Solar Generator vs. Gas Generator: Which One Is Better?
When the power goes out, you're choosing between two very different tools. The solar generator vs gas generator question isn't really about which one wins outright. It's about which one fits how you'll actually use it. A gas engine gives you instant, high-output power the moment you pull the cord. A solar generator, like the EcoFlow DELTA Pro Ultra, sits ready and silent, drawing on a battery you charge from sunlight or a wall outlet. Cost, noise, maintenance, and where you can safely run one all factor into the decision below.
Solar vs Gas Generator: Quick Comparison
Both types tackle the same solar generator vs gas generator problem: power when the grid goes down, just through different mechanics. One stores energy ahead of time in a battery. The other converts fuel into electricity on demand. Here's the side-by-side breakdown.
Fuel
Emissions
Noise
Maintenance
Lifespan
Solar Generator
Sunlight or wall outlet
None during use
Silent to near-silent
Minimal, no moving parts
Rated by charge cycles, often 2,500+
Gas Generator
Gasoline or propane
Carbon monoxide, exhaust fumes
60–90 dB, audible at a distance
Regular oil changes, filters, fuel management
Rated by engine hours, varies with upkeep
Pros and Cons of Solar Generators
Weighing a solar vs gas generator purchase comes down to trade-offs on both sides. Here's where solar comes out ahead, and where it doesn't.
Pros:
  • Runs completely silent, with no engine noise to disturb neighbors or wildlife
  • Zero emissions, so it's safe to run indoors or in an attached garage
  • No fuel to buy, store, or let go stale between uses
  • Minimal maintenance, since there are no moving parts to service
Cons:
  • Higher upfront cost than a comparable gas unit
  • Runtime is limited without sunlight or another way to recharge
  • Peak power output generally trails a similarly priced gas generator
  • Charging speed depends on how much sun you're getting that day
Pros and Cons of Gas Generators
Pros:
  • Lower upfront purchase price
  • Higher peak power output for demanding tools and appliances
  • Refuels in minutes instead of waiting on a recharge
  • Fuel stays widely available, even during regional outages
Cons:
  • Ongoing fuel costs add up with repeated use
  • Needs regular oil changes, filter swaps, and general upkeep
  • Loud enough to disturb neighbors or campsites nearby
  • Produces carbon monoxide and must never run indoors or in enclosed spaces
How to Choose a Generator?
Picking between a solar power vs gas generator setup starts with a few practical questions: how much power you actually need, where you'll run it, how often you'll use it, and how much risk you're willing to manage around fuel and exhaust.
How Many Watts Do You Need?
Add up the wattage of the appliances you actually need to run, then build in extra headroom for startup surge, the extra jolt of power many appliances draw the instant they switch on. Sizing off total home square footage alone tends to leave you short. This guide on solar generator size walks through it appliance by appliance.
Which One Is Cheaper to Operate in the Long Run?
Gas is cheaper to buy but keeps costing you every time you refuel and every time it needs an oil change. Solar costs more upfront, then settles into a near-zero running cost, since sunlight doesn't come with a bill.
Which One Needs Less Maintenance?
Solar generators have no moving parts, so there's essentially nothing to service. Gas generators need oil changes, air filter swaps, and fuel that hasn't gone stale sitting in the tank.
Which One Is Better for the Environment?
Gas generators burn fossil fuel and produce direct emissions every time they run. Solar generators produce none during use, though it's worth noting upfront that manufacturing the batteries carries its own environmental footprint. When it comes to overall impact, the gas vs solar generator comparison isn't entirely one-sided, just lower during actual operation for solar.
Which Generator Is Better for Your Situation?
The gas generator vs solar decision usually comes down to where and how you're using it. Here's how the two compare across the most common situations.
Home Backup
For whole-home or essential-appliance backup during an outage, a gas generator can run longer if you've got fuel on hand and a safe place to vent it outdoors. A solar generator is the safer call for anything near an attached garage or living space, since there's no fuel to store and no exhaust to manage.
Mobile Lifestyle
RVs, van life, road trips, and campgrounds tend to favor solar. Plenty of campgrounds restrict or ban gas generators outright over noise, and running one quietly next to your site isn't really an option. This is where the solar power vs gas generator comparison tends to favor solar outright, since it runs silent and works in enclosed spaces a gas unit never could.
Construction or Job Sites
Daytime commercial and job site use tends to favor gas, since power tools draw heavy continuous loads that gas engines handle more easily. For a lot of crews, the gas generator vs solar call tips back toward gas here. Solar avoids the fuel logistics and refueling downtime, but it needs enough capacity and recharge time to keep pace with a full workday.
Choose EcoFlow Solar Generators
Once you've landed on solar, the next question is capacity. If you've been going back and forth on a solar vs gas generator purchase, EcoFlow's lineup of solar generators covers everything from whole-home backup to a more mobile, mid-tier setup. For the full rundown, the best solar generators roundup is a good place to start, or check out the two options below.
EcoFlow DELTA Pro Ultra, best for higher-capacity, whole-home-oriented backup needs.
The EcoFlow DELTA Pro Ultra is built to carry serious loads, from central AC to a full kitchen, without blinking.
6kWh base capacity, expandable up to 90kWh for whole-home, multi-day backup. 7,200W continuous output handles high-draw appliances like central AC. 5.6kW solar input recharges quickly using rooftop or portable panels. Ideal for whole-home backup and extended outages.
EcoFlow DELTA Pro Portable Power Station, best for a more mobile, mid-tier setup suited to RV or outdoor use.
The EcoFlow DELTA Pro Portable Power Station covers heavy-duty needs without the whole-home footprint, and it's built to travel.
3.6kWh capacity, expandable up to 25kWh for extended trips or backup. 3,600W continuous output (7,200W surge) runs heavy-duty appliances and power tools. 1,600W solar input charges in as little as 2.8 hours of strong sun. Ideal for RV life, road trips, and mobile job sites.
Neither type wins outright, so in the solar generator vs gas generator decision, it comes down to fit. Gas generators offer more raw power and a lower price tag upfront. Solar generators trade that for quiet, low-maintenance, long-term value: no fuel runs, no oil changes, no exhaust to manage. Which one works depends on your budget, how you'll use it, and how much upkeep you want to deal with. If you're leaning solar, the EcoFlow DELTA Pro is a solid mid-tier place to start.
Are solar generators better than gas generators?
Neither is universally better in the solar generator vs gas generator debate. Gas wins on upfront cost and peak power. Solar wins on noise, safety, and long-term maintenance.
What is the disadvantage of a solar generator?
The main drawbacks are a higher upfront cost and a runtime that depends on how much sun is available to recharge it.
Which is better for camping, a Jackery or a gas generator?
For campsites that restrict gas generators over noise, the gas vs solar generator choice usually comes down easily in solar's favor. EcoFlow's solar generators run quiet with no fumes to manage, which matters more at a campsite than raw peak output.
Can a solar generator run a house?
Larger solar generators like the EcoFlow DELTA Pro Ultra can power essential home circuits, and even whole-home setups when paired with a smart home panel. The exact capacity you need depends on what you want to keep running during an outage.
Portable Power Stations
