How Far Should Portable Generators be From the House
Portable generators bring peace of mind during blackouts, wild weather, and camping trips. But they must be placed carefully. It's not just about how loud they are or where you can reach the outlet—it's about preventing carbon monoxide poisoning, fire hazards, and property damage. This guide helps you understand the right distance and safe setup—no guesswork required.
Carbon Monoxide and Generator Use
Carbon monoxide (CO) is called the "silent killer" for a reason—it's invisible, odorless, and can be deadly even at low concentrations. It's a normal byproduct of the combustion of fuel. When a portable power station is fueled by gasoline, diesel, or propane, it will always release CO as a component of the exhaust, whether it's a new or old model. Even newer generators with sophisticated emission controls still emit dangerous levels of the gas.
In poorly ventilated areas, CO can build up around structures, particularly during calm weather or in partially enclosed areas such as patios and small gardens. The gas does not easily disperse in such conditions. Once built up, CO can enter the home through cracks, soffits, attic vents, or air intakes—potentially reaching dangerous levels indoors without any warning signs.
4 Serious Risks of Placing Generators Too Close
It's not just CO you need to worry about. Setting your generator too close comes with multiple hazards:
1. Heat Damage
When a generator runs, its exhaust gases can reach temperatures over 500°F. If placed too close to your home, the heat can warp, melt, or burn nearby materials such as siding, deck railings, or plastic furniture. Extended exposure can also discolor walls or cause permanent damage to your home's exterior.
2. Noise Pollution
Portable generators typically produce between 60 and 90 decibels of noise—similar to the sound of a lawnmower. When placed near bedrooms, living areas, or open windows, this noise can easily seep indoors, disturbing sleep and increasing stress levels. This can be especially unpleasant during storms or outages, when peace and quiet are already in short supply.
3. Fire Hazards
Fire risk is another major concern. The muffler and engine parts of a generator get extremely hot during operation. If the unit is surrounded by dry leaves, mulch, or wooden decking, those materials can catch fire. Fuel spills during refueling or leaks from the tank can also ignite if exposed to these high temperatures.
4. Legal and Insurance Issues
Improper generator placement can have legal and financial consequences. Some home insurance policies may not cover damage caused by misused or poorly placed generators. In addition, many city building codes and regulations have specific rules about generator distance and operation. Violating these codes may result in fines, denied claims, or forced relocation of your setup.
Place Your Portable Generator 20 Feet Away
That means 20 feet from doors, windows, vents, or crawl space openings. And always angle the exhaust pipe away from those areas.
Why 20 Feet
When You Might Need More Than 20 Feet
  • Windy conditions: Wind can push exhaust toward your home even from 25+ feet away.
  • Wall design and fences: Recessed patios, retaining walls, or nearby hedges can trap fumes.
  • Multi-level homes: CO can rise into second-floor windows even when the unit is 20 feet away.
  • Neighbor concerns: If you're in a tight community, fumes and noise can also affect others. Move it further back to be a good neighbor.
Pro tip: If you're unsure, test the generator in an open space first and use a CO monitor indoors to check for any trace leakage.
Best Outdoor Placement for a Portable Generator
Choosing where to put the generator goes beyond distance. Think of it like setting up a small engine outdoors—you need ventilation, stability, and weather protection.
What to Look For:
Feature
Why It Matters
Flat, stable surface
Prevents tipping or fuel leakage
Non-flammable base
Concrete, gravel, or fireproof paver pads
Good airflow
Avoid fences or overhangs that trap exhaust
Water protection
Use a generator tent or vented canopy
Never place your generator:
  • On grass or soft ground
  • Directly under a tarp (condensation hazard)
  • Inside a shed or plastic storage bin
Two EcoFlow Smart Generators with green bodies and silver tops placed on grass in front of a house, displaying digital screens showing battery levels at 99%.Two EcoFlow Smart Generators with green bodies and silver tops placed on grass in front of a house, displaying digital screens showing battery levels at 99%.
How to Use Cords or Transfer Switches Safely
When your generator sits 20+ feet away, powering your house becomes a logistics issue. Here's how to connect safely:
Option 1: Extension Cords
  • Use outdoor-rated, heavy-duty cords (12-gauge or thicker).
  • Match the cord's wattage rating to your generator and devices.
  • Never run cords through windows, under carpets, or across walkways.
Option 2: Transfer Switch
  • Connects directly to your home's electrical panel.
  • Lets you power hardwired systems like heat, AC, or sump pumps.
  • Eliminates backfeeding risk (which endangers utility workers and neighbors).
Best practice: Hire a licensed electrician to install a manual or automatic transfer switch. It's safer and more efficient in the long run.
Comparison of Portable Generator Types
Even for "quiet" or "eco" models, the 20-foot rule still applies. Here's how the main types compare:
Type
Advantages
Drawbacks
Open-Frame Gas Generator
High power output; suitable for whole-house backup or job sites
Noisy, higher emissions, not ideal for sensitive electronics
Inverter Generator
Clean, stable power for electronics; quiet and lightweight
Lower output; higher cost per watt
Dual-Fuel Generator
Can run on gasoline or propane; longer runtime; flexible fuel storage
Heavier; higher upfront cost
Looking for something safer and easier to use? The EcoFlow Smart Generator 4000 (Dual Fuel) is built for exactly that. It automatically shuts off if carbon monoxide levels get too high, works with the DELTA Pro 3 for hands-free backup power, and lets you check everything from an app indoors. You can use either gasoline or propane, and it runs more efficiently than most. Just remember—no matter how smart your generator is, it still needs to sit at least 20 feet from your home.
EcoFlow Smart Generator 4000 offers 4000W peak power, dual fuel support, and app control—ideal for emergencies, RVs, and backup home power.
Distance Is the First Line of Safety
If in doubt, go further. Even 25–30 feet may not be overkill in windy or tightly packed neighborhoods.
Use the 20-foot rule as a minimum—not a suggestion.
A portable generator is a powerful tool—but only when used with caution. The key is distance: 20 feet or more, exhaust pointed away, on a dry, solid surface. Add a safe connection method like a transfer switch and resist the temptation to bring the generator closer "just for a minute."
Set it up right the first time, and your generator will be a lifeline—not a liability.
FAQs about Generator Safety Distance
Q1: Can I place my generator on a wooden deck?
A: Not recommended. Wood is flammable, and generator exhaust areas get very hot. Plus, vibration can make the unit shift or tip. If you must use a deck, place a thick fire-resistant mat or non-combustible board underneath, and keep the hot side clear of railings, clutter, or leaves.
Q2: How do I protect my generator from rain if it's outside?
A: Use a generator tent or canopy designed for ventilation and weather protection. These allow airflow while shielding against rain. Never use a tarp—it traps moisture, blocks airflow, and increases shock or CO risk.Avoid DIY wooden or plastic boxes unless they're properly vented and heat-safe.
Q3: Can I build a shed or box around my generator?
A: Yes, but it must be well-ventilated. Include cross-venting with slats or vents at different heights, and keep space around the exhaust. A weatherproof roof is fine, but don't fully enclose the sides. Fans and cutouts help but require careful DIY work. Safer option: buy a commercial enclosure rated for generator use.
Q4: What if my property doesn't allow 20 feet of clearance?
A: Work with what you have—safely. Use a dolly to move the generator farther from the house, even down a slope or near a fence. Long outdoor-rated cords can bridge the gap. If fumes or noise are an issue, try an inverter generator or mount a ventilated, weatherproof box in a distant spot. For long-term use, think about installing a standby generator.
Portable Power Stations
