How to Prepare for a Hurricane: Build Your Emergency Plan & Backup Power System
When hurricanes occur, you will experience destructive winds, floods, and blackouts that may extend up to days or weeks. What separates panic from preparation is planning and having power backups in place before the storm strikes. In this article, we will discuss what you should do to protect your loved ones, your property, and your food storage from being damaged during a power outage.
Key Takeaways
  • Backup power is critical: Power failures are inevitable during hurricanes, so make sure you have a clean, silent, reliable power source.
  • Create two kits: Prepare both a Go-Kit and a Stay-at-Home Kit to meet your needs in short and prolonged emergencies.
  • Family emergency plan: Make sure you know what you need to do, whether to evacuate or stay at home and find a safe room for sheltering.
  • Keep your food safe: Close all the doors of the refrigerator and freezer for as long as possible.
  • Plan: Start preparing long before the hurricane season to avoid stress.
EcoFlow DELTA 3 Max Portable Power Station
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. 2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. 3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2 kWh product.
The EcoFlow DELTA 3 Max is the perfect device for those families that need to prepare for hurricane season. Despite its small size, the DELTA 3 Max provides enough power to run pumps, cell phones, refrigerators, and other important devices even during a blackout. It requires no fuel, emits no smoke, and makes no noise.
These features make it an excellent backup power solution for situations when the power grid goes down, because you can use it safely indoors without negatively affecting health. Its small size lets the user move the generator wherever needed. Plus, its multiple output ports let you charge several devices at once. With a few upgrades, the generator can charge from any power source, from wall sockets to solar batteries.
Focus on Backup Power First
Hurricane outages are common during severe storms and often last several days. While you can generate electricity with gasoline-powered generators, they come with downsides, including exhaust gas, dangerous fumes, the risk of monoxide poisoning, and storage problems.
Portable power stations are a better choice. These devices run quietly and emit no pollutants so that you can use them safely indoors. With enough energy capacity, they can power lights, charge smartphones and tablets, run a fridge, and even run medical equipment in an emergency.
Another benefit is that these devices are usually expandable, and you can add extra batteries or connect to a home backup system to provide power during long outages.
You can also charge these devices from different sources, including wall outlets, vehicle chargers, or solar power after the clouds have cleared.
Expandable Capacity : 4–48 kWh, from 1 day to week of home power during outages. Powerful and Versatile: Delivers both 120V and 240V outputs with up to 4,000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6,000W of power when needed.
EcoFlow DELTA Pro 3 is designed for whole-house backup and is the most flexible system for use during hurricane season because of its higher capacity and high output, which means that it can supply energy to some essential circuits in the house, thus enabling refrigerators, lights, phones, and any other communication devices to work even during long blackouts. Unlike gasoline-powered generators, it is noiseless, produces zero emissions, and is safe to use indoors.
Another advantage is its flexibility: after the storm passes and the skies clear, you can recharge the DELTA Pro 3 from solar panels, wall outlets, or even your car, so you can use it without worrying about fuel supplies.
EcoFlow DELTA Pro Ultra Whole-Home Backup Power
Discount auto-applied at checkout-The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use. 7.2-21.6 kW output, powerful enough to run your whole home even with a central AC 6 kWh-90 kWh capacity, whole-home backup for extended outages
If you need a more powerful energy source, you can choose EcoFlow DELTA Pro Ultra, which lets you expand capacity and power your whole house during a storm.
Build Your Hurricane Emergency Kit & Survival List
You can't prepare for hurricanes without packing all the supplies in your go-bag. Put all the necessary things into two separate bags to be prepared for both evacuation and stay-at-home cases:
Go-Kit (3 days, portable)
  • One gallon of water per person per day
  • Food that won’t go bad and a manual can opener.
  • NOAA weather radio (battery-powered or hand-crank)
  • Flashlights and batteries
  • First aid kit and at least 7 days’ supply of medication
  • Important documents in waterproof bags, cash, and copies of your IDs
  • Phone charger and power banks
  • Hygiene supplies and additional stuff for your children or pets
Stay-at-Home Bag (2 weeks)
  • Additional supplies of food and water
  • More batteries and charging cables for the power station
  • Tarpaulins, duct tape, gloves, and sanitation supplies
These tips align with guidelines from the American Red Cross, the National Weather Service, and NOAA. Connecting a power station to your kit will keep your phones, lamps, and appliances working when normal batteries are depleted.
In addition to powering up the devices, having a reliable source of electricity provides an extra layer of protection for necessities such as:
  • Medication: Portable oxygen generators, CPAP devices, or refrigerated medication can stay functional and safe.
  • Communication: With charged phones and radios, you can stay connected with your family members and get emergency warnings.
  • Food safety: Keeping your refrigerator and freezer running helps prevent unnecessary food spoilage and illness.
  • Comfort: Lights reduce stress in dark environments, while fans and other electrical devices provide a comfortable indoor atmosphere.
Combining official recommendations with backup power sources makes your kit truly essential in an emergency.
Develop an Easy‑to‑Follow Family Emergency Plan
Preparedness involves not only materials but also people. A plan ensures everyone knows what to do in a disaster.
  • Evacuation Zones: Call your local emergency management agency and ask if you live in an evacuation zone. Know your escape route and practice it in advance.
  • Evacuate or Stay in Place: Do not occupy trailer homes or travel trailers during hurricane-force winds. Decide in advance what course of action to take.
  • Safe Room: Pick a sturdy, inner, windowless room on the lowest floor that is not expected to flood. Fill it with water, food, flashlights, and a Go-Kit.
  • Communication Plan: Develop a communication plan, including contact numbers, in case your telephone line is not working. Exchange emergency contacts, set a meeting point, and discuss the plan with your relatives before hurricane season begins.
  • Special Considerations: Think about your elderly parents, children, pets, or anyone using special medical equipment. Have a backup system prepared for them.
Secure Your Home
Hurricane preparation reduces potential harm to your property and helps keep your home safe during the storm.
  • Wind protection:
  • Get shutters or precut boards ready for your windows.
  • Secure any loose items outside that could become flying objects, such as patio furniture, charcoal grills, and garden supplies.
  • Garage doors are susceptible to wind damage, reinforce them.
  • Flood protection:
  • Clear your gutters of any leaves or other debris to prevent flooding.
  • Raise your most important utilities as much as possible – electric panels, air conditioning and heating units, and appliances if you can.
  • Have sandbags, plastic sheets, and other sealants on hand to divert water.
  • Store your valuables in higher places in your house.
  • Insurance:
  • Check your policies ahead of time; you must purchase flood insurance separately from your regular homeowners insurance.
  • Take pictures of your house beforehand.
  • You can protect yourself from the most serious damages by preparing ahead of time.
Get Information and Take Action When the Storm Arrives
  • Alerts: Sign up for local emergency alerts.
  • Watch vs. Warning: A Hurricane Watch means conditions are possible within 48 hours; a Warning means conditions are expected within 36 hours.
  • Evacuation: If officials issue an order, leave promptly with your Go‑Kit.
  • Sheltering: If staying home, move to your safe room, stay away from windows, and monitor updates.
  • Power Prep: Fully charge your power station before the storm arrives so it’s ready the moment power fails.
After the Storm
  • Wait for the official all‑clear before leaving your safe room or returning home.
  • Avoid downed power lines and floodwater.
  • Use power stations according to manufacturer instructions; never operate gas generators indoors.
  • Photograph damage for insurance claims.
  • Discard food that has been warm or exposed to floodwater.
How much backup power do I need for a hurricane?
Most households need sufficient energy to keep their fridge, lights, cellphones, and any necessary medical equipment working for up to 1–3 days. A 2 kWh-capacity power station will suffice for these needs; bigger units support longer outages.
Is it possible to operate a portable power station inside during a hurricane?
Yes, high-quality portable power stations generate no emissions and are created for indoor operation.
How long will my EcoFlow power station work during the power cut?
It all depends on the power station and its load. Medium-size models can keep your fridge and lights running for many hours; extendable power stations can run for days.
Which is better for hurricanes, a gas generator or a power station?
The power station is safer and quieter to use inside a house. A gas generator offers more runtime but should be operated outdoors because of serious CO risks.
Do I need solar panels for hurricanes?
Solar panels are not necessary but very helpful. Once the weather clears, solar panels will charge your power station without using fuel.
A reliable electricity source, an emergency kit filled with essentials, and a solid family plan can help reduce the risk and stress of a hurricane. Start by preparing your electricity needs now, and once you have everything covered, the rest becomes much simpler. Check out how to prepare with battery backups and power solutions.
Home Backup
