Gas Fireplace Cost to Run: The Real Numbers
Running a gas fireplace can cost anywhere from $0.20 to $0.60 per hour, depending on its BTU rating and local gas prices. If you use it for a few hours each evening, that cost can add up over the course of a month. The good news is that you can estimate your own cost pretty easily. This guide breaks down the hourly and monthly numbers, compares natural gas with propane, and covers simple ways to keep the bill in check without giving up the comfort of a warm fire.
The Formula Behind Gas Fireplace Operating Cost
Your gas fireplace gas cost mainly depends on the fireplace's BTU rating and the price you pay for natural gas. A simple formula can give you a quick estimate of what the fireplace costs to run each hour: (BTU rating ÷ 100,000) × price per therm = cost per hour.
The Formula Behind Gas Fireplace Operating CostThe Formula Behind Gas Fireplace Operating Cost
How to calculate the hourly cost
For example, a 20,000 BTU fireplace running on gas priced at $1.50 per therm would cost about $0.30 per hour. Running it for four hours would cost about $1.20 for the day, or roughly $36 over 30 days at the same rate. This gives you a useful starting point, but your actual bill can change based on your fireplace and local gas rates. A few factors have the biggest effect on the final cost:
  • BTU rating: A larger fireplace generally uses more gas while running.
  • Gas price: Natural gas rates vary by location and can change with the season.
  • Runtime: Running the fireplace longer each day will increase your monthly cost.
For a closer estimate, check the gas rate on your latest utility bill instead of relying on a national average. You can also compare this calculation with natural gas generator costs, since fuel price and runtime affect those operating costs in a similar way.
Typical Hourly and Monthly Costs
A fireplace's BTU rating has a direct effect on how much gas it uses, so larger models generally cost more to run. The table below gives a rough idea of what you could spend if you run a fireplace for four hours every day, though your actual cost will vary with local gas rates and daily usage.
Fireplace Size
Cost Per Hour
Monthly Cost (4 hrs/day)
20,000 BTU
$0.20-$0.30
$24-$36
30,000 BTU
$0.30-$0.45
$36-$54
40,000 BTU
$0.40-$0.60
$48-$72
These are estimates, so your bill can land outside these ranges. Your local gas rate, fireplace size, and daily runtime all matter. If you're also comparing other ways to heat a room, this guide to propane vs. electric heaters can help you compare their running costs. Fuel choice is another big part of the calculation. A fireplace using natural gas won't have the same operating cost as one running on propane.
Keeping the Fireplace Running During an Outage
Some gas fireplaces rely on electricity for ignition and blower fans. When the power goes out, those electrical components may stop working even if your gas supply is still available. A backup power system can keep compatible fireplace components running during an outage, helping you stay warm while the rest of the house is without power.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. •High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
After the EcoFlow DELTA Pro Ultra X, the EcoFlow DELTA 3 Max offers a more compact option for homes that don't need whole-home backup. Its 2,048Wh capacity and 2,400W output can handle essential appliances during an outage, while its portable design makes it easier to move where you need backup power.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Fuel choice can change your fireplace's running cost quite a bit. Natural gas and propane have different prices and usage rates, so the same fireplace can cost more or less to run depending on which fuel it uses.
Natural Gas vs. Propane Fireplace Costs
Fuel choice can make a noticeable difference in what you pay to run a fireplace. Natural gas is usually less expensive per hour, while propane tends to cost more for the same general heating use. Your actual cost will depend on local fuel prices, the fireplace's BTU rating, and how long you run it each day.
Natural Gas vs. PropaneNatural Gas vs. Propane
Natural gas
A gas fireplace costs on average about $0.30 to $0.60 per hour depending on the BTU rating and your local rate for natural gas. Homes connected to a natural gas line can take advantage of the household supply without the need to store fuel on the property, which can make it a practical option for homeowners who already have gas service. Your actual cost will still depend on the rate charged by your local utility and how often you use the fireplace.
Propane
Propane fireplaces can cost $1 or more per hour, depending on the fuel price, fireplace size, and how quickly the unit uses propane. The supplied figures use an average propane price of about $3 per gallon. Homes without natural gas service may rely on propane instead, which can make running a similar fireplace more expensive over time. If you're comparing fuel costs for backup equipment, this guide to propane vs. gas generators covers a similar question.
Tips to Lower Gas Fireplace Costs
Small changes to how you use and maintain your fireplace can help keep gas use under control and prevent unnecessary runtime. A few simple adjustments to your heating habits can also make it easier to manage monthly energy costs.
  • Use a thermostat or timer: Set a schedule so the fireplace doesn't run longer than needed to keep the room comfortable.
  • Heat one room at a time: Use the fireplace for zone heating instead of trying to warm the whole house. This can reduce how long you need to run it.
  • Keep the fireplace clean: Regular cleaning and maintenance help the burner operate efficiently and deliver consistent heat.
  • Compare heating costs: Compare heat pump and furnace costs to see how your fireplace's operating cost fits with your home's primary heating system.
A gas fireplace usually costs about $0.20 to $0.60 per hour to run, based on the BTU rating and fuel price. Four hours of daily use can add roughly $24 to $72 to a monthly bill under the cost assumptions above. The easiest way to estimate your own cost is to divide the fireplace's BTU rating by 100,000, then multiply that number by your price per therm. If you use the fireplace for zone heating, limit its runtime, and keep it properly maintained, you can enjoy the heat without running it longer than needed. A power outage is a separate concern. If your fireplace relies on electric ignition or a blower, backup power can keep those components running when the grid goes down.
How much does it cost to run a gas fireplace for 8 hours?
If we take the above estimates for an hour, the cost of running a gas fireplace for 8 hours could be in the region of $1.60 to $4.80 for a 20,000 to 40,000 BTU model. Running it for that long each day can add up quickly over a month, so your fireplace's BTU rating and local gas price are important factors.
Is propane or natural gas cheaper for a fireplace?
It usually costs less per hour to run a gas fireplace on natural gas than on propane. How much you'll save depends on your local fuel prices, the BTU rating of your fireplace and how long you run it. Homes without access to a natural gas line may need to use propane instead.
Does a gas fireplace work during a power outage?
It depends on the fireplace model and what components need electricity. Many fireplaces require power to start and to operate a blower fan, so you may lose that functionality during an outage, even if the gas supply is still available. Check your fireplace manual to see whether your model can operate without power.
How can I lower my gas fireplace running costs?
Start with a thermostat or timer to prevent needless run time, especially when the room is not occupied. You can also use the fireplace for zone heating instead of warming the whole house, while regular cleaning and maintenance can help the burner operate properly.
Is a gas fireplace cheaper to run than central heating?
There's no single answer because operating costs depend on the fireplace, heating system, fuel prices, home size, and how much heat you need. A gas fireplace can make sense for heating one room, while a central system may be better suited to heating the whole house.
Save Bills
