WSSI: How the Winter Storm Severity Index Turns a Forecast Into Likely Impacts
Six inches of snow might be an ordinary winter day in Buffalo but enough to disrupt roads, schools, and daily routines in Atlanta. Snowfall totals alone cannot explain that difference. The Winter Storm Severity Index (WSSI) helps bridge that gap by illustrating how anticipated snow, ice, and wind could affect cities based in part on local conditions. Understanding the definition of WSSI can help you interpret storm maps, examine National Weather Service (NWS) advisories and decide if your home requires a backup power plan ahead of severe winter weather.
What Is WSSI? A Plain-Language Definition
WSSI stands for Winter Storm Severity Index. Developed by NOAA's Weather Prediction Center (WPC), this National Weather Service product maps the potential impacts of winter storms across the contiguous United States. Instead of simply reporting snowfall totals, it shows how disruptive winter weather could be.
What the WSSI is and isn't
The Winter Storm Severity Index (WSSI) helps explain the potential impacts of winter weather, including snow, ice, and blowing snow. However, it is not an official warning or a precise prediction of when and where specific impacts will occur.
  • Purpose: The Winter Storm Severity Index (WSSI) helps communicate the potential impacts of winter weather, including snow amount, snow load, ice accumulation, and blowing snow.
  • Not an official warning: The Weather Prediction Center (WPC) says the WSSI does not depict official warnings. Always check official National Weather Service (NWS) forecasts and warnings.
  • Not a specific impact forecast: A WSSI rating does not guarantee a particular outcome. For example, a “moderate” rating does not automatically mean schools will close.
  • No exact timing: The WSSI does not indicate precisely when impacts will occur during the forecast period.
  • How the overall rating works: Each component is rated on a 1-to-5 scale, and the overall WSSI reflects the highest component value rather than average.
  • How to use it: Treat the WSSI as a guide to potential impacts, then check local NWS updates and local authorities for official alerts, timing, school closures, and travel guidance.
Why local climate matters
The same snowfall can have a greater impact in a Southern city that rarely sees snow than in a snowbelt community accustomed to winter driving and snow removal, while urban areas receive slightly higher weight in the Snow Amount component. Knowing how to use National Weather Service forecasts can help you compare the WSSI with local warnings and better understand potential risks. Because the index shows possible impacts rather than guaranteed outcomes, consider your local climate and outage risks when deciding whether your home needs backup power.
When a High WSSI Rating Should Trigger a Home Backup Plan
A Major or Extreme WSSI rating doesn't mean your house will definitely lose power. However, certain map layers highlight conditions that can damage trees and power lines. If your home depends on electricity for heating, water, refrigeration, or medical equipment, use a high-impact forecast as a prompt to review your backup plan.
Ice-covered trees and power linesIce-covered trees and power lines
Layers that point to outage risk
The WSSI's Snow Load and Ice Accumulation layers can help identify winter weather conditions that may increase the risk of power outages. Heavy snow can weigh down trees and power lines, while ice combined with wind can damage trees and utility infrastructure, potentially disrupting electricity for days.
  • Snow Load: Estimates the severity associated with the weight of snow on trees and power lines.
  • Ice Accumulation: Assesses impacts associated with accumulated ice and wind, including transportation disruption and downed trees or power lines.
A tiered backup list
A tiered backup power plan helps you prioritize essential devices first and expand coverage based on your household’s needs and budget. Start with communication and lighting, then consider keeping essential appliances running or powering critical circuits through a professionally installed backup system.
Backup tier
What it covers
Possible solution
Tier 1: Stay informed
Phones, weather radio, flashlights
Rechargeable batteries, spare batteries, and standard charging arrangements
Tier 2: Protect essentials
Refrigerator, router, lights
Portable power station or suitable home battery
Tier 3: Protect critical circuits
Compatible 240V well pump or heating circuit
Professionally installed home backup system
Choosing Home Backup Power
Once you know which appliances and circuits matter most, you can compare backup systems based on output, storage capacity, and electrical compatibility. For households preparing for extended outages, a winter power-outage preparation plan can help you organize supplies and decide which devices deserve priority. For homes that need more than phone charging and lighting, a permanently installed battery system may be worth considering.
EcoFlow TITAN 5000 Classic
The EcoFlow TITAN 5000 Classic provides 4,000W of rated AC output at 120V and 5kWh of battery capacity per unit. It can expand to 30kWh with additional batteries and, when paired with the compatible 120V Smart Home Panel 10, can support up to 10 selected circuits. Installation should be completed by a licensed electrician.
• 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don't even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
EcoFlow TITAN 5000 Plus
For homes with compatible 240V requirements, the EcoFlow TITAN 5000 Plus offers 7,200W of battery output and 5kWh of capacity per unit. It can support selected 120V and 240V circuits with the appropriate Smart Home Panel 10 configuration. An electrician should verify running and startup requirements before connecting a well pump or heating equipment.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
How the two products divide the job
The EcoFlow TITAN 5000 Classic and EcoFlow TITAN 5000 Plus serve different backup needs depending on the circuits your household needs to keep running during a winter storm. The Classic is intended for compatible 120V essentials, while the Plus can support suitable 240V circuits within its rated output and installation requirements.
  • EcoFlow TITAN 5000 Classic: Consider this model for compatible 120V essentials such as a refrigerator, lights, Wi-Fi router, and phone chargers.
  • EcoFlow TITAN 5000 Plus: Consider this model if your backup plan includes a compatible 240V heating circuit or well pump and a larger solar array connected directly to the unit’s supported solar input.
  • Confirm electrical compatibility: Have a licensed electrician verify the correct Smart Home Panel 10 configuration, circuit voltage, running watts, startup demand, and total connected load. Electric furnaces, auxiliary heat strips, ranges, and water heaters can exceed a system’s output when used together.
  • Plan for winter recharging: Rooftop solar systems connected to the utility grid generally shut down during an outage unless configured with compatible backup equipment. Panels connected to the TITAN’s supported solar input may recharge the unit, but snow cover, short daylight hours, and cloudy weather can reduce production.
  • Treat Storm mode as an extra precaution: EcoFlow's Storm mode can charge a compatible system ahead of supported severe weather events, but it may not respond to every local NWS alert. Check forecasts and warnings yourself, and charge the system ahead of a storm whenever possible.
Runtime estimate (example only)
To estimate backup runtime, multiply the battery's capacity in watt-hours by 0.85 to account for assumed conversion losses, then divide by your average load in watts. For example, a 5,000Wh EcoFlow TITAN 5000 Classic could provide roughly 14 hours at a 300W average load, while a 15kWh setup could provide about 42 hours under the same conditions. Actual runtime depends on measured loads and usage, so check how ice accumulation can cause power outages when assessing storm risks, and remember that the WSSI cannot predict how long an outage will last.
WSSI Impact Levels and Map Layers, Decoded
The WSSI uses five impact levels to describe how disruptive winter weather could be. The overall rating shows the greatest expected impact among the components, while individual layers explain which hazard is driving it.
The five impact levels
The Winter Storm Severity Index (WSSI) uses five impact levels to describe the potential disruption from winter weather, ranging from limited impacts to widespread, historic impacts. Understanding these levels can help you assess possible travel difficulties, recovery time, and preparation needs, but they do not guarantee specific outcomes.
Level
WSSI Primer description
Limited
Small accumulations of snow or ice are forecast, with minimal impacts expected, if any.
Minor
Roughly aligns with NWS advisory-level criteria. Minor disruptions are possible, particularly for people who are unprepared.
Moderate
Roughly aligns with NWS warning-level criteria. Snow or ice events may require a day or two of recovery.
Major
Significant impacts are possible, even with preparation. Recovery from snow or ice events may take several days.
Extreme
Historic, widespread, severe impacts are possible, with recovery potentially taking many days to a week or longer.
The layers behind the rating
The Winter Storm Severity Index (WSSI) combines several layers to show how different winter weather hazards may affect communities. Each layer highlights a specific type of impact, helping you understand what is driving the overall severity rating.
  • Overall Winter Storm Impacts: Shows the highest severity value across the WSSI components, rather than an average of all the ratings.
  • Snow Amount: Estimates potential impacts from snowfall while accounting for local climate, since the same snowfall can affect different communities in different ways.
  • Snow Load: Highlights potential impacts from the weight of accumulated snow on trees and power lines, which can increase the risk of damage and outages.
  • Ice Accumulation: Shows potential impacts from accumulated ice, including transportation disruption and damage to trees and power lines, especially when combined with wind.
  • Blowing Snow: Highlights potential disruptions from snow blown or drifted by wind, which can reduce visibility and make travel hazardous.
Time windows and updates
The WPC WSSI page provides Day 1, Day 2, and Day 3 forecasts, a combined Days 1–3 view, and a rolling 24-hour outlook. A product description from the 2022–2023 season stated that updates were issued every two hours for up to 72 hours, while the experimental Probabilistic WSSI (WSSI-P) described the likelihood of different impact levels over Days 1–7; check the live WPC page to confirm current availability and forecast ranges. Since snowfall can affect communities differently, from places that regularly manage heavy snow to cities that see the most snow, use the map as a starting point and cross-check local forecasts and warnings before making plans.
Pairing the WSSI With Your Local Forecast in Four Steps
The Winter Storm Severity Index (WSSI) shows potential winter weather impacts, while local forecasts and official alerts provide more specific timing and safety guidance. Use these four steps to understand the risk in your area before making travel or household decisions.
WSSI map and winter storm preparation workspaceWSSI map and winter storm preparation workspace
  1. Check the overall rating: Open the WPC Winter Storm Severity Index and locate your area to see the potential impact level.
  2. Inspect the component layers: Check whether snow amount, snow load, ice accumulation, or blowing snow is driving the overall rating and which hazards may affect your community.
  3. Check local timing: Review your local NWS forecast and hourly weather information to understand when conditions may develop, since the WSSI does not provide exact event timing.
  4. Follow official watches and warnings: A Winter Storm Watch means significant winter weather is possible, while a Winter Storm Warning means it is expected or occurring. Follow local authorities’ instructions and update your plans as conditions change.
Winter storm watches and warnings can change as forecasts evolve, so having a consistent preparation routine helps you respond to new information. Planning what to do before, during, and after a winter storm can help you organize emergency supplies, protect essential household needs, and review your recovery steps. Also, remember that “Winter Severity Index” can refer to other tools, so check the source to ensure you are reading the NWS Winter Storm Severity Index (WSSI).
WSSI vs. Other "Winter Severity Index" Tools
Searching for the term "winter severity index" can lead to tools that measure something different from the NWS WSSI. Some evaluate an entire winter season, while others track the effects of winter conditions on road maintenance.
Index
Who runs it
What it measures
Type
WSSI
NWS Weather Prediction Center
Potential impacts of an upcoming winter storm
Forecast
AWSSI
Midwestern Regional Climate Center, with NWS research
Season-long severity based on observed temperatures, snowfall, and snow depth
Historical record
MoDOT Winter Severity Index
Missouri Department of Transportation
Winter's impact on travelers and transportation operations
Operational performance measure
The NWS WSSI estimates potential impacts from an individual winter storm, while the Accumulated Winter Season Severity Index (AWSSI) tracks conditions across an entire season. Several state transportation departments, including Missouri DOT, use their own indexes to monitor winter maintenance needs. Understanding how snow, ice, and wind combine during severe winter weather helps explain why impacts vary by location and season.
The Winter Storm Severity Index (WSSI) translates potential snow, ice, and wind impacts into five severity levels, accounting for local climate. However, it is not an official warning and does not provide exact timing. Check the overall rating, review individual layers, consult your local NWS forecast, and follow official alerts. If snow load or ice accumulation frequently threatens your area, consult a licensed electrician to determine whether the EcoFlow TITAN 5000 Classic or EcoFlow TITAN 5000 Plus suits your backup power needs.
What does WSSI stand for?
WSSI stands for Winter Storm Severity Index, a National Weather Service product from NOAA's Weather Prediction Center that maps potential winter storm impacts.
Is the WSSI the same as a winter storm warning?
No. The WSSI estimates potential impacts across an area. Official NWS watches, warnings, and advisories communicate specific weather threats and should guide your decisions.
What do the WSSI levels mean?
The five levels are Limited (also called Winter Weather Area in some materials), Minor, Moderate, Major, and Extreme. They range from minimal expected disruption to widespread, potentially historic impacts.
Does a Major WSSI rating mean my power will go out?
No. A Major rating doesn't predict an outage at a particular address or tell you how long electricity might be unavailable. Snow Load and Ice Accumulation can help identify conditions associated with downed trees and power lines.
Is "winter severity index" the same as WSSI?
Not always. The term can also refer to seasonal climate measurements, such as the AWSSI, or transportation-maintenance tools such as Missouri DOT's Winter Severity Index. The WSSI specifically forecasts potential impacts from approaching winter weather.
Home Backup
