection hardware. Panels, cables, and collection conditions still determine how much solar energy reaches storage.
The larger model weighs about 30.6 kg but has the same 3,600 W total rated 120 V AC output. More storage doesn't add voltage or increase that output limit.
As of November 16, 2026, the 3800 is on pre-order, with shipping listed for early December. Check the current estimate before ordering.
Choose between these stations as alternatives. They aren't a connected pair, and neither is a whole-home power supply by itself.
Match Each Day's Solar Input to Your Use
Compare energy collected with energy used over the same period. That shows whether you're replacing enough energy to support your plan.
Count Energy on Both Sides
Consider a hypothetical day with an average panel-side input of 150 W for four hours. That gives 600 Wh before losses.
A device drawing a steady 100 W for four hours uses 400 Wh. Here is the simple balance:
Item
Example Calculation
Energy
Panel-side collection
150 W average × 4 h
Device use
100 W × 4 h
400 Wh
Difference
600 Wh minus 400 Wh
200 Wh before losses and reserve
That 200 Wh isn't guaranteed spare energy at an outlet. It still has to cover energy lost during conversion and any charge you keep in reserve.
This small example teaches the sums, rather than justifying a large battery purchase. When sizing backup energy for selected devices, add each device's use and allow for losses.
Hypothetical comparison of 600 Wh collected and 400 Wh used before losses and reserve.Hypothetical comparison of 600 Wh collected and 400 Wh used before losses and reserve.
Plan for a Day That Falls Short
If you use more energy than you replace, the battery's charge drops. More storage can delay running out, but it can't fix that shortfall every day.
Reduce use, check actual input over time, or plan another supported charging source. Daylight hours aren't all hours of full panel output.
Dividing rated battery capacity by a device's watts gives only a rough runtime estimate. Devices switching on and off, energy losses, settings, and startup needs also change the result.
Allow for Your Location and the Season
A setup that meets your needs in July may fall short in December. Plan for the month when you need the energy, rather than relying on a yearly average.
Natural Resources Canada's solar planning tools provide monthly estimates for locations across Canada. Their modelled yields describe grid-connected systems without batteries, so they aren't a recharge forecast for a portable kit.
Compare solar potential across Canada, then check the actual place you'll put the panels. A nearby tree or building can shade that spot even in a sunny region.
Toronto's solar installation considerations explain how shade, clouds, and snow affect collection. Check changing shade through the day, and don't climb onto a snowy roof to clear panels.
Panel conditions and battery temperature are separate checks. Both Gen4 stations need a dry, ventilated location and a charging temperature of 0 °C to 45 °C.
Weather-resistant solar panels don't make the power station weatherproof. Keep the station protected, and don't plan to charge it below its allowed temperature.
Choose the Right Connection Before You Buy
A portable setup serves selected plug-in devices. A system connected to home circuits needs a different design, so settle the connection method before buying equipment.
Check the Solar Input, Not Just Panel Watts
Matching panel wattage alone doesn't establish compatibility. Each solar input on these Gen4 models accepts 11 to 60 V DC, up to 20 A, and no more than 1,000 W.
Check these details against the exact model manual and proposed panels:
  • Voltage: Check the array's open-circuit voltage, including its value in expected cold conditions. It must stay within the station's input limit.
  • Current: Check the array's short-circuit current against the manual's limit, rather than relying on watts alone.
  • Connections: Confirm suitable connectors and cables for the exact panels and station. Don't assume an adapter makes any combination safe.
Have a qualified installer or the manufacturer resolve unclear compatibility. Don't improvise panel wiring or tap an existing rooftop array to charge a portable station.
DELTA 3000 Gen4 in a dry indoor work area beside a small device charger.DELTA 3000 Gen4 in a dry indoor work area beside a small device charger.
Keep Home Wiring a Separate Decision
When planning a home solar array, decide which circuits need power during an outage. Ordinary grid-connected solar usually shuts down when the grid fails.
BC Hydro's outage guidance explains that backup depends on an approved battery configuration, wiring, and professional setup. That utility's approval requirements apply to its own service area.
Neither standalone Gen4 station directly supplies 240 V equipment or an entire HVAC system. Hardwired loads need suitable professional installation and approval for the exact setup.
Never feed a station into a wall outlet. Adding a battery alone doesn't make an existing rooftop system work during a blackout.
Check the Costs Against the Energy You Can Use
Value depends on useful energy and the full cost of your setup. Keeping selected devices available during an outage has a different purpose from cutting your power bill.
Include panels, storage, suitable cables, and any professional work in the budget. A cheaper panel package can lose its appeal if it needs different equipment or doesn't suit your site.
For bill savings, count the grid electricity your system actually replaces. Use your local electricity rates and any applicable utility terms for exported energy, rather than a national savings estimate.
When checking solar costs and payback, use current quotes and your own energy figures. A payback calculation is a planning tool, not a guaranteed return.
Start With One Clear Solar Power Plan
Write down your devices, their energy use, and the gap before your next charge. Check that list against local solar conditions and the connections your equipment needs.
Once those details are clear, compare solar generators for selected devices to find a setup that fits. Choose storage and collection capacity together, so the battery can support your use and receive the next charge.
Is there a generator powered by solar?
A solar generator usually combines panels with a battery power station. Panels make electricity, while the battery stores it for later, so available power depends on the station's output, remaining charge, and solar collection.
Do I need a battery for rooftop solar?
You don't always need a battery, since some grid-connected solar systems work without one. Storage is a separate choice, and outage backup requires suitable equipment and a system designed for that job.
Can solar panels power a home during a blackout?
Ordinary grid-connected solar usually shuts down during an outage. A properly designed backup system may serve selected loads, but panels or a portable battery alone don't establish that capability.
Can I charge a solar battery from the grid?
You can if the exact system supports AC charging. Check its charging options and limits, and remember that energy drawn from the grid isn't entirely solar-generated simply because it enters a solar battery.
Solar energy
