Power Strip vs Extension Cord: Differences, Safe Loads, and Smart Setups
Power strip vs. extension cord sounds like a simple choice until a breaker trips or a cord gets warm. A power strip gives you more outlets in one place. An extension cord gives you extra reach. Neither one increases the capacity of the wall outlet behind it. The U.S. Consumer Product Safety Commission (CPSC) warns that damaged or overloaded extension cords can overheat and start a fire. This guide explains how each works, how to read cord ratings, which appliances need a direct wall connection, and how to power small devices during an outage.
Power Strip vs Extension Cord: What Is the Difference?
Power Strip vs Extension Cord: What Is the Difference?Power Strip vs Extension Cord: What Is the Difference?
A power strip adds outlets at one spot. An extension cord carries power farther. Both draw electricity from the same wall outlet, so neither gives you more electrical capacity. A power strip works well when you have several low-power devices in one area, such as a desk with a monitor, phone charger, and lamp. An extension cord helps when an appliance or tool needs to reach an outlet that's farther away. Use one only when necessary and for temporary setups. The CPSC advises against using extension cords as a substitute for proper household wiring.
Feature
Power strip
Extension cord
Main job
More outlets in one place
More reach
Typical use
Desk, TV stand, chargers
Temporary run to a tool or lamp
Adds capacity?
No
No
Surge protection
Only if labeled as a surge protector
No
A power strip doesn't automatically protect connected devices from voltage spikes. Check the label to tell a power strip from a surge protector. If the product isn't labeled as a surge protector, don't assume it offers that protection. The CPSC’s extension cord safety alert advises checking the cord’s rating and inspecting the plugs, sockets, and insulation. A hot plug or socket can signal a deteriorated connection or an overload. Keep cords out of walkways and replace damaged ones rather than trying to repair them. When the power goes out, a battery can run some of the same small devices without relying on a wall outlet.
Running Small Loads From a Battery During an Outage
A power station can keep phones, a lamp, or a Wi-Fi router running during an outage. Place it in a dry indoor area and plug compatible devices directly into its outlets. Avoid connecting multiple strips and extension cords in a chain.
Using EcoFlow DELTA 3 Classic for small devices
EcoFlow power stations provide backup electricity without producing exhaust fumes during indoor use. For small electronics, connect each compatible device directly to the power station and keep the setup dry. Check the device's power requirements before connecting it, and leave high-draw appliances such as space heaters out of this setup.
EcoFlow DELTA 3 Classic + Bag (one 1,024Wh power station)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
EcoFlow DELTA 3 Classic can cover everyday electronics while the grid is down. Plug a phone charger, lamp, or router straight into the unit rather than adding a chain of strips and cords. Check each device's wattage and the power station's outlet limits before connecting several loads at once.
Estimate how long the battery can run small loads
The following examples use an estimated 870Wh of usable energy from one 1,024Wh EcoFlow DELTA 3 Classic. The device wattages are placeholders, so check the labels on your own router, chargers, lamp, and laptop before relying on these figures.
Example load
Watts used
One EcoFlow DELTA 3 Classic (870Wh usable est.)
Router + phone charging (placeholder)
about 20W
about 44 hours
LED lamp + laptop (placeholder)
about 70W
about 12 hours
These are estimates, not guaranteed runtimes. The calculation uses 85% of the battery's rated capacity: Estimated runtime = (1,024Wh × 0.85) ÷ load in watts. Actual runtime depends on the devices connected, their power use, and conversion losses. Replace the placeholder wattages with the figures from your equipment labels. Keep the power station in a dry location with enough ventilation and follow its user manual. Plug a portable electric space heater directly into a suitable wall outlet. Use the station for temporary backup of compatible loads. Simple steps for winter electrical fire prevention also include keeping cords in good condition and away from heat sources. Next, check the cord's gauge and current rating before using one with a device.
How Do You Read Extension Cord Ratings?
Extension cord ratings tell you how much current the cord can handle. A lower wire-gauge number means thicker wire, which generally supports more current. The CPSC advises checking the rating on the complete cord’s tag or packaging. Its household safety alert recommends at least 16 AWG unless an 18 AWG cord has fuse protection.
Compare the gauge and amp rating
Two Southwire Polar/Solar cords with the same wire gauge show how ratings can differ by product. The wattage column illustrates resistive loads at 120V.
Southwire Polar/Solar model, length, and gauge
Maximum current (manufacturer rating)
Resistive-load example at 120V
1287SW0002, 25 ft, 16/3 AWG
13A
1,560W
1289SW0002, 100 ft, 16/3 AWG
10A
1,200W
A 16-gauge cord has thicker wire than an 18-gauge cord. That difference matters when you're choosing a cord for an appliance. Check the appliance's current draw and compare it with the cord's rating. Don't choose a cord based on appearance alone. The CPSC has also identified undersized wires, loose connections, faulty components, and improper grounding in recalled extension cords. Look for a certification mark from a recognized testing organization, and inspect the cord before each use. Don't use one with cracked insulation, exposed wires, loose plugs, or damaged connectors.
Choose the right cord for the location
Indoor and outdoor cords aren't interchangeable. Use a cord marked for outdoor use when working in the yard or connecting equipment outside. Check its rating and condition before plugging in tools or seasonal decorations. Keep these precautions in mind:
  • Keep cords out of walkways: Route them where people won't trip over them.
  • Don't run cords under rugs: Heat can build up, and damage may go unnoticed.
  • Avoid wet areas: Use equipment and connections rated for the conditions.
  • Unplug damaged cords: Replace cords with worn insulation, loose connections, or exposed wiring.
  • Don't overload the cord: Match its rating to the connected appliance.
Outdoor outlets also need the right protection. Use outdoor GFCI outlets when connecting yard tools and other outdoor equipment. A GFCI helps reduce the risk of electric shock, but it doesn't make a damaged or overloaded cord safe.
Which Appliances Should Go Straight Into a Wall Outlet?
High-wattage appliances that produce heat need special care. The CPSC says electric space heaters should plug directly into a wall outlet, never into an extension cord or power strip. Use strips for suitable low-power electronics, not as a way to connect high-draw heating equipment.
Which Appliances Should Go Straight Into a Wall Outlet?Which Appliances Should Go Straight Into a Wall Outlet?
Why space heaters shouldn't use cords or strips
A space heater can draw a large amount of current for long periods. A 1,500W resistive heater at 120V draws about 12.5A, above the 10A rating of the 100-foot Southwire cord in the table. For a portable electric space heater, follow CPSC guidance and plug it directly into a suitable wall outlet. Follow the heater manufacturer’s circuit instructions.
The CPSC also advises keeping space heaters at least 3 feet from anything that can burn. Keep them away from curtains, bedding, clothing, furniture, and other combustible materials. Don't leave a heater unattended, and turn it off when you leave the room or go to sleep. Check space heater power use before choosing a circuit or planning backup power. The wattage on the heater's label helps you estimate its electrical demand.
Avoid chaining power strips and extension cords
Plugging one power strip into another or connecting several extension cords can create unsafe setups. Each added connection introduces another point that can loosen, overheat, or become damaged. Use a wall outlet that's close enough for the device, and have an electrician address outlets that don't meet your household needs. If you need more outlets at a desk or entertainment center, choose a properly rated power strip and stay within its load limit. If a tool needs temporary reach, use an extension cord rated for that tool and the work environment. Neither option should become a permanent substitute for an outlet.
A power strip adds outlets, while an extension cord adds reach. Neither increases the capacity of the wall outlet. Before using a cord, match the rating on its tag or packaging to the equipment. Keep cords away from rugs and walkways, and plug electric space heaters directly into suitable wall outlets. Avoid chaining strips and cords together. During an outage, EcoFlow DELTA 3 Classic can supply power to small devices such as phones, a lamp, and a router. Connect compatible loads directly to its outlets, keep the unit dry, and check actual device wattages before estimating runtime. It's a practical way to keep essential electronics running without relying on a chain of extension cords.
Is a power strip safer than an extension cord?
Neither is automatically safer. The right choice depends on the product's rating, condition, and connected load. Use a power strip for suitable devices in one location and an extension cord only when you need temporary reach.
Can I plug a space heater into a power strip?
No. The CPSC advises plugging electric space heaters directly into a wall outlet. Don't connect one to a power strip or extension cord. Follow the heater manufacturer's instructions and keep the unit at least 3 feet from combustible materials.
What gauge extension cord do I need?
Choose the appropriate gauge for the cord length and intended use, then match the actual amperage and voltage ratings on the cord’s label or packaging to the appliance manufacturer’s requirements.
Can I plug a power strip into an extension cord?
It's best to avoid that setup. Plug a power strip directly into a suitable wall outlet, and use an extension cord only when temporary reach is necessary. Don't connect multiple strips or cords in a chain.
Does a power strip protect against surges?
Only a product labeled as a surge protector is designed to provide surge protection. A basic power strip adds outlets but doesn't necessarily protect connected devices from voltage spikes.
