Backpacking vs Hiking: What's the Difference and What Do You Need?
Hiking and backpacking take you outdoors, but the trips call for different levels of preparation. A day hike usually involves a few hours on a trail and a light pack. Backpacking means carrying shelter, food, and other supplies for at least one night away from home. That extra time outdoors changes what you pack, how you plan your route, and where you get water. Here's how the two activities compare, what gear each requires, and how to prepare for a safe trip.
Backpacking vs Hiking: Key Differences
Backpacking vs Hiking: Key DifferencesBackpacking vs Hiking: Key Differences
The biggest difference between hiking and backpacking is how long you stay out. Hikers usually finish the route in a day, while backpackers carry what they need to camp overnight or longer. That affects pack size, food, water, shelter, and planning.
Factor
Hiking
Backpacking
Trip length
Hours, same day
One night or more
Pack
Daypack
Multi-day pack
Shelter
Emergency only
Tent, tarp, or hammock
Food and water
Snacks, water
Meals, stove, water treatment
Planning
Route, weather
Route, campsites, permits, water sources
Gear and pack weight
Day hikers can usually carry everything they need in a small daypack. Backpackers need more room for a tent, sleeping bag, sleeping pad, cooking supplies, extra clothing, and food for each day. The right gear also depends on the trail, weather, and trip length. Compare lightweight and heavy backpacking gear before choosing what to carry.
Food, water, and safety
Both hikers and backpackers should carry the National Park Service's Ten Essentials. These items help you prepare for changing weather, minor injuries, and unexpected delays. The list includes:
  1. Navigation, such as a map, compass, or GPS device.
  2. Sun protection, including sunscreen and sunglasses.
  3. Extra clothing.
  4. Illumination, such as a headlamp or flashlight.
  5. First-aid supplies.
  6. Fire-starting equipment.
  7. A repair kit and basic tools.
  8. Extra food.
  9. Extra water and a way to purify it.
  10. Emergency shelter.
Day hikers typically carry enough food and water for one trip, plus a little extra to cover their own backs if they get held up. Backpackers need to plan their meals for each day, and have a way to treat water on the trail. Both should be ready for changing weather and unexpected delays. You may also hear trekking used for long walks that last several days. Some treks require you to carry your camping equipment, while others involve staying overnight in lodges or huts. Your phone, headlamp, and camera may need charging on either trip. Where you charge them depends on whether you have a vehicle or a fixed base camp.
Charging Gear Before and After the Trail
A small power bank is easier to carry on a hike or backpacking trip than a large battery. At the trailhead, in your vehicle, or at a fixed base camp, a power station can recharge phones, cameras, and headlamps before you leave or after you return. It stays at the support point, not in your backpack.
EcoFlow DELTA 3 Classic for a trailhead or car camp
If you have a vehicle or fixed camp nearby, the EcoFlow DELTA 3 Classic gives you a place to recharge several devices between outings. Its 1,024Wh LFP battery can support compatible phones, cameras, and headlamps. It weighs about 27 lb, so keep it in your vehicle or at camp rather than carrying it along the trail. Protect it from rain and moisture when using it outdoors. At a trailhead or car campsite, a 1kWh power station can recharge a group’s small devices several times. The EcoFlow DELTA 3 Classic also supports up to 500W of solar input, giving you another charging option at a suitable base camp with compatible panels and enough sunlight.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Estimated charges for common devices
The table below shows how many full charges the EcoFlow DELTA 3 Classic could provide under the stated assumptions. These are estimates, not guaranteed results.
Device (example)
Energy per charge (placeholder)
Charges from EcoFlow DELTA 3 Classic (870Wh usable est.)
Smartphone
about 15Wh
about 58
Headlamp battery
about 5Wh
about 170
Camera battery
about 15Wh
about 58
Estimates use 870Wh of usable capacity, based on 85% of the battery's 1,024Wh rated capacity. The device energy figures are placeholders. Actual battery capacity, charging losses, and device requirements will affect the number of charges. Check the battery label or manufacturer's specifications before planning. A power station makes sense when you have a vehicle or fixed camp where it can stay. For a route without vehicle access or a fixed resupply point, leave it out of your gear plan. Carry a small power bank or another trail-appropriate option instead. Our guide to backpacking power options covers lighter ways to keep essential devices charged on the trail.
How to Plan a Hike or Backpacking Trip
Start with the park or forest website. Check trail conditions, closures, weather alerts and any restrictions that may impact your route. In the US, summer storms, wildfire season or even winter weather can change conditions fast. An easy trail under mild conditions can become a challenge when temperatures soar or storms move in. Before you go, be sure to know:
  • The trail distance, elevation changes, and expected hiking time.
  • Where the trail starts and where you plan to finish.
  • Whether the route has reliable water sources.
  • What weather conditions to expect during the trip.
  • Whether permits, campsite reservations, or parking passes are required.
Backpackers should also check campsite rules and campfire restrictions for the specific park or forest. Don't assume that a fire is allowed just because a campsite has an existing fire ring.
How to Plan a Hike or Backpacking TripHow to Plan a Hike or Backpacking Trip
Share your plans and know how to navigate
Tell someone where you're going and when you expect to return. Share your route and any planned overnight stops. If your plans change, let that person know when you can. The National Park Service also recommends knowing how to use a topographic map, compass, or GPS unit before heading out. Downloading a map can help when cell service is limited, but don't rely on your phone as your only navigation tool. Carry a suitable backup and learn how to use it.
Plan food and water for the full trip
For a day hike, pack enough water and snacks for the route, along with extra supplies in case you get delayed. Backpackers need a meal plan for each day and a reliable way to treat water when the route requires it. Don’t wait until you're thirsty to drink. NPS recommends drinking water regularly when outdoors. On longer trips, decide how much to carry based on the reliability of water sources on your route. You can also consider portable solar chargers for backpacking if your route and campsite setup allow you to recharge small devices during the trip.
Which should you try first?
If you're new to outdoor trips, begin with a day hike on a marked trail. You can learn how your shoes, pack, clothing, and water supply work without having to carry overnight gear. Pick a trail for your fitness level and give yourself plenty of time to finish before dark. Once you are comfortable with day hikes, try a one-night backpacking trip near a trailhead or established campsite. This gives you a chance to test your shelter, sleeping bag, food, and cooking setup without committing to a long route.
Try your gear out at home before you go. Pitch your tent, check your sleeping pad, test your stove as per its instructions, and make sure your headlamp works. Make sure your pack is adjusted so that the weight is sitting nicely. If you're shopping for a first pack, compare camping backpacks for comfort and choose one that fits your body and the gear you'll carry.
Backpacking vs. hiking comes down mainly to the length of the trip and what you need to carry. Day hikers return home the same day, while backpackers bring shelter, food, and supplies for overnight stays. Both should carry the NPS Ten Essentials, check the weather, and share their plans with someone before leaving. Start with a day hike, then try a short overnight route when you're ready. If you have a vehicle or fixed base camp, an EcoFlow DELTA 3 Classic can recharge phones, cameras, and headlamps before or after the trail. Keep it at that support point, not in your pack.
What is the difference between hiking and backpacking?
As a day trip, hiking usually requires a smaller pack with water, snacks and basic safety gear. Backpacking is camping out overnight. You have to carry your shelter, sleeping bag, food and other supplies with you. You'll also need to plan your campsite, water sources, and route for the full trip.
Is trekking the same as backpacking?
Not really. A trek is usually a longer walk, often lasting several days and covering different kinds of terrain. Some trekkers carry their own camping equipment, and others stay in lodges or huts along the way. Backpacking specifically involves carrying the supplies you need for an overnight stay outdoors.
What should I bring on a hike?
Bring the National Park Service’s Ten Essentials: navigation, sun protection, extra clothing, illumination, first-aid supplies, fire-starting equipment, a repair kit, extra food, water and emergency shelter. Adjust your supplies to the route and weather.
Is backpacking harder than hiking?
Backpacking is usually a bit more involved as you’ll be carrying a heavier pack and will need to plan your food, water, shelter and overnight stops. The difficulty also depends on the trail, elevation, weather, and your experience.
How do I charge my phone while backpacking?
Carry a small power bank or a suitable solar charger for use on the trail. If you have a vehicle or fixed base camp, you can recharge your devices there with a larger power station. A unit such as the EcoFlow DELTA 3 Classic should stay at that support point rather than going into your backpack.
Outdoors
