Home Winterization Checklist: What to Finish Before the First Hard Freeze
Winter damage rarely starts with the storm itself. It starts weeks earlier. Think of a drafty attic, a garden hose still hooked to an outdoor faucet, or a furnace nobody has checked since last year. This home winterization checklist covers the jobs to finish in fall, while the weather still helps. You'll seal air leaks, protect your pipes, and get the heat checked. You'll also test your alarms and restock supplies. And if winter outages hit your area, you'll see how to plan backup power for the circuits that matter most.
Seal Air Leaks and Check Insulation First
Drafts make a house harder to heat and colder when the power goes out. If you're winterizing a home, checklist order matters. Air sealing comes first because it helps everything else. Some of it takes an afternoon, and some of it calls for a contractor.
Easy Fixes and Hidden Attic Leaks
ENERGY STAR says sealing and insulating your home can save up to 10% on your yearly energy bills. Simple fixes include weatherstripping doors and caulking around windows. The bigger job is sealing hidden attic leaks. ENERGY STAR's attic air sealing guide says to do that before you add insulation. Check behind kneewalls and around recessed lights. Also check flue or duct chases and the spots where walls meet the attic floor.
When to Call a Contractor
Some attic work belongs with a pro. Flues get very hot and need space around them. Leave vermiculite alone until a lab tests it. Old knob and tube wiring is a fire risk near insulation. ENERGY STAR also suggests hiring help for tight attics, wet insulation, mold, or poor airflow.
Here's the to-do list. Most of it fits into one weekend:
  • Weatherstrip exterior doors and caulk window gaps.
  • Look for attic leaks and check insulation depth.
  • Call a contractor for any red flags above.
Your climate, current depth, and ceiling type all shape how R-value works in attics. A tighter house also holds heat longer. That helps the pipes in its colder corners, too.
Protect Pipes and Outdoor Plumbing From Freezing
Frozen pipes are one of the costliest winter surprises. Most prevention is simple and cheap, but it has to happen before the first deep cold snap.
Simple Steps That Stop Pipes From Freezing
Indiana's utility consumer counselor keeps a clear list of frozen pipe prevention tips. Here's what it says:
  • Unhook hoses from outdoor faucets and store them indoors or in the garage.
  • Insulate exposed pipes in basements, crawl spaces, and attics.
  • Open cabinet doors so room heat reaches the pipes under sinks.
  • When it drops to zero or below, let a pencil-size stream run from one faucet, especially at night.
  • If you travel, don't set the thermostat lower than 55 degrees.
  • Know where your main water shutoff valve is.
Heat tape, foam sleeves, and steady indoor heat are the main tools for preventing frozen pipes this winter. But pipes are most at risk when the heat stops. That often happens in a winter outage.
Plan Backup Power for Winter Outages: EcoFlow TITAN 5000 Classic and EcoFlow TITAN 5000 Plus
If your area loses power during winter storms, add backup planning to your fall checklist. List the loads that keep the house safe. Think fridge, lights, internet, and any heating or pump circuits that need power. A home battery can cover chosen circuits. But it doesn't replace insulation, and it isn't a steady heat source.
Which Loads Should Come First
The fridge usually tops that list. FoodSafety.gov's outage food tips say a closed fridge keeps food cold for about 4 hours. A full freezer holds its temperature for about 48 hours, or 24 hours if it's half full.
Estimating Runtime for Your Load List
Here's an example only. Say your fridge, router, and a few lights draw 400W combined. Take one 5,017.6Wh battery unit and multiply by 0.85 to allow for conversion losses. Divide by 400W, and you get about 10.7 hours. Use the nameplate or measured watts for your own gear. Fridges cycle on and off, and cold rooms change real runtime.
Supporting Essential Home CircuitsSupporting Essential Home Circuits
Choosing Between 120V and 240V Backup
Fall is the time to plan. Installation needs dry weather and an open spot on an electrician's calendar. EcoFlow TITAN home batteries back up chosen circuits through Smart Home Panel 10. The two models below differ by voltage.
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. •North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
Some winter loads run on 240V, especially in rural homes with their own well. For those circuits, the split-phase EcoFlow TITAN 5000 Plus is the better match. Just have your installer confirm the numbers first.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
Charged devices, a stocked pantry, and a heat plan are the basics of being ready for a winter outage. Backup power covers the outage. Your heating system still needs its own fall checkup.
Service Heating Equipment and Test Your Alarms
Your furnace or boiler matters most all winter, and it's also a leading fire and carbon monoxide risk. A yearly inspection catches problems early, and alarm testing takes minutes.
Yearly Inspections and CO Alarms
The EPA's carbon monoxide indoor air guide says to have a trained pro check your furnace, flues, and chimney every year. The pro should also clean and tune them up. The guide warns against idling a car in the garage, too. It notes that the Consumer Product Safety Commission recommends CO alarms on each level, outside each sleeping area.
Safe Heating Habits All Winter
NFPA heating tips, shared by state fire marshals, add a few habits. Keep anything that can burn at least three feet from heating equipment. Turn portable heaters off when you leave the room or go to bed. Never use your oven to heat your home. Will you run a generator? The CDC's carbon monoxide prevention tips say to run it outside, at least 20 feet from doors, windows, and vents. The CDC also says to install a battery-operated CO detector.
Book the service first, since fall calendars fill fast. Here's the list:
  • Book furnace or boiler service and replace the filter.
  • Schedule a chimney sweep if you burn wood.
  • Test smoke and CO alarms, and replace batteries as needed.
Blocked flues, idling cars, and misused generators are common causes of carbon monoxide dangers in winter emergencies. Next, head outside. The roof, gutters, and trees take the brunt of winter.
Clear the Gutters, Trim Trees, and Check the Roof Line
Snow and ice put weight and water on every outdoor surface. Fall cleanup lowers the chance of ice dams, broken limbs, and leaks. Leave ladder and roof work to a pro if it makes you uneasy.
Nebraska's Department of Insurance says clean gutters help prevent ice dams. They let meltwater drain. Ice dams form when snow melts and refreezes because of poor attic insulation. So check your attic insulation and roof or soffit vents at the same time.
Next, cut back dead, dying, diseased, or broken branches, as Nebraska suggests. Texas insurance officials also say to trim trees that hang over your house and cars. Fix any roof leaks now, and take a few minutes to review your winter coverage with your insurance agent.
Attic sealing, clean gutters, and roof vents all work together when preventing and removing ice dams. Once the house is sealed, serviced, and cleaned up, restock your storm supplies.
Restock Winter Supplies and Run a Final Walk-Through
Supplies are your last line of defense if a storm closes roads or cuts power. Check what's left from last year and fill the gaps.
Preparing Essential Winter SuppliesPreparing Essential Winter Supplies
What to Keep in Your Winter Kit
The Texas Department of Insurance suggests bottled water, food that won't spoil, and batteries in case the power goes out. Add a battery or hand-crank radio. A NOAA Weather Radio with a tone alert is ideal. Then pack flashlights, a first aid kit, a manual can opener, and phone chargers with a backup battery. During a storm, follow National Weather Service alerts and local officials.
Your Final Walk-Through Checklist
When you're winterizing your home, checklist items that need a contractor go on the calendar first. Use this table as a winterizing home checklist for your final walk-through:
Area
Task
Done?
Drafts
Weatherstrip doors, caulk windows, check attic leaks and insulation
Plumbing
Unhook hoses, insulate exposed pipes, find the main shutoff
Heating
Professional inspection; chimney cleaned if used
Alarms
Exterior
Clean gutters, trim branches, fix roof leaks
Supplies
Water, food, radio, flashlights, batteries, first aid
Backup power
List must-run circuits; get a licensed electrician's quote if adding a home battery
Thermometers, a closed door, and coolers are the basics of fridge and freezer food safety in a blackout. Print the table, tape it inside a cabinet door, and reuse it as your winterize home checklist next fall.
A home winterization checklist works best in fall. Seal drafts, protect pipes, and service the heat. Then test alarms, clean up outside, and restock supplies. Pick a weekend for the DIY jobs, and book the furnace check and contractor work now. Do winter outages hit your area often? Consider the EcoFlow TITAN 5000 Classic for 120V essentials or the EcoFlow TITAN 5000 Plus for calculated 240V circuits. Either one pairs with Smart Home Panel 10, installed by a licensed electrician.
When should I winterize my house?
Aim for fall, before the first hard freeze. That leaves time to book a heating inspection and finish outdoor work in dry weather.
What temperature should I leave my house at when I'm away in winter?
Keep it at 55 degrees or higher. Indiana's utility consumer counselor says not to go lower. A colder house raises the risk of frozen pipes.
How often should a furnace be inspected?
Once a year. The EPA and fire safety officials say a qualified pro should clean and inspect your heating gear, flues, and chimney each year.
Do I need a carbon monoxide alarm if I have gas heat?
Yes, any fuel-burning appliance calls for CO alarms. The EPA notes that the CPSC recommends one on each level of your home, outside each sleeping area.
Can a home battery keep my house warm during a winter outage?
Not by itself. A home battery backs up chosen circuits. It doesn't replace insulation or act as a steady heat source. Ask an electrician whether your heating system's electrical loads fit a backup plan.
Home Backup
