Pacific Power Outage: How to Check and Report It
A Pacific Power outage can happen for several reasons, from winter storms in Oregon and Washington to wildfire-related shutoffs in California. Pacific Power serves more than 850,000 customers across the three states, so knowing where to check outage information and how to report a problem can save time when the power goes out. The quickest way to get useful information is to check the Pacific Power outage map first. If your outage isn't listed, report it by phone, text, or through your online account. It's also worth having backup power ready before storm season, especially if your home depends on electricity for heating, cooling, medical equipment, or refrigeration.
How to Check the Pacific Power Outage Map
Pacific Power's outage map shows current outages across Oregon, Washington, and California. You can use the map to check whether your neighborhood is affected. When available, it also shows estimated restoration times. The map can show how widespread an outage is. You can also check whether nearby areas are experiencing similar service interruptions.
How to Check the Pacific Power Outage MapHow to Check the Pacific Power Outage Map
Find your outage on the map
Go to Pacific Power's outage page and open the outage map. You can zoom in on your area or search around your ZIP code to get a closer look at nearby outages. The map can change as crews inspect damage and update restoration information. During a major storm, check it again later rather than relying on an earlier estimate. Restoration times can change as crews learn more about damaged lines, roads, and equipment. You can also compare the way different utilities share outage information. This guide to real-time outage updates looks at another utility's approach.
How to Report a Pacific Power Outage
If your outage doesn't appear on the map, report it to Pacific Power so the utility has a record of the issue. You can report an outage by phone, text, or through your Pacific Power account, giving you options if one method isn't convenient during a storm.
Report by phone
Call 1-877-508-5088 to report a Pacific Power outage or a dangerous downed power line. Keep the number saved in your phone before storm season so you can report an outage quickly, even if you're dealing with poor internet access or a busy outage map.
Report by text
Text OUT to 722797 to report an outage. You can also text STAT to the same number to check the status of an outage you've already reported. Texting can be handy when phone lines are busy after a major storm. Your phone may be one of the few ways you can get updates if your home internet is also down.
Report online
You can also report an outage after signing into your Pacific Power account. This option works from a computer or mobile browser and gives you another way to report the problem if you'd rather not call. Once you've reported the outage, keep an eye on the map and status updates. If you notice a downed line or another immediate hazard, stay away from it and report it separately.
Backup Power for Pacific Power's Storm Season
Reporting an outage is the first step, but you may still be without power while crews assess the damage and make repairs. That's where backup power can help keep the essentials running. Pacific Power's service area faces winter windstorms, heavy snow, and wildfire-related shutoffs. Having a charged power station ready can help during an extended outage. A power station can keep your refrigerator running and your phones charged. It can also power lights and other essential devices while you wait for service to return.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. • High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
If you don't need whole-home backup, a smaller portable power station may be a better fit. The EcoFlow DELTA 3 Max can keep essential appliances and devices running during an outage, while its portable design makes it easier to move where you need power.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
The cause of an outage can also affect how long it takes to restore power. Knowing what typically causes outages in your area can help you plan for the wait.
Pacific Power's Service Area and Common Outage Causes
Pacific Power serves customers across Oregon, Washington, and California, but the outage risks aren't the same everywhere. Oregon and Washington see many outages tied to winter windstorms and heavy snow. California customers may also face planned power shutoffs because of wildfire risk.
Winter weather can put pressure on power lines and other equipment. Strong winds can bring down trees or branches, while heavy snow can damage lines and make it harder for crews to reach affected areas. If you live in one of these areas, it's useful to have a plan for an outage that lasts longer than a few hours. Keep flashlights charged, have extra batteries available, and make sure your backup power equipment is ready before the next storm arrives.
California wildfire shutoffs
California has a different concern. Pacific Power may shut off power as a safety measure when wildfire conditions create a high risk to the electrical system. A Public Safety Power Shutoff, or PSPS, is planned around wildfire conditions rather than caused by an active storm outage. If you live in an area where wildfire-related outages are possible, preparing for wildfire power outages can help you plan for a longer loss of electricity.
Staying Safe During a Pacific Power Outage
Power outages create a few hazards that are easy to overlook. Damaged electrical equipment can remain dangerous even when the surrounding area looks quiet, especially after severe weather or downed lines. Staying away from damaged equipment and taking a few basic precautions can help prevent injuries while you wait for power to return.
Staying Safe During a Pacific Power OutageStaying Safe During a Pacific Power Outage
Stay away from downed power lines
Never approach a downed power line or assume it's safe because you don't see sparks or hear noise. Stay well away from the area and call 911 if there's an immediate danger, then report the line to Pacific Power so crews can assess it. If a fallen tree has brought down a line across your driveway, don't try to move the tree or clear the area yourself. Keep people and pets away until utility crews confirm that the area is safe.
Don't run a generator indoors
Never run a gas generator inside your home, garage, or another enclosed space. Carbon monoxide can build up quickly and become deadly. Keep generators outside and well away from doors, windows, and vents. If you're using a battery power station instead, follow the manufacturer's instructions for placement, charging, and the equipment you connect to it.
Check your service equipment
If the service mast or weather head attached to your home is damaged, Pacific Power may not be able to restore service until a licensed electrician repairs it. That's one reason it's worth checking your home's electrical setup before severe weather arrives. Knowing where your main panel is and understanding basic steps for protecting your home during an outage can also help you prepare for an extended power interruption.
If you're dealing with a Pacific Power outage, start with the outage map and report the problem if it isn't already listed. Save 1-877-508-5088 and 722797 in your phone. That way, you have Pacific Power's reporting options ready when you need them. For longer outages, backup power can keep essential devices and appliances running while you wait for service to return. The EcoFlow DELTA Pro Ultra X is designed for whole-home backup, while the EcoFlow DELTA 3 Max offers a more portable option for essential power needs.
How do I report a Pacific Power outage?
To report an outage, call Pacific Power at 1-877-508-5088, text OUT to 722797, or log into your Pacific Power account. For outage status, text STAT to 722797 if you have already reported the outage. Reporting the outage gives Pacific Power the information it needs to track the issue and update restoration details.
What's the phone number for Pacific Power outages?
The phone number for reporting a Pacific Power outage is 1-877-508-5088. You can also use this number to report a dangerous downed power line, but stay away from the line and call 911 first if there is an immediate danger. Save the number in your phone so you have it ready when an outage occurs.
What states does Pacific Power serve?
Pacific Power serves customers in Oregon, Washington and California. The utility serves more than 850,000 customers in the three states, with risks of outages varying by area. Winter storms and heavy snow can affect Oregon and Washington, while wildfire-related shutoffs can affect parts of California.
What is a Public Safety Power Shutoff?
A Public Safety Power Shutoff, or PSPS, is a planned power shutoff that is utilized when wildfire conditions pose a threat to the electrical system. Pacific Power may conduct PSPS events in certain areas of California when the risk of wildfire is high. These planned shutoffs are different from outages caused by storms or equipment damage.
Who fixes a damaged service mast during a Pacific Power outage?
A licensed electrician needs to repair a damaged service mast or weather head before Pacific Power can restore power to the home. These components are part of the home's electrical service equipment. If yours is damaged, arrange for an electrician to make the necessary repairs before restoration.
Power Outages
