How Does a Heat Pump Work in Cold Canadian Weather?
- How Does a Heat Pump Heat a Home in Winter?
- How Much Electricity Does a Heat Pump Use?
- How Does a Heat Pump Compare With Other Heating Systems?
- How Can Canadian Homeowners Manage Heat Pump Energy Use?
- What Should Canadians Consider Before Choosing a Heat Pump?
- Conclusion
- FAQ
- Should I Replace My Gas Furnace with a Heat Pump?
A modern cold-climate heat pump can keep pulling usable heat from what feels like thin winter air long after the temperature has dropped well below freezing—a fact that still surprises anyone who grew up with a furnace roaring in the basement. What does change as the mercury falls is how efficiently it runs and how much heat it can deliver, and this is why, on the worst nights of the year, plenty of Canadian houses still fall back on a second source.
It’s worth understanding how one of these systems behaves in winter before you start collecting quotes, because its performance determines what you’ll spend on hydro, how it measures up against a gas furnace, and whether the unit you’re pricing is actually built for a climate like ours. This guide walks through how a heat pump draws heat out of cold outdoor air, what drags its winter performance down, and what’s worth sorting out before a deep freeze or an outage.
How does a heat pump work in winter? Instead of burning fuel at the heat pump itself, an air-source system transfers heat from outdoor air into the home. The main refrigeration components are the outdoor coil, compressor, indoor coil, and expansion device.
Outdoor Unit Extracts Heat From Cold Air
The cycle starts outside your exterior wall, where a fan draws outdoor air across a heat-exchanger coil. Refrigerant temperature and pressure vary by system, allowing the coil to absorb heat from outdoor air even below freezing within the equipment's rated operating range.
Because the refrigerant is colder than the outdoor air moving over the coil, heat transfers into it and the refrigerant becomes a low-pressure gas. A guide to cold-climate heat pumps in Canadian winters explains how compressors, defrost controls, sizing, and maintenance affect low-temperature performance.
Compressor Raises the Heat Temperature
To answer “how does a heat pump work for heating?”, follow the refrigerant into the compressor in the outdoor cabinet. Compression raises the vapour’s pressure and temperature, preparing it to release heat at the indoor coil. The exact pressures and temperatures depend on the refrigerant, equipment design, and operating conditions.
Indoor Unit Releases Heat Into the Home
The hot gas moves through insulated refrigerant piping to an indoor air handler or ductless head. Cooler return air passes across the indoor coil, where heat transfers to the air and the refrigerant condenses to a liquid. After the expansion valve lowers its pressure and temperature, the refrigerant returns outdoors and the cycle repeats while the system can extract enough heat to meet demand.
How much electricity does a heat pump use? The answer depends on the home’s heat loss, thermostat setting, outdoor temperature, equipment capacity, and efficiency. When evaluating backup from a power station, use the heat pump’s verified electrical input, starting characteristics, auxiliary-heat demand, and desired runtime.
Heat Pump Electricity Use Depends on Heating Demand
Heating demand depends on the conditioned area and the building’s heat loss. A drafty 2,500-square-foot century home may require more continuous output than a tightly sealed townhouse, although climate and indoor setpoint also matter. Heat lost through walls, windows, ceilings, and air leakage increases the energy the system must supply.
Outdoor Temperature Affects Heat Pump Energy Use
The wider the difference between outdoor and indoor temperature, the harder an air-source heat pump generally works. Natural Resources Canada notes that coefficient of performance declines as outdoor temperature falls, but the actual value is model- and condition-specific. Use the manufacturer’s extended performance tables and the home’s design temperature instead of assuming one COP range applies to every system.
Heat Pump Efficiency Depends on the System and Home
Seasonal performance depends on the equipment, installation, controls, airflow, and building envelope. A variable-speed compressor can adjust output to changing heat loss rather than cycling only at full capacity. A solar generator does not reduce the heat pump’s electrical demand, so backup sizing still requires verified input, starting behaviour, and expected runtime.
A heat pump generally uses less electricity than baseboard or electric resistance heating to deliver the same amount of heat, but performance varies with weather and equipment. A guide to home heating systems can help compare heat pumps, furnaces, hydronic systems, and electric resistance options. A gas furnace’s output and cost also depend on its rating, fuel price, and operating conditions.
| Heating System | Primary Fuel Source | Average Efficiency | Cold-Weather Behaviour | Typical Canadian Scenario |
| Cold-Climate Heat Pump (ccASHP) | Electricity | 150% – 350% (COP 1.5 – 3.5) | Model-specific output; verify published capacity at the local design temperature | May suit homeowners replacing aging A/C and furnace equipment |
| Natural Gas Furnace | Natural Gas | 92% – 98% AFUE | Rated output is generally less dependent on outdoor air temperature | Common in urban and suburban areas on established municipal gas grids |
| Electric Resistance Heating | Electricity (Duct heaters) | 100% (COP 1.0) | Consistent output, but 1 kWh of power for every 1 kWh of heat delivered | Typically auxiliary or emergency backup within heat pump air handlers |
| Baseboard Heaters | Electricity | 100% (COP 1.0) | Operates by room; sustained use can raise winter electricity costs | Often found in older apartments, cottages, or rural homes without ducts |
Insulation, thermostat strategy, and regular maintenance can reduce heating demand, while outage planning addresses a different risk. Backup requirements depend on the heating equipment, circuits to be supported, and expected outage duration.
Improve Home Insulation to Reduce Heating Demand
The building envelope strongly affects heat-pump demand. Caulking suitable window gaps, replacing worn weatherstripping, and improving attic insulation can slow heat loss. The benefit depends on the home’s existing condition, climate, and the quality of the retrofit.
Optimize Heat Pump Settings for Efficient Heating
Heat pumps usually perform best with modest, stable temperature settings, although the recommended control strategy depends on the equipment and any backup heat. A deep overnight setback can trigger high-demand recovery or supplemental resistance heat in some systems. Follow the manufacturer’s thermostat guidance and compare energy use before and after changing the schedule.
Plan Backup Power Wisely for Winter Outages
Freezing rain, wet snow, wind, and falling branches can interrupt electric service. Because heat pumps, furnace blowers, thermostats, and controls depend on electricity, heating may stop during a grid outage. Size backup power from verified running and starting loads, the circuits to be supported, and the required runtime:
Dual-Fuel (Hybrid) Systems: A heat pump paired with a gas furnace may need backup electricity for the blower, ignition, thermostat, and controls. The EcoFlow DELTA Pro 3 Portable Power Station provides 120 V and 240 V output options. Actual demand and runtime depend on the furnace and other connected loads. Confirm equipment ratings, connection method, and transfer equipment before sizing backup.
All-Electric Heat Pumps: Whole-home central heat pumps draw 2.5 kW to 4.5 kW continuously in freezing weather, and auxiliary electric heat strips can spike demand past 10 kW. For extended outages, battery systems like the EcoFlow DELTA Pro Ultra Whole-Home Backup Power, featuring 240V split-phase output and scalable capacity up to 90 kWh, can maintain critical sub-circuits. By locking out energy-intensive electric resistance strips and running the variable-speed heat pump on a maintenance cycle alongside home essentials, you maintain safe indoor temperatures without overloading the system.
Before anyone quotes you a price, settle three things: how the unit performs at low temperatures, what a heat-load calculation says the house needs, and what it costs to run next to the alternatives. Local climate, your electricity rate, and whatever backup heat you have belong in the decision too.
Check the Heat Pump’s Cold-Climate Rating
Choose a heat pump whose published low-temperature capacity matches the home’s calculated load and local design conditions. A baseline model intended for milder weather may lose capacity sooner than a certified cold-climate unit. Review Natural Resources Canada guidance and model-specific performance data; some cold-climate air-source heat pumps can operate near -30°C, while supplemental heat may still be required below the unit’s rated range.
Consider Home Heating Requirements
A qualified HVAC technician should perform a CSA F280 heat-load calculation before equipment is specified. Oversized equipment may cycle inefficiently, while undersized equipment may rely more heavily on supplemental heat during cold snaps. Window area, ceiling height, air leakage, insulation, and local design temperature all affect the result.
Compare Installation Costs and Energy Use
A system’s lifetime running cost matters alongside its purchase price, and a cold-climate heat pump often costs more upfront than a new gas furnace. Federal program availability has changed: the Canada Greener Homes Grant is closed, the Canada Greener Homes Loan stopped accepting new applications on October 1, 2025, and July 31, 2026 was the final application date for the Oil to Heat Pump Affordability program. Homeowners should verify current provincial and utility incentives before budgeting a project.
Cold-climate heat pumps can provide heating and cooling from one system, but winter performance depends on the model, outdoor temperature, installation, and the home’s heat loss. Insulation, a steady thermostat strategy, routine maintenance, and a realistic outage plan can improve comfort and energy performance. Compare rated low-temperature capacity with the home’s calculated heating load before choosing equipment.
Replacement depends on the furnace’s condition, local energy prices, the home’s heating load, electrical capacity, and the heat pump’s low-temperature performance. Some homeowners choose an all-electric system, while others retain a furnace in a dual-fuel configuration.
How Long Can a Heat Pump Run Continuously?
A heat pump can run continuously for hours or even days at a time, and it’s built specifically to do so. Inverter-driven units operate most efficiently by settling into a lower, steady speed rather than stopping and starting frequently, which is also what gives you even heating.
At What Temperature Do Heat Pumps Become Ineffective?
There is no single cutoff temperature for every heat pump. Capacity and efficiency decline differently by model as outdoor temperature falls. Compare the manufacturer’s extended performance data with the home’s design load and planned supplemental-heat controls.
What Is the Average Lifespan of a Home Heat Pump?
A residential heat pump may serve for roughly 15 to 20 years, but climate, runtime, installation, maintenance, and equipment design affect service life. Filter care, professional maintenance, and keeping the outdoor unit clear can support reliable operation.
