What Temperature Should Your Water Heater Be Set To?
Most of us never touch the dial on the water heater. The showers run hot, and that seems like the end of it. But plenty of tanks are sitting at 140°F right now. That runs 20 degrees above what federal guidance suggests for a typical home. Water heating also accounts for about 12% of the energy your home uses, according to ENERGY STAR. So this one setting shows up on your bill and at your tap. Let's look at the right number, the risks, the savings, and how to change it.
What Is the Recommended Water Heater Temperature?
The recommended hot water heater temperature for most homes is 120°F. The federal home energy checklist from DOE says it plainly. Turn the tank down to the warm setting at 120°F.
That number balances two things you care about. Water still feels hot at the faucet. The tank stops burning fuel to hold heat nobody in the house uses.
So what temp to set your water heater controls to on an ordinary day? Start at 120°F. The catch is that it rarely matches what you have right now, and a few households genuinely need something else. Here is how the common cases break down.
Your Situation
Setting to Aim For
Why It Changes
Most households
120°F
Hot enough for showers, laundry, and dishes, with low scald risk and less standby heat loss
A newly installed tank
120°F already
A normal hot water heater temp out of the box is 120°F, since major brands now preset it there
An older home
Often 140°F today
The typical hot water heater temperature here is whatever the last installer or owner left behind
Large household, heavy hot water use
Above 120°F
Demand can outrun what a 120°F tank keeps up with on back-to-back showers
Older dishwasher with no heating element
140°F
It leans on the tank for sanitizing heat instead of heating its own water
Someone immunocompromised at home
140°F
Bacteria control depends on a hotter tank
You need hot storage and a safe tap
Store at 140°F, deliver at 120°F
A thermostatic mixing valve blends the output down before it reaches the fixtures
Most homes land in the first row. Before you change anything, work out which row you are in. The answer usually comes from the people in the house rather than from the tank itself.
That last row is the one people miss. A mixing valve costs more than turning a dial, and a plumber has to fit it. It is also the only option that gives you bacteria control and a safe tap at the same time.
One more thing worth checking is the dishwasher. Newer models heat their own water, so they no longer force the whole house to run at 140°F. If yours has a sanitizing cycle, it almost certainly has its own heating element.
The right number depends more than comfort. Safety is where this setting pulls in two directions at once.
Why Water Heater Temperature Matters for Safety
The ideal water heater temperature isn't just about comfort. It's the number where two competing risks both stay under control. The same setting that protects against one raises the other. A table shows that trade-off faster than a paragraph can.
Temperature
Scald Risk
Bacteria Risk
Best For
Below 120°F
Risk is minimal (requires prolonged exposure)
Elevated, Legionella can grow
Not recommended for any household
120°F
About 5 minutes
Controlled
Most households
130°F
About 30 seconds
Minimal
Rarely necessary outside specific needs
140°F
About 6 seconds
Minimal
Immunocompromised households, high-demand dishwashers
The takeaway isn't that one number is universally correct. It's that 120°F keeps both risks in check for most homes, and 140°F should be a deliberate choice, not a factory default left untouched.
A Couple of Common Myths, Cleared Up
Some homeowners assume a hotter tank means hot water lasts longer through a shower. In practice, a mixing valve or the shower's own hardware blends hot and cold before it ever reaches you. A higher tank temperature mostly just means more energy spent heating water that gets diluted anyway. Others assume turning the temperature down risks running out of hot water faster. That's not really how it works either. The tank still holds the same volume, it's just stored a bit cooler.
Safety explains the floor and ceiling of that range. What happens inside it is mostly a question of money.
How Water Heater Temperature Affects Your Energy Bill
For most households, the ideal hot water temperature question has one clean answer, and it happens to be the cheaper one too. Dropping the temperature isn't just a safety call. It also shows up directly on the monthly bill.
Compare Your Water Heating OptionsCompare Your Water Heating Options
What Dialing Down From 140°F to 120°F Actually Saves
Turning the temperature down from 140°F to 120°F can save an average household of 36 to 61 dollars a year in standby heat loss, according to the Department of Energy. Adding tank and pipe insulation stacks on top of those savings, cutting standby heat loses the energy wasted while heated water sits idle in the tank by an additional $28 to $57 per year.
The Bigger Picture on Water Heating Costs
Water heating typically accounts for about 12% of a home's total energy consumption according to ENERGY STAR data, but can represent 14 to 18 percent of an average household's utility bill—costing roughly $400 to $600 per year, according to the U.S. Department of Energy. Getting the temperature right is one of the simplest ways to trim that expense without sacrificing daily comfort..
Trimming the bill is one part of running a water heater efficiently. The other part is making sure it keeps running at all.
Running Your Water Heater Efficiently, Whatever the Setting
Getting the temperature right helps control costs on a normal day. But an electric water heater still needs power to run at all, and that's exactly where it becomes vulnerable during an outage. Pairing an electric water heater with battery backup closes that gap. Hot water stays available even when the setting is dialed in perfectly but the grid isn't cooperating. The two EcoFlow systems below cover that need at two different scales.
Whole-Home Backup That Covers Your Water Heater Too
A whole-home battery can power an electric water heater alongside essential household circuits during an outage. Runtime depends on the battery's capacity and the heater's power demand. A 12kWh system, for example, can provide hours of water-heater operation, not multi-day heating through an extended outage. A full whole-home battery backup guide walks through how to size a system for a specific household.
EcoFlow DELTA Pro Ultra X
• 100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. •High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
Portable Backup for Smaller Electric or Point-of-Use Heaters
A portable power station is a practical option for a smaller electric point-of-use heater. It also works for keeping other essentials running while a larger water heating issue gets sorted out. Even optimizing time-of-use electricity rates with battery backup can factor into which scale of backup makes sense for a given home.
Reliable Power When It MattersReliable Power When It Matters
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. •Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
With backup power covered, the last step is making the change yourself.
How to Check and Adjust Your Water Heater Temperature
Start by finding out where you stand. Run the hot tap closest to the tank for two minutes. Then hold a cooking thermometer in the stream.
Whatever it reads is your real starting point. It is often hotter than the label suggests. The whole job takes about ten minutes. You need a screwdriver and that thermometer, and nothing else.
The steps differ by fuel type. An electric tank hides its controls behind a panel, so the power has to come off first. A gas tank puts its dial out in the open near the floor.
Step
Electric Water Heater
Gas Water Heater
1. Make it safe
Turn off the power to the water heater on the electrical panel before doing anything else.
No breaker step is needed, since the control sits on the outside of the tank.
2. Reach control
Remove the access panel or panels from the tank with a screwdriver.
Locate the temperature dial on the gas control valve near the bottom of the tank.
3. Clear the way
Pull back any insulation covering the thermostat.
Nothing to move. The dial is already exposed.
4. Set the temperature
Set both thermostats to the same number, which is 120°F for most homes.
Turn the dial to 120°F, or to the warm setting if the dial is not numbered.
5. Close it up
Replace the insulation and panels, then restore power to the breaker.
Note where the dial started, in case you want to go back later.
6. Check your work
Wait a few hours for the tank to settle, then check the faucet with a thermometer.
Wait a few hours for the tank to settle, then check a faucet with a thermometer.
One detail trips people up on electric tanks. Most have two thermostats, an upper and a lower one. Both need to match. If they do not, the tank works against itself and burns more energy than it should.
Give the change a week before you judge it. If showers run short, nudge the setting up in small steps. There is no need to jump back to 140°F.
And if you want cooler water at one sink without touching the tank, an anti-scald valve handles that job on its own. A plumber can fit one in an afternoon. That costs far less than heating the whole house hotter for a single fixture.
The dial is one of the quickest wins in the house. Once it is set, plenty of other ways to lower bills take about the same ten minutes each.
The ideal water heater temperature for most homes is 120°F, and it earns that spot by holding two risks in balance at once. You get less scald risk at the tap and controlled bacteria growth in the tank. You also trim the second-largest energy expense in the house. Homes that truly need 140°F still have a clear reason to pick it. Check your own tank with a thermometer at the faucet, then adjust toward 120°F if nothing in your household calls for heat. If outages are common where you live, pair that electric tank with backup power from the DELTA Pro Ultra X or the DELTA 3 Max.
What temperature should a water heater be set at?
For most households, 120°F. Federal guidance points to that setting for a reason. Water stays hot enough for showers, laundry, and dishes, while scald risk and standby energy loss both stay low. Homes with an immunocompromised resident or an older dishwasher may need 140°F.
Is 140 degrees too hot for a water heater?
For most homes, yes. The Consumer Product Safety Commission notes that burns occur after roughly six seconds of contact with 140-degree water. The setting still makes sense for bacteria control in some households. It should be a deliberate call, not a factory default.
How much money can I save by lowering my water heater temperature?
The Department of Energy rule of thumb is 3% to 5% off water heating costs for every 10°F you turn the tank down. Going from 140°F to 120°F puts you near 6% to 10%. Water heating is about 12% of home energy use, so it adds up over a year.
Can I set my water heater below 120 degrees?
It is not a good idea. Legionella bacteria grow best between 77°F and 113°F, so a cooler tank trades a small saving for a health risk. Keep 120°F as your floor. Use anti-scald valves at the fixtures if you want cooler water at the tap.
Save Bills
