What a Lightning Protection System Does and How to Install One
Lightning feels rare until a storm knocks out the power on your street. Canada actually sees millions of strikes a year, and the overwhelming majority never touch a building at all. This guide covers what a lightning protection system actually does, how to tell if a property needs one, what inspection and installation involve, and how to stay protected between storms.
What Is a Lightning Protection System?
Before getting into components and installation, it helps to clear up what this kind of system actually does, since the name itself leads a lot of people astray.
A lightning protection system does not stop a strike from happening. What it does is give the current aa low-impedance path to ground from the roof to the ground, so the charge bypasses the building's structure and wiring instead of burning through them. A common misconception follows from that: a lightning rod does not attract a strike that would otherwise have missed the building entirely. It intercepts a strike that was already headed for that spot.
In Canada, installation follows CSA B72, the national installation code for lightning protection systems. It plays a role similar to NFPA 780 and UL 96 in the United States, though the codes are not identical, so a system designed to a US standard isn't automatically compliant here. A storm knocking out the power is often the first sign a home wasn't fully protected in the first place, and our guide to preparing your home for storms covers that side of things in more practical detail.
Understanding what the system does is one thing. Seeing what it's actually made of is another.
The Components of a Lightning Protection System
A complete system is really several separate parts working together, and each one solves a different piece of the problem.
Air terminals, also called strike termination devices, are short rods placed near roof peaks and corners to intercept a strike before it reaches the structure.
Conductors are braided metal cables that carry the current from the air terminals down to the ground.
Bonding connections link other metal objects on the building, gutters, vents, pipes, to the same system. This step prevents dangerous side flashes between separate metal parts that would otherwise sit at different electrical potentials during a strike.
Ground terminations, usually rods, plates, or a buried mesh, route the charge safely into the earth once it reaches the bottom of the system.
Surge protection devices address a different part of the overall protection strategy. A nearby strike, one that never touches the building directly, can still send a damaging voltage spike through the power lines. A surge protector installed at your main electrical panel is built specifically to stop that.
A physical system and a surge protection device are not interchangeable. One keeps a direct strike from setting the structure on fire. The other keeps a nearby strike from frying a router, a fridge control board, or a home office setup. Neither one, though, keeps the lights on once the grid itself goes down, which is where backup power comes in.
Knowing the parts of a system is useful, but not every property needs the full setup right away.
Signs a Property Needs Lightning Protection
Some properties genuinely carry more risk than others, and knowing which factors matter helps put the decision in perspective rather than treating it as an all-or-nothing purchase.
Tall, isolated structures, or ones near open water or the tallest trees on the property, take a disproportionate share of strikes compared to shorter buildings nearby. A history of nearby strikes, valuable or sensitive electronics, a home office, or medical equipment that needs continuous power are all reasons to weigh protection more seriously than the average home might. According to Environment and Climate Change Canada, Canada averages over 2 million lightning strikes a year, with roughly 9-10 fatalities and 100-150 injuries annually, figures worth confirming directly on canada.ca before publishing, since the exact numbers are periodically updated.
Power surges are one of the more common signs something nearby has already been struck, and they don't always announce themselves the way a direct hit does. Our breakdown of warning signs of surges covers that specific gap. For a property where a single room's worth of backup isn't enough, sizing up to whole-home coverage is worth considering.
Once a property looks like a candidate, the next question is how an existing or new system actually gets checked.
Lightning Protection Inspection: What It Involves
An inspection is really two separate checks, one visual and one electrical, and both matter for different reasons.
Visual inspection checks for corrosion, loose connections, or components that shifted during a windstorm, an ice storm, or recent roof work. Continuity and ground resistance testing confirms the path to ground is still low resistance. Industry references generally cite resistance thresholds in the low single-digit ohms, but the specific threshold under CSA B72 should be confirmed with a licensed Canadian inspector rather than assumed from a non-Canadian standard.
A reasonable default is an annual visual check with a fuller inspection every few years, and always after a severe storm, a roof replacement, or any renovation that touches the roofline. Our own shelf cloud storm safety tips cover how to spot the kind of severe wind event that should trigger an inspection sooner rather than waiting for the scheduled check.
Inspection catches problems in a system that already exists, but plenty of homeowners are starting from zero.
Installing Lightning Protection: What the Process Looks Like
Installation is not a project to take on yourself or hand to a general contractor, given how much the bonding and grounding work determines whether the system actually functions during a real strike.
The general process runs through a site assessment, a system design matched to the building's height and materials, air terminal and conductor placement, grounding work, and a final certification and test. Cost varies a lot by home size, roof complexity, and whether the installer carries UL or CSA certification. No reliable, current CAD figure turned up in research for this guide, so treat any specific price you see elsewhere as needing a live quote rather than a number to plan a budget around. Timing the work is worth planning ahead of storm season rather than after the fact, the same logic behind our winter storm preparation checklist, which applies just as much to scheduling a lightning system installation as it does to stocking an emergency kit.
Whether a system is brand new or years old, staying protected is an ongoing job rather than a one-time purchase.
Staying Protected Between Storms
Schedule an inspection after any major storm, a roof replacement, or a renovation that touches the roofline, rather than waiting for the next scheduled check to come around on its own.
A physical system and panel-level surge protection cover the building and its wiring. Anything that genuinely cannot tolerate even a brief outage, a sump pump, a medical device, a home office, still needs its own backup power on top of that layer. Our guide to staying prepared for outages covers what that third layer actually looks like in practice. Treat all three layers, the physical system, the surge protection, and the backup power, as one plan rather than three separate purchases made at different times, since each one covers a gap the other two leave open.
A lightning protection system doesn't stop a strike. It gives the current a safe path to ground, and pairing it with surge protection and backup power covers the gaps a rod and cable alone can't.
Get an existing system inspected on schedule, and treat backup power as part of the same protection plan rather than an afterthought bought after the first bad outage. The DELTA 3 Ultra Plus and DELTA Pro Ultra linked above cover a single room or a whole home, depending on which layer of that plan you're missing.
Does a lightning rod attract lightning to a house?
No. A lightning rod intercepts a strike that was already headed for that spot on the building. It doesn't draw a strike that would have otherwise missed the structure entirely.
How often should a lightning protection system be inspected?
A reasonable default is an annual visual check with a fuller inspection every few years, and always after a severe storm, a roof replacement, or renovation work that touches the roofline.
What does it cost to install lightning protection on a home?
Cost varies significantly by home size, roof complexity, and installer certification. No reliable current figure is stated here; get a live quote from a certified installer rather than budgeting from an outdated number.
Can lightning damage electronics without a direct strike?
Yes. A nearby strike can send a damaging voltage spike through the power lines even without touching the building itself, which is exactly what a whole-home surge protector is designed to stop.
Is a whole house surge protector the same as a lightning protection system?
No. A lightning protection system gives a direct strike a safe path to ground and protects the structure itself. A surge protector guards the wiring and electronics inside from voltage spikes, including ones caused by a nearby, indirect strike.
Does homeowners insurance in Canada cover lightning damage?
Most standard homeowners policies in Canada cover lightning-related damage, but coverage details, deductibles, and any exclusions vary by insurer and policy, so confirm your specific coverage directly with your provider.
