What to Do When the Power Goes Out at Home
The TV cuts off mid-sentence. The fridge stops humming. If it's nighttime, the house just goes black, all at once. For a second or two, your brain scrambles for a plan it doesn't have: is it just us? Where did we put the flashlights? What do I even check first?
That scramble is the whole problem, honestly, not the outage itself. Most people can handle a dark house for a few hours. What trips them up is not having a plan for it.
This covers what to check in the first few minutes, how to keep food and medicine safe, staying warm or cool without HVAC, and when a situation stops being a wait-it-out thing and becomes a call-someone thing. For a broader preparedness checklist, see these power outage essentials before the next outage.
A portable power station solves a lot of it too, something like the DELTA 3 Max Plus for most households, or the DELTA Pro Ultra X when the load is bigger, but that's not the whole answer.
What to Do When the Power Goes Out, Immediately
Nobody thinks clearly in the first few minutes of an outage. That's normal. Here's what actually matters before the panic settles down.
Check If It's Just Your Home or the Whole Block
Look outside first. Dark streetlights and dark windows next door usually mean it's a grid problem, not something specific to your house. If the neighbors still have lights on, though, check your breaker panel before calling the utility; there's a decent chance it's just a tripped switch.
Most utilities have a live outage map now. Pull it up before you assume anything - it'll show what's affected and give you a rough restoration estimate. If your address isn't showing up, report it. Some outages don't get logged until enough people call in or submit through the app.
Unplug Sensitive Electronics
When power comes back after a storm, it often comes back with a surge. Computers, TVs, gaming consoles - unplug them while you're waiting. Leave one lamp switched on somewhere so you know the moment power's restored without walking room to room checking. Anything you can't unplug, put on a surge protector.
Keep food and medicine safe during a power outageKeep food and medicine safe during a power outage
Keeping Food and Medicine Safe
This is where the clock actually matters. People underestimate how fast it starts running.
How Long Food Stays Safe in the Fridge and Freezer
Four hours, roughly, for a closed fridge. A full freezer buys you closer to 48 hours if the door stays shut; a half-full one more like 24. Every time the door opens to check on things, that clock resets a little, so try to leave it be.
An appliance thermometer takes the guesswork out of it. Below 40°F, it's fine. Above that for more than 2 hours, especially with meat or dairy, just throw it out. Not worth finding out the hard way.
Managing Medications That Need Refrigeration
Insulin and similar medications usually tolerate short temperature swings better than people expect, but check the manufacturer's guidance rather than guessing. A cooler packed with ice can hold safe temperatures for a day or more if it comes to that. Keep a written list of critical medications and dosing schedules with your emergency documents too. Sounds like overkill until you're trying to remember exact numbers by flashlight at 2 a.m.
Staying Warm or Cool Without Power
HVAC is usually the first thing to go, and depending on the season, that turns into its own emergency fast.
Staying Warm in a Winter Outage
Layers and blankets first, before anything involving a flame or a plug. Shut the doors to rooms nobody's using so body heat stays put in one space instead of spreading thin across the whole house.
And this one matters: never run a generator, camp stove, or charcoal grill indoors, not in the garage, not with a window cracked. Carbon monoxide builds up fast, and it doesn't announce itself. Battery-powered heated blankets get you warmth without that risk attached.
Staying Warm in a Winter OutageStaying Warm in a Winter Outage
Staying Cool in a Summer Outage
Cross-ventilation works when the air outside is actually cooler than inside. Open windows on opposite sides of the house and let it move through. If it's 95 out, skip it.
Stay hydrated. Don't do anything physically demanding during the hottest part of the day - that's when heat exhaustion gets people, usually without much warning. Find out where your nearest cooling center is before you ever need that information.
A small battery-powered fan makes a real difference and barely dents your backup power reserves.
Backup Power, Your Best Tool for a Long Outage
Everything so far gets you through the first stretch. This is what gets you through the rest of it.
When a Portable Power Station Is Enough
For most short to moderate outages, a portable power station is plenty: phones, routers, small appliances, a day or more of runtime, no fumes, no trip to the gas station, quiet enough to run right there in the living room. For households that need a longer-lasting backup setup, learn more about battery backup for home options.
Matching Battery Capacity to Your Household Needs
Sizing this right comes down to what you actually need powered, not the biggest number on the shelf.
For phones, Wi-Fi, laptops, lights, and a fridge during a short outage, something in the 2kWh class does the job. The EcoFlow DELTA 3 Max Plus (2,048Wh) fits that everyday load well.
EcoFlow DELTA 3 Max Plus Portable Power Station
· Capacity: 2,048 Wh (LFP/LiFePO4) · AC Output: 3,000W (6,000W surge) · X-Boost™ 3.0: Up to 3,800W · AC Input: 1,800W · Max Solar Input: 1,000W · USB-C Output: 140W max · UPS Switchover: < 10ms · Weight: 22.1 kg (48.7 lbs) · Warranty: 5 years
And for whole-home backup during genuinely extended outages, that's a different scale of problem entirely. The EcoFlow DELTA Pro Ultra X is built for demand well past what a single portable unit can handle. For larger loads and longer outages, explore EcoFlow's whole-home backup power solutions.
Write down what you actually can't go without. Look up what those things draw in watts. Buy around that list, not whatever happens to be on sale.
DELTA Pro Ultra X
· Capacity: 12.288 kWh standard (6,144 Wh × 2) – expandable to 184.32 kWh · AC Output: 12kW continuous, 120/240V – up to 36kW with 3 parallel units · Max Solar Input: 10kW (2 ports, 5,000W each) · AC Input: 12kW, 50A · UPS Switchover: <10ms standalone, <20ms with Smart Home Panel 3 · Battery Chemistry: LFP · IP Rating: IP54 · Noise Level: <30 dB at 0.5m · Weight: Inverter 76.06 lbs (34.5 kg) / Battery 111.3 lbs (50.5 kg) · Warranty: 5 years
Staying Informed During an Outage
Cell towers get overloaded, the internet drops with the grid, and suddenly staying informed takes more effort than it should.
Battery or Hand-Crank Radios for Local Updates
A NOAA weather radio picks up restoration updates and emergency alerts even when every network around you is dead. Hand-crank models never run out of batteries, which matters more than it sounds like it should. Keep your utility's outage reporting number written down somewhere too; data service tends to get spotty at exactly the wrong moment.
Conserving Phone Battery
Airplane mode plus Wi-Fi calling, if it's available, cuts a surprising amount of drain since the phone stops hunting for signal constantly. Dim the screen. Kill background apps. Save what battery's left for calls and texts that actually matter, not for scrolling.
When to Call for Help
Most outages just need patience. A few need action, and it helps to know which is which before you're standing in the middle of one.
Signs You Should Report the Outage
Downed power lines are always live. Always. Report them immediately and keep everyone away, including pets. Sparking equipment or a burning smell near the breaker panel means calling the utility right then, not waiting to see if it settles down. And if there's any smell of gas near the property, leave first and call from a safe distance. That's not a judgment call.
When to Check on Vulnerable Neighbors
An elderly neighbor living alone might need help with food, meds, or just staying at a safe temperature. Anyone on powered medical equipment should get checked on early in a prolonged outage, not after a day or two has quietly slipped by. A knock on the door takes thirty seconds, and it can cause a real problem before it becomes one.
Most of this comes down to what's already set up before the power ever goes out. A calm plan is really the only thing standing between a stressful evening and a genuinely bad one.
Backup power, decent food safety habits, and a way to stay informed cover almost everything a household runs into.
Frequently asked questions
What is the first thing to do when the power goes out?
Look outside. If the streetlights are out and the neighbors are dark too, it's the grid. If it's just your place, check the breaker panel first before calling the utility company.
How long can food stay safe in the fridge during a power outage?
Four hours in a closed fridge if you leave the door shut. A full freezer buys you about 48 hours; half-full, closer to 24. When in doubt, throw it out - food poisoning on top of a power outage is not the situation you want to be in.
Is it safe to use a generator indoors during an outage?
No. Generators, camp stoves, charcoal grills - all of them produce carbon monoxide, and it builds up fast in an enclosed space. A cracked window or open garage door doesn't fix it; use it only outside, away from windows and doors.
How do you keep medication cold without power?
A cooler with ice packs holds safe temperatures for 24 hours or more. Insulin and similar meds can often tolerate brief swings in temperature, but check the manufacturer's guidance rather than assume, and keep a written list of medications and dosing schedules with your emergency documents.
Can a portable power station keep the internet running during an outage?
It can, as long as your router and modem stay plugged into it. A 2kWh-class station like the DELTA 3 Max Plus handles a router alongside phones, laptops, and lights for a day or more without much trouble.
When should you report a power outage to your utility company?
As soon as you notice it isn't already listed on their outage map. Immediately, no delay, if there are downed lines, sparking equipment, or a gas smell nearby. Downed lines are always treated as live.
Power Outages
