RV Fireplace Guide: How Electric Units Heat, What They Draw, and How to Run One Safely
Few things make a camper feel more like home than a fireplace glowing on a cold night. In most RVs, though, that fireplace is an electric heater with an LED flame, and it takes a big bite out of the power supply. On a 30-amp hookup, one running on high can crowd out other appliances. Off the grid, it can drain a 2kWh battery in a little over an hour. This RV fireplace guide covers how these units differ from propane heat, what they draw, and how to run one safely, plugged in or dry camping.
Electric RV Fireplace vs Propane Furnace: What Each One Actually Does
The "fireplace" in most modern RVs is an electric heater with an LED flame display, not a gas appliance. It runs on 120V AC, so it only heats when shore power, a generator, or a battery system feeds it. The propane furnace is a separate system that heats through the RV's ducts. A camper fireplace and a furnace share a goal, but they work differently.
What the Maker Specs Show
Three Furrion Greystone models show what is typical.
  • Curved 26" (WF2613L): Rated at 120V, 1,400 watts, and 4,600 BTUs. It has a digital thermostat, thermal cut-off, safety shut-off timer, and one-year warranty.
  • 3-Color Crystal LED wall mount, 26" (F2653BCFW): Listed at 1,500W and 5,100 BTUs. Current is 6.25A on low and 12.5A on high.
  • Built-in 60" (GF60SW15A-BL): Rated at 1,500W, 120V AC, 60Hz, and 12.5A. Settings run from 62°F to 82°F, with an automatic shut-off timer.
  • Lippert's electric category: Lippert lists electric units with LED flames and an integrated safety cut-off for overheating.
Where Propane Heat Fits In
The furnace is not free heat off the grid either. The Jayco 2025 Class A owner's manual warns that frequent furnace use substantially raises battery draw and propane use. It needs both propane and 12V power.
Some models may run the LED flame with the heater off, but the three Furrion pages do not say. Owners should check the fireplace manual before counting on a flame-only mode.
Question
Electric fireplace
RV propane furnace
Power source
120V AC
Propane, plus 12V for controls and blower (Jayco)
Typical rating (examples)
1,400 to 1,500W; 4,600 to 5,100 BTU (Furrion pages)
Varies by model; check the RV manual
Heat delivery
Room where it is installed
Ducted through the RV
Works with no shore power?
Only with a generator or battery system sized for it
Yes, while propane and battery last
Most owners use both systems over a cold season. Splitting heat between the furnace and a fireplace is a common part of staying warm while living in an RV through a northern winter.
Since the fireplace is purely electric, the real question is how much of the shore power it takes up.
How Many Watts Does an RV Electric Fireplace Use on 30A or 50A Shore Power?
On high heat, the Furrion models above are rated at 1,400 to 1,500 watts, about 12.5 amps at 120V. That is a big slice of a 30-amp service. The fireplace usually cannot run alongside other heavy loads.
The Basic Arithmetic
This is simple math, not a maker rating. A 30-amp service at 120V offers 30 × 120 = 3,600W. A 1,500W fireplace draws 1,500 ÷ 120 = 12.5A, matching Furrion's listed figure. About 17.5A is left for everything else.
On low, the F2653BCFW lists 6.25A, or about 750W at 120V. For that model, low heat roughly halves the draw. Other models vary.
What RV Makers Say About Limits
  • One big load on 30A: Keystone RV recommends running only one major 120-volt appliance at a time on 30-amp service to avoid tripped breakers.
  • More room on 50A, still finite: Keystone says 50-amp service can run two air conditioners and several other appliances together.
  • No house outlet adapters: On a standard 15-amp wall outlet with an adapter, Keystone says to run no 120-volt appliances. The adapter should power only the converter.
  • Never upsize the breaker: If the fireplace trips a breaker, owners should switch off other loads and find the cause before resetting.
Load (example)
Rated draw
Share of a 30A, 120V service
Fireplace on high (Furrion, 1,500W)
12.5A
About 42%
Fireplace on low (Furrion F2653BCFW)
6.25A
About 21%
Remaining after fireplace on high
n/a
About 17.5A
Service size shapes every heating choice on board. Before adding a fireplace, it helps to know how 30 and 50 amp systems differ in what they can run at once.
At a campground pedestal, those amps come from the grid. Off the pedestal, every one of them has to come from a battery or generator.
Can You Run an RV Fireplace Without Shore Power?
It can be done, but only for a short, planned session. A 1,500W heater drains batteries fast. A portable power station can run a single electric fireplace for RV use within its rated output. A larger unit can also keep a fridge and Wi-Fi going alongside it.
Runtime Estimates
Estimates only. The assumption is usable energy = capacity × 0.85 for conversion losses, using Furrion's listed ratings.
Setup
Calculation
Estimate
EcoFlow DELTA 3 Max, 1,500W fireplace on high
2,048Wh × 0.85 = 1,741Wh; 1,741 ÷ 1,500W
About 70 minutes
EcoFlow DELTA 3 Max, 1,400W fireplace (WF2613L) on high
1,741 ÷ 1,400W
About 75 minutes
EcoFlow DELTA 3 Max, F2653BCFW on low (about 750W, calculated)
1,741 ÷ 750W
About 2.3 hours
EcoFlow DELTA 3 Ultra Plus, 1,500W fireplace on high
3,072Wh × 0.85 = 2,611Wh; 2,611 ÷ 1,500W
About 1 hour 45 minutes
EcoFlow DELTA 3 Ultra Plus, fireplace 1 hour on high, then fridge and comms
2,611Wh minus 1,500Wh = about 1,111Wh left
Divide by the fridge, router, and phone label watts to estimate the rest
Rules for Battery-Powered Sessions
  • Plan on the rated draw: The estimates above assume continuous operation at the rated wattage. Thermostat cycling can reduce average consumption and extend runtime, but the result depends on the duty cycle and other connected loads. Short sessions take the chill off, and the furnace and layers handle the rest.
  • Plug in directly: The U.S. Fire Administration says to plug portable heaters straight into an outlet, never an extension cord or power strip. Owners should not rewire built-in units. An RV service technician handles that.
  • Skip a faulty unit: A fireplace that has tripped breakers, smells hot, or shows damage should be unplugged and checked first.
Dry camping on a cold evening is where a battery-powered fireplace session earns its keep. There is no generator noise at quiet hours and no exhaust near the door. EcoFlow portable power stations recharge from solar panels or a generator, among the other charging options EcoFlow lists for each model. These two match the setups in the table above.
If the plan is one 120V fireplace for a warm-up before bed, with nothing else heavy running, the mid-size unit covers the load within its rated output.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
When the fireplace has to share power with a 120V fridge and phones or Wi-Fi, a bigger battery and higher output give each load its own share without pushing the station past its rating.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•Smart Output Priority: Choose in the app which outputs stay powered to stretch runtime when it counts. Controlling home circuits requires a compatible home connection installed by an electrician. • Expandable Capacity: 3kWh base, expandable to approximately 11kWh. Pairs with a compatible EcoFlow Smart Generator for automatic start and stop. •6 Ways to Charge: Reaches 0 to 80% in 48 minutes with combined solar and generator charging.
The EcoFlow DELTA 3 Max suits one fireplace used on its own. The EcoFlow DELTA 3 Ultra Plus suits a fireplace plus a fridge and communications running together. For both, high-wattage heat drains the battery fast, so short sessions are the plan.
Battery planning is the core of cold-weather dry camping. Counting watt-hours before a cold weekend is part of planning power for off-grid camping, and heat is usually the biggest line item.
Whatever powers it, the fireplace still sits inches from walls, furniture, and bedding. Safety comes next.
Clearance, Ventilation, and Carbon Monoxide Safety in an RV
A camper electric fireplace produces no combustion gases, but it is still a heater in a tight space. Propane appliances, generators, and camp stoves are a different risk, because they can produce carbon monoxide.
Electric Fireplace and Heater Safety
These general heater rules come from the U.S. Fire Administration. The fireplace's own installation manual sets exact clearances.
Heater clearance from bedding in RVHeater clearance from bedding in RV
  • Keep 3 feet clear: Bedding, clothing, and curtains should stay at least 3 feet from the heater.
  • Turn it off for sleep: Heaters should be off at bedtime or when leaving the room. The shut-off timer on Furrion units helps here.
  • Look for a testing lab mark: USFA advises a heater tested by a recognized testing laboratory, with nothing else on the same circuit.
  • Keep airflow clear: The front and vents need open space. The model's manual gives exact distances.
Carbon Monoxide and Propane
Carbon monoxide (CO) is an odorless, colorless gas. The CDC says it kills without warning. Furnaces, stoves, lanterns, generators, and small engines can all produce it, and sleeping people can die before symptoms start.
  • Stoves and chemical heaters stay outside: The CDC says never to use a portable gas camp stove or flameless chemical heater indoors.
  • Generators need distance: The CDC advises running them outdoors, more than 20 feet from windows, doors, and vents. At a campground, that includes neighbors' rigs.
  • Know the symptoms: The CPSC lists headache, dizziness, weakness, nausea, vomiting, sleepiness, and confusion. Anyone who suspects CO poisoning should reach fresh air and call 911.
  • Respect the alarms: The Jayco manual says to move to fresh air at once if the CO alarm sounds. If the propane alarm sounds, shut off the propane and do not start the engine. Never silence an alarm by disconnecting the battery.
  • Test before each trip: Owners should test the rig's CO and LP alarm, as the manual describes.
A battery power station has no exhaust, so it can sit inside the RV, away from water and with its vents clear.
Cold snaps raise CO risks for campers and homeowners alike. Running heaters and generators more often is exactly why carbon monoxide risks in cold weather climb each winter.
With safety rules in place, the last step is picking a fireplace that fits the wall, the wiring, and the way a rig is used.
Choosing an RV Fireplace: Size, Mounting, and Features
Fireplaces for RVs come as built-in inserts, wall-mount units, and wide built-in platforms. Measure the opening, confirm the wattage the service can spare, and compare safety features before buying.
Measuring RV wall for fireplace insertMeasuring RV wall for fireplace insert
  • Size and mounting: The WF2613L cutout is 26" W x 6-1/8" D x 20-1/2" H. The F2653BCFW box is 20.5" x 26.375" x 5.375". The GF60SW15A-BL is 60"W x 4-5/8"D x 18-1/8"H.
  • Controls: The WF2613L has a digital thermostat. The GF60SW15A-BL offers 62°F to 82°F settings. It and the F2653BCFW add a remote and shut-off timer.
  • Wattage: Electric fireplace wattage is 1,400W for the WF2613L and 1,500W for the other two. On 30-amp rigs, lower wattage and a low setting leave more room for other loads.
  • What "efficient" means: All resistance heaters turn power into heat. An efficient electric fireplace is sized right for the space and used with a thermostat, not one that uses less energy per BTU.
  • Testing lab listing: None of the three Furrion pages states UL, ETL, or CSA certification. Buyers should look for a recognized lab mark on the unit or in its manual.
  • Warranty and installation: All three list a one-year warranty. Replacing a built-in unit can involve RV wiring, so an RV dealer or qualified technician should do it.
Quick checklist: opening size, mount type, wattage and amps, low and high settings, thermostat, timer, overheat cut-off, testing lab mark, and warranty.
Any new 120V appliance has to fit the rig's existing setup. Knowing the RV electrical system helps decide whether a 1,500W fireplace belongs on a 30-amp rig.
A 120V electric heater with a flame display, rated around 1,400 to 1,500W on the models checked, stands apart from the propane furnace. On 30-amp service, it should usually run without other heavy loads. Check the amps, keep 3 feet of clearance, use the timer, and test the CO and propane alarm before every trip.
For short off-grid sessions, the EcoFlow DELTA 3 Max handles a single unit within its rated output. The EcoFlow DELTA 3 Ultra Plus adds room for a fridge and communications devices. Both can be compared on the EcoFlow US site.
How many watts does an electric fireplace use in an RV?
The Furrion models checked list 1,400 to 1,500 watts on high, which is about 12.5 amps at 120V. Other models differ, so the rating label on the unit itself is the best guide to its exact draw. High and low settings change the number.
Can a 30-amp RV run an electric fireplace?
Usually, if the fireplace runs on its own. Keystone RV recommends running only one major 120-volt appliance at a time on 30-amp service, which helps avoid tripped breakers on the pedestal. Check the amps before adding other loads.
Is electric heat safer than propane heat in an RV?
An electric unit burns no fuel, so it is not a carbon monoxide source the way propane appliances are. It is still a heater, so keep anything flammable 3 feet away and turn it off at bedtime. The shut-off timer on many units can help.
Does an electric fireplace replace the RV furnace?
No. It warms the area around it, while the furnace heats the whole rig through ducts. Most owners use the fireplace to supplement the furnace, not to replace it, especially on very cold nights when the whole rig needs heat.
How long can a portable power station run an electric fireplace?
Not long on high heat. A 2,048Wh EcoFlow DELTA 3 Max runs a 1,500W fireplace for roughly 70 minutes (estimate), so plan short warm-up sessions and rely on the furnace and layers after that. Larger batteries add time but do not change the draw.
RV and Motorhomes
