How Does a Solar Cell Generate Electricity? From Sunlight to Your Canadian Home
Every rooftop solar panel is made up of smaller components called solar cells. They have no moving pieces, yet they turn sunlight into electricity all day. So how does a solar cell generate electricity? The answer starts with silicon, light, and a tiny electric field. This guide walks through the process step by step in plain words. Then it follows that power into your home. You will see where it goes, how cold and snow change output, and why storage matters.
How Do Solar Cells Generate Electricity, Step by Step?
A solar cell turns light into power without a single moving part. The trick happens inside a thin slice of treated silicon. Here is what goes on, one step at a time.
The Silicon Sandwich Inside Every Cell
Most solar cells are made from silicon, a material called a semiconductor. A semiconductor carries electricity better than glass but not as easily as copper.
Makers treat the silicon with tiny amounts of other elements. This process is called doping.
  • The n-type layer gets an element like phosphorus. It adds extra electrons, which carry a negative charge.
  • The p-type layer gets an element like boron. It leaves gaps, called holes, where electrons are missing.
Where the two layers meet is the p-n junction. Some free electrons cross over and fill nearby holes. This creates an internal electric field that helps separate electrons and holes generated by sunlight.
Unlike solar thermal panels that heat water, photovoltaic (PV) cells turn light straight into electricity.
From Photon to Current in Six Steps
Sunlight travels as tiny packets of energy called photons. The table below follows one photon as it becomes electric current.
Step
What happens
Plain-language picture
1. Sunlight arrives
Photons strike the cell’s surface. Some bounce off, but many pass into the silicon.
Rain falling on a roof
2. Photons are absorbed
Silicon soaks up photons that carry enough energy.
A sponge taking in water
3. Electrons break free
That energy knocks electrons loose from their atoms. Each one leaves a hole behind.
Marbles knocked out of a tray
4. The field sorts them
The p-n junction pushes electrons to one side and holes to the other.
A one-way ramp
5. Electrons flow through a wire
Thin metal lines collect the electrons. They travel through a circuit and return to fill holes on the other side.
Water running through a loop of pipe
6. DC power comes out
Electrons move in one direction only. This is direct current, or DC.
A river that only flows one way
As long as light keeps hitting the cell, the cycle repeats. More light means more current.
One cell on its own makes only a small amount of power. To run a home, cells need to work as a team, and that is where panels and inverters come in.
From One Cell to a Home Solar System
A single cell makes only a few watts, so cells are grouped into bigger units. The power then needs one more change before reaching your outlets.
Cells, Modules, and Arrays
Level
What it is
What it adds
Cell
One small square of treated silicon
A few watts of DC power
Module (panel)
Dozens of cells wired together under glass in a frame
Enough power to be useful on a roof
Array
A group of panels wired together on a roof or ground mount
Enough power to cover a real share of household use
Wiring cells or panels in a chain (series) raises the voltage. Wiring them side by side (parallel) raises the current. Many panels also include bypass diodes. These let power route around a shaded cell, so one shadow does not shut down the whole panel.
Why Your Home Needs AC Power
Your outlets and most appliances run on alternating current, or AC. In AC, the flow of electrons switches direction many times each second. Solar panels only make DC, so the power has to be converted first.
Most homes rely on an inverter to change DC power into AC for everyday use. Common setups include:
  • String inverters: One box handles the DC from a whole row of panels.
  • Microinverters: A small inverter sits behind each panel.
  • Battery systems with built-in conversion: Some home batteries take DC from panels directly and supply AC to your home.
Many inverters and charge controllers also use MPPT, or maximum power point tracking. MPPT keeps adjusting to pull the most power from the panels as light changes through the day.
Once the power is in AC form, your home can use it. The next question is where all that electricity actually ends up.
Where Does Solar Electricity Go in a Canadian Home?
Solar power does not wait around. The electricity your panels generate can be used immediately, exported to the grid, or stored, depending on your system, and the split changes through the day. Planning a household solar setup in Canada starts with knowing those paths.
Used Right Away
Your home uses solar power first. If the fridge and lights are running at noon, solar feeds them directly, so you buy less from the grid.
Sent to the Grid for Bill Credits
When panels make more than your home needs, the extra can flow back to the grid. How you get credit depends on your province and utility.
  • Ontario: Net metering under Ontario Regulation 541/05 lets you earn bill credits for surplus power. Unused credits carry forward for up to 12 consecutive months.
  • Other provinces and territories: Programs may be called net metering or net billing. Credit rates, size limits, and rules vary.
Check your local utility’s program before you install.
Why Rooftop Solar Usually Shuts Off in a Blackout
Most rooftop systems connected to the grid switch off when the grid goes down. This protects utility crews working on the lines. So panels alone often will not keep your lights on in an outage.
Stored in a Home Battery for Later
A battery saves extra solar power for the evening or an outage. How long it lasts always depends on what you plug in or connect.
Two models fit this kind of setup well. The EcoFlow TITAN 5000 Plus accepts up to 8kW of solar through two 4kW MPPT inputs. That suits larger arrays.
•100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $1,100 per year. • Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
The EcoFlow TITAN 5000 accepts up to 4kW of solar through one MPPT input, which suits smaller arrays. It can also charge from a generator.
EcoFlow TITAN 5000
• 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. • 100% Whole-Home Savings. Save up to $1,000/year. • Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Both models start with 5kWh of storage, expand to 30kWh, and work with the grid. Plug-in devices run from either unit directly. Home circuits or hard-wired appliances need the compatible SHP10 installed by a qualified electrician. The SHP10 covers up to 10 selected circuits, not every appliance at once. Both units are rated IP20, so place them indoors in a dry spot.
If you already have compatible rooftop solar, the TITAN 5000 Plus can work with it through the SHP10 in a no-export setup. A qualified electrician can confirm whether your system fits.
Modern home with rooftop solar panels and an attached garageModern home with rooftop solar panels and an attached garage
Where your solar power goes is only half the story. How much power your panels make in the first place depends on a few key factors.
What Affects How Much Electricity a Solar Cell Can Produce?
Two identical panels can make very different amounts of power. Light, angle, temperature, and weather all play a part. Heat, shade, and dirt all lower the share of sunlight panels convert into usable power.
Factor
How it changes output
What it means in Canada
Sunlight strength
Fewer photons on cloudy days mean less current. Output drops but rarely stops.
Overcast coastal regions see lower output than sunnier prairie regions.
Day length
Fewer daylight hours mean less total energy.
Long June days boost output. Short December days cut it.
Panel angle and direction
Panels facing the sun square-on catch the most light.
South-facing panels work best. A steeper tilt helps catch low winter sun.
Temperature
Hot cells lose some voltage. Cool cells perform better.
Cold, bright days can be surprisingly productive.
Shade
Even partial shade on a few cells cuts panel output.
Trees, chimneys, and nearby buildings matter more than many expect.
Snow and dirt
Anything covering the glass blocks light.
Heavy snow can stop output until it slides or melts off.
Cold and Snow: A Closer Look
Many Canadians assume winter ruins solar, but cells actually like the cold. Panels are rated at a cell temperature of 25°C, and cooler cells can beat that rating in bright sun.
The real winter limits are short days and snow cover. A light dusting often melts or slides off. Heavy snow can block output until it clears. Use a soft roof rake from the ground if you must clear panels. Never climb onto an icy roof.
Rooftop solar panels partly covered with snow in winterRooftop solar panels partly covered with snow in winter
Estimating Output Where You Live
Natural Resources Canada offers free photovoltaic potential and solar resource maps for the whole country. You can look up expected yearly output per kilowatt of panels for over 3,500 Canadian municipalities. It is a useful reality check before sizing an array.
A solar cell works by letting sunlight free electrons in silicon. The p-n junction then pushes them into a steady DC current. Panels and arrays scale that power up, and an inverter turns it into AC for your home. From there, it is used right away, stored, or sent to the grid. To keep more solar power for evenings and outages, the EcoFlow TITAN 5000 or TITAN 5000 Plus is worth a look.
Do Solar Cells Make Electricity on Cloudy Days?
Yes, but less of it. Clouds block some photons, so fewer electrons break free. Panels still produce power on bright overcast days, just at a lower rate.
Does a Solar Cell Make AC or DC Electricity?
A solar cell makes DC, or direct current. An inverter converts it to AC so your outlets and appliances can use it. Some home battery systems do this conversion inside the unit.
How Does a Solar Cell Make Electricity in a Canadian Winter?
It works the same way as in summer. Cold temperatures can even help a cell convert light a little more efficiently. Total output is lower because days are shorter and snow can cover panels.
Can Solar Panels Power My Home During a Blackout?
Not on their own, in most cases. Most rooftop systems connected to the grid shut off during an outage for safety. A home battery with the right switching equipment can keep selected circuits running for a time. How long depends on your load and stored energy.
How Long Do Solar Panels Keep Producing Electricity?
Natural Resources Canada describes well-functioning systems lasting 25 years or more. It also notes output slowly drops by about 0.6% per year as panels age.
Home Solutions
