TSA-Approved Power Banks You Can Carry on a Plane
Traveling today often means carrying multiple devices, and a reliable power bank is a must so you don’t wind up with dead batteries. But if you’re flying, not all batteries are allowed on board. TSA, FAA, and airline-specific rules all may limit where and how you can bring them, making it essential to know the guidelines before you pack. In this guide, we’ll cover what sizes are permitted, safety tips for travel, and recommend the best TSA-approved power banks to carry with you to stay powered up.
Can I Take a Power Bank on a TSA Flight?
Yes, you can travel with power banks on TSA flights. In fact, they are rapidly becoming one of our travel essentials that we never leave home without. However, since the TSA and FAA classify them as lithium-ion batteries, they’re not allowed in your checked luggage. Spare lithium-ion batteries have not been allowed in checked luggage for many years due to the potential safety risks of thermal runaway, which may result in fire. Still, devices like shavers and others containing lithium-ion batteries are allowed in checked luggage if properly powered off.
That said, most standard power banks and spare batteries are allowed in your carry-on luggage. The rules allow any standard storage device for your Android or iPhone, laptop, tablet, or other personal electronic devices you may bring in your carry-on bags. Anything up to 100Wh is generally permitted without approval, 101-160Wh requires airline approval (max two per person), and over 160Wh is typically forbidden unless installed in equipment and given approval.
Furthermore, all spare batteries must be protected from short circuits by being placed in packaging, a battery case, or having taped terminals in order to prioritize safety. Also, ensure your power bank's Wh rating is clearly marked to ensure a smooth journey through airline screening. However, before flying, you should always check with your specific airline, as different airlines often have airline-specific rules you may also need to follow.
EcoFlow RAPID Magnetic Power Bank (10,000mAh) on black background
TSA Travel Regulations for Power Banks
When you fly, you must follow both TSA and FAA rules, which apply to different aspects of all flights. Here are the two rules regarding power banks that are most important to know when flying.
  • The TSA website states that portable chargers or power banks containing lithium-ion batteries must be packed in carry-on bags since they are prohibited in checked luggage.
  • The FAA rules state that lithium-ion batteries must not exceed 100 watt-hours per battery, without airline approval. Fortunately, for those who need a lot of power, the EcoFlow RAPID Pro is the maximum size power bank you can bring on an airline without approval, so you can stay powered up for the duration of your flight.
These rules are not as strict as they sound since they allow nearly all lithium-ion batteries you might carry with you in your electronic devices. Though exceptions exist, they apply mostly to bigger batteries. For example, some after-market extended-life laptop batteries are known to go over the allowed watt-hour rating for regular transport. The same goes for professional audio/visual gear. Professional cameras, lighting setups, or portable sound systems often use hefty battery packs that exceed standard limits and require special handling and airline approval.
Tips for Travelling With Power Banks
  1. Power banks and batteries should have their terminals covered to prevent accidental short circuits. You can place them in a bag or a pouch, or put tape over the ends.
  2. Travel with your power banks in your carry-on purse or bag, not what you intend to put in the overhead storage compartment.
  3. Always ensure it is easily accessible for TSA screening.
  4. Consult your airline, as some airlines have additional rules regarding when you can use them, like not during take-off or landing, and where you can store them, like on your person in a visible location and not in the overhead storage bins.
  5. Choose models like the EcoFlow RAPID Magnetic Power Bank (10,000mAh) with safety features like ultra-low internal resistance technology, internal cooling systems, and temperature sensors to reduce the overheating issues of magnetic charging.
  6. Avoid extreme temperatures.
  7. Keep your power bank away from metallic objects.
  8. Ensure the output ports of your battery storage are compatible with your electronic device(s). For those with high power needs, you may want one with multiple ports.
  9. Choose reputable models with good warranties.
  10. Never attempt to modify or disassemble a power bank.
EcoFlow RAPID Pro power bank
Can I Bring a 20000MAH Power Bank On a TSA Plane?
Yes, 20,000mAh power banks are allowed on TSA planes. However, they must be brought with you in your carry-on luggage and cannot be checked due to concerns over the safety of lithium-ion batteries in checked luggage.
What Power Banks Can I Take On a Plane?
Any power bank under 100Wh in capacity is allowed on a plane as long as you carry it with you in your carry-on bags, as they are not allowed in checked luggage. However, you can bring models up to 160Wh if you get approval from the airline.
Can You Carry a Power Bank in a Carry-on Bag?
Yes, you can carry power banks in carry-on bags with you as long as they don’t exceed 100Wh (~27,000mAh) in capacity. Any model between 100Wh and 160Wh in capacity requires approval from the airline. However, power banks are considered spare lithium-ion batteries and are never allowed in checked luggage.
Power Banks Help Travelers Stay Connected
Flying with a power bank doesn’t have to be complicated. As long as you keep it in your carry-on, stay under the 100Wh limit, and follow TSA safety guidelines and airline-specific rules, you’ll have no issues powering your devices in the air. For travellers who want maximum capacity without hassle, the EcoFlow RAPID Pro is one of the best TSA-approved options, giving you top-tier performance while staying within the 100Wh size airline limits. Travel lighter, stay connected, and keep your tech running anywhere you go.
