How to Power a Garage Heater During Canadian Winters
- What Type of Power Does a Garage Heater Need?
- How Much Electricity Does a Garage Heater Use?
- How Do You Power an Electric Garage Heater?
- Power High-Wattage Heaters With Increased Output Capacity
- How Can You Reduce Garage Heating Electricity Use in Winter?
- How Can You Use a Garage Heater Safely?
- Conclusion
- FAQ
Once temperatures drop below freezing, an unheated garage becomes a place you hurry through, and the cold is hard on stored paint, tools, and car batteries. Heating it properly isn’t just a matter of picking the right-sized unit—you have to match its voltage and power draw to the wiring you already have, then figure out where insulation and backup power fit into your setup. Knowing what that heat costs over a Canadian winter, and how to run it safely, matters just as much.
What you can run in your garage comes down to the space you want to heat and the wiring or fuel line already there. Warming one workbench calls for a very different setup than heating an entire 2-car garage.
Heater Type | Primary Power Source | Typical Voltage / Supply | Best Use Case |
Portable Electric | Grid Electricity | 120V (15A circuit) | Spot heating a small workbench |
Hardwired Electric | Grid Electricity | 240V (20A–40A circuit) | Heating an entire 2-car garage |
Forced-Air Gas / Propane | Natural Gas / Propane + Electricity | Fuel line + 120V outlet | Rapid heating in large spaces |
Ductless Heat Pump | Grid Electricity | 240V dedicated circuit | Year-round heating and cooling |
Electric Heaters Require 120V or 240V Power
An electric garage heater may be a 120V portable unit for spot heating or a larger wall- or ceiling-mounted model on a dedicated 240V circuit. Portable units commonly draw up to 1,500W, while larger models vary by design and rated output. Understanding how electric heating works helps you compare the load with the available circuit, but a licensed electrical contractor should confirm conductor size, breaker capacity, and installation requirements.
Gas Heaters Require Fuel and Sometimes Electricity
A gas garage heater may use natural gas or propane for heat while still requiring electricity for a blower, ignition system, controls, or thermostat. Fuel-burning units must be approved for the intended location, installed to applicable local requirements, supplied with combustion air, and vented exactly as the manufacturer specifies. Do not assume that opening a garage door or window makes an unvented model safe.
Heat Pumps Require Electricity for Heating Operation
Cold-climate ductless mini-split heat pumps are used in provinces such as British Columbia, Quebec, and Nova Scotia. Rather than making heat with resistance coils, they use electricity to run an inverter-driven compressor that transfers heat from outside. Many garage-sized mini-splits need a dedicated 240V circuit and outdoor disconnect. Efficiency and low-temperature capacity vary by model, outdoor temperature, and installation, so compare certified performance data instead of assuming the same result at -25°C or -30°C.
The wattage printed on the unit and the hours it runs give you a rough estimate of how much electricity it uses. The thermostat cycles the heater on and off, and your local rate sets what those kilowatt-hours actually cost.
Calculate Consumption Using Heater Wattage
Divide the wattage by 1,000 to get kilowatts, multiply by the hours the heater runs, and then apply the current rate from your local utility. Rates and time-of-use periods vary by province, utility, and billing plan, so a single Canada-wide price would not be accurate.
1,500W (1.5 kW) portable heater: 6 kWh over 4 hours
5,000W (5.0 kW) hardwired heater: 20 kWh over 4 hours at full output
7,500W (7.5 kW) heavy-duty heater: 30 kWh over 4 hours
A thermostat switches the heater off once the space reaches the selected temperature, so the unit may not run continuously. Actual daily use depends on insulation, air leakage, outdoor temperature, thermostat settings, door openings, and how often the space is occupied.
Understand Starting and Running Power Requirements
Air compressors and table saws can pull extra power briefly at startup, while a resistive heater generally draws close to its rated load once energized. Heat pumps and gas unit heaters may have compressors or blower motors with higher starting demand. When sizing a portable power station or household circuit, compare both running watts and startup requirements with the equipment specifications.
A permanent electric heater usually runs on its own dedicated circuit. If you also want heat during an outage, a solar generator or other backup system must match the heater’s voltage, connection method, running load, and any startup demand. Winter solar production can be limited, so stored capacity and a safe recharge plan matter as well.
Connect Electric Heaters to Dedicated Household Circuits
Most permanent units are wired directly into the home’s main breaker panel. Circuit, breaker, conductor, disconnect, and overcurrent-protection requirements depend on the heater’s nameplate rating, installation instructions, and the electrical code adopted in the province or territory. A licensed electrical contractor should calculate the load and complete or verify the installation rather than relying on a generic breaker-size example.
Support 120V Heating Loads With Expandable Battery Storage
For a 120V garage heater, an expandable battery system gives you a flexible way to manage energy use or keep the workspace warm during a grid outage. The EcoFlow TITAN 5000 Classic Whole-Home Backup Power paired with the Smart Home Panel 10 (120V) starts at 5kWh of storage and can be expanded up to 30kWh as needed. If a deep freeze keeps the heater running longer, add modules to match its draw and the hours you need. Where you put the system matters in that kind of cold, since lithium-iron-phosphate (LFP) batteries are rated for indoor temperatures and should not be stored or charged below freezing. To feed the garage circuits safely, install the TITAN 5000 Classic and 120V SHP 10 in a conditioned space near the main panel, such as a basement or utility room. You’ll still need a licensed electrician to check the exact wiring setup and confirm the load is compatible.
High-wattage, hardwired 240V garage heaters need a power system built for split-phase voltage and higher output. Paired with the 240V Smart Home Panel 10, the EcoFlow TITAN 5000 Plus Whole-Home Backup Power supports 120V/240V split-phase power and delivers up to 7.2kW of battery output. That gives homeowners more flexibility when planning garage heating, since the system can support compatible 240V heating equipment that meets circuit and load guidelines. As with any indoor-rated battery backup system, house the unit and sub-panel inside a temperature-controlled area rather than an unheated winter garage. Before installation or operation, have a qualified electrician confirm the heater’s rated wattage, dedicated circuit setup and overall system compatibility.
When heat escapes through the garage door, walls and roof, the heater has to run much more often. Cutting down that heat loss makes the space more comfortable and trims your power bill.
Insulate Garage Doors, Walls, and Ceilings
Fitting rigid foam board into the recesses of a standard garage door cuts heat loss through its metal panels right away. Where wall studs or rafters are exposed, pairing a proper vapour barrier with fibreglass batts or mineral wool helps keep heat from escaping through the exterior walls and roof.
Seal Gaps to Prevent Cold Air Infiltration
Insulation will not block a prairie wind blowing under the garage door, so check the bottom rubber seal and perimeter weatherstripping every fall before the first snowfall. To stop drafts, replace cracked seals and run exterior-grade caulking around window frames and the spots where pipes or wires enter the wall.
Control Heating With Programmable Thermostats
Keeping an empty garage at 20°C all week wastes electricity. A programmable or smart line-voltage thermostat can hold it at 5°C to 8°C while the garage sits empty, enough to keep pipes and stored liquids from freezing, then bring it up to 16°C automatically an hour before you head out for weekend projects.
Garage heaters share space with vehicles, tools and stored materials, so clearance and installation matter as much as output. Check the manufacturer’s instructions and local codes before using any heating equipment.
Verify Circuit Ratings Before Connecting Heaters
Good electrical safety starts with checking the breaker rating, conductor size, receptacle condition, heater nameplate, and other loads on the circuit. Do not place a high-wattage portable heater on a circuit that is already serving a freezer or power tools unless a qualified professional has confirmed the combined load and installation are suitable.
Maintain Required Clearances Around Heating Equipment
Keep gas cans, sawdust, cardboard boxes and aerosol solvents away from heat sources in the garage. Follow the manufacturer’s minimum clearance guidelines. Portable and ceiling-mounted heaters typically need at least 3 feet (1 metre) of clear space in front. For a ceiling-mounted unit, allow that much space underneath as well. For a portable heater, check the manufacturer’s instructions for any clearance required beneath your model. Mount wall units well away from stored chemicals and vehicle hoods.
Ensure Proper Ventilation for Fuel-Burning Heaters
Natural gas, propane, kerosene, and diesel heaters can produce carbon monoxide and other combustion pollutants. A diesel garage heater or other fuel-burning unit should be used only when the model is approved for the intended space and installed, supplied with combustion air, and vented according to its instructions and local requirements. Health Canada advises against using outdoor fuel-burning equipment in a garage and recommends certified carbon monoxide alarms; follow the alarm manufacturer’s placement instructions rather than using a generic mounting height.
The right garage-heating setup starts with the heater’s voltage and wattage, then factors in the circuit, the space and how long you need heat. A dedicated circuit is the usual choice for a permanent heater, while a backup battery system may support a compatible load when its output matches the unit’s draw. Insulation and draft sealing can also help the heater run less often and trim winter power bills. For any hardwired unit or backup connection, have a licensed electrician sign off on the installation.
Can You Plug an Electric Garage Heater into a Regular Outlet?
Yes, you can plug a portable electric heater rated at 1,500 watts or less into a standard 120V, 15-amp household outlet as long as nothing else on that circuit is drawing a heavy load. A larger 240V garage heater cannot run on a standard outlet; it needs to be hardwired or plugged into a dedicated high-amperage receptacle installed by an electrician.
Is a 1500 Watt Heater Enough for a Garage?
No, a 1,500W heater will not heat an entire single- or two-car garage through a Canadian winter—it puts out only about 5,120 BTUs. However, it does work well as a spot heater aimed at a workbench or a small seating area in a well-insulated space.
Are Extension Cords Safe for Garage Heaters?
No, standard household extension cords are not safe for garage heaters: sustained high amperage can overheat the cord, melt its insulation and start a fire. Plug portable heaters directly into a wall outlet, and use a permanently wired circuit for larger units.
Is It Safe to Heat a Garage with a Propane Heater?
Yes, as long as you use a unit rated for indoor or garage use, vent it properly outdoors and have a working carbon monoxide detector. Unvented construction-style torpedo heaters should never be left running unattended in a closed garage because of carbon monoxide and moisture buildup.
