How to Survive a Tornado: What to Do Before, During, and After
A tornado warning can arrive with only minutes of notice, which means how to survive a tornado usually comes down to what's already known and already packed, not what gets figured out in the moment. This guide covers the warning signs worth watching for, how to shelter indoors, outdoors, in a vehicle, or in a mobile home, what belongs in an emergency kit, and what to do once the tornado has passed, drawing on guidance from the Canadian Red Cross and the City of Calgary. Tornado safety starts well before the sky turns green.
Know the Warning Signs of a Tornado
A tornado rarely announces itself clearly, and by the time it's obvious, the safest window to act may already be closing. A handful of signs are worth knowing well before storm season arrives.
  • A rotating, funnel-shaped cloud reaching toward the ground
  • An approaching cloud of debris, even without a visible funnel
  • A sky that turns dark, sometimes with a green or yellow tint
  • Large hail, often just ahead of the worst winds
  • A roar that sounds like a freight train
A tornado watch means conditions are favourable for one to form, while a tornado warning means one has actually been spotted or is imminent. Canada's alert system has also shifted toward warnings that target the exact area at risk rather than covering an entire region, which narrows down who actually needs to act right now.
Tornadoes can also shift direction with little notice, so waiting to actually see the funnel before taking shelter isn't a safe plan. It also helps to know how a tornado looks and behaves differently from a sudden straight-line wind blast, since the two get confused constantly and can call for slightly different responses.
Knowing the signs only helps if a kit is already packed.
Build a Tornado Emergency Kit Before Storm Season
tornado safetytornado safety
A warning gives minutes, not days, which means the kit needs to already exist before the sky turns green. Here's what belongs in it.
The Canadian Red Cross recommends building a kit that covers at least 72 hours: enough water and food for everyone in the household, a flashlight, a battery or hand-crank radio, a first aid kit, and any medications that can't be replaced on short notice.
  • Water and non-perishable food for at least 72 hours
  • Flashlight and spare batteries
  • Battery or hand-crank radio
  • First aid kit
  • Medications and copies of prescriptions
Power is one of the first things to go once a tornado passes through, and a way to actually charge and run the essentials belongs in that kit rather than something to figure out afterward. Being able to stay self-sufficient through those first 72 hours is the same standard most emergency preparedness guidance points to, and it's worth building that discipline into backup power the same way it applies to water and food.
EcoFlow DELTA 3 Max Plus (2048Wh)
2,048 Wh capacity with 3,000 W continuous output and a 6,000 W surge rating, small enough to keep charged in a closet alongside the rest of the kit. Fastest recharge lands around 43 minutes to 80 percent using generator charging. Sized to run a fridge, a router, and a handful of essentials through the outage that commonly follows a tornado, rather than just keeping a phone topped up. Priced around $1,399 CAD.
Kit's ready, next is knowing exactly where to go.
Where to Shelter During a Tornado
Where to go matters as much as knowing a tornado is coming, and the right answer changes depending on where the warning catches you.
Indoors, the lowest level or a basement is safest. Without one, a small interior room away from windows works instead; get under sturdy furniture, cover the head and neck, and stay off elevators.
Outdoors, get inside if it's at all possible. If not, lie flat in a ditch or low ground and cover the head, staying clear of trees, and never shelter under an overpass, since wind speeds can intensify under an overpass rather than offering real protection.
In a mobile home, leave immediately for the nearest sturdy building. Mobile and manufactured homes offer little protection regardless of how well they're tied down.
While driving, don't try to outrun a tornado. Reach a solid structure if one is close enough; if not, pull over, turn the hazards on, and get to a low-lying area away from the car, or, as a last resort, stay buckled in with the head below window level.
Much of this same playbook, lowest level, away from windows, an interior room, applies to any severe storm producing damaging winds, not just a confirmed tornado.
EcoFlow DELTA Pro Ultra
Starts at 6.144 kWh in a single unit, expandable up to 90kWh across a full system. Continuous output of 7,200 W with a 10.8 kW surge; a single inverter accepts up to 5.6 kW of solar input, climbing to 16.8 kW across a three-inverter system. Built for households that want whole-home backup already staged before a warning is even issued, not something to shop for during the window they should be sheltering instead. Pricing starts around $5,799 CAD for a base configuration.
Sheltering gets you through the tornado, what's next matters just as much.
What to Do After a Tornado Passes
how can you be prepared for a tornadohow can you be prepared for a tornado
Surviving the tornado itself is only half the job. What happens in the next few hours matters just as much for staying safe.
Stay sheltered until it's actually confirmed safe to come out, rather than stepping out the moment the wind dies down. Once outside, watch for downed power lines, gas leaks, broken glass, and structures that look unstable, and stay out of any building that's been damaged until it's been checked.
After that, checking on neighbours, family, and pets comes next, along with photographing any damage for insurance before starting to clean up.
Power outages after a tornado can stretch on for days rather than hours, which is exactly where the backup power covered above starts to earn its keep, since running the existing fridge off a charged unit is a lot more reliable than icing down a cooler and hoping it lasts.
Before, during, and after are all covered, here's the short version to remember.
Surviving a tornado comes down to three things that all need to happen before the sky turns green: spotting the warning signs early, knowing exactly where to shelter, and having a kit and backup power already staged rather than improvised. None of that works if it's assembled the week a watch gets issued. Build the kit and confirm the backup power is charged this month, and the DELTA 3 Max Plus and DELTA Pro Ultra options covered above are already staged to make that possible.
What is the safest place to be during a tornado?
The lowest level of a sturdy building is safest, ideally a basement or a small interior room with no windows. Get under sturdy furniture and cover the head and neck until it's confirmed safe to come out.
How much warning do you typically get before a tornado hits?
A tornado warning can arrive with only minutes of notice, sometimes less, which is why having a kit and a shelter plan ready ahead of time matters more than reacting quickly once the warning sounds.
Is it safe to shelter in a car during a tornado?
A car isn't a safe place to ride out a tornado. Reach a sturdy building if at all possible; if there isn't one nearby, pull over, turn on the hazards, and get to low ground away from the vehicle, or stay buckled in with the head below window level as a last resort.
What should be in a tornado emergency kit?
At minimum, enough water and food for 72 hours, a flashlight, a battery or hand-crank radio, a first aid kit, and any medications that can't be replaced quickly. A charged backup power station, like the EcoFlow DELTA 3 Max Plus, is worth adding too, since it can run a fridge and a few essentials once the power goes out.
What's the difference between a tornado watch and a tornado warning?
A watch means conditions are favourable for a tornado to develop, so it's time to stay alert. A warning means a tornado has actually been spotted or is imminent, which means taking shelter immediately rather than waiting to see it first.
How long can a power outage last after a tornado?
It varies widely, but outages after a tornado can run for days rather than hours, especially where the damage takes out transmission infrastructure rather than just a local line. That's long enough that a portable power station, something like the DELTA Pro Ultra for a whole household, ends up doing a lot more work than a flashlight and a few candles.
