Portable Gas Generators: What to Know Before You Buy One
A portable gas generator that's too small to run the fridge, or too loud to use near neighbours, ends up being the wrong purchase no matter how good the price was. This guide covers the main types on the market. It covers how much power they actually deliver. It covers the safety risks worth knowing. It also covers how they compare to a battery-based alternative.
Why So Many Generator Purchases Go Wrong
Buying a generator seems simple until you actually stand in the store. The wattage numbers on the box mean little without context. Reviews contradict each other. Salespeople push whatever's in stock.
Most bad purchases come from one of two mistakes. Either the buyer guesses at wattage instead of calculating it, or they buy based on price alone. Both lead to the same result: a generator that disappoints the first time it's actually needed.
This guide walks through the numbers that actually matter. It also covers the safety side most buyers only think about after something goes wrong.
Types of Portable Gas Generators
  • Open-frame conventional generators are the cheapest option, typically running 3,600W to 9,500W. They're louder and produce a less stable power output.
  • Inverter generators cost more but produce cleaner, more stable power. This matters for laptops and other sensitive electronics. They tend to run quieter too, often in the 52 to 65 decibel range.
  • Dual fuel and tri-fuel models can switch between gasoline, propane, or natural gas. This is useful when one fuel type is hard to find during a widespread outage. Understanding which fuel type matches local supply is worth doing before you buy.
  • High-capacity units (15,000W and up) exist mainly for whole-home backup rather than portable or camping use, despite still being sold in the "portable" category.
The type explains how a generator runs. How much power it actually delivers is the number that decides if it fits the job.
How Much Power Does a Portable Gas Generator Actually Deliver?
gas generators portablegas generators portable
Running watts and starting watts are two different numbers. A generator needs enough starting watts to handle the surge when a fridge or well pump first kicks on.
Most residential portable models cluster between 3,500W and 5,800W of running power. That's enough for a fridge, some lighting, and a few small appliances at once, not a full house.
Runtime depends heavily on tank size and load. A generator run at 25% load can often last 15 to 20 hours per tank, far less at full load. A side-by-side look at runtime by fuel type and generator capacity is useful for comparing a specific gas model against a solar or battery equivalent.
Tank size matters more than most buyers realize. A larger tank means fewer trips outside to refuel during a storm. It also means more weight to move if you need to relocate the unit.
For the same wattage range most gas generators cover, an alternative exists with no fuel involved at all.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
• 3600 W Powerful Output: 7200 W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4600 W such as clothing steamers, electric dryers, lawnmowers, and electric frying pans. • Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. •3-11 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • 6 Ways to charge, Ready in Just 48 Mins: Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging
Power output is one side of the decision. What a gas generator can do if it's used incorrectly is the side too many buyers skip.
Safety Risks Worth Knowing Before You Buy
Carbon monoxide poisoning is the most serious risk. It's why every portable gas generator should run at least 20 feet from the house, with exhaust pointed away from windows and doors.
Running a generator in a garage, even with the door open, is one of the most common causes of CO poisoning incidents. The gas can still pool indoors.
Fuel storage adds its own risk too. Gasoline needs to be stored safely away from the house and rotated periodically so it doesn't degrade. A full breakdown of safe placement distance and setup around the home is worth reading in full before the first use, not after buying one.
Carbon monoxide has no smell and no colour. That's what makes it so dangerous. A working CO detector inside the home is worth having regardless of how careful you are with generator placement outside.
None of these risks apply to a battery-based system.
EcoFlow DELTA Pro Ultra
•Dual UL-Certified Safety: The only portable power station certified to both UL 1973 and UL 9540 standards, delivering maximum reliability for home backup. •7.2 kW–21.6 kW High Output: Delivers robust power capable of running entire households, including high-load systems like central air conditioning. • 6 kWh–90 kWh Scalable Capacity: Expandable energy storage that provides continuous whole-home power for weeks during extended outages. •Smart Home Panel 2 Integration: Features automatic switchover, prolonged outage support, and intelligent scheduling to lower utility bills. • 5 Versatile Charging Options: Offers multi-source recharging flexibility to ensure power redundancy under any condition. • Automatic Low-Temp Self-Heating: Built-in heating activates automatically below 0°C (32°F) to maintain normal battery operation in freezing climates.
Safety is one reason people look at alternatives. Cost and maintenance are usually the other two.
Portable Gas Generator vs. Battery Power Station: How They Compare
Portable Gas Generator vs. Battery Power StationPortable Gas Generator vs. Battery Power Station
Factor
Gas Generator
Upfront cost
Lower
Higher
Ongoing cost
Fuel, oil changes, maintenance
None
Noise
Loud enough to affect conversation
Near-silent
Startup
Manual
Automatic
Emissions
Yes, requires safe placement
None
A gas generator costs less upfront in most cases, but ongoing fuel costs and regular maintenance, oil changes, carburetor cleaning, fuel stabilizer, add up over years of ownership. A battery power station costs more upfront but has no ongoing fuel cost and effectively no engine maintenance, since there are no moving parts to service.
A direct side-by-side on cost, maintenance, and noise between the two backup types is worth reading for anyone still deciding, since the right answer depends heavily on how often backup power is actually needed.
Choosing the Right Portable Generator for Your Needs
Add up the running watts of everything that needs to run at once. Then add the highest single starting-watt appliance on top. That lands on the minimum size actually needed.
A generator bought for occasional camping trips has very different requirements than one bought for whole-home outage backup. Buying for the bigger use case usually makes more sense than buying twice.
Portability matters more than people expect. A 9,000 W conventional unit is not something one person moves alone, while a smaller inverter model usually is.
How Often Do You Actually Need Backup Power?
This question shapes the whole decision more than any spec sheet. Someone in a storm-prone rural area with frequent outages has different needs than someone in a city with rare, short outages.
  • Frequent outages (several times a year): the ongoing cost difference between fuel and battery use adds up fast, worth factoring into the decision.
  • Occasional outages (once a year or less): upfront cost and ease of storage matter more, since the unit sits unused most of the time.
  • Rare but severe risk (major storm zones): capacity and runtime matter most, since a short outage isn't the concern, a multi-day one is.
Be honest about which category actually describes your situation. It changes which type of backup makes financial sense.
Portable gas generators range from small inverter units to whole-home-capable systems. Picking the right one comes down to wattage needs, safety setup, and how often it will actually run.
Size the generator to real wattage needs. Plan for safe placement and fuel storage before the first outage. Weigh a battery-based alternative if fuel logistics and noise are a concern. The DELTA 3 Ultra Plus and DELTA Pro Ultra cover that alternative at two different scales.
What size portable gas generator do I need to run a fridge?
Most fridges need 150 to 200 running watts and a starting surge up to 1,600 watts, well within the range of even a small 2,000 W inverter generator.
How far from the house should a portable gas generator be placed?
At least 20 feet, with the exhaust pointed away from windows and doors to prevent carbon monoxide from entering the home.
Is a dual fuel generator worth the extra cost?
It depends on fuel access in your area. Being able to switch between gasoline and propane matters most when one fuel type runs short during a widespread outage.
How long can a portable gas generator run on one tank?
Typically 15 to 20 hours at 25% load, much less at full load, depending on tank size and the specific model.
Is a battery power station a real alternative to a gas generator?
Yes, for most residential wattage needs. It costs more upfront but eliminates fuel costs, maintenance, noise, and carbon monoxide risk entirely.
How often does a portable gas generator need maintenance?
Regular oil changes, periodic carburetor cleaning, and fuel stabilizer treatment are standard upkeep, on a schedule similar to a small engine or lawn mower.
Home Backup
