Snowstorm in Idaho: What Each Region Gets, Where to Check Live, and How to Keep Critical Circuits On
A single Idaho winter storm tells two completely different stories. You might see an inch of slush around Pocatello and Chubbuck. Meanwhile, Island Park and Galena Lodge get buried under 15 inches of powder.
This guide breaks down what Idaho valleys and mountains receive in a typical winter. You will learn how to track storm alerts live by county. You will also see who to call when power lines go down.
When lines drop during deep freezes, keeping critical circuits running is essential. We will cover quiet battery backup setups for your refrigerator, lights, and Wi-Fi.
Please note: this guide provides planning tools, regional data, and safety steps. It does not provide live weather forecasts.
One Storm, Very Different Totals: Does It Snow in Idaho, and How Much by Region?
Yes, it snows throughout Idaho, but snowfall varies considerably by elevation and location. A storm that brings light snow to the Snake River Plain can bury mountain communities under much deeper accumulations.
One example comes from the National Weather Service (NWS) Pocatello's summary of November 30 through December 2, 2022. Galena Lodge received 17 inches in 24 hours, while Island Park recorded 15 inches during the storm. The Pocatello area received much less.
Snow covering vehicles and houses in IdahoSnow covering vehicles and houses in Idaho
The anatomy of an eastern and central Idaho storm
The National Weather Service in Pocatello documented this exact spread from November 30 to December 2, 2022. Valleys saw light dustings while the high country was completely hammered.
Location
Reported Snowfall
Galena Lodge
17.0 inches (24-hour)
Island Park
15.0 inches (storm total)
Bellevue
6.4 inches
Stanley
5.1 inches
Driggs
3.1 inches
Pocatello Area (3 E Pocatello)
1.5 inches
Southwest Idaho and the Treasure Valley
Boise receives less snow than many Idaho mountain communities. The NWS Boise 2025 annual climate report lists a 1991–2020 average of 17.6 inches of snowfall per year. Boise recorded 13.7 inches in 2025.
The surrounding mountains receive considerably more snow. In the Treasure Valley, winter weather can also bring dense fog, freezing conditions, and slick roads.
Cold air sometimes settles in the valley beneath warmer air above it. This inversion can trap fog and moisture near the ground. Visibility may drop below a quarter mile, making even familiar routes dangerous.
Freezing rain is uncommon in Boise but occurs more often around Ontario, Oregon. Bridges and overpasses deserve particular attention because thin ice can remain after snowfall ends.
North Idaho: More snow in many mountain areas
North Idaho generally experiences heavier winter snowfall in its mountainous areas. Communities around Coeur d'Alene, Sandpoint, and Winchester can see substantial accumulation, although actual totals depend on the storm and season.
The NWS Spokane La Niña study examined winters from 1949–1950 through 2016–2017. During La Niña winters, average snowfall was:
  • Coeur d'Alene: 63.0 inches
  • Sandpoint: 81.0 inches
  • Winchester: 112.7 inches
These figures reflect specific La Niña cycles rather than standard baseline averages. Because numbers shift across county lines, checking localized live conditions is vital.
Eastern Idaho and the central mountains
Eastern Idaho's valleys, high-elevation communities, and mountain passes can experience very different conditions during the same storm. Island Park, Stanley, Driggs, and the Wood River Valley may receive heavier snow than lower-elevation locations.
Wind can make conditions worse by blowing snow back across roads. Drifting snow may reduce visibility, cover pavement, and force highway closures even after snowfall slows.
These regional differences explain why a statewide weather headline isn't enough. You need local alerts, current road reports, and reliable information about power outages.
Is a Snowstorm Hitting Idaho Right Now? Four NWS Offices, Idaho 511, and Outage Maps
Idaho does not rely on a single central weather office. Four separate National Weather Service offices cover the state.
The right alert page depends strictly on which county you live in. You must combine that office with Idaho 511 for roads and local utility maps. Doing this gives you an accurate live check instead of an outdated forecast.
This article cannot tell you if flakes are falling on your street right now. Use the breakdown below to find your specific regional monitoring hub.
Region
Counties (examples from the NWS listing)
NWS office
Southwest Idaho, Treasure Valley, Magic Valley, West Central Mountains
Ada, Canyon, Boise, Valley, Elmore, Twin Falls, Owyhee and 7 others (14 total)
NWS Boise
Eastern and central Idaho, Snake River Plain, Wood River Valley
Bannock, Bonneville, Bingham, Blaine, Fremont, Teton, Custer and 12 others (19 total)
NWS Pocatello/Idaho Falls
North Idaho Panhandle, Palouse, Lewiston
Kootenai, Bonner, Boundary, Shoshone, Benewah, Latah, Nez Perce, Lewis (8 total)
NWS Spokane
North central mountains and Salmon area
Clearwater, Idaho, Lemhi (3 total)
NWS Missoula
Real-time road updates: Idaho 511
Never trust a broad regional weather forecast when planning highway travel. Check road surfaces through Idaho 511 via 511.idaho.gov or their mobile apps.
The system categorizes road conditions from "Good" to "Closed" in real time. It offers pass conditions, active camera feeds, and automated route alerts.
The Idaho Office of Emergency Management provides key road rules for severe storms:
  • Check 511.idaho.gov before pulling out of your driveway.
  • Keep your gas tank at least half full at all times.
  • Pull over in a safe, plowed area if blowing snow ruins visibility.
  • Carry emergency blankets, road flares, and tire chains in your trunk.
Before cold weather reaches the valley floor, knowing the steps to take during winter storms helps ensure phones are charged and supplies are ready. Once high winds kick up, power lines often fail next.
Real-time road updatesReal-time road updates
Blizzard Backup for Critical Circuits: EcoFlow TITAN 5000 Classic and EcoFlow TITAN 5000 Plus
When a blizzard knocks out power, most homes do not need everything back at once. They need the refrigerator, some lights, phones, and the Wi-Fi router running. Some homes also need to support a larger 240V appliance like a well pump.
A home battery wired to selected circuits handles that job cleanly. A licensed electrician sets up those priority circuits through a suitable panel.
Idaho winter conditions make that level of preparation critical. During the 2022 storm, NWS Pocatello reported wind gusts up to 65 mph. Near-whiteout conditions shut down US-20 from Ashton all the way to Targhee Pass.
Blowing and drifting snow routinely leaves rural roads impassable for days. The Idaho Office of Emergency Management urges households relying on electric heat to plan backup sources. They also recommend keeping at least three days of food and water per person.
When roads are blocked, running out to buy fuel for a generator is out of the question. A dedicated home battery avoids fuel storage hazards and runs quietly indoors.
Here is how the two systems compare on the specs that decide which blizzard loads they can carry.
When severe winter storms strike, the EcoFlow TITAN 5000 Classic delivers reliable 120V backup power. It keeps your refrigerator cold, lights on, and Wi-Fi running silently without gas fumes or complex wiring hassles.
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Engineered for demanding winter outages, the EcoFlow TITAN 5000 Plus delivers high-output 120V/240V power. It seamlessly supports heavy-draw essentials like rural well pumps and multiple major appliances to keep your entire household safe and self-sufficient.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
How the two products divide the job
If every must-run load is 120V, EcoFlow TITAN 5000 Classic fits. Think refrigerator, a few lighting circuits, the Wi-Fi router, and phone chargers. Wire it through Smart Home Panel 10 (120V version). The Classic model does not power any 240V appliances.
If your list also includes a compatible 240V load, like a rural well pump, compare EcoFlow TITAN 5000 Plus. Pair it with Smart Home Panel 10 (240V version).
Whether it can carry a specific pump depends on the pump's nameplate starting and running watts. It also depends on what else runs at the same time. A licensed electrician should confirm the circuits and loads for either system.
Runtime example (labeled estimate)
A DOE Building America Solution Center example EnergyGuide label shows a refrigerator using about 630 kWh a year. That's roughly 1.7 kWh a day.
  • EcoFlow TITAN 5000 Classic base capacity: 5,000Wh
  • Planning assumption for conversion losses: 0.85
  • Usable energy: about 4,250Wh
  • 4,250Wh ÷ 1,700Wh per day: about 2.5 days for that refrigerator alone
Plugging in lighting circuits and routers will shorten that baseline runtime. Connecting additional expansion batteries will extend it significantly.
Check the yellow EnergyGuide label on your refrigerator for its specific annual rating. Check your router and LED fixtures for their rated operating wattage to estimate your total household draw.
Placement rules
Both power stations carry an IP20 rating. They require a clean, dry, ventilated indoor installation space within their standard operating temperatures.
EcoFlow's US specifications list an operating discharge range from 14°F to 113°F.
Never install either battery in an unheated outbuilding, shed, or uninsulated detached garage. Idaho cold snaps easily drop ambient air below 14°F. That level of cold will compromise battery performance and trigger automated low-temperature safety cutoffs. Keep your units inside an insulated utility room or attached garage.
Comparing how to choose a home battery starts with listing the circuits you can't do without, then matching capacity and output to them.
Once the storm passes, the snow that matters most for Idaho is what stays in the mountains, which is what the official Idaho snow report measures.
Idaho Snow Report: Ski Conditions vs. the NRCS Snowpack Report
Searching for an Idaho snow report can lead to two different types of information. Ski resorts publish recreation updates focusing on fresh powder and lift openings. In contrast, the USDA Natural Resources Conservation Service (NRCS) tracks snowpack water volume. The NRCS monitors this mountain reservoir to evaluate spring runoff, irrigation supply, and flood hazards.
How the NRCS measures mountain snowpack
The NRCS Idaho Snow Survey tracks high-elevation precipitation across automated SNOTEL stations and physical snow courses. They do not focus on overall fluff. Instead, their key metric is Snow Water Equivalent (SWE), the exact amount of water held in the snowpack.
The agency provides real-time SWE mapping alongside monthly Water Supply Outlook Reports. These show water reserves destined for Snake River Plain reservoirs.
Spring 2026 snowpack conditions
The NRCS Idaho Water Supply Outlook Report from May 1, 2026, highlighted clear regional swings:
  • Statewide snowpack measured at 58% of the 1991–2020 median normal.
  • Statewide snow water equivalent peaked earlier on March 17 at 14.5 inches.
These figures illustrate conditions from the spring 2026 runoff season. They should not be used to predict future winter accumulations. Always check the newest monthly update to monitor your river basin.
Navigating different winter snow reports
Different questions require looking at different data sources:
  • Looking for fresh ski powder? Check individual resort mountain condition reports.
  • Checking irrigation reserves or runoff risks? Review the NRCS Idaho Snow Survey interactive data maps.
  • Wondering if mountain passes are clear? Open Idaho 511 highway reports before driving.
  • Tracking storm arrival times? Consult your regional NWS county warning desk.
Big year-to-year swings in Idaho snowpack often line up with El Niño and La Niña weather patterns, which is why NWS Spokane tracks La Niña winters separately.
Snowpack numbers give the long view. Past storms show what a heavy winter can do to roofs and highways.
Idaho Snowstorms on the Record: The 2017 Disaster Declaration and Storm-Driven Highway Closures
The full weight of an Idaho winter is documented in disaster archives, not just headlines. Heavy valley snowfall during the 2016–2017 season triggered a formal state emergency declaration. Meanwhile, blowing drifts routinely shut down critical highway corridors across eastern counties.
These severe historical events show why keeping emergency supplies and backup power ready is essential.
The historic winter of 2016–2017
On February 9, 2017, the Idaho Office of Emergency Management expanded a State Disaster Declaration. Governor C. L. "Butch" Otter added Ada and Boundary counties, bringing the total to six:
  • Ada County
  • Boundary County
  • Canyon County
  • Custer County
  • Payette County
  • Washington County
The emergency declaration cited historic snow accumulations, widespread roof failures on structures, and subsequent snowmelt flooding.
The NWS Boise winter newsletter noted January 2017 was Boise's snowiest month since December 1983. Boise officially hit 11 degrees below zero on January 6 during that deep freeze.
Eastern Idaho highway shutdowns
High winds and dry snow make eastern Idaho roads notoriously dangerous. During the November 30 to December 2, 2022 storm, NWS Pocatello reported severe whiteouts that forced major highway closures:
  • I-15 Northbound: Shut down from Stoddard Creek Road to the Montana border due to crashes.
  • US-20: Closed completely between Ashton and Targhee Pass because of massive drifts.
  • State Highway 87: Blocked entirely through Raynolds Pass.
  • US-26: Shut down between Ririe and Swan Valley.
  • State Highway 33: Closed from Newdale to Tetonia.
Near Henrys Lake on January 7, 2022, sudden ground-blizzard conditions triggered a 39-vehicle pileup on US-20. First responders transported 14 individuals to nearby hospitals. Fortunately, zero fatalities occurred.
Roof snow and ice dams
Heavy snow loads combined with interior attic heat lead to structural stress and ice damming. Never climb onto a snow-covered, frozen roof.
Use an extendable roof rake from ground level to pull snow off the eaves. If buildup looks excessive, hire a licensed, insured roofing contractor to clear the weight safely.
Stocking a winter survival kit with backup power keeps your family safe when highway closures cut off travel for days.
Who Restores Power After an Idaho Snowstorm: Idaho Power, Avista, Rocky Mountain Power, and Co-ops
Multiple electric utilities supply power across Idaho's distinct geographical regions. Each utility maintains its own dispatch team, reporting line, and live restoration tracker. Check outage maps online first on your mobile phone before placing a call. Dispatch centers may have already logged your neighborhood fault.
Utility
Where to check
How to report (as labeled on its own outage page)
Idaho Power
Outage map: tools.idahopower.com/outage
Outage Center says it can take up to 10 minutes for an outage to show; if it isn't listed after that, call the number shown under "Customer Service," 208-388-2323 (toll-free 1-800-488-6151). Primary account holders with a mobile number on file get automatic outage text alerts.
Avista
Outage map: outagemap.myavista.com
Report online at outage.myavista.com, in the Avista app, or "call customer service at (800) 227-9187 to report an outage"; text REG to AVISTA (284782) for notifications.
Outage map with an Idaho tab: rockymountainpower.net/outages-safety.html
"Call to report an outage": 1-877-508-5088; "Text your outage report": text OUT to 759677.
Kootenai Electric Cooperative (Rathdrum)
kec.com/outages-safety/outage-map/
Report through SmartHub, by calling (855) 938-3508, or by texting OUT to (855) 938-3508 (registered SmartHub users).
Downed lines: High winds and heavy snow regularly drop live power lines onto roadways and private property. Idaho Power explicitly instructs individuals to stay at least 100 feet away from any downed line. Treat every downed wire as live and lethal. If you spot a fallen wire, immediately call 911 to alert local first responders. Do not approach clearing debris until utility service crews verify the line is fully de-energized.
Other cooperatives and municipals: Many remote Idaho communities receive power from member-owned electric cooperatives or city-run utilities. Examples include Fall River Electric, Clearwater Power, and Lost River Electric. These providers set their own restoration protocols and maintain local dispatch boards. Save your local cooperative's direct phone number in your mobile contacts before storm season hits.
Generator safety: If you operate a gas generator alongside a battery backup, follow strict safety protocols. The Idaho Office of Emergency Management outlines clear guidelines:
  • Run combustion generators outdoors at least 20 feet away from windows, doors, and vents.
  • Never run fuel engines inside garages, even if overhead doors are raised.
  • Install certified carbon monoxide alarms on every floor of your home.
  • Protect generators from wet snow using an open-sided, approved running shelter.
  • For a connection to house wiring, have a licensed electrician install an approved transfer switch or suitable interlock; never backfeed a wall outlet. For individual appliances, follow the manufacturer's manual.
Any connection to house wiring needs a transfer switch or interlock installed by an electrician. No backfeeding.
Rural Idaho homes on private wells lose running water when the pump loses power, so a water plan for power outages belongs next to the outage map bookmark.
An Idaho snowstorm can bring 1.5 inches to Pocatello and 15 inches to Island Park. Check your county's NWS office, Idaho 511, and your utility's outage map instead of statewide headlines. Before severe weather strikes, map out your must-run appliances. Check appliance wattage labels with an electrician to match your home with the right backup setup. If you need to keep 120V essentials running smoothly, explore the EcoFlow TITAN 5000 Classic. If you also need to support a 240V well pump, check out the EcoFlow TITAN 5000 Plus.
Does it snow in Idaho?
Yes, snow falls throughout Idaho every winter. Boise averages 17.6 inches per year according to 30-year climate records. Mountain passes and northern counties often receive well over 80 to 100 inches annually.
Where can I check if a snowstorm is hitting Idaho right now?
Check the specific National Weather Service office covering your county (Boise, Pocatello, Spokane, or Missoula). Pair their alerts with real-time road conditions on Idaho 511 and check your utility provider's outage tracker.
What is the Idaho snow report?
Skiers use the term to track resort powder conditions, trail depth, and chairlift status. State hydrologists use it to describe the NRCS Snow Survey, which monitors Snow Water Equivalent (SWE) for water reserves and runoff risks.
Who do I call if a snowstorm knocks out my power in Idaho?
Contact your specific electric utility: Idaho Power, Avista Utilities, Rocky Mountain Power, or your local electric cooperative. If you see a downed power line, keep clear and dial 911 immediately.
Can a home battery keep my house running during an Idaho blizzard?
A home battery can power selected priority circuits rather than an entire high-draw house indefinitely. The EcoFlow TITAN 5000 Classic covers essential 120V circuits. The EcoFlow TITAN 5000 Plus adds support for compatible 240V equipment like well pumps via professional panel installation.
Power Outages
