Massachusetts Nor'easter: What It Does on the Coast, Inland, and to Your Power
- What a Massachusetts Nor'easter Does on the Coast vs. Inland
- Four Benchmark Massachusetts Nor'easters, by the Numbers
- Riding Out a Blizzard Outage: Home Battery Options
- Where to Check a Massachusetts Nor'easter Right Now
- Eversource, National Grid, Unitil, or a Municipal Light Plant: Outage Maps by Territory
- Getting Ready: Coastal Homes vs. Inland Homes
- Conclusion
- FAQs
If you're in Scituate or Marshfield, a Massachusetts nor'easter can have you watching the tide and the seawall. Head about 40 miles inland to Worcester, and the concern may be how much snow lands on the roof, trees, and power lines. The difference can be dramatic during the same storm. The Boston tide gauge's highest recorded water level came from a nor'easter on January 4, 2018, not a hurricane. This guide breaks down what different parts of the state can expect, how major storms compare, and where to check the forecast and outages when conditions change.
The National Weather Service defines a nor'easter as an East Coast storm associated with northeast winds along the coast. These storms are most frequent and most severe from September through April and can bring heavy rain or snow, strong winds, rough seas, and coastal flooding. In Massachusetts, where you live often determines which hazard becomes the biggest problem.
Part of the state | Main nor'easter threat | Why | What usually knocks out power |
South Shore (Scituate, Marshfield, Hull) | Coastal flooding and wave damage around high tide | East and northeast facing shoreline takes the onshore wind and surf directly | Flooded streets and equipment, wind on wet or snow-loaded lines |
Cape Cod and the Islands (including Nantucket) | Highest wind gusts, coastal flooding, erosion | Most exposed land to the storm's center offshore | Wind. In January 2015 nearly all of Nantucket lost power (NOAA Weather Prediction Center) |
Boston Harbor and the North Shore | Tidal flooding on the waterfront, heavy snow or rain | Storm surge stacked on an astronomical high tide | Wind plus heavy, wet snow |
Worcester Hills and central Massachusetts | Biggest snow totals | Colder air and higher elevation keep precipitation as snow | Snow load on trees and lines |
Berkshires | Snow, with totals that vary by elevation | Farther from the coastal storm track; forecast by NWS Albany, not NWS Boston/Norton | Snow load, isolated wind damage |
Why the tide matters more than the wind speed
Coastal flooding depends heavily on timing. A storm surge arriving around high tide can produce a much bigger problem than the same surge arriving several hours earlier or later. At Boston's tide gauge, the National Weather Service flood thresholds are 12.5 feet for minor flooding, 14.5 feet for moderate flooding, and 16 feet for major flooding, measured above mean lower low water.
Why the rain and snow line moves
A small change in the storm's track can shift the rain and snow line. That's why a Boston forecast can change noticeably as the storm gets closer. If you're planning around snow totals, check the latest NWS Boston/Norton snowfall forecast instead of relying on an earlier forecast or a statewide number.
Check the forecast and outages
For most of Massachusetts, start with NWS Boston/Norton for watches, warnings, snowfall forecasts, and coastal flood information. The Massachusetts Emergency Management Agency also provides emergency information and links to its statewide outage map. On the South Shore, the storms that can be hardest to manage are the ones that bring coastal flooding and snow together. Roads can become difficult to use at the same time crews are dealing with trees, lines, and heavy snow.
Massachusetts has a handful of storms that people still use as reference points. The Blizzard of '78 set the standard for destructive winter storms. The January 2015 storm brought record snow to Worcester and major problems on Nantucket. The January and March 2018 storms showed how serious coastal flooding can become.
Storm | What it's remembered for | Verified figures | Source |
Blizzard of '78 (February 5 to 7, 1978) | The benchmark for everything since | Boston 27.1 inches, Worcester 20.2 inches, Rockport 32.5 inches; gusts of 79 mph in Boston and 93 mph in Chatham; storm lasted nearly 36 hours; about 3,500 cars stranded on Route 128; 73 deaths in Massachusetts; about 2,000 homes destroyed across New England | NWS Boston/Norton, "The Blizzard of '78 Revisited" |
January 26 to 28, 2015 | Record snow in Worcester, wind on Nantucket | Worcester recorded 34.5 inches of snow, its heaviest snowfall in records dating to 1892. Nantucket recorded a peak gust of 78 mph, and nearly the entire island lost power. NOAA also reported coastal flooding in eastern Massachusetts. NCEI rated it a Category 3 ("Major") Northeast storm on the Regional Snowfall Index (RSI 6.16), ranking 26th among all 423 historical storms cataloged in the nationwide NCEI RSI database since 1900. | NOAA Weather Prediction Center event review; NOAA NCEI |
January 4, 2018 | Highest water level on record in Boston | Boston tide gauge (NOAA Station 8443970) peaked at 15.16 feet above MLLW on January 4, 2018, surpassing the 1978 record (15.10 ft) to become the highest observed water level in the station's history (records dating back to 1921). | NOAA Tides and Currents, station 8443970 |
March 1 to 3, 2018 | Days of coastal flooding plus hurricane-force gusts | Boston Harbor recorded its third highest tide at 14.67 feet (records back to 1921); gusts of 85 to 93 mph reported in coastal Massachusetts; flooding documented at Peggotty Beach in Scituate | NOAA Weather Prediction Center event review |
The Blizzard of '78 lasted nearly 36 hours and left about 3,500 vehicles stranded on Route 128. The January 2015 storm brought Worcester its heaviest snowfall on record dating to 1892. In January 2018, Boston's tide gauge reached its highest observed level, and another storm two months later brought days of coastal flooding and wind gusts above 80 mph. The February 2026 blizzard showed that heavy snow and strong winds can still create widespread power problems. For homeowners, the takeaway is simple: the power can go out while roads are still too difficult for utility crews to reach.
A gas generator has to run outside, away from doors, windows, and attached garages, which isn't easy during a Massachusetts nor'easter. A battery power station produces no exhaust, so it can run indoors as designed and stay close to the devices you need to power.
Start with the essentials
You don't need to power every appliance during an outage. Start with the equipment that protects food, keeps critical systems running, and helps you stay connected.
Refrigerator: Keep food cold during a longer outage.
Sump pump: Especially important for coastal homes and houses with low-lying basements.
Furnace blower or boiler controls: Many heating systems still need electricity to operate.
Wi-Fi router: Keep internet access available for weather and emergency updates.
Phone chargers: Keep phones ready for alerts and calls.
CPAP or other medical equipment: Include any essential device that depends on household power.
Check the wattage on each device's label or manual and add up the loads you expect to run at the same time. Actual power draw varies by appliance, so your own numbers are more useful than a general estimate. If you want those essential loads covered during a longer outage, an installed battery system can back up selected home circuits instead of requiring you to connect each device separately.
If you don't need an installed system, a portable option can cover a smaller set of essentials. The EcoFlow DELTA 3 Max can be moved where it's needed and is a practical fit for renters, condos, or households that want to power individual devices during an outage.
How the two divide the job
The EcoFlow DELTA Pro Ultra X is the installed option for homeowners who want selected circuits, such as heating controls, a sump pump, refrigerator, or lights, to stay powered during a longer outage. It requires Smart Home Panel 3 and installation by a licensed electrician. The EcoFlow DELTA 3 Max is the portable option for renters, condo owners, and coastal households that may need to move backup power to a higher floor or another location.
Estimated runtime
Runtime depends on what you have plugged in. As a simple estimate, multiply capacity by 0.85 and divide by the total load in watts. The EcoFlow DELTA 3 Max (2,048Wh) would run a steady 200W load for about 8.7 hours, while the EcoFlow DELTA Pro Ultra X (12,000Wh) would provide about 10.2 hours at 1,000W. These are planning estimates, not guarantees, since actual runtime varies with the devices and how often they cycle.
EcoFlow system | Example load | Estimated runtime |
EcoFlow DELTA 3 Max (2,048Wh) | 200W | About 8.7 hours |
EcoFlow DELTA Pro Ultra X (12kWh) | 1,000W | About 10.2 hours |
Recharging during a long outage
If the outage lasts more than a day, you'll need a way to recharge. The EcoFlow DELTA 3 Max can recharge from a wall outlet when grid power returns or from a generator operated outdoors. For the EcoFlow DELTA Pro Ultra X, recharging depends on the installed setup and available power source. Because a gas generator can't run inside a garage or enclosed porch, battery backup for nor'easter outages gives homeowners another way to keep essential equipment running indoors. Backup power covers the hours after the lights go out. Knowing where to check the tide forecast and outage map helps you plan for how long that backup may need to last.
Nor'easter forecasts can change quickly, especially when the rain and snow line is close to Boston. Bookmark the official sources before the next watch is issued rather than trying to find them during the storm.
NWS Boston/Norton: Check watches, warnings, snowfall forecasts, and coastal flood forecasts for most of Massachusetts at weather.gov/box.
NWS Albany: Use weather.gov/aly for Berkshire County forecasts and storm reports.
NOAA Boston tide gauge: Station 8443970 shows observed water levels against the predicted tide.
MEMA: The Massachusetts Emergency Management Agency provides emergency information, preparedness guidance, and shelter information at mass.gov/mema.
MEMA outage map: MEMA links to its statewide power outage map through its emergency resources.
Mass 2-1-1: Call 2-1-1 for information about shelters, warming centers, and other storm-related assistance that isn't an emergency.
For an immediate emergency, including a downed power line, call 911. Stay away from the line and anything touching it. Once the warning is posted, the forecast becomes less useful than a plan for staying safe at home. Keep furnace and dryer vents clear of drifting snow, avoid unnecessary travel, and know which utility serves your address.
Massachusetts has three major investor-owned electric companies plus many municipal light plants. The utility listed on your electric bill is the one to contact when the power goes out. Don't assume a neighbor has already reported the problem.
Company (legal name) | Where it serves | Outage map | Outage phone, as the company labels it |
Eversource (NSTAR Electric Company, doing business as Eversource Energy) | Greater Boston, parts of MetroWest and the South Shore, Cape Cod and Martha's Vineyard, and western Massachusetts | outagemap.eversource.com (Eastern Massachusetts and Western Massachusetts views) | To report a power outage or check outage information, visit Eversource’s official Report an Outage page or refer to your electricity bill for the appropriate contact number. |
National Grid (Massachusetts Electric Company and Nantucket Electric Company) | Parts of central, northeastern, southeastern, and western Massachusetts, plus Nantucket | National Grid Outage Central (nationalgridus.com) | "Electrical Outages": 1-800-465-1212 (listed as "Power Outage," 24-hour assistance, on National Grid's Massachusetts Electric phone page) |
Unitil (Fitchburg Gas and Electric Light Company) | Fitchburg area in north central Massachusetts | 1-888-301-7700 (Unitil's automated outage reporting line) | |
Municipal light plants | Massachusetts has 41 municipal light plants serving all or part of 50 municipalities, including Braintree, Hingham, Reading, Concord, Peabody, Belmont, and Wellesley. | Each plant's own site | Each plant's own outage line |
Massachusetts has many municipal light plants alongside Eversource, National Grid, and Unitil, so check your electric bill to know who serves your address. For a downed line, stay away and call 911 first, then your utility. Before the storm, bookmark the Eversource outage map and National Grid outage map so you can quickly check your street's status and restoration estimate. With that saved, you can focus on preparing your home, which looks different on the coast than it does in the hills of Worcester County.
A Hull homeowner and a Holden homeowner aren't preparing for exactly the same storm. One needs to watch the next high tide and possible flooding. The other may be more concerned about snow loading on trees, roof weight, and blocked roads.
Coastal homes (South Shore, Cape, Islands, harbor neighborhoods) | Inland homes (MetroWest, Worcester County, Berkshires) |
Know the time of the next two high tides and watch the Boston gauge forecast | Clear gutters and trim weak limbs before the season; snow load breaks them onto lines |
Move cars to higher ground before the tide, not during it | Keep the gas tank at least half full (mass.gov) |
Test the sump pump and plan a backup power source for it | Clear snow from furnace and dryer exhaust vents after the storm (mass.gov) |
Move power stations, chargers, and valuables above the first floor if flooding is forecast | Check the roof for heavy snow load (mass.gov) |
Follow local evacuation instructions if they're issued | Check on older neighbors (mass.gov) |
What every Massachusetts home should do
If you use a fuel-powered generator, operate it outdoors at least 20 feet away from your home or other buildings, with the exhaust directed away from doors, windows, and ventilation openings. Follow the manufacturer’s instructions for safe operation in wet weather, and never run a generator inside a home, garage, or enclosed porch.
A Massachusetts nor'easter can mean coastal flooding in Scituate, heavy snow around Worcester, or strong winds on Nantucket, all from the same storm. The Blizzard of '78, the January 2015 storm, and the 2018 nor'easters show how different those risks can be. Before winter, bookmark NWS Boston/Norton and MEMA's outage resources, save your utility's contact information, and decide which household loads need backup. For a few essentials, the EcoFlow DELTA 3 Max is a portable option. For selected home circuits, the EcoFlow DELTA Pro Ultra X with Smart Home Panel 3 provides a larger installed setup.
When is nor'easter season in Massachusetts?
The National Weather Service says nor'easters are most frequent and most severe from September through April, although they can occur at any time of year. In Massachusetts, that period covers the months when coastal flooding, heavy snow, strong winds, and winter travel problems are most likely to occur together.
What was the worst nor'easter in Massachusetts history?
The Blizzard of '78 remains the usual benchmark for Massachusetts because of its snowfall, wind, duration, and widespread damage. The storm brought 27.1 inches to Boston and 73 deaths in the state. Boston's highest recorded tide, however, came from the January 4, 2018 nor'easter.
What is the highest tide ever recorded in Boston?
The Boston tide gauge reached 15.16 feet above MLLW on January 4, 2018, the highest observed level in the station's record. The storm was a nor'easter, making it an important benchmark for coastal flooding in Boston and nearby communities.
Is a nor'easter the same as a blizzard?
No. A nor'easter is a type of East Coast storm that can bring heavy rain or snow, strong winds, rough seas, and coastal flooding. A blizzard describes specific wind and visibility conditions that can develop during some nor'easters. A storm can therefore be a nor'easter without meeting the definition of a blizzard.
How do I check power outages in Massachusetts during a nor'easter?
Check the outage map for the utility serving your address, such as Eversource, National Grid, Unitil, or a municipal light plant. Report the outage directly to your utility, and call 911 for a downed line or other immediate danger. MEMA also provides a statewide outage map.
